#1 Posted : 08 August 2003 15:35:26(UTC)
G'day everyone,
I have spotted some Marklin 460 SBBs on eBAY. They have an 8xxxx number..
What's HAMO and are they AC three rail or a predcessor of the TRIX line?
Offline Lars Westerlind
#2 Posted : 08 August 2003 16:53:54(UTC)
Lars Westerlind
HAMO are DC locos, made by Märklin before they bought TRIX.
So they have no slider, no relay, but a DC motor (normally). There is a rather large chance that they are easily converted to 3R operation.
/lw
#3 Posted : 08 August 2003 17:16:39(UTC)
Thanks Lars..
Is there a set that you can order to make the conversion (eg like the digital conversion sets that come with the motor)??
#4 Posted : 09 August 2003 03:42:48(UTC)
HAMO was manufacturer that Märklin bought in the 60:s, I think... The Märklin 2-rail DC loks were called HAMO until they bought Trix a couple of years ago. After the Trix merger, the HAMO loks were incorporated into Trix line of loks...
Basically HAMO loks are Märklin 2-rail DC locos with a Märklin motor - but using a "HAMO magnet" (discussed in many digital conversion scenarios) instead of the normal 2-coil stator of the "AC" motor in the Märklin catalog.
The other difference is that the wheelsets are isolated, as they must be when running 2-rail DC.
Since HAMO locos are originally Märklin locos, but adapted for 2-rail, normally there are already holes for the pick up slider mounting and such, so a reverse engineering effort to "restore" it to 3R operation is not such a big job, as Lars also points out.
With the SBB 460, you could get the 60901 set and install it after rewiring the internals & adding the pick up shoe, or use a LokPilot or similar - in case of keeping the original motor...
If you want to run it as a "pure AC" lok, then you will have to replace the "HAMO magnet" with a coil stator and add a reversion relay, but I think a LokPilot would be the better/easiest option in that case too, while keeping the original motor...
And - if you get them - and wonder more about on how to make them run, we are here to help you...wink
#5 Posted : 09 August 2003 06:54:47(UTC)
Thanks everyone..
It will be a while before I go down this path.. I already have 4 loks (one is not even announced yet) that are waiting in line for me to buy from my dealer in the near future.. Noel is still stressing over my last request to have telex couplers installed on the two 460s I already own.. After I buy next 4 loks, I might look deeper into the idea as it seems to be a cheaper way to increase the loco population..
Hamo 8394 BR 03 Digital conversion (Collector's Corner general)
by Imagine 01/07/2025 21:46:50(UTC)
HAMO (General MRR)
by rhfil 03/05/2021 21:04:07(UTC)
Converting a Hamo to a 3 rail (Digital)
by Allen Lee 14/09/2020 02:55:25(UTC)
HAMO convert to 3 rail. (H0-scale)
by mikemasey 23/07/2020 00:41:21(UTC)
Hamo digital BR86, info please (Digital)
by mvd71 26/03/2020 06:31:36(UTC)
3023.2/3923 Instructions manual and Marklin versus Hamo (Collector's Corner general)
by mbarreto 03/12/2019 13:17:15(UTC)
HAMO 8353 E03 conversion (Digital)
by DasBert33 28/10/2019 12:09:43(UTC)
Marklin Hamo (General MRR)
by Len Matthews 26/07/2018 08:36:32(UTC)
Hamo 8371 ICE set (H0-scale)
by HighSpeeds410 10/12/2017 21:34:42(UTC)
Marklin Hamo on code 83 (General MRR)
