Offline cristhianrada
#1 Posted : 02 April 2020 01:55:59(UTC)
cristhianrada
Brazil
Hi you all,
I won a marklin in the 70 from my dad, I gave to my son another marklin, the differences are the material of the rails, the 70s are metal, and the new one are in plastic. I was in Germany in 2016, and I bought just only 2 pieces for the compatible rails! Do you know where can I find these rails in São Paulo/Brazil?
#2 Posted : 02 April 2020 02:51:57(UTC)
Welcome :-)
The earlier track you refer to is called 'M' track (for 'Metall')
The newer plastic track is called 'C' track, C often referred to as 'Click' for how easy it is to connect
There is an adapter section to join M and C together, I think this must be what you are referring to.
I cannot help you with any shops in your region or Country but someone else will have some recommendations I'm sure.
Used track is also readily available on ebay. Used M track should not cost you more than $1 per piece, but Turnouts (Switches/Points) are more expensive. Used C track a little more expensive but be careful, there was a period of poor manufacture and the plastic is very brittle and breaks off too easily
Did you also get a catalogue or any booklet from your Father with the 1970's pieces?
Put up some photos if you can, we love to see photos :-)
Steve
#3 Posted : 02 April 2020 22:49:40(UTC)
cristhianrada
Brazil
Hi Steve,
Yes, I was referring to.Well, I m waintig for some information about that. And I found some tracks on the ebay, but that ones are confiable?
Unfortunately, I'm lost the catalogue about the trains in the 70's.
I will setup the tracks, and after post the photos, for these moment without the 70´s loco, cause the newer is digital, and I dont know how to run alnd older and newer together.
Edited by moderator 03 April 2020 11:13:47(UTC)  | Reason: Edited to not include Cookee's entire post, as we don't need to read it twice!
#4 Posted : 03 April 2020 04:17:04(UTC)
You can download many of the Marklin catalogues and books here....
http://www.lctm.info/Secciones/Trenes/Biblioteca/
Most of them are in English, but with a few other languages also.
You can run a newer Digital Loco from a normal Transformer, but if it is Blue, make sure the case is Plastic. Older Blue trafos with Metal case can be dangerous.
But you cannot control an older 'Analogue' (non-digital) Loco from a Digital controller.
#5 Posted : 03 April 2020 11:15:34(UTC)
The C to M track connector piece is item number 24951. You should be able to get them from any local Marklin dealer or off ebay.
Offline waorb
#6 Posted : 03 April 2020 19:49:26(UTC)
waorb
Brazil
Hello Christian.
Welcome to the forum!
You could start here for some pieces:
https://www.riograndemodelismo.com.br/
https://www.jorgetrens.net.br/
Unfortunately Märklin in Brazil is quite expensive. JorgeTrens have a lot of tracks on his MercadoLivre portal/shop.
My layout is based on C track, but I think I have some M tracks... I'll check...
As Steve said, send us some photos. Yes, we love them. Drool
Walter
#7 Posted : 03 April 2020 21:24:46(UTC)
cristhianrada
Brazil
Hi everybody,
fisrt of all, tks for the explanations Steve.
so, I try to use the conector form C to M, and I setup the track with these tracks together, but when the digital loco arrived to the M track , its stopped, like was not energized. Do you think I need turn on
the old traffo for the M track, so then the loco be able to run in the mixed tracks? with two traffos, the old n the digital together. this weekend I will try to use the older loco and set separete, and together, then I will take some photos and post here.
tks bigdaddy...I have 3 peaces from this connector, and I will buy another to setup a big old n new track mixed.
walter, obrigado pelas informações, dei uma olhada superficial, mas esses dois sites apresentam outras marcas de trenzinhos, nao do marklin, é isso mesmo? abs
Hello Christian.
Walter
#8 Posted : 04 April 2020 02:05:47(UTC)
NO NO NO do not do that. You will destroy the output stages of the digital controller. Only use one type of controller at a time.
This sounds like your M track needs cleaning to get rid of dirt from the rails. A wipe down with some old denim cloth should work wonders here.
#9 Posted : 04 April 2020 06:54:58(UTC)
As Alan said, you should be able to simply connect your M & C tracks together and run the Loco.
If you can, try using a 12v lamp or a meter if you have one to check voltage on the M rails
Never mix analogue and digital control on the same track. That would be... Bad
#10 Posted : 05 April 2020 15:40:32(UTC)
cristhianrada
Brazil
Hi Allan,
Ok, i dont do that!
I was set up separate this two old and new sets. So guys, do you know how I find on ebaumy the correct name about the basis for this passenger wagon? I need to fix, but I didn’t found on eBay.
Do you think I need turn on18391562-FC0A-4250-AE60-5FBD783BCCFA.jpegF3888394-DD7F-4201-9249-48B3AFC7EAEE.jpegDD1E002D-7156-4515-952E-12B5F8A534AD.jpegA236BB6A-9E63-427B-AB2E-9111C1DB4E7C.jpeg61067490-6564-4709-90B7-D54EC47CF041.jpeg716BAF22-7CF6-4C04-AEE9-C13B3D9E78A2.jpeg
#11 Posted : 05 April 2020 22:28:39(UTC)
cristhianrada
Brazil
Hi buddies,
I found a catalogue from the 80s, send the photo, a a video from the two sets running ok! Nothing like a correct cleaning! Lol4CC8E045-0522-4998-BD24-C42183EF32A0.jpeg IMG_8798.MP4 (6,385kb) downloaded 18 time(s).
Hi Allan,
Ok, i dont do that!
