Offline jselter
#1 Posted : 31 August 2004 22:16:09(UTC)
jselter
I've been trying to install a 72270 in my Makido without success.
All the other functions of the loco work fine from the mobile
station - light switch on and off, sound effects work, whistle works,
bell works, propulsion works so I believe it's set up for dig.
operatons.
Here's what has got me baffled. There's a brass spring tab in the area
where the smoke unit is installed in the frame of the loco. It
appears that the top of the smoke unit grounds to the stack and the
connection is made at the bottom of the smoke unit at this brass spring tab. Problem is I can't see how the wire coming out of
the smoke unit can make contact with that brass tab. The smoke unit works great when I test it on the track - that is I connect a wire to the upper part of the smoke unit with an alligator clip, connect to the outside rail and touch the wire coming out of the bottom of the smoke unit to the center stud. If I only touch the bottom of the smoke unit to the center stud - not the wire - nothing happens.
Obviously I doing something wrong. Marklin's instructions are vague, to say the least.
Lost in smoke,
Thanks, Joe
Joe
Offline laalves
#2 Posted : 31 August 2004 22:32:54(UTC)
laalves
Yes, Märklin's instructions are vague. I have had several different problems with smoke generators.
First, if there's a wire in the "live" contact of the generator and a brass spring tab in the loco, you don't need the wire. Desolder it. Ensure that a healthy and shiny round drop of solder is in left in the contact. Then make sure that the spring tab has no corrosion (old locos). If it does, pickup a fine sandpaper bit and clean. With or without corrosion a bit of rubbing alcohol in moist tissue will remove any oily residue left from your fingers, gear oil or even smoke fluid. You should also bend up the tab a bit, not to much: danger of loss of the spring effect.
If all else fails (like in my 1999 BR10 Insider), solder a wire from the tab to the generator..........
Luis
Offline Gregor
#3 Posted : 31 August 2004 22:44:33(UTC)
Gregor
Hi Joe,
Maybe you should check if the function output still works: By using a Volt meter or connecting a light bulb to the brass strip and mass.
Gregor
#4 Posted : 31 August 2004 23:00:25(UTC)
Hi Joe - Mikado is GREAT [:p] !!! Can't wait to get mine in September ...
Best Regards and - welcome to the Forum Smile
Offline jselter
#5 Posted : 31 August 2004 23:12:54(UTC)
jselter
[size=1" face="Verdana" id="quote]quote:Originally posted by Gregor
<br />Hi Joe,
Gregor
Gregor, the mass is the loco's body right?
Joe
Offline McLae
#6 Posted : 01 September 2004 05:09:08(UTC)
McLae
I have had the same problems with other Loks and smoke.
here is what to try next:
On the bottom of the smoke unit, there is a wire. This must touch the brass tab.
Turn the Smoke unit so the wire is on a different side. Some testing and 3-D visualization needed here. [:p] Turn smoke unit so the wire points toward the front of the Lok. If that does not work, try turning toward the back. (turn the whole unit, not just the wire!)
If still does not work, gently straighten the wire just a bit. Repeat the turning and testing.
Also, remember that it might take 20-40 seconds for the smoke to show, even when everything is working fine. And, if you use too much oil, no smoke then either[xx(].
The McLae
Offline Gregor
#7 Posted : 01 September 2004 11:59:56(UTC)
Gregor
Hi Joe,
Indeed mass is the loco's body.
If the function output works well (light bulb test on brass strip), and the generator itself works well (you demonstrated that already), then there is something wrong with the contact. Contact on one side is made by the brass strip. This is the most probable cause of your problem. You can check the connection as described by The McLae. On the other side the smoke generator is clamped in the loco's chimney. There should be conductive contact on that side as well. I don't know the Mikado loco, but if the inside of the chimney is heavily painted (should not be the case), then you don't have contact on that side. This is not very likely though, but something to be checked.
BTW, I once got so fed up with the same problem, that I soldered a wire between the brass strip and the smoke generator. The wire was long enough to be able to remove the loc cover, and short enough not to get stuck in the wheels or drive shafts.
Good luck,
Gregor
Offline jselter
#8 Posted : 01 September 2004 16:53:40(UTC)
jselter
Thanks to all for your help. I'll work on it this weekend.
Joe
Offline rschaffr
#9 Posted : 01 September 2004 18:00:37(UTC)
rschaffr
Hi. Just to add my experiences, I have a BR53 (3102) which has two smoke generators in it. I had a terrible time getting both to work. I repositioned the non-working one, and the other would stop. I lifted the contact wires slightly and experimented with position until I FINALLY got both working. Took about 10 tries. The complication on this lok is that you have to remove the front bogie to take the shell off. I didn't get smart enough to leave it off for trial until about the fifth iteration. They are both working beautifuuly now. Just keep at it.
-Ron
Offline jselter
#10 Posted : 05 September 2004 03:35:25(UTC)
jselter
Ron,Gregor,McLae,Luis,
Sitting in my workshop waiting for "Frances" to do her deed so I finally took a magnifying glass to the instructions and now I've seen the light or smoke.
Thanks to all of you.