by Bryan 22/11/2017 22:51:22(UTC)
Hamo trams and trolly cars DC 2 rail, and when did they start (H0-scale)
by MalinAC 08/08/2017 10:36:26(UTC)
ESU HAMO magnets and Marklin mSD3 decoders (Digital)
by ktsolias 19/11/2016 18:37:56(UTC)
Hamo ac (H0-scale)
by MalinAC 09/06/2016 15:46:40(UTC)
Converting HAMO locos (Digital)
by xxup 11/11/2015 03:22:36(UTC)
Hamo 3829 (General MRR)
by Tom Jessop 02/01/2015 03:26:29(UTC)
Would like some information please - Hamo Steam Loco (General MRR)
by Ausipeet 02/01/2015 01:45:27(UTC)
Hamo Question - Is this a real model? (H0-scale)
by mike c 21/12/2014 22:21:44(UTC)
Trix or Hamo BR 17? (H0-scale)
by disavelo 19/06/2014 23:17:22(UTC)
Which CV52 setting correspond to 5-pole drumcol HAMO? (Digital)
by Martin T 17/02/2014 23:10:05(UTC)
How to convert a Hamo model for analog use. (General MRR)
by Ian555 19/10/2012 09:46:05(UTC)
HAMO factory-conversion Locomotives for cross-border traffic (H0-scale)
by BR01097 09/03/2012 05:15:00(UTC)
Question about converting Marklin(Hamo) 2 rail to 3 rail (Digital)
by dodger0325 09/10/2011 04:49:43(UTC)
HAMO 8328 Coverted to AC Digital (marklin 3028) (H0-scale)
by xxup 05/03/2011 09:36:36(UTC)
Hamo? (Collector's Corner general)
by kbvrod 16/02/2011 00:46:38(UTC)
Your most profitable find? (new topic from Hamo Trams and Trolleys) (Collector's Corner general)
by cookee_nz 27/01/2011 10:46:21(UTC)
Hamo trolleys and diesels? (Collector's Corner general)
by cbass 23/01/2011 14:28:26(UTC)
What is a HAMO magnet? (Digital)
by Kevin Weis 02/01/2011 18:57:33(UTC)
Hamo DC to 3-Rail AC digital comversion (Digital)
by Jay 06/06/2010 20:02:49(UTC)
Help: Convert a Marklin Hamo (General MRR)
by joeyn15 19/11/2009 10:07:09(UTC)
by xxup 01/03/2009 14:02:34(UTC)
What is the "button" under HAMO lok's chassis for? (H0-scale)
by Brakepad 13/11/2008 10:08:44(UTC)
Converting Hamo from 2-rail to 3-rail? (H0-scale)
by Brakepad 13/09/2008 15:14:51(UTC)
Marklin Hamo 38691 E19 questions (H0-scale)
by kimballthurlow 03/08/2008 04:54:46(UTC)
Does Anyone Here Have Early HAMO Locs? (Collector's Corner general)
by Roman 01/01/2008 22:33:28(UTC)
Hamo to AC (Collector's Corner general)
by drstapes 02/11/2007 23:57:42(UTC)
Hamo Conversions (H0-scale)
by Falconrep 28/10/2007 20:01:07(UTC)
Marklin Hamo Locos (General MRR)
by nevw 11/07/2007 02:13:31(UTC)
Changing Hamo to 3 rail digital (Digital)
by Hodgkiss54 30/04/2007 08:35:32(UTC)
pin under Marklin/HAMO loks (H0-scale)
by tekin65 21/12/2006 11:17:43(UTC)
Update - Hamo conversion - bad slow running (Digital)
by rugauger 23/04/2006 22:55:16(UTC)
Hamo-Lokpilot conversion trouble (Digital)
by laalves 29/03/2006 06:02:00(UTC)
Hamo Magnet (Digital)
by RayF 03/03/2006 00:09:36(UTC)
Hamo Pics (H0-scale)
by McLae 23/02/2006 03:59:42(UTC)
Is HAMO exactly Marklin ? (H0-scale)
by 2ndChancer 24/12/2005 02:03:21(UTC)
HAMO Multiplex (Digital)
by MärCo 15/06/2005 10:25:18(UTC)
Digital conversion with Hamo magnet (Digital)
by rugauger 16/04/2005 15:32:15(UTC)
HAMO problems (H0-scale)
by cvanhaasteren 01/04/2004 22:08:20(UTC)
Hamo magnet for DCM-Motors? (Digital)
by GERSON 23/01/2004 11:44:26(UTC)
Hamo magnet number. (Digital)
by perz 05/11/2003 00:46:45(UTC)
Hamo magnet numbers (Digital)
by Winst0n 01/06/2003 21:27:25(UTC)
This page was generated in 0.388 seconds.
