Offline morsing
#1 Posted : 16 January 2020 10:48:10(UTC)
morsing
Spent a good 20 minutes after hooking up my first m83 only to realise the manic red LED flashing did not mean it was broken.
Is this flashing really necessary? I dare not think how it will alert me if it is actually broken...
Marklin C-track + CS3+
#2 Posted : 16 January 2020 11:39:27(UTC)
Good Point!
When a LED are flashing it means started sequence program in other way.
Why Märklin don´t do that is an mysterious...
Offline morsing
#3 Posted : 16 January 2020 11:40:45(UTC)
morsing
Good Point!
And when does it finish this sequence program?
Henrik
#4 Posted : 16 January 2020 11:44:10(UTC)
Sorry?
When you use for exemple Lenz switch decoder and push program button the LED start flashing by start program.
Märklin do other way by show flashing LED as power on.
Offline morsing
#5 Posted : 16 January 2020 11:45:36(UTC)
morsing
So that's my point... It's annoying and unecessary. And how it is going to indicate a problem when there's already a manically flashing LED there?
#6 Posted : 16 January 2020 11:50:10(UTC)
Yes...it should have steady light instead that remain power on.
#7 Posted : 19 January 2020 03:35:43(UTC)
... I dare not think how it will alert me if it is actually broken...
I struggle to think of many things in the modelling world the "alert you if they are broken"
In the majority of cases something just "doesn't work (as expected)".
As with most problem determination it come down to observation and isolation of what IS working in order to locate the broken link in the chain.
To this end the monitor indicators (as described on page 12 of the manual) on the m83 assist with that problem determination where they can.
Monitor Lights
• If the m83 is connected correctly, a monitor light will blink.
• The second monitor light blinks briefly one time when the decoder is addressed, i.e. when it is switched or programmed.
• If both monitor lights at the connections blink rapidly, then the red and the brown wires were mistakenly swapped.
• The monitor lights at the switching outputs display the current status of the circuit being switched.
I do agree that a minimum amount of effort from Marklin could identify more precisely
- which LED relates to " .. a monitor light .."
and
- "The second monitor light"
But emotive descriptions like "manic red LED flashing" are not very helpful as I have no idea what manic red LED flashing looks like.
If your symptom aligns with one of the states identified in the manual I would ask that that terminology be used.
About M84/M83 (Digital)
by ellim 03/10/2025 08:59:17(UTC)
Problem on M83 and buzzing sound from Electric Turnout Mechanism (Digital)
by geir 09/01/2025 23:00:03(UTC)
m83/m84 broken? (Digital)
by Goofy 15/11/2024 17:13:28(UTC)
Brake module programming with CS3, M83, and digital signal 76496 (Digital)
by marklinist5999 19/05/2024 17:12:03(UTC)
24997 uncoupler problem with M83 decoder (H0-scale)
by fabstar68 19/12/2023 16:42:14(UTC)
Configure M83 with Mobile Station 2 (Digital)
by abeeche 14/12/2023 19:46:36(UTC)
m83 decoder wire length to turnouts (Digital)
by swisslocofan 27/05/2023 04:16:19(UTC)
Rocrail Connection - M83 and Switches (H0-scale)
by Eddie7979 30/04/2023 09:11:08(UTC)
Digital, m83 (Digital)
by Don Morris 02/12/2022 04:36:48(UTC)
M83 decoders (Digital)
by Don Morris 09/03/2022 03:53:15(UTC)
Loading two M83 decoders into a CS3 connected together (Digital)
