Offline Snowfun
#1 Posted : 30 December 2021 09:08:30(UTC)
Snowfun
Can anyone provide some advice about the track power supply please?
Is it necessary to use the (not cheap!) 8590 track piece (as opposed to simply soldering the power wire to the track directly)? Presumably the more power connections to the track the better? How many might reasonably be recommended on, say, a loop of 5m?
On a not totally unrelated issue, is it possible to get a crossover in which one track direction is isolated from the other? So, for example, the crossover enables two independent loops to overlap.
Thanks.
Tim
Offline Carim
#2 Posted : 30 December 2021 10:29:29(UTC)
Carim
Hi Tim,
Yes, you can solder power wires directly to the rails. If you are not creating blocks per se, a connection every 100 - 150cm should be fine.
For the crossover, just have an air gap or insulated joiners between the two points - then both circuits are physically joined but electrically separate.
Carim
Offline Snowfun
#3 Posted : 30 December 2021 15:21:42(UTC)
Snowfun
Thanks.
I made an error using the term “crossover”. Apologies. I meant a “crossing” as in track item 8559. Imagine 2 independent (electrically isolated and entirely separate) ovals of track one of which overlaps the other. Thus requiring two crossings in the physical form of 8559.
8559s wouldn’t do this because - if I understand it correctly - the two “routes” are electrically connected. I need a crossing in which route 1 (let’s say straight across) is electrically separated from route 2 (ie the -13 and +13 degree tracks). Does such a thing exist (in one of the other manufacturers?) or would I need to home build?
Good to hear that the power wires can be soldered directly to the rail - I’ll incorporate copper wire under the board with feeders at regular intervals.
Tim
Offline Carim
#4 Posted : 30 December 2021 16:59:24(UTC)
Carim
Sorry but I don't have an 8559 crossing, so I don't know how that is wired. I know that both routes are electrically connected on the double slip but I would think it strange if they were on a crossing. Do you have a multimeter to check?
Carim
Offline Mman
#5 Posted : 30 December 2021 17:47:07(UTC)
Mman
307D1E23-89BC-4067-A10D-12492C23A382.jpegE69597DE-788D-4CDC-B3CA-B66FC20D2F97.jpegI have carefully examined my 8559 diamond crossing and compared it with a double slip and as Carim states with the double slip the same applies to the diamond - all routes are electrically connected so, no, it wouldn’t work as you had hoped.
I don’t have any other makes of diamond to know whether insulating ones exist.
Märklin points are not isolating either, but Rokuhan ones can be made to be by removing links, whether their diamond can be so adapted I don’t know.
There is anAmerican manufacturer of Z track I believe.
Anything is possible though, by isolating each of the four ends of the diamond and feeding it from either circuit via a universal relay for example, triggered by circuit tracks activated by approaching trains you could do what you want.
Regarding feeds other than 8590 items, I recently bought a large quantity of used Märklin Z track and with it came several fishplates to which wires had been soldered, this would eliminate the risk of melting the plastic track parts when soldering to the rails directly.
ChrisG
Offline Mman
#6 Posted : 30 December 2021 18:11:48(UTC)
Mman
A206F6F4-6852-4864-A04D-F889FDF2616E.jpegWhat I do have, however, is a Rokuhan scissors crossover incorporating a diamond and as you can see it is completely different to the Märklin type. This is one which isolates the two routes. I don’t have a separate Rokuhan diamond to examine.
ChrisG
Offline Mman
#7 Posted : 30 December 2021 18:29:38(UTC)
Mman
7B901FA9-E41C-4F39-A1EF-5835CEF37431.jpegHad a look at MTL Z track online and they don’t shew a diamond or slip, also looked at Rokuhan and their 13 degree diamonds and slips are constructed in the same way as Märklin ones but they do have a 90 degree crossing which may have possibilities.
