Offline jeffd
#1 Posted : 25 December 2018 15:40:48(UTC)
jeffd
Happy Holidays from the US! I have been restoring / repairing analog locomotives from a large collection the past year but have never opened a digital one. I came across the following locomotive in the collection and it is dead on my analog layout. I think it is probably a digital one but having never seen one I thought I would look for a confirmation. Did this old analog collector actually buy a digital loco when everything he had is analog? If it is digital, is there any way for me to test it on my analog equipment?
Thanks for your thoughts
JD
#2 Posted : 25 December 2018 15:51:53(UTC)
Is it Märklin?
Is it H0 gauge?
What is the first character of the serial number? E would be analogue, D or H or M would be digital.
Offline jeffd
#3 Posted : 25 December 2018 16:15:25(UTC)
jeffd
It is a Marklin HO. Where do you find the serial number?
JD
#4 Posted : 25 December 2018 16:21:46(UTC)
Usually somewhere at the bottom of the loco or the tender.
What's the ref. number on the box?
30xx and 35xx is analogue, 36xx is digital, 33xx and 34xx could be either.
Offline Markus Schild
#5 Posted : 25 December 2018 16:33:00(UTC)
Markus Schild
This is an analogue steamer 3511. The circuit is part of the "high-performance-drive". The two potentiometers are to adjust acceleration and maximum speed. To check what's wrong I would unsolder the motor and test the motor with a DC-source e.g. a 9V-battery. The motor is a FAULHABER - DC-motor.
Markus
Offline jeffd
#6 Posted : 25 December 2018 17:32:27(UTC)
jeffd
Thanks for confirming it is an analog and a 9 v batter did turn the motor. The high performance drive is not so much. All I get is a click when i try to reverse it and no motion on the track??????
#7 Posted : 26 December 2018 08:43:26(UTC)
You write you have analog layout.
If locomotive are 3511 and it doesn´t work you have default with the PCB.
To change locomotive and use analog on the three rail layout with the Märklins trafo it ain´t easy to fix it.
Today most use digital and there is digital decoder which also does work for the analog layout when the decoder are set for the analog too.
#8 Posted : 26 December 2018 09:08:53(UTC)
Markus Schild
The conversion to digital of that locomotive is at least difficult. The PCB which drives the motor also holds the slider. First I would remove the PCB and check first if there is something faulty visible on the underside. Maybe it can be repaired.
If there is nothing repairable I see two solutions: The PCB comes up more or less regularly on Ebay Germany from locomotives which were converted or dismantled for spares. Just wait and see to get a spare. The other solution is to replace the PCB with this one: http://luessi.ch/shop/ca..._info.php?products_id=54 With that PCB a decoder could be installed.
Markus
Offline dickinsonj
#9 Posted : 29 December 2018 01:33:44(UTC)
Markus
Excellent advice Markus.
I replaced the decoder board in my 3611 using a board from luessi and it worked perfectly, and the only solution that I have seen for the odd slider arrangement. The last time I checked Märklin had quit supplying those parts, so it is a good time to get that sorted out. That Würrtemberg Class C is one Beautiful Lady alright. BigGrin
Fabrice gets the credit for showing me where to get that part btw, which I might never have found on my own! Cool
#10 Posted : 29 December 2018 02:49:18(UTC)
Watch this space, I'm in the progress of converting mine to digital with an ESU sound decoder, I've already made up a circuit board by replacing the original one, the slider holder I've de-soldered it from the original board and soldered it onto the board. I''be using an 8 pin ESU sound decoder but will remove the 8 pin plug, shorten the wires and solder them onto the new board. I also be looking at the steam generator and side rods gear lights.
unfortunately when I drilled the hole I've hand drilled it afterwards to make it slightly larger and broke the corner off but it doesn't affect the tightness when screwing it down., as you can see the round 23mm loudspeaker fits nicely, just into its place and also the ESU sound decoder has plenty of room., the wires I'll be using will be insulated copper wire (12) they are easier to bend and stay in position, they will be fed through the underside of the circuit board and soldered on top.
thanks 5 users liked this useful post by river6109
Offline Ross
#11 Posted : 29 December 2018 23:21:19(UTC)
Ross
Hi Jeff,
You maybe interested in my article how I converted Lady C locos to have cabin light and telex couplerss with ESU LokPilot decoders.