by marklinist5999 04/07/2021 17:20:17(UTC)
is controlling a 7039 hobby home signal with m83 possible? (Digital)
by marklinist5999 30/06/2021 15:00:20(UTC)
M83 (60832) (Model railroad wiring)
by Thewolf 12/03/2021 17:57:06(UTC)
M83 M84 and S88 wire sizes (Model railroad wiring)
by Demch 28/12/2020 21:42:23(UTC)
use of two M83 with an MS2 (problems resolved) (Digital)
by Garoux 12/12/2020 15:31:55(UTC)
Electrical wire connections to the Decoder m83 (Digital)
by fosuna 04/10/2020 11:57:41(UTC)
Viessmann 5221 connection m83 (Digital)
by kehdi737w 04/07/2020 11:44:04(UTC)
CS3 m83 Light Control (Digital)
by kehdi737w 02/07/2020 22:46:27(UTC)
m83 power supply + Viess. Signals (Digital)
by kehdi737w 27/06/2020 10:37:38(UTC)
7186 and m83 decoder (Digital)
by ocram63_uk 25/05/2020 12:21:11(UTC)
m83 - 2 turnouts with single address (Digital)
by bzzi 30/04/2020 01:23:00(UTC)
Blinking light with M83 from CS2 (Digital)
by ronsch 06/04/2020 20:58:55(UTC)
Configure M84 to Act as an M83 (Digital)
by rrf 15/12/2019 14:44:45(UTC)
Märklin m83 (Digital)
by Allrad 07/12/2019 09:25:03(UTC)
M83 wiring three way turnout (General MRR)
by springboard 31/10/2019 14:10:48(UTC)
Marklin Decoder m83, 60832, and external power supply (Digital)
by ocram63_uk 28/10/2019 09:15:30(UTC)
M83 and CS3 for uncoupler (Digital)
by klamort 19/10/2019 19:09:48(UTC)
How to program m83 value with the MS2? (Digital)
by Goofy 10/09/2019 11:26:09(UTC)
M83 + Switch Powerpack + 60822 (Digital)
by MarcelV 11/08/2019 06:04:29(UTC)
M83 (60832) parametrization with CS3 (Digital)
by FLhoir 25/02/2019 11:02:17(UTC)
K83 to M83 transition (Digital)
by sjbartels 21/02/2019 21:39:49(UTC)
M84 and M83 (Model railroad wiring)
by Thewolf 17/02/2019 20:14:07(UTC)
Problem with M83, M84 & Universal Power Supply (Digital)
by rrf 01/02/2019 22:53:38(UTC)
Problem with the m83 and Roco semaphore (Digital)
by Goofy 23/10/2018 12:33:53(UTC)
M83 problem (Digital)
by nevw 25/09/2018 07:40:56(UTC)
CS3,mfx m83,60821 and tortoise motor (Digital)
by Goofy 17/09/2018 18:28:27(UTC)
ESU SwitchPilot V2.0 51820 vs new VIESSMANN 5285 Multi-protocol switching decoder vs Märklin M83 (Digital)
by Peluo 08/09/2018 18:42:14(UTC)
CS3 Plus, Decoder m83 60832 and Control 60821 (Digital)
by Vipe 31/03/2018 20:57:19(UTC)
Using the 60831 M83 Decoder (Digital)
by Bones 17/03/2018 14:45:47(UTC)
Electrical Connections to The m83 (60831) decoder and Mini trix trains (Digital)
by BR221 10/03/2018 00:02:15(UTC)
60822 universal power supply / 66367 power pack for M83/M84 (H0-scale)
by ae66green 17/01/2018 17:08:46(UTC)
Whether to buy the new Marklin M83 (60832) for use with the CS3 (Digital)
by johnpatrickwack 08/11/2017 14:13:13(UTC)
Is the Z21 start controller compatible with m83 (60831) decoders (Digital)
by BR221 31/08/2017 06:26:52(UTC)
M83 power supply via booster (Digital)
by antazio 28/04/2017 20:51:41(UTC)
m83 questions (Digital)
by Donb 30/01/2017 20:36:32(UTC)
Now that the new m83/m84 are coming in 2017... whats the difference again? (H0-scale)
by Minok 14/01/2017 00:01:46(UTC)
M83 decoders and Cs2 (Digital)
by Fernando Perez 08/01/2017 02:05:57(UTC)
Märklin M83 - 60831 (Digital)
by Scones 03/12/2016 21:11:28(UTC)
FYI: 66361<66365> to be replaced with 66360<66367> (PowerSupply for MS2, L88, m83(opt), m84(opt) ..) (News from Märklin and others)
by clapcott 13/10/2016 20:59:52(UTC)
Connecting m83's (Digital)
by Drongo 08/07/2016 14:42:41(UTC)
This page was generated in 0.601 seconds.
