2 Pages12>
CS3
Online David Dewar
#1 Posted : 05 October 2016 15:51:35(UTC)
Will next year upgrade my CS to the new one. From what I can see the CS3 PLUS has the S88 built in and that is about all. AS I have a S88 decoder I don't see the point in buying the more expensive version. Am I right in thinking this. Any reply welcome.
#2 Posted : 05 October 2016 16:01:01(UTC)
is this you David ? what a surprise, long time no heard., welcome back
#3 Posted : 05 October 2016 16:05:45(UTC)
Hi, David,
Welcome back.
It's become more complicated.
The Plus version has the Link S88 built in so you can connect S88 directly to the CS3 plus.
The Plus version does not have an S88 decoder built in, it just has the connector for the S88 decoders built in.
You can buy the Link S88 separately for the CS3 and it will still be cheaper than the CS3 plus.
You need the Link S88 to connect your S88 to the CS3.
Online David Dewar
#4 Posted : 05 October 2016 16:55:40(UTC)
Thank you. It is indeed me. Long time since been on and good to see some of my pals are still on the go.
Looks like I will get the CS3 and I presume a cable which will be different to the one I have which connects my old CS2 to the S88. Not much point in paying more for very little extra although I will need to price the link for my S88.
BTW does Nev still post. Hope he is OK.
#5 Posted : 05 October 2016 16:57:41(UTC)
Hi David,
Good to hear from you again!
Offline sjlauritsen
#6 Posted : 05 October 2016 16:59:21(UTC)
sjlauritsen
Cheaper, yes, but not by much. To put things in perspective (using retail prices):
CS3 Plus: 799,99 €
CS3 + S88 LINK + Power supply for the S88 LINK (66361): 649,99 + 84,99 + 49,99 = 784,97 €
Price difference approx. 15 €
If S88 is required, I would go for the CS3 Plus at any time.
Søren from Denmark
#7 Posted : 05 October 2016 17:54:39(UTC)
I sometimes see his posts on Facebook.
He has moved to N gauge some time ago.
#8 Posted : 05 October 2016 18:08:15(UTC)
Welcome back Dave.
Offline mjrallare
#9 Posted : 05 October 2016 19:40:02(UTC)
mjrallare
Nice to hear from you David! ThumpUp
Yes, where is the Pink Panter? And John Black is another one that springs to my mind.
/Torbjörn
Online David Dewar
#10 Posted : 05 October 2016 20:29:58(UTC)
Thanks guys. Have not heard from John Black for about two years. Sent emails but no reply but hope he is OK.
Once the CS3 units have been on sale it will give me a better idea of what to go for. I have just used my CS2 and an S88 hooked up with a cable and an older Marklin transformer ..60052. Looks like I am going to have to buy a lot of new stuff if what I have wont work with the newer CS.
Nice to see some old faces still on the site.
#11 Posted : 05 October 2016 20:35:17(UTC)
The CS3 manual says that the CS3 can not be used with transformers. You will need a power supply (DC) for the CS3.
#12 Posted : 05 October 2016 21:25:38(UTC)
Hi Dave, welcome back. Long time no hear!
Nevie pops up on the forum every now and then, the last time was about 3 weeks ago - https://www.marklin-user...ntral-now-INVERPINE-in-N
Plus, he sends me lots of Joke emails!
Apart from the S88 Link being built into the CS3+, the CS3+ also allows you to have extra CS3's as remote controllers. Since you have a CS2, both the CS3+ and CS3 allow you to use the CS2 as a remote controller (if the manual is to be believed).
#13 Posted : 05 October 2016 21:34:15(UTC)
... From what I can see the CS3 PLUS has the S88 built in and that is about all. AS I have a S88 decoder I don't see the point in buying the more expensive version. Am I right in thinking this. Any reply welcome.
No it does not have a S88 built in, It has the (new RJ45) S88 port to which you can attach NEW S88s (60881 / 60882)
If you have some legacy S88 (6088 / 60880) , then you need a 60883 (S88 Link = L88) to connect to ANY CS3 (60216/60226) REGARDLESS
Are you planning to keep your CS2(s) (as extra throttles) ?