Do you think I need turn on the old traffo for the M track, so then the loco be able to run in the mixed tracks? with two traffos, the old n the digital together. this weekend I will try to use the older loco and set separete, and together, then I will take some photos and post here.
Edited by moderator 06 April 2020 09:46:49(UTC)  | Reason: Removed repeated images
Trix - Marklin compatibility (H0-scale)
by Ivan 05/04/2024 10:03:39(UTC)
Mobile station 1 and CS3plus compatibility (Digital)
by biswasg 25/03/2024 10:00:10(UTC)
Faller compatibility with Marklin c-tracks (H0-scale)
by fabstar68 19/12/2023 15:23:05(UTC)
Central Station 3 transformer compatibility 6002 (Digital)
by vandermerwe 26/07/2022 12:35:09(UTC)
dcc controller (Mobile station) compatibility (Digital)
by MalvernStation 12/12/2021 21:35:41(UTC)
Transformer compatibility (General MRR)
by rjleeiv 28/11/2021 22:08:02(UTC)
Marklin Start Up compatibility w/older digital engines (H0-scale)
by eccarleton 31/03/2021 14:51:36(UTC)
Brand Compatibility (Digital)
by Lusito 28/02/2021 20:47:12(UTC)
Locomotives compatibility (General MRR)
by F456GT 15/02/2021 20:22:31(UTC)
New C Track layout and compatibility with some Marklin items (H0-scale)
by plg 26/11/2020 19:25:59(UTC)
Marklin HO track compatibility with PIKO / ROCO HO (H0-scale)
by Ammorphis 25/10/2019 12:14:13(UTC)
ESU 31331 and Marklin R1 compatibility query (H0-scale)
by madhu.gn.71 29/06/2019 12:50:37(UTC)
Possible incompatibility between New Marklin locos and Rokuhan controllers (Small scale)
by husafreak 19/06/2019 00:41:53(UTC)
My world compatibility (H0-scale)
by budi@ups4.com 30/05/2019 10:38:40(UTC)
MTH compatibility with Märklin and ECOS (General MRR)
by Cargodog 13/04/2019 09:14:37(UTC)
[answered][Urgent]: Help needed on 3301's (Delta) compatibility with Marklin Digital (H0-scale)
by madhu.gn.71 02/09/2018 08:11:33(UTC)
Digital Compatibility (Digital)
by hkost 26/04/2018 20:13:35(UTC)
N Gauge Compatibility (Small scale)
by Kapalua 17/12/2017 20:28:30(UTC)
Marklin K-tracks 21xx and 22xx compatibility (H0-scale)
by fje 04/01/2017 22:29:20(UTC)
Digital System Compatibility (Digital)
by mb300e4m 11/11/2016 14:41:42(UTC)
ESU 31031 Electric loco and compatibility with Marklin C track... (H0-scale)
by vnangli 12/05/2016 17:05:28(UTC)
compatibility of marklin and other systems (H0-scale)
by quarkhirad 04/05/2015 07:32:34(UTC)
Compatibility of marklin ho catenary (H0-scale)
by quarkhirad 25/04/2015 11:55:20(UTC)
6080, 6090 compatibility issues with MS2 (Digital)
by taliesin 26/03/2015 19:20:23(UTC)
Compatibility between locos and passenger cars.. (General MRR)
by vnangli 16/03/2015 03:49:45(UTC)
Newbie question re coupler compatibility (H0-scale)
by arawata 21/06/2014 12:23:22(UTC)
Compatibility question. (Digital)
by Marklin in Oz 21/05/2014 04:09:54(UTC)
PIKO and Maerklin compatibility (H0-scale)
by madhu.gn.71 16/04/2014 10:59:37(UTC)
Fleischmann Coupler Compatibility? (H0-scale)
by Roman 31/10/2012 21:32:50(UTC)
Compatibility between Central station 2 (60125) and Trix Mobile Station 1. (Digital)
by Gustavo Villa 11/09/2012 16:27:02(UTC)
Compatibility of Jouef With Märklin (H0-scale)
by Hirayama 23/07/2012 13:31:54(UTC)
DCC compatibility (Digital)
by phantomtracer 27/11/2008 02:00:33(UTC)
MFX and ESU LokProgrammer Compatibility (Digital)
by Hobbit 04/12/2007 15:52:53(UTC)
Intellibox incompatibility? (Digital)
by mrmarklin 06/08/2007 04:07:02(UTC)
Compatibility of 2681, 4998 and 4999 with Systems (Digital)
by Sander van Wijk 17/06/2007 02:26:14(UTC)
Compatibility of 6050 Interface (Digital)
by Franz 18/04/2007 10:29:15(UTC)
track compatibility... (General MRR)
by shaygetz 20/02/2007 05:41:59(UTC)
Digital compatibility? (Digital)
by phantomtracer 27/12/2006 16:05:48(UTC)
No Compatibility 6021 and ESU V2.0? (Digital)
by efel 14/11/2005 16:07:12(UTC)
Mfx loco compatibility (Digital)
by Lars Westerlind 02/06/2005 00:43:29(UTC)
Mobil Station compatibility (Digital)
by jorge 23/05/2004 18:12:11(UTC)
HO Compatibility question (H0-scale)
by Bill190D 30/12/2003 04:01:46(UTC)
Daisy compatibility with Marklin (Digital)
by tayloma 10/09/2003 08:42:35(UTC)
Mehano & Marklin Compatibility (H0-scale)
by andrews 24/04/2003 20:49:39(UTC)
This page was generated in 0.593 seconds.
