Offline rhobson1968
#1 Posted : 10 July 2009 02:13:21(UTC)
rhobson1968
You have been a member since:: 21/02/2009(UTC)
I have what appears to be a Marklin ICE 3371. I opened it and there is a digital 8 address code. I think it is a 3671. When I put it on my digital layout it doesn't act like a digital and acts like an analog and goes automatically at one speed. Another issue is it won't reverse and only goes one direction on analog. Any ideas?
Never quit building.
#2 Posted : 10 July 2009 11:53:38(UTC)
Maybe it doesn't have automatic system detection, so you have to set the address code either to analog (all switches off) or to a valid digital address.
The original 3371 was analog only (no Delta decoder).
No explosion diagram for 3671.
36xx locos should have automatic system detection, but have you tried all switches off?
Is a valid digital address set?
#3 Posted : 10 July 2009 12:54:49(UTC)
Ralph, when you say it does not reverse in analogue, do you mean that there is no reponse at all to the reversing pulse, or that the train does not move in the other direction? Do the lights change over when you activate the reverse?
Offline mmervine
#4 Posted : 10 July 2009 15:01:03(UTC)
mmervine
Do you have both locos connected? This set would have pick up shoe switching, so both locos need to be connected for proper operation.
Offline Dave Banks
#5 Posted : 10 July 2009 15:30:33(UTC)
Dave Banks
Ralph, try setting the address to an address other than 01 or 80 & see what happens & make sure the the two end cars are hooked up together.
D.A.Banks
Offline rhobson1968
#6 Posted : 10 July 2009 17:18:49(UTC)
rhobson1968
I tried about 12 different addresses and both locos are connected. The back loco operates but I think the issue is the digital address process isn't working. I have set it with all switches off. When I run it on analog and do the reverse action it just goes faster forward.
Offline mmervine
#7 Posted : 10 July 2009 17:50:13(UTC)
mmervine
If you can't figure this out, you could try doing a conversion like this:
http://www.ete-ene.org/3...%20Convert%20Article.htm
#8 Posted : 10 July 2009 18:53:28(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by rhobson1968
<br />I have what appears to be a Marklin ICE 3371. I opened it and there is a digital 8 address code. I think it is a 3671. When I put it on my digital layout it doesn't act like a digital and acts like an analog and goes automatically at one speed. Another issue is it won't reverse and only goes one direction on analog. Any ideas?
You are not matching the code number of your loco with your digital address,
you said it has a digital 8 address code.
If you look at any Loco booklet you'll find the 80 code addresses.
My guess it is 71 but I'm not certain.
regards.,
Offline rhobson1968
#9 Posted : 10 July 2009 19:47:37(UTC)
rhobson1968
I will try that... Thanks.
Offline HGH
#10 Posted : 22 July 2009 17:38:44(UTC)
HGH
[size=1" face="Verdana" id="quote]quote:Originally posted by mmervine
<br />If you can't figure this out, you could try doing a conversion like this:
Hello together,
with this pcbs you can convert you 3x71 to work with modern decoders, but there are some things you must know.
- The head-lights could not be dimmed, becouse they are controled via a relay.
- there is no pickup-shoe switching, like the original decoders do have.
I have made a conversion set, that has all the missing features.
Take a look to this here:
http://hgh-esn.ath.cx/p0...v_lpx-2_LDP.htm?LDP-3x71
I have build a lot of pieces over the last years and all buyers were very pleased.
If you are interested, please contgact me via email.
with kind regards ... HGH
modell-railroading is fun
#11 Posted : 22 July 2009 18:52:19(UTC)
Hans,
this is very interesting.
apparently there is someone else ( http://www.digital-bahn.de ) producing platinen for the ICE (3371, 3671)to be coupled e.g. with an 8 pole ESU decoder (sound)
so what does your electronic board do for the Ice.
a.) seperate board for switching power from pick up shoe
b.) Interior light ?
c.) dimming of lights: head and interior lights ?
d.)seperate functions for lights ?
regards.,
Offline HGH
#12 Posted : 22 July 2009 23:24:44(UTC)
HGH
[size=1" face="Verdana" id="quote]quote:Originally posted by river6109
<br />.....so what does your electronic board do for the Ice.
d.)seperate functions for lights ?.....
Hi John,
as I sad:
&gt; I have made a conversion set, that has all the missing features.
Once again:
My version has ....
1. a pickup-shoe switch (extention kit)
2. dimming of head lights via the decoder
3. switching of Interior lights by separate decoder-function (F1)
4. 8-pol connector
<u>.... future version(s):</u>
- 21-pol. mtc-connector
- cabin lights switching via extra-function
- Interior-Lights with LEDs to reduce power
- dimming of Interior lights
This page was generated in 0.629 seconds.