If so, you can retain your existing S88 connections through it - via the system bus adapter cable 60123 to the CS3/CS3+.
New S88s MAY be connected behind old S88s on a chain - with adapter 60884 (just not the other way around)
Note: There is a separate power statement about NOT allowing the track output of a CS3 (60226) to connect to an older CS2 ( approx 60213 but is actually a Hardware level issue that some 60214s have). The CS3+ (60216) may connect in an environment with ONE (CS3=60226 or older CS2)
Edited by user 06 October 2016 06:44:10(UTC)  | Reason: Cable part number correction
#14 Posted : 05 October 2016 22:07:11(UTC)
Hello David - it's great to see you back with us..
Nev recently had another metal bit installed - half a hip this time, so he will still be recovering with the aid of the holy water. RollEyes I am about due for another call from Nev, so I will make sure that he knows you are back online.
#15 Posted : 05 October 2016 22:33:04(UTC)
Good to see you again, David ThumpUp
#16 Posted : 05 October 2016 23:25:02(UTC)
The company Tams offers adaptors between old-style plugs and new-style plugs - and I do hope an adaptor for €5.95 is all that is needed to connect an old S88 to a new CS3 plus.
But I'm not sure if voltage levels can be a problem.
Online David Dewar
#17 Posted : 05 October 2016 23:41:57(UTC)
Thanks again for the welcome. Peter I see is still able to come up with the technical stuff much of which a mere mortal like me has no clue.
However it is clear that I will need to start again with power through to control and whatever is now needed to replace my old S88. Better to go this way than mix old with new I think. I will use my current CS2 on the work bench as with four shuttles and the two controls on the Cs I don't need to hook up any other CS or MS.to the layout.
I am doing quite a bit of work changing the layout and having ordered a new loco and coaches for Christmas thought in the new year I would go for the new CS3.
Will wait until some of you guys get a CS3 when hopefully I can learn more.
Bottles of the holy water have now been despatched to all.
#18 Posted : 06 October 2016 00:18:00(UTC)
As others have indicated, the CS3+ has the Link S88 built in, so its just one less part you need to buy depending on what you already have for S88 usage.
Another difference is in what can be connected together in terms of other Central Stations. If you want to be able to connect several CS3s and the like to your CS3 you would want to get the CS3+ for that reason; if its just you then that additional flexibility isn't necessary.
#19 Posted : 06 October 2016 07:06:00(UTC)
.....But I'm not sure if voltage levels can be a problem.
Agreed,
If the CS3 port is set for 12V then the related statement from the L88 manual applies
12 volts only in conjunction with the S88 AC/DC (S88 AC = 60881, S88 DC=60882)
In the CS3/+ manual Marklin simply state ...
Zudem verfügt sie über einen eigenen S88-Anschluss und damit über eine direkte Anschlussmöglichkeit für die Rückmeldemodule 60881 und 60882.
which covers them for someone playing with an unsupported product.
The 6088/60880 are implied as unsupported because Marklin to not offer an adapter cable that is the opposite of the 60884.
#20 Posted : 06 October 2016 07:59:08(UTC)
It depends what kind of digital traffic you want on the model railway.
I myself don´t need S88 to use it.
So if i´m interested to get one CS3,it will be without contact to the S88.
Edited by user 07 October 2016 10:22:43(UTC)  | Reason: Not specified
#21 Posted : 06 October 2016 08:16:01(UTC)
[...] which covers them for someone playing with an unsupported product.
Märklin are famous for backwards compatibility.
With CS3, support for transformers ends and you cannot connect 6015/6017 or old S88 directly.
According to the information available now the CS3 Plus comes with a crippled Link S88 built in and an external Link S88 is still needed for backwards compatibility.
Maybe other options will be supported/documented once the CS3 is widely available.
S88 from third parties may support 12 V and may work with the CS3 Plus ...
Information about differences between 60216 and 60226 is clear as mud and deciding which version to get is not a simple task with the available information - especially for those who already have a CS2 without galvanic insulation.
#22 Posted : 06 October 2016 22:48:36(UTC)
CS3 Plus: 799,99 €
I think the logic is flawed.
The CS3 (60226) option, as outlined above, is immediately functional ...