ChrisG
Offline Mman
#8 Posted : 30 December 2021 20:49:50(UTC)
Mman
AF153D50-82CA-4A72-83AC-A2E6312F188A.jpeg9EFA37AD-CAB3-4854-9437-0A3B0B2CA15E.jpegThe instructions for the Rokuhan slip suggests power routing is possible, the instructions for the diamond don’t mention it.
ChrisG
Online Donb
#9 Posted : 30 December 2021 21:00:25(UTC)
Donb
Thanks.
Tim
heres some prewired fishplates on eBay you might be interested in,
https://www.ebay.ca/itm/203252069480
Best Regards,
Don
CS3, ( Commander is now retired) , C track and Z scale, mostly DB/DR and SBB, SJ
Offline Snowfun
#10 Posted : 30 December 2021 21:43:42(UTC)
Snowfun
Lots of useful info!
I had a quick look too at the picture of an Atlas 19 degree crossing (2813) - it appears to be a possibility. Worth getting one to try. My issue then is to match it to the Marklin track. Possibly nothing a file can’t handle…
I’ll also get a Rokuhan slip to try out.
Nothing is built yet so I’m exploring all the possibilities and options to fine tune the layout.
Tim
Offline Toosmall
#11 Posted : 30 December 2021 23:45:49(UTC)
Toosmall
The nickel rail has about 4 time the resistance of copper. So I solder about every 2 metres when using 660mm track sections which I mostly use, or solder where convenient. No point using the power feed rails, they are ugly apart from the expense and usually in the way of other scenery.
I also solder a thin bit of wire to the track and then a thicker section on the end of that and heat shrink the joint.
For getting block sections to work, DPDT 2amp relays are the go and I plug them in to circuit board CPU seats so they are not directly soldered in, easy to swap. If a relay fails it is easy to unplug and plug in a new spare relay. Easy, cheap, quick to replace.
The second side of the DPDT relay can feed LEDs on your control board to show you powered and unpowered or directional sections.
Use a black marker pen to camoflauge the solder.
DC power supply (Digital)
by Bernd 08/12/2023 16:58:22(UTC)
Need a 15v AC power supply recommendation for 89401 signal (Small scale)
by Bilge Rat 07/06/2023 19:42:05(UTC)
Use AC HO Marklin turnouts with DC power supply? (H0-scale)
by Yigal 14/05/2023 07:41:52(UTC)
MS2 replacement power supply (H0-scale)
by revmox 23/01/2023 23:30:41(UTC)
Compatible power supply for Marklin M Track? (General MRR)
by Skywalker646 10/12/2022 02:49:53(UTC)
Power supply socket (General MRR)
by Rwill 21/02/2021 11:09:48(UTC)
Arduino, 60113 box with MFX additional power supply (Digital)
by NicoNumberFour 07/12/2020 12:26:42(UTC)
Power supply of digital 11/5000 locomotives (H0-scale)
by Garoux 15/07/2020 15:00:23(UTC)
digital and classic power supply from transfo (General MRR)
by Garoux 15/07/2020 14:43:52(UTC)
m83 power supply + Viess. Signals (Digital)
by kehdi737w 27/06/2020 10:37:38(UTC)
Marklin Decoder m83, 60832, and external power supply (Digital)
by ocram63_uk 28/10/2019 09:15:30(UTC)
design of power supply wires (Model railroad wiring)
by Thewolf 28/08/2019 14:36:35(UTC)
Power supply problem? (General MRR)
by Sir Timbo 03/04/2019 06:20:39(UTC)
power supply 60822 (General MRR)
