Offline Keyser
#1 Posted : 25 August 2022 01:34:28(UTC)
Keyser
Finally got my CS3 hooked up and track plan done. Everything works except for one turnout. It will go from straight to curved. But, it will not switch back to straight. All other turnouts and decouplers work correctly. I hooked it up by itself. It still will switch from straight to curved but not back again. After manually switching to straight it will then digitally switch to curved. I do not even get any clicking of the switch motor when trying to return to a straight run. Before I tear the switch motor apart to determine what may be wrong, does anyone have any simpler explanations? Or, things to try before taking things apart?
Offline PMPeter
#2 Posted : 25 August 2022 02:16:58(UTC)
PMPeter
It sounds like you are suffering from the notorious microswitch problem that has been plaguing the Maerklin K and C track switch motors for years. However, you haven't told us what track system you are using and what type of switch motor you are talking about.
If you are indeed using either a K or C track attachable turnout motor then the fix is straight forward for a digital (not analogue) system. You can safely jumper out the micro switches and that should cure your problem. There are several videos and previous threads on this forum of how to do this.
#3 Posted : 25 August 2022 11:16:57(UTC)
Make sure it is a motor problem by fitting it to another turnout and see if the same occurs.
#4 Posted : 25 August 2022 13:40:22(UTC)
Hi Keyser (a first name would be much more friendly)
As already said by our friends above, most likely an end swicht inside the motor is the culprit (C and K tracks)
By swapping the docoder with another one, you will be able to verify that the switch motor is faulty.
What to do?
- the real solution is to jump the micro-switches inside the motor. It works 100% in digital operation but in analogue mode (not your case I understand) the button push must be limited to 1 second.
- the lazy solution: to spray contact fluid inside the motor while moving it manually and testing for digital operation. It may work again but the cure is only temporary.
Note: I have 53 of these motors in all sort of track pieces (normal, curved points, triple points, Double Slip sw.) and I ended up strapping ALL these microswitches.
Every time I thought Märklin has solved the problem and didn't do the change, I was proved wrong. So better do it preventatively, no matter what Märklin says if you build a fixed layout with scenery.
Once strapped, these motors work fine.
Notes:
- if you strap these switches then the control block with LEDs (analogue mode) will all be lit all the time
- to be fair to Märklin I met this problem already from 1974 using Fleischmann and Arnold N scale track pieces. I also read complains about Roco and Fleischmann still today.
In case you don't know how to strap those switches, here is a video for C Track motors
Offline Keyser
#5 Posted : 25 August 2022 16:56:52(UTC)
Keyser
Thanks to all of you. Now when I open this turn-out I will feel like I am in a dim room instead of completely blind. This does leave me with one question. If it still works with the micro-switches shorted, why are the switches there in the first place? What is their purpose?
Offline PMPeter
#6 Posted : 25 August 2022 17:42:07(UTC)
PMPeter
They are there for analogue mode operation. In case someone holds a pushbutton down too long or the button gets stuck, the microswitch is supposed to open at the end of travel and cut the power to the solenoid. Otherwise you get the distinct burning smell and the release of the dreaded smoke. In digital operation, they are not needed because the power to the solenoid is cut off by the digital timer setting. Therefore, the micro switches at each end can safely be jumpered out. Note Jean uses the word "strapping" which must be a translation but is the same as jumper or bridging.
#7 Posted : 25 August 2022 18:16:37(UTC)
The more likely scenario in analogue operation is the point being connected to a contact track and the train stopping on the contact track leaving power applied to the solenoid. This will definitely burn out the solenoid in these switch motors - it even does it in the first generation M track points and signals.
There is still the possibility of someone holding a push button down for too long, or a fault or short circuit somewhere, and hence the microswitches fitted to the point motors. The problem then is that when the microswitch opens there is a tiny spark which eventually pits and oxidises the contacts of the microswitch, resulting in the symptom you have. As stated above when used on a digital system it is fine to solder a bridge across the microswitch pins to effectively take it out of the circuit, and rely on the digital system to turn the pulse off after a short time (somewhere around 1/4 to 1/3 of a second).
Offline Keyser
#8 Posted : 25 August 2022 18:35:01(UTC)
Keyser
Okay that makes sense. Thank you for the explanation. I am an old “tinkerer”. Guns, motorcycles, cars , jeeps and in this case trains. But, somewhere in my education, electronics seems to have escaped me.