- with 16 sensor inputs
- PLUS the ability to operate in direct or matrix mode as an added benefit.
- PLUS expandability to 93 S88s (31 per bus port , in addition to the inpering 16 ports of the L88 making 94 s88s) rather than of 31 on a single bus
- PLUS Three(3) bus ports instead of one(1) - so you can go both left and right around your layout
- PLUS interoperability of 6088/60880
The CS3+ (60216) solution STILL REQUIRES a 60881/60882 to be functional - and does not offer a matrix mode of configuration or the same amount of expandability/interoperability.
My assessment is that if a S88 is required , go for the CS3 (60226) option
#23 Posted : 10 October 2016 12:43:19(UTC)
I am sorry that I cant help you with the original topic, but just HAD to shout out a welcome back!
#24 Posted : 10 October 2016 20:25:25(UTC)
Heh? Are you sure thats right?
As I read the product descriptions: To run S88 based feedback you need 2 components the link back to the central station and then the AC or DC sensor input module. Depending on the size of the layout you expect to want to control, you might pick one over the other. With the CS3 you have to purchase both of those, with the CS3+ you get the part of the S88L link already built into the CS3+, so thats one less part to might need to purchase. The L88 of course comes with 16 S88 inputs on it (bus 0?), and has the interface for the older style S88 bus.
So if you have older style layout needing the L88 (to get the bus 3), and/or only need 16 S88 inputs on the layout, then you can get away with just the single L88 + CS3 and your good to go. If you anticipate needing more than 16 S88 inputs and don't need the old style S88 bus that the L88 provides, then you can just purchase the S88AC (or S88DC), and plug them directly into the CS3+.
In both cases you need to buy additional components to get S88 functionality, but you have the option of picking the right combo for what your existing layout or future layout needs really requires. No need to buy what you don't need.
For me, not having any parts at present, and knowing I'll likely exceed 16 S88 sensors, going with the CS3+ seems like a no brainer.
If you have deployed S88 gear that requires the old style S88 bus, the the L88 is needed, and if that or you already have an L88, there's no point in getting the CS3+, you've got the S88 galvanic isolation in your L88 already, go for the cheaper CS3.
So its not about S88 or not, but what sort of S88 needs you already may have, and what you expect to need.
#25 Posted : 10 October 2016 21:15:48(UTC)
In the context of the post about price comparisons for a minimum S88 configuration I stand by my comment.
To be FUNCTIONAL you need a minimum of
With CS3(60226) ....
OR
With CS3+(60216) ....
CS3+ (60216) AND 60831/2
Therefore
CS3 Plus: 799,99 €
should actually read
CS3 Plus: 799,99 € + S88 (60831) 49,99 € = 849,98
So the original comparison conclusion of ONLY a 15 € benefit saving now becomes a 65 € benefit
I went on to offer a set of other business case benefits leveraging this initial investment decision.
I did not offer any "pluses" for the 60216 solution as it relates to S88 topic because I could not think of any.
While this is addressed at a new "has nothing" scenario, I will point out that there will more than likely be an equal or higher number of prospective buyers that already have a MS2. If I were to include this in the economics, I can reuse the 66361 and save another 49,99 € (NOTE: I use the figure quoted above. This item is not produced any more )
Some may need to weigh this economic (price) benefit against other needs/functions, however with the savings you are well on the way to buying a booster (60174/5)
NOTING that a CS3(60236) may support both a L88 (60883) and Booster (60174/5) without the need for an additional Terminal (60125 )
Edited by user 11 October 2016 04:33:06(UTC)  | Reason: Not specified
Offline sjlauritsen
#26 Posted : 11 October 2016 06:29:00(UTC)
sjlauritsen
Therefore
CS3 Plus: 799,99 €
You are absolutely right. It should had read that.
The price difference still is not huge though. IMO: If you are to use S88, and to connect with existing equipment, a friend or whatever. You are still better of spending the additional money and go for the CS3 Plus.
Søren from Denmark
#27 Posted : 11 October 2016 21:07:22(UTC)
Fair enough, as long as prospective users appreciate that it is not a binary yes/no decision.
A CS3 (60226) can ...
- use S88s
- connect to existing equipment
- connect to a friends (controller)
- connect to whatever (PC, ...)
