Offline MalinAC
#1 Posted : 11 January 2017 16:55:55(UTC)
MalinAC
Ireland
Hi guys, Im going to try and build a solid centre rail track layout and I need some help with the wiring. Is there a Marklin book that shows how to wire up the different parts of the layout and if so whats the part number.Im using 3600 track. I would appreciate any help as I want to find out what all the different track pieces do and how to wire them up .Eddie
Offline seatrains
#2 Posted : 11 January 2017 17:21:45(UTC)
seatrains
Eddie, others on the list with more knowledge will chime in with the Marklin titles but a book that I like is Layout Building Handbook for Operators of Marklin HO Trains, by Carl Weaver. It was formerly called "Greenbergs Model Railroading with Marklin HO". This resource is strictly for analog Marklin. You will see it sometimes on ebay and Amazon in the used books. My copy is 8.5 x 11 and soft cover.
Carl shows with pictures and diagrams what he did on his layout and has M and K track tips. He also has tips for working with signals and accessories. My local library used to have a copy. Good luck and post progress picturesBigGrin
Thom
thanks 3 users liked this useful post by seatrains
Marklin 60116 Digital Controler -- Electrical Requirements (Digital)
by WetterauSüd 13/07/2024 00:26:10(UTC)
Electrical pick up (H0-scale)
by Ray Di Ciacca 20/02/2024 03:19:37(UTC)
Concerning Possible Electrical short circuits? (General MRR)
by ShannonN 06/09/2023 01:20:42(UTC)
K-track electrical double switch turnout mechanism option (Accessories reviews)
by river6109 16/05/2022 08:14:48(UTC)
Electrical wire cross sectional surface for a decoer (Digital)
by sdel95 20/12/2020 16:22:13(UTC)
Electrical wire connections to the Decoder m83 (Digital)
by fosuna 04/10/2020 11:57:41(UTC)
Electrical pick-up and running in (Small scale)
by Poor Skeleton 08/05/2020 00:42:11(UTC)
Increase electrical supply on the layout (Model railroad wiring)
by avio 06/07/2019 14:54:08(UTC)
Why is there an electrical potential difference between track and ground ? (Digital)
by Johnvr 03/03/2019 16:00:41(UTC)
24711/24712 Electrical Problems (H0-scale)
by dickinsonj 17/01/2019 15:33:00(UTC)
Puzzling electrical problem with Marklin 43867 cars (H0-scale)
by johnpatrickwack 07/01/2019 21:48:25(UTC)
K track electrical question (H0-scale)
by Harvey 13/11/2018 04:56:35(UTC)
Electrical diagram of Intellibox 1 (Digital)
by efel 16/07/2018 16:34:07(UTC)
Trix Entertainment Car # 23490 has poor electrical contact (General MRR)
by Fredashay 13/03/2018 02:24:41(UTC)
Electrical Connections to The m83 (60831) decoder and Mini trix trains (Digital)
by BR221 10/03/2018 00:02:15(UTC)
An electrical short circuit that I can't explain to myself. (General MRR)
by Thewolf 05/03/2018 10:53:24(UTC)
Electrical continuity (General MRR)
by Thewolf 11/02/2018 01:18:31(UTC)
Electrical shock from rails? (Model railroad wiring)
by Danlake 13/11/2017 09:58:12(UTC)
electrical turnouts not working (Small scale)
by Rocca 14/11/2015 10:59:16(UTC)
newly constructed symmetric 4 pin electrical couplings (H0-scale)
by river6109 13/04/2015 18:19:04(UTC)
How to properly set up the electrical system for automatic train operation (Digital)
by Martin T 28/12/2014 22:15:41(UTC)
"Restoration Corner" Questions on Original Marklin Factory Paint and Electrical (Painting & Weathering)
by 5HorizonsRR 13/08/2014 22:57:08(UTC)
US FCC and electrical certification questions (H0-scale)
by mike c 18/12/2013 21:11:37(UTC)
Electrical coupler questions (H0-scale)
by camcath 08/08/2013 13:17:12(UTC)
It is possible to repair a CS2 that suffered a electrical cut-off while updating? (Digital)
by RUBEN SPAIN 11/03/2013 22:34:04(UTC)
Newbie Electrical Questions (Model railroad wiring)
by Mike M 26/02/2013 18:48:17(UTC)
Maxi 5454 Central Pacific Locomotive - Electrical Issues (Big scale)
by Thewhip1970 25/01/2013 21:33:56(UTC)
HO electrical wire, could I use Ethernet Cable? CAT 5 (H0-scale)
by Marklin3200 22/01/2013 17:47:08(UTC)
transformer 6627 electrical connections (Big scale)
by traindude 21/11/2012 05:01:16(UTC)
boosters and cs2 and electrical shorts (Digital)
by Andreas K 16/11/2012 12:34:27(UTC)
3071 Electrical Diagram and Digital Conversion Question (Digital)
by 5HorizonsRR 22/10/2012 07:20:56(UTC)
conversion decorder set have electrical shock (Digital)
by thanethm11 15/09/2012 18:50:34(UTC)
electrical question - ESU 50200 (Digital)
by dpetersen 05/07/2012 19:08:06(UTC)
Is there an Electrician or Electrical Engineer on the Forum? (Digital)
by Drongo 31/07/2011 13:33:12(UTC)
Tracking an electrical fault in a layout (H0-scale)
by kimballthurlow 21/10/2010 11:06:18(UTC)
ICE 2 train electrical couplings (H0-scale)
by river6109 16/09/2010 18:19:25(UTC)
Märklin, Roco & Fleischmann electrical couplings (H0-scale)
by river6109 22/08/2009 05:22:50(UTC)
Exorcism of electrical demons when digital on M (Digital)
by Writhdar 17/02/2009 23:39:30(UTC)
Electrical Supply Authoritys ( stuff ups ) (General MRR)
by Rowan 20/09/2008 04:43:35(UTC)
Wheel pitting due to electrical arcing (Digital)
by Marty 16/08/2008 19:13:48(UTC)
Silly question - Electrical (H0-scale)
by soren36 08/09/2006 17:38:08(UTC)
Is the Marklin HO Electrical Book no. 715 in Engli (General MRR)
by biswasg 19/01/2006 21:56:53(UTC)
Marklin 3014 electrical fault (H0-scale)
by go-2004 12/04/2005 12:15:49(UTC)
Electrical Problem (General MRR)
by John Winter 09/06/2004 08:54:00(UTC)
Electrical schemes (Digital)
by DCCTRAIN 08/12/2003 19:52:33(UTC)
electrical mechanism (H0-scale)
by alonso231gery 27/11/2002 18:03:04(UTC)
electrical on turnouts and signals. (General MRR)
by Lorene 16/11/2002 00:13:31(UTC)
electrical (General MRR)
by Lorene 13/09/2002 23:42:49(UTC)
Electrical - Wiring (General MRR)
by camagliocco 01/07/2002 20:38:03(UTC)
This page was generated in 0.559 seconds.