Curved Lh Manual turnout.....Zscale (Small scale)
by spinnerguy 09/04/2024 22:34:36(UTC)
Wire Marklin turnouts 8561 to Rokuhan RC-03 (Small scale)
by dmazyn 22/01/2024 16:47:19(UTC)
Use of M-turnout motors in C-turnouts (General MRR)
by gimo49 20/01/2024 12:27:07(UTC)
Wiring 3 way turnout - 24630 (H0-scale)
by Alex H 14/01/2024 14:28:17(UTC)
Three way turnout (c-Track) with Viessmann 4568 (Digital)
by Puttputtmaru 07/01/2024 23:29:44(UTC)
74470 Led light for C-track turnout (H0-scale)
by Flupke 16/12/2023 19:32:25(UTC)
Problems with turnouts (H0-scale)
by Arnstein 11/12/2023 11:00:30(UTC)
Broken turnout 24611 (H0-scale)
by trainman11 08/12/2023 12:57:24(UTC)
M-track Curved Turnout Derailment: Fixed (H0-scale)
by dlwestphalen 19/11/2023 19:45:09(UTC)
C track curved turnouts - single track to four (H0-scale)
by einotuominen 31/10/2023 07:38:03(UTC)
Marklin C track turnout decoders (Digital)
by Alex H 12/10/2023 09:20:42(UTC)
Ideas for wiring of turnout lighting and lighting in general (General MRR)
by Luna 23/09/2023 01:07:47(UTC)
Marklin 74470 Turnout Lanterns (Digital)
by Alex H 31/08/2023 14:27:08(UTC)
Turnouts (General MRR)
by sudibarba 20/08/2023 04:09:21(UTC)
Marklin turnouts are not power-routing (General MRR)
by Yoginath 06/07/2023 14:26:26(UTC)
How to make Marklin Ktrack turnout power-routing (General MRR)
by Yoginath 01/07/2023 05:56:24(UTC)
Wide turnouts (General MRR)
by river6109 29/06/2023 10:17:13(UTC)
Old M-turnout digitized (Digital)
by pBonavoglia 04/06/2023 10:17:15(UTC)
Turnout decoder, mobile station (Digital)
by pBonavoglia 31/05/2023 17:04:10(UTC)
m83 decoder wire length to turnouts (Digital)
by swisslocofan 27/05/2023 04:16:19(UTC)
Turnout mechanical issue (Small scale)
by einotuominen 25/05/2023 12:01:51(UTC)
Use AC HO Marklin turnouts with DC power supply? (H0-scale)
by Yigal 14/05/2023 07:41:52(UTC)
Poor turnout connectivity? (Small scale)
by einotuominen 30/04/2023 10:39:13(UTC)
C-Track threeway turnout short circuit (Digital)
by einotuominen 30/03/2023 10:53:07(UTC)
Märklin Z turnout solenoids (Small scale)
by einotuominen 24/03/2023 10:08:13(UTC)
Pickup shoe short circuit Turnouts (24771/2)? (H0-scale)
by flyhalf 22/01/2023 20:55:12(UTC)
Marklin turnout motors (H0-scale)
by David Dewar 03/01/2023 13:31:11(UTC)
3 way turnout with digital (General MRR)
by Puttputtmaru 07/09/2022 00:29:38(UTC)
Märklin Wide Radius Turnouts geometry (H0-scale)
by Patrik 01/09/2022 14:32:38(UTC)
Marklin 3600 WB Remote Operated Turnouts (Collector's Corner general)
by mb300e4m 01/08/2022 21:55:58(UTC)
Turnout Routes on CS3 (Digital)
by Diesel2000 25/07/2022 14:29:49(UTC)
What do you control yours turnout and signals? (Digital)
by Goofy 11/07/2022 08:35:18(UTC)
C-track turnout mechanism stops working (H0-scale)
by Wirring 27/06/2022 22:37:24(UTC)
C track Turnout noob question (H0-scale)
by stratos858 13/06/2022 23:11:03(UTC)
Rocrail and threeway K turnouts (Model railroad software)
by pmgsr 17/05/2022 21:20:37(UTC)
K-track electrical double switch turnout mechanism option (Accessories reviews)
by river6109 16/05/2022 08:14:48(UTC)
Contact track on K-track turnout? (H0-scale)
by DanK 03/04/2022 23:59:17(UTC)
Intermittent switching of turnouts (Digital)
by IBtrain 03/02/2022 06:34:02(UTC)
DCCNext and M turnouts (Model railroad wiring)
by IBtrain 14/01/2022 20:13:45(UTC)
Connecting 3way turnout to Ecos and Rocrail (Digital)
by IBtrain 06/01/2022 08:46:06(UTC)
Turnout mechanism c track (H0-scale)
by DB Fan 05/01/2022 04:46:15(UTC)
Turnout decoders (General MRR)
by Christo Swanepoel 17/11/2021 06:25:18(UTC)
Own turnout switch box setup? (Model railroad wiring)
by mramstedt 16/11/2021 22:27:06(UTC)
Turnout which to use (H0-scale)
by Puttputtmaru 01/10/2021 23:09:09(UTC)
turnouts (Big scale)
by Krish 13/08/2021 08:05:39(UTC)
Change position order of a turnout Ex; W2 W1 W3 W4 back to W1 W2 W3 W4 (Digital)
by marklinist5999 09/07/2021 17:59:20(UTC)
Found the culprit that snaps off all my C-Track turnout Lanterns (H0-scale)
by Dave Banks 05/07/2021 10:37:48(UTC)
Sticky turnouts (Digital)
by Rwill 12/06/2021 14:04:05(UTC)
MS2 Controlling Digital Turnouts in Analog Mode (General MRR)
by Joao Zilio 15/04/2021 19:29:53(UTC)
Turnouts (Model railroad wiring)
by Mr. Ron 07/03/2021 19:21:05(UTC)
This page was generated in 0.502 seconds.
