Offline Imagine
#1 Posted : 07 July 2018 07:39:46(UTC)
Imagine
A 2 rail Marklin Hamo BR E 91 #3828 was recently purchased. A fine looking lok that runs well in analog. but it does not respond in digital mode. The manual recommend address 28 that was set in the Marklin MS2 and nothing happened. The "find" was attempted on the MS2 and it showed no lok. The set default was tried and no response. The manual showed a keyboard to reset the address, yet when the lok was opened there was a decoder, but no board. Any suggestions to get the lok to operate in the digital mode?
#2 Posted : 07 July 2018 08:37:10(UTC)
I do not understand what you mean "... a decoder, but no board."
Could you take a photo?
Do you have another Maerklin or Hamo digital loco to compare?
#3 Posted : 07 July 2018 09:41:37(UTC)
May I ask who said the loco was digital compatible ?
Offline Markus Schild
#4 Posted : 07 July 2018 13:10:14(UTC)
Markus Schild
A #3828 should be able to run on DCC as it comes out of the box. It does not work with MM oder other formats. Did you check that the adress was for DCC format?
Markus
#5 Posted : 07 July 2018 13:20:54(UTC)
The 3828 was a Hamo 2-rail digital version for use with 6027 Central until= (2-rail) with 6035 control 80.
Offline Imagine
#6 Posted : 27 July 2018 18:58:37(UTC)
Imagine
Thank you for your responses. All off the recommendations were reviewed and yes it is a DCC decoder without a switch panel. After extensive reacing an article was found in French revealing the correct address of 9. The lok ran like a Swiss watch several times around the layout after a bit of lubing.
thanks 2 users liked this useful post by Imagine
Digital wiring (Digital)
by Mjn2ts 09/04/2024 00:45:26(UTC)
Converting digital to analog (!) (H0-scale)
by Jay Zvolanek 28/03/2024 05:15:04(UTC)
Roco 69618 AC digital (MFX decoder) br118 won't work on digital (H0-scale)
by Lev.Sever 18/03/2024 23:39:27(UTC)
70412 and 70421 digital light signal equipments (Digital)
by biswasg 14/03/2024 14:58:20(UTC)
Digital conversion of 4-6-2 steam loco from 1961 (Digital)
by Bcur 28/02/2024 17:56:38(UTC)
Custom smoke generator for digital use (Digital)
by einotuominen 17/02/2024 11:44:17(UTC)
Digital Conversion of a Delta Ae 8/14 - PC Board Part #? (Digital)
by 5HorizonsRR 06/02/2024 20:39:15(UTC)
Adding digital passenger cars to a Marklin digital engine (Digital)
by Zeeboo04 25/01/2024 17:06:37(UTC)
43630 I.C. digitalcab control car (Digital)
by marklinist5999 23/01/2024 14:31:29(UTC)
29821 digital mega starter set (H0-scale)
by mike@complexplastics 15/01/2024 18:41:40(UTC)
Märklin digital mobile station 1 compatible trains etc (Digital)
by Alex222 04/01/2024 18:57:50(UTC)
ESU 50708 Digital Interior Lighting (Digital)
by Eddie7979 24/12/2023 10:43:49(UTC)
ICE 3370 or 3770 digital conversion (H0-scale)
by StanN 21/12/2023 22:59:50(UTC)
analog to digital (H0-scale)
by Makistrain 16/12/2023 00:09:00(UTC)
Digital Signal 76393 (Digital)
by Flupke 20/11/2023 15:19:18(UTC)
Where to start - Analog to Digital (Digital)
by Aussie Susan 08/11/2023 02:11:05(UTC)
Digital Engines on Analog Layout (H0-scale)
by FastEddie 19/10/2023 00:08:49(UTC)
Rocco AC Rail on Marklin digital (Digital)
by Zeeboo04 28/09/2023 22:06:47(UTC)
Newbie Digital Guy with issues - Nevermind - I figured it out! (Digital)
by Pinballwizard 18/09/2023 21:44:33(UTC)
Z digital (Digital)
by BenP 09/09/2023 16:02:05(UTC)
Digital Transfer for Locomotives (Digital)
by TEEPOL 06/09/2023 15:50:06(UTC)
digital loco with 6080 decoder in analog mode (H0-scale)
by 3104V200 25/08/2023 08:04:09(UTC)
Diamond Crossings digital (H0-scale)
by heinrichhess 04/08/2023 11:44:06(UTC)
noise stationary digital (H0-scale)
by heinrichhess 04/07/2023 02:52:29(UTC)
how much £ to covert a bus digital (H0-scale)
by heinrichhess 01/07/2023 00:46:47(UTC)
Time to go digital? (Digital)
by MtrackJai 23/06/2023 18:00:31(UTC)
how to identify a digital loco (H0-scale)
by heinrichhess 07/06/2023 21:38:51(UTC)
Trouble with digital loco 37691 (General MRR)
by polabear 05/06/2023 18:02:05(UTC)
Hag digital conversion (General MRR)
by mvd71 06/05/2023 05:58:50(UTC)
Unknown digital unit connected to straight tracks (Model railroad wiring)
by 3030guy 10/04/2023 10:54:30(UTC)
Digital (Digital)
by Tie 27/03/2023 20:48:25(UTC)
ESU Digital Lighting 50708 with MFX+ (Digital)
by Kiko 25/03/2023 22:52:53(UTC)
digital 74461 with 72710 controlbox (General MRR)
by gladop 10/03/2023 23:14:20(UTC)
Märklin My World loco on Digital layout; what’s the address? (Digital)
by Max J 09/03/2023 23:31:11(UTC)
Wowie Zowie! Faller digital car system ... (General MRR)
by thing fish 03/03/2023 08:34:41(UTC)
Two new digital cab control (Digital)
by Goofy 22/01/2023 08:35:09(UTC)
Digital conversion of Märklin 3511 (Digital)
by Martti Mäntylä 04/12/2022 17:36:42(UTC)
Digital, m83 (Digital)
by Don Morris 02/12/2022 04:36:48(UTC)
Using MS2 to control Brawa LOK with Brawa Premium-Digitaldecoder version 3.0 (Digital)
by Johnny rum rider 20/11/2022 14:20:16(UTC)
HAG RE 4/4I Digital Lighting Conversion- Swiss Headlight Changeover? (Digital)
by 5HorizonsRR 19/11/2022 21:58:09(UTC)
Pickup shoe for digital driving? (Digital)
by einotuominen 21/10/2022 18:13:51(UTC)
Digital 7186 turntable (Digital components and Software reviews)
by BenP 13/10/2022 17:08:38(UTC)
Can a CS3 run ho digital 2 rail as well as Marklin (Digital)
by Newbie 09/10/2022 05:41:40(UTC)
Can Digital Bahn GleisReporter C track connections/contact track (Digital)
by einotuominen 06/10/2022 10:49:05(UTC)
Märklin Mak Digitalization (Digital)
by rytter 10/09/2022 23:58:11(UTC)
3 way turnout with digital (General MRR)
by Puttputtmaru 07/09/2022 00:29:38(UTC)
Solved a problem with BR80 3404 RAG running digital (Model railroad wiring)
by kimballthurlow 21/08/2022 10:54:25(UTC)
DIGITAL (Digital)
by jens tautor 01/08/2022 01:01:59(UTC)
by Marklinisten 11/07/2022 08:56:20(UTC)
Digital Access (News from Märklin and others)
by bugsmasher 25/06/2022 17:00:28(UTC)
This page was generated in 0.532 seconds.