Financially (budget) there is also a benefit in not having to fork out a big lump sum when the equivalent solution may be achieved in steps.
Offline TEEWolf
#28 Posted : 12 October 2016 03:57:59(UTC)
The Problem is not the missing S88. The point is the CS 3 has no galvanic isolation and because of that Maerklin omitted the S88 port as well as a CAN bus input port. So you obligatory have to buy a L88, before you may use your S88. I wrote something about this topic here:
post #44 galvanic isolation.
The CS 3+ has this galvanic isolation inside, plus the direct S88 connection, plus the direct input for the Maerklin CAN bus. Now you know why its name is "CS 3 plus".BigGrin
Actually for about 15 € more you get a CS 3+, which allows you a chain connection with other CS - how many you have. The CS 3 is a dead end chain device in the CAN bus, because of the missing input port, which are a result of the not existing galvanic isolation. Instead of the CAN input port the CS 3 has a second Maerklin connecting port. This is helpful for a L88 and then for your S88.BigGrin Blink.
Offline sjlauritsen
#29 Posted : 12 October 2016 06:39:40(UTC)
sjlauritsen
- use S88s
It can, but still we have the limitations with regards to hardware compatibility. I believe that for users unsure where to take their layout, for users with the 60213 and some with 60214, for users unsure on what HW versions their friends might have, for a club investing in Märklin Digital for the club layout and relying on members bringing their CS's: A CS3 Plus will give them the least of problems in these scenarios.
Absolutely. I know a lot of people where the CS3 (60226) would make perfect sense.
Søren from Denmark
thanks 2 users liked this useful post by sjlauritsen
#30 Posted : 12 October 2016 06:43:21(UTC)
There is no correlation that can be drawn between these two aspects (other than the marketing of the CS3).
e.g. The CS2 (60213) has a CAN bus In port AND has no galvanic isolation.
Offline TEEWolf
#31 Posted : 12 October 2016 19:47:12(UTC)
Hi clapcott,
what is your real problem?
I accept that some people still want to use their devices from Maerklin Delta, Maerklin System and the earlier Maerklin Digital. But you cannot mix them up as you want, because of the sometimes existing and sometimes not existing galvanic isolation. And this is to be continued by Maerklin.
I do not have a 60212, 60213, 60214, 60215 and even not yet a 60216. For my interest is the differences between the 60216 and 60226. This I cleared up as written before. If you want to get help for your specific problem, please let me know. Perhaps I can help you too.
So I found a Maerklin publication “Technical Tip # 315” for the Central Station 60213 - 60215 Part 1. I expect then also a part 2. But this I never found, as well as these technical tips I never found in English. But in the tip # 315 I see that there are various ports at a 60215 for a CS 60212, 60213 but never for a 60214. On the other hand in the manual for the 60215 Maerklin mentioned for the delivery contents a “Zusatzblatt (Hinweis) Central Station 60213”. This means an “extra sheet (reference) Central Station 60213”. I have no idea about this paper, but it is definitely a hint that a 60213 has to be treated separately.
So I keep with my statement, that the missing galvanic isolation requires a different combination and attachment within the various CS types. How it has to be done? For this I do have to do more inquiries, but please tell me first, what your concern is.
#32 Posted : 12 October 2016 20:30:52(UTC)
CS3 delay again until end of October or Early November.
#33 Posted : 12 October 2016 21:46:43(UTC)
If I buy the CS3, How can I transfer data (Locos, turnout/signal/layout) to CS3 from CS2?
I read the manual with english translate said use the USB Stick?
#34 Posted : 12 October 2016 22:32:32(UTC)
Don't get me started! OhMyGod.......(Just kidding, Peter is actually a great guy)
I think Peter is well aware of the issues with galvanic isolation (or lack thereof), he was just pointing out that there is no correlation between whether a device does or doesn't have galvanic isolation and does or doesn't have a CAN input.
Peter is actually our Digital expert within our Marklin Club - he knows more about Digital systems than anyone I know, and also understands the electrical / electronic principles when using them. He's also a whizz with computers and programming them.
I would respectfully suggest that it would be more Peter helping Wolf rather than the other way around.
