Offline Imagine
#1 Posted : 07 July 2018 07:39:46(UTC)
Imagine
A 2 rail Marklin Hamo BR E 91 #3828 was recently purchased. A fine looking lok that runs well in analog. but it does not respond in digital mode. The manual recommend address 28 that was set in the Marklin MS2 and nothing happened. The "find" was attempted on the MS2 and it showed no lok. The set default was tried and no response. The manual showed a keyboard to reset the address, yet when the lok was opened there was a decoder, but no board. Any suggestions to get the lok to operate in the digital mode?
#2 Posted : 07 July 2018 08:37:10(UTC)
I do not understand what you mean "... a decoder, but no board."
Could you take a photo?
Do you have another Maerklin or Hamo digital loco to compare?
#3 Posted : 07 July 2018 09:41:37(UTC)
May I ask who said the loco was digital compatible ?
Offline Markus Schild
#4 Posted : 07 July 2018 13:10:14(UTC)
Markus Schild
A #3828 should be able to run on DCC as it comes out of the box. It does not work with MM oder other formats. Did you check that the adress was for DCC format?
Markus
#5 Posted : 07 July 2018 13:20:54(UTC)
The 3828 was a Hamo 2-rail digital version for use with 6027 Central until= (2-rail) with 6035 control 80.
Offline Imagine
#6 Posted : 27 July 2018 18:58:37(UTC)
Imagine
Thank you for your responses. All off the recommendations were reviewed and yes it is a DCC decoder without a switch panel. After extensive reacing an article was found in French revealing the correct address of 9. The lok ran like a Swiss watch several times around the layout after a bit of lubing.
thanks 2 users liked this useful post by Imagine
Marklin 3075: from digital to analog (H0-scale)
by philippe99 09/08/2025 17:55:09(UTC)
Hamo 8394 BR 03 Digital conversion (Collector's Corner general)
by Imagine 01/07/2025 21:46:50(UTC)
Marklin 55035 Problem with digital commands (Big scale)
by Fabionino 03/06/2025 13:57:21(UTC)
How many digital decoders for C Track can you use? (Digital)
by michelvr 25/05/2025 23:29:05(UTC)
Digital Newsletter Back Issue link (Digital)
by BwanaJoe 11/05/2025 14:31:01(UTC)
Old Digital Gear and old Magazines (General MRR)
by BwanaJoe 05/05/2025 19:54:43(UTC)
Digital upgrade questions for the experts (Big scale)
by roundsaturn31 26/04/2025 16:49:44(UTC)
Old passenger cars with interior lighting on digital layouts (Digital)
by Evergreen 21/04/2025 15:47:07(UTC)
Digital Cameras-Nothing Works (Model railroad photography)
by analogmike 16/04/2025 14:11:57(UTC)
Trafo 6646 and Digital Loco (Digital)
by mb300e4m 26/03/2025 01:32:15(UTC)
incandescent bulbs in digital conversion (Digital)
by einotuominen 18/03/2025 18:14:34(UTC)
Loco digital conversion led light question (Digital)
by Mjn2ts 17/03/2025 20:11:49(UTC)
Digital Operation of the classic Marklin Crane 6051 (Digital)
by Johnvr 16/03/2025 17:07:42(UTC)
Digitally operated turnouts / switches (Digital)
by osoraku 16/03/2025 16:52:36(UTC)
Toughts in this Roco Ac digital (Digital)
by Adrian666 14/03/2025 03:01:05(UTC)
Issue with digital wagon (Digital)
by Adrian666 10/03/2025 19:14:54(UTC)
Other digital brands on cs3+ marklin system (Digital)
by Adrian666 10/03/2025 19:09:40(UTC)
Problemer med digital dekoder på CS3 (Digital)
by tgj 03/03/2025 19:03:18(UTC)
Analog to digital Marklin 2862 (H0-scale)
by rickjames84 28/02/2025 22:28:20(UTC)
Digital equiped turnouts controlled digital or analog (Digital)
by Stefanio 26/02/2025 21:29:15(UTC)
Ground wire on loc digital conversion upgrade (Digital)
by garben 14/02/2025 04:44:59(UTC)
CV values for digital pantographs (Digital)
by Dirtboy 12/02/2025 21:31:03(UTC)
Roco digital crane magnet instructions wanted (Digital)
by patnaik 22/01/2025 21:16:55(UTC)
Help with digital upgrade (Digital)
by artvegas 19/01/2025 06:05:44(UTC)
Digital wiring - (Digital)
by Twinrover1965 09/01/2025 13:50:02(UTC)
Building my a digital Layout - Finally (Digital)
by White Buffalo 05/01/2025 22:03:21(UTC)
Anybody converting analog to digital in the US? (Digital)
by fynrfin 04/01/2025 22:02:16(UTC)
SEH800 Digital Conversion 60760 (H0-scale)
by johnhendry 04/01/2025 17:24:23(UTC)
A digital "Kranwagen" (#46715) controlled by the computer (Model railroad software)
by PeFu 31/12/2024 00:44:20(UTC)
Digital blocking (Digital)
by Paul Hedge 29/12/2024 04:09:36(UTC)
Reversing a digital loco on an analog setup (General MRR)
by rdn0609 15/12/2024 20:00:05(UTC)
What is the Purple Wire in Marklin Digital Wiring? (Accessory decoder) (Digital)
by 5HorizonsRR 07/12/2024 02:50:00(UTC)
Digitalizzare Re 4/4 34341 marklin (Digital)
by maxgand 23/11/2024 20:14:55(UTC)
Frogs - Digital/Analouge (General MRR)
by HO Collector 25/10/2024 22:55:13(UTC)
Digital loco, analogue transformer? (H0-scale)
by ChrisKenna 14/10/2024 09:41:20(UTC)
Return Digital Conversion back to Analogue (Digital)
by AjayTele 10/10/2024 06:24:06(UTC)
Digitalizzare Marklin 3155 (Digital)
by maxgand 07/10/2024 21:47:38(UTC)
Marklin 7651 digital crane (General MRR)
by 3864jk 06/08/2024 19:01:34(UTC)
Retrofit legacy Marklin M series with a digital controller. (Digital)
by Blisterexe 27/07/2024 20:12:03(UTC)
Marklin 60116 Digital Controler -- Electrical Requirements (Digital)
by WetterauSüd 13/07/2024 00:26:10(UTC)
Question about delta decoder on digital system (H0-scale)
by alevas 08/07/2024 19:19:45(UTC)
Brake module programming with CS3, M83, and digital signal 76496 (Digital)
by marklinist5999 19/05/2024 17:12:03(UTC)
3054 digital conversion and magnet mount problem (Digital)
by lpesce 05/05/2024 00:30:07(UTC)
Convert analogue locomotive to digital (Digital)
by Alex222 27/04/2024 11:30:20(UTC)
Digital wiring (Digital)
by Mjn2ts 09/04/2024 00:45:26(UTC)
Converting digital to analog (!) (H0-scale)
by Jay Zvolanek 28/03/2024 05:15:04(UTC)
Roco 69618 AC digital (MFX decoder) br118 won't work on digital (H0-scale)
by Lev.Sever 18/03/2024 23:39:27(UTC)
70412 and 70421 digital light signal equipments (Digital)
by biswasg 14/03/2024 14:58:20(UTC)
Digital conversion of 4-6-2 steam loco from 1961 (Digital)
by Bcur 28/02/2024 17:56:38(UTC)
Custom smoke generator for digital use (Digital)
by einotuominen 17/02/2024 11:44:17(UTC)
This page was generated in 0.393 seconds.
