Offline timvenn20183
#1 Posted : 03 March 2014 19:24:24(UTC)
timvenn20183
I have a request regarding the usage of a 60635 and 60113 Mobile Station 2 and a 6002 to power accessories. After a search of the forums I am still not 100% sure what the best way is to connect the MS2 with its related power supply and a 6002 for the accessories. My layout is a small M-track layout with 10 signals, 9 turnouts and 8 uncoupling rails. What I would like to do is run the loks off the MS2 and supplied power supply but the accessories and lighting from the 6002. Since my signals are not connected to the track in any way I have no problem with those. The problem comes with the turnouts (and their lights) and uncoupling rails.
Is there a Marklin recommended / safe way of doing this ?
Thanks in advance.
#2 Posted : 04 March 2014 04:32:42(UTC)
The following image is from the Markin FAQ#407
http://www.maerklin.de/m...faq/Technik-Tipp-407.pdf
While it is aimed at the crossing device, the concept is the same for any device (like an M track turnout light) that uses(requires) the same electrical return as the trackbed/rail (Brown)
The diagram does show 2 separate Brown connections to the track, one from the transformer and one from the controller.
If you wish you may connect then together before making a single connection to the rail.
#3 Posted : 04 March 2014 15:18:49(UTC)
timvenn20183
Many thanks. This is what I had suspected but feel a lot more comfortable connecting it now.
This page was generated in 0.317 seconds.