Custom smoke generator for digital use (Digital)
by einotuominen 17/02/2024 11:44:17(UTC)
Smoke generator (H0-scale)
by Keim 01/03/2023 01:58:22(UTC)
Smoke Generator for Marklin 5441 Set (Big scale)
by JTaylo93 22/01/2023 16:57:27(UTC)
Sk800 smoke generator (General MRR)
by Keim 29/07/2022 23:05:41(UTC)
Smoke generator and LokSound XL (Big scale)
by ktsolias 25/08/2021 11:33:31(UTC)
Smoke Generators For Maxi Locomotives?? (Big scale)
by ErikNewland98 20/11/2020 07:16:17(UTC)
Roco BR86 Steam loco smoke generator (H0-scale)
by seanshintaro 16/03/2020 07:53:35(UTC)
Smoke generator (General MRR)
by rhfil 10/01/2020 16:40:03(UTC)
Adding Smoke Generator to Starter set Loco? (H0-scale)
by SBB_CFF_FFS 03/01/2020 02:32:44(UTC)
72270 smoke generator (H0-scale)
by Seaquake 14/11/2018 18:41:47(UTC)
Smoke generator fluids - scented no oil? (General MRR)
by Minok 14/04/2018 23:23:05(UTC)
Smoke generator for 3092 Lok-Question (H0-scale)
by analogmike 05/12/2017 03:05:52(UTC)
Smoke generator liquids (General MRR)
by ocram63_uk 01/10/2017 14:20:00(UTC)
Seuthe Smoke generator quirky (H0-scale)
Belarus Zeitgaiss 21/09/2017 15:04:35(UTC)
Steam #3005 ...Smoke Generator? (H0-scale)
by Zeitgaiss 14/09/2017 16:04:25(UTC)
39551 G 5/5 Smoke Generator Installation (H0-scale)
by CanadianKid 29/04/2017 07:59:19(UTC)
Märklin 55441 smoke generator (Big scale)
by airsoftrc 13/04/2017 23:48:47(UTC)
Glowing Smoke Generator in BR 95 - 39095 (H0-scale)
by Armando 07/01/2017 23:38:09(UTC)
Problem with Seuthe 10 Smoke Generator Installation (Digital)
by AmalfiCoast 25/12/2016 19:22:06(UTC)
7226 Smoke Generator... is it on? (H0-scale)
by Minok 16/12/2016 22:21:11(UTC)
New technology smoke generator (Digital)
by river6109 01/04/2016 01:21:43(UTC)
Smoke generator always on (General MRR)
by waorb 18/03/2015 15:41:43(UTC)
Smoke Generator with 60965 ? (H0-scale)
by GvanWyk 26/06/2014 21:55:10(UTC)
BR24 from startset 29240 - Smoke generator contact function in MS2? (H0-scale)
by marc 04/03/2014 22:26:42(UTC)
installininstalling smoke generator to Marklin BR 80 from start set 55035 (Digital)
by tsigkas 19/12/2012 16:10:09(UTC)
How to install the smoke generator in BR50.40 (H0-scale)
by shannon 27/03/2012 04:09:38(UTC)
Introduction of newbie&Smoke generators overloading 37024 (Digital)
by 65kombi 03/01/2012 04:39:35(UTC)
Advice on smoke generator and ESU lokpilotv4 (Digital)
by French_Fabrice 11/12/2011 09:30:42(UTC)
Which smoke generator (H0-scale)
by gachar001 01/08/2011 03:40:05(UTC)
Smoke Generator issue with a 3092 Engine not working (H0-scale)
by jbn1jbn 09/01/2011 00:37:42(UTC)
Smoke Generator issue with a 3092 Engine (Model railroad wiring)
by jbn1jbn 09/01/2011 00:36:07(UTC)
Smoke Generator/Rauchsatz (H0-scale)
by wolfk88 04/12/2010 20:06:25(UTC)
7226 Smoke Generator Problem (Digital)
by JH 30/11/2010 17:44:02(UTC)
Smoke generator question for M* 26562 (H0-scale)
by gachar001 23/09/2010 18:13:39(UTC)
Installing smoke generators on Marklin trains,should a rookie attempt it? (H0-scale)
by I_love_Marklin_37538 15/09/2010 09:22:22(UTC)
Installing smoke generator in BR10.0 (H0-scale)
by Armando 05/11/2009 22:54:59(UTC)
cleaning a smoke generator in BR 50 (H0-scale)
by kimballthurlow 03/03/2009 15:12:32(UTC)
BR23 (36240) Smoke Generator (H0-scale)
by jmgepb 08/01/2009 16:38:44(UTC)
Which smoke generator is right ? (Digital)
by wurttemberg 23/12/2008 23:42:56(UTC)
Smoke Generator question 72270 vs. 7226 (H0-scale)
by MARKLIN LOVER 06/12/2008 01:16:05(UTC)
smoke generator, advice needed (H0-scale)
by Seetal 12/10/2008 22:47:32(UTC)
BR50 smoke generator issue (H0-scale)
by gachar001 10/06/2008 17:56:58(UTC)
Equivalant smoke generator (H0-scale)
by Legless 24/05/2008 14:38:08(UTC)
Smoke Generators ON and OFF (H0-scale)
by DamonKelly 15/09/2007 17:53:18(UTC)
Question on smoke generator (H0-scale)
by efel 09/10/2006 17:00:29(UTC)
Smoke generator for a 3048 steamer (H0-scale)
by dbmike 08/10/2006 05:18:43(UTC)
72270 Smoke generator kit (Digital)
by kiwi 05/07/2006 12:28:47(UTC)
Digitalizing and smoke generator (Digital)
by al_pignolo 26/03/2006 21:20:30(UTC)
Märklin smoke generator (72270) (General MRR)
Belarus dakje_Rook 11/01/2006 21:20:24(UTC)
Smoke Generators. (General MRR)
by franciscohg 22/10/2005 21:36:35(UTC)
This page was generated in 0.514 seconds.