Plus, the problems Wolf raises about galvanic isolation really only apply if you're trying to use a CS2/CS3 without galvanic isolation as a track booster. If you're only using them as a remote console only (which is what I'm intending to do - I have enough 60124 boosters already), then there won't be a problem.
Offline TEEWolf
#35 Posted : 12 October 2016 22:34:31(UTC)
Which manual in English? On the Maerklin internet page in English they offer you a manual, but it is the same in German one as on the German page.Sad
But in this manual, Maerklin explains on page 6 under the heading “Import of CS 2 data”.
First, make a backup from your complete data from the CS 2 on an USB stick, as it stands in the manual for the CS 2.
Second, stick the stick into one of the USB ports of the CS 3 and follow the menus behind the button “System”. Then all your data from locos, magnet articles and track data will be transferred to the CS 3.
#36 Posted : 12 October 2016 23:01:08(UTC)
Can not find 'System' on CS2, I am using the 60213.
#37 Posted : 13 October 2016 00:06:05(UTC)
I think Wolf said 'System' relates to the CS3 menu's.
For the CS2, perform a system backup (as per CS2 manual instructions) to a USB stick.
Online David Dewar
#38 Posted : 13 October 2016 11:32:10(UTC)
Did not think my initial post would have gone this far. As David says Peter is an expert on all Marklin digital to the extent that most of the time he is way beyond me lol.
However I have almost decided to use my CS2 to run my shuttle lines with my S88 and get a CS3 for the rest of the layout. The shuttle lines can have a different power supply to the rest of the layout. Does mean I wont have an S88 for the main lines but it could be added later if necessary but at present or in the near future is not required. This would not suit most I expect but for me should be OK and will save cash when changing to the new controller.
Will wait however until the CS3 has been bought and tested by our experts on the forum.
Maybe we should have a competition as to who will be first to make the change.
Many thanks for all the comments.
#39 Posted : 13 October 2016 14:33:59(UTC)
Nothing on Manual Can you link manual in PDF? What page number?
Offline TEEWolf
#40 Posted : 13 October 2016 16:48:22(UTC)
Hi Steven,
as BDNZ wrote already, I refer to the page 6 of the CS 3 manual link here:
60216 Manual only in German
Meanwhile you can switch the page to an English version
60216 Internetpage in English
But the manual behind the button "manuals" is still in German.Sad & Angry
On the screen of the CS 3 shall be a button "system", not on the screen of a CS 2. For the CS 2 it is only recommended to follow the manual of the CS 2.
Wolfgang
Offline TEEWolf
#41 Posted : 13 October 2016 18:17:23(UTC)
BDNZ are you teasing me? Confused
Or did you find Maerklins "Technischer Tip 315" in English? Please let me know where. Here you find mine:
Maerklin Technischer Tipp Nr. 315
I guess I found clapcotts own problem. In April 2016 he wrote in a post that he owes a CS 60213!
“Today I learnt that my CS2 (60213 = v3 HW) is not compatible with the new CS3 (60226)”
https://www.marklin-user...5695-CS3-incompatability
Yes that is it and I see it in the same way! And if he had never returned his CS 60213 and rebuilt by Maerklin, than I would recommend him to buy a 60216 instead of the 60226, if he wants to buy a CS 3. Because Maerklin (or was it in another thread? - sorry I do not remember) wrote somewhere, that one CS without a galvanic isolation will always be functioning in a environment of a full galvanic isolation for a digital MRR.
By my opinion, this is a major reason, why till up today Maerklin is changing the old booster 60713 for free, but not one CS. And a booster is cheaper as a CS.
But to the ports and their variety at a CS 2 – this is another story. Because yes you always have an in- and output for the CAN bus, but Maerklin always writes also about restrictions and limitations, which I do not know.
And the CS has none of the “Maerklin device port” as the new CS 3 60226 will have 2 of them!
But in the technical tip # 315 Märklin shows a port “60173” at a CS 2 or is it a CS? And what do they write:
“Das Vorgängermodell 60173 nicht benutzen. Dieses wurde durch 60174 ersetzt!“
“Do not use the previous model 60173. This was displaced by 60174!”
Don't you think the word “goobledygook” Love would be a good one for this? Couldn't be this a similar situation for the CS prior to the CS 2 60215 as well?