by Thewolf 03/02/2019 02:10:39(UTC)
Problem with M83, M84 & Universal Power Supply (Digital)
by rrf 01/02/2019 22:53:38(UTC)
Intellibox II Transformer/Power Supply (Digital)
by jbblunck 15/02/2018 16:54:40(UTC)
60822 universal power supply / 66367 power pack for M83/M84 (H0-scale)
by ae66green 17/01/2018 17:08:46(UTC)
Repairing a 60061 Power Supply (Digital)
by Bigdaddynz 21/10/2017 11:46:01(UTC)
Power Supply for CS3 (Digital)
by compatty 08/10/2017 14:11:45(UTC)
Connecting power supply common wires (H0-scale)
by Donb 04/05/2017 18:18:43(UTC)
M83 power supply via booster (Digital)
by antazio 28/04/2017 20:51:41(UTC)
Power Supply (H0-scale)
by Twisterdodger 27/04/2017 15:41:34(UTC)
Nielsenr - CS2 Power Supply For Large Scale Trains (Big scale)
by Nielsenr 07/03/2017 16:59:18(UTC)
S88 and power supply (Digital)
by Harvey 08/01/2017 17:12:45(UTC)
Power supply layout.... the bulshitt (General MRR)
by Thewolf 09/09/2016 16:49:58(UTC)
MÄRKLIN 60657 Mobile Station with Junction box 60116 + Power supply 66361 (Digital)
by Barton 04/08/2016 21:57:53(UTC)
Märklin Safety Power Supply 66470 vs. 6631 (General MRR)
by sjlauritsen 02/08/2016 15:23:17(UTC)
A Power supply for new M83. Is a 60822 needed? (Digital)
by frickwg 19/03/2015 22:30:36(UTC)
Power Supply / Transformer for CS2: 60055 vs. 60065 (Digital)
by cwp_marklin 02/03/2015 21:29:07(UTC)
Power Supply for MS 2 - Anyone using 66185 for MS 2? (Digital)
by SAK 19/02/2015 08:07:17(UTC)
Power Supply for Accessories other than 6646 (Digital)
by stlcards54 13/02/2015 17:43:53(UTC)
Suitable replacement for the 18VA power supply (Small scale)
by nevw 29/11/2014 23:52:19(UTC)
Power Supply inside wagon (Digital)
by sevs 28/07/2014 10:06:00(UTC)
CS2 & 60065 power supply (50 VA) rare behavior (Digital)
by eduard71 12/03/2014 20:30:50(UTC)
MS2 with own power supply and 6002 for accessories on M-track (Digital)
by timvenn20183 03/03/2014 19:24:24(UTC)
Power Supply Mobile Station 2 (Digital)
by mike c 12/01/2014 02:05:39(UTC)
29486 Set, which 120V Power Supply? (H0-scale)
by mike c 07/01/2014 05:29:49(UTC)
by wsscott 27/11/2013 17:49:29(UTC)
12 V DC power supply to Viessmann 5211 (Digital)
by DaleSchultz 10/11/2013 17:21:36(UTC)
Power supply for analog BR 89 3000 (H0-scale)
by Bagrym 17/12/2012 10:38:19(UTC)
Secondary power supply for switches, decoders etc. (Digital)
by Semaphore 13/10/2012 19:30:53(UTC)
PC Lap top power supply for digital train? (Digital)
by wurttemberg 09/05/2012 10:22:10(UTC)
Ecosboost 8amp power supply - variable or not. (Digital)
by diesel 28/04/2012 14:02:33(UTC)
ECoS power supply replacement (Digital)
by GSRR 13/01/2012 18:36:54(UTC)
accessory power supply (H0-scale)
by Shintaro 28/10/2011 07:53:41(UTC)
Power supply for k83 decoders (Digital)
by ChrisP 21/10/2011 09:20:21(UTC)
New power supply & booster (Digital)
by Drongo 08/06/2011 07:06:24(UTC)
Switching Power supply (Digital)
by James 01/03/2011 15:18:52(UTC)
Marklin Switched Mode Power Supply (General MRR)
by GSRR 19/01/2011 18:32:38(UTC)
DON'T use car batteries as power supply. (Digital)
by Purellum 27/10/2010 21:53:17(UTC)
This page was generated in 0.805 seconds.
