Offline PeFu
#1 Posted : 31 December 2024 00:44:20(UTC)
PeFu
I have a digital "Kranwagen", a crane (Märklin #46715), acquired around the turn of the millenium. It has almost never been used due to "messy" functionality; You select function F1 for "twisting", F2 for "jib" and F3 for "hook", and then control the direction for the respective function by using the speedometer of the built-in engine decoder. Pretty tough at least for me to remember which direction is up and down, clockwise and counterclockwise etc. The TrainController PC software has some excellent features using "variables" to access engine decoder functions and to create a more intuitive interface to the "Kranwagen". From that, it is also easy to automise actions which you can see in the clip. I also add a snapshot of how to use variables in operation, in the example the action is to "twist the crane clockwise".
Smile
thanks 5 users liked this useful post by PeFu
Offline Ross
#2 Posted : 31 December 2024 03:55:03(UTC)
Ross
Hi Pe,
Well done. I'm not using TCG10.0B2 so I had to use flagman and macros which also works well.
Have fun.
Ross
thanks 3 users liked this useful post by Ross
Offline PeFu
#3 Posted : 31 December 2024 10:22:39(UTC)
PeFu
Can you do that without first assigning the kranwagen to a block?
Offline Ross
#4 Posted : 31 December 2024 21:21:42(UTC)
Ross
Hi Pe,
I create dummy blocks that are not physical as all items require a block to run in schedules.
Ross
This page was generated in 0.346 seconds.