Lady C Article
I hope it provides ideas along with other peoples suggestions.
Have fun.
JD
Edited by user 02 January 2025 00:01:48(UTC)  | Reason: Not specified
Ross
thanks 4 users liked this useful post by Ross
#12 Posted : 31 December 2018 11:15:20(UTC)
Hi Jeff,
Lady C Article
Have fun.
JD
Ross you can see my continuous conversion under "on my workbench"
Offline Ross
#13 Posted : 31 December 2018 22:00:45(UTC)
Ross
Hi John,
Thanks for directing me to "on my workbench". All the best with your conversion. I'll look forward to seeing how you transfer all the wire connections back to the decoder in the tender.
Ross
Time to go digital? (Digital)
by MtrackJai 23/06/2023 18:00:31(UTC)
29146 conversion - Delta to digital? (H0-scale)
by The Crocodile 26/12/2021 13:29:12(UTC)
Marklin 86582 - Is this digital? (H0-scale)
by Karl 19/10/2019 14:46:35(UTC)
[Question] How to convert Märklin 3021 to digital? (Digital)
by Dino 03/08/2019 17:57:23(UTC)
Block control - stay with relays or use digital? (Digital)
by fynrfin 19/03/2019 18:53:37(UTC)
Converting an old analog loco with Telex to digital? (Digital)
by Jabez 05/11/2016 22:21:46(UTC)
Silence information about digital? (Digital)
by Goofy 27/03/2016 17:51:36(UTC)
Märklin 5713 DB BR 55 3964 analog or digital? (Big scale)
by Janne75 30/11/2014 10:42:23(UTC)
Roco on Marklin Digital? (H0-scale)
by morsing 17/08/2014 10:54:05(UTC)
MTH 3E+ HO locomotives running on Marklin Digital? (Digital)
by StuartA 25/05/2013 20:06:43(UTC)
RAPTOR DIGITAL? (Digital)
by 1spur 20/01/2013 17:31:25(UTC)
Going digital? (Digital)
by BrandonVA 02/02/2012 16:36:09(UTC)
ID locomotive/convert to digital? (Collector's Corner general)
by dpetersen 08/01/2012 05:47:47(UTC)
Quality of household electricity - does it matter for digital? (Digital)
by kimballthurlow 31/10/2011 22:11:17(UTC)
Lux cleaning car conversion to digital? (Digital)
by eduard71 07/05/2011 15:22:28(UTC)
Analog locos, old, to digital?? (Digital)
by Joseph Meiring 09/04/2011 17:32:16(UTC)
Going Digital? (General MRR)
by Joseph Meiring 01/02/2011 21:57:00(UTC)
by Joseph Meiring 22/08/2010 23:24:02(UTC)
Marklin 3371 ICE or digital? (H0-scale)
by rhobson1968 10/07/2009 02:13:21(UTC)
Converting 3015 to digital? (Digital)
by TroyYang 22/05/2009 04:33:00(UTC)
Help- MAXI Engine- Digital? Delta? or DC Only? (Digital)
by steameng8 02/02/2009 23:56:21(UTC)
Convertering 2868 to digital? (Digital)
by amalongi 05/01/2009 21:45:53(UTC)
make a 3005 digital? (H0-scale)
by obxbill 02/01/2009 04:29:41(UTC)
New user dilemma: classic or digital? (H0-scale)
by hansbos 04/08/2008 01:46:52(UTC)
How to convert a Ma 3658 to newer digital? (Digital)
by meina222 27/02/2007 02:55:25(UTC)
how to dive into digital? (Digital)
by tekin65 16/10/2006 01:36:59(UTC)
can analogue be used with digital? (Digital)
by zand 1985 13/12/2005 16:50:33(UTC)
Problems converting a 3434 to digital? (Digital)
by Mikael 03/11/2005 14:05:35(UTC)
#3149 engine...convert to digital? (H0-scale)
by littledragon 28/07/2005 20:11:32(UTC)
How big a transformer for digital? (Digital)
by elsleuth 05/01/2005 20:33:23(UTC)
At what point did you decide to go digital? (Digital)
by jocoyn 30/01/2004 15:11:34(UTC)
What are the stages/strategies for Digital? (Digital)
by streetmagick 28/02/2003 21:45:42(UTC)
This page was generated in 0.566 seconds.