Sorry, as I wrote already, that I do not have any CS at the moment myself and so I have to do theoretically further researches for “old new problems”. I only wanted to know, which one of the CS 3 fits for me perfectly.
But no problem for me, gathering together information about these “old new problems” in the various German communities - and do not forget the Swiss ones as well, if you want it. Please let me know.
But also Clapcott can and hopefully will help me - no doubt about it. Teaching me about electronics and English – no problem. And already I have a question: does the so called terminal 60125 (isn't it in English not a hub instead of a terminal?) also have a galvanic isolation inside?
Wolfgang
#42 Posted : 14 October 2016 21:18:21(UTC)
Oh Well, the first CS3plus on ebay.de.
#43 Posted : 14 October 2016 21:44:04(UTC)
yeah, thats one of my issues with Märklin - their naming conventions. A terminal would be an 'end item' or a 'data entry/display device'. From the functional descriptions I've seen, the device is like a 'bridge' - in that it is a way to connect to the data network (bus), from a different signaling system.
#44 Posted : 15 October 2016 08:13:01(UTC)
The "terminal" has a terminating resistor. The resistor will be active only on the last terminal in the chain, the terminals in between are just hubs.
Maybe Märklin cannot imagine that anybody will buy more than one of those overpriced thingies.
#45 Posted : 15 October 2016 10:55:38(UTC)
http://www.ebay.de/itm/M...0fac6:g:caEAAOSwYIxYAJxH
Offline TEEWolf
#46 Posted : 15 October 2016 17:06:58(UTC)
Thank you and you are a real Bigdaddy from the other side of the world!Smile Wink
How did you find this link? There I guess you are not so familiar with German circumstances, here the link to the German MRR shop in Recklinghausen. Heavyly coverd with coal from the Ruhrpott mines, but you found it! Great and well done. BigGrin
http://www.modellbahn-ce...lus--neuheit-2016--.html
Recklinghausen is a city in the state Nordrhein-Westfalen (NRW). NRW is not the "North-Railroad-Western" Laugh where also our member H0 is living. It is a federal state in Germany as, say like Queensland in Australia - sorry do not know if NZ is a State with federal counties too, but I realized you love Australia.BigGrin Blushing
Recklinghausen is not far away from Dortmund, with the very well known "Ruhrpott" beer city coaches. Drool BigGrin Yeah, here we are! I guess next time, I come to this aerea, I step into their huge model railroad world.
http://www.modellbahn-ce...hop_content.php?coID=202 Love
Did not know yet, that there is a competition rally with a Maerklin product - like the annual rally about a "Beaujolais Primeur". Laugh
https://en.wikipedia.org/wiki/Beaujolais_nouveau
But where the hell, from whom did they get a CS 3+ first? Hundreds of kilometers away from Goeppingen? Huh
Probabely they found a lost container, filled up with CS 3 and CS 3+ on their way to New Zealand via Bremen? Laugh BDNZ - did you place such a big order for Mr. Maerklins order book?Laugh
Offline DasBert33
#47 Posted : 16 October 2016 08:34:06(UTC)
DasBert33
Had a chance to play with CS3 yesterday. Marklin had brought a demobox to a local mrr fair. At the same fair there was one dealer (huenerbein) that had 2 for sale for the price of 720 euros, but they weren't sold on the first day. I didnt ask more to check whether that price included the supply or not.(I think it did!)
The device looked nice but I was not entirely convinced yet. Coming from a Ecos1 the speed knobs are really something to get used to.
The layout display looks nice with the rounded corners, but editing with the touchscreen was not easy. Probably a mouse would have been better, but that was not available on the CS3 I used.
Bert
thanks 3 users liked this useful post by DasBert33
#48 Posted : 16 October 2016 10:46:59(UTC)
I searched ebay.de for Märklin 60216 - that is one of the links that appeared, but the only one with a CS3 (or CS3+).
....sorry do not know if NZ is a State with federal counties too.....
No, we have no states in NZ - population is only 4.5 million. We have provinces (I live in the Wellington province). NZ is made up of 3 main islands - the North Island, the South Island and Stewart Island. There's another large island to our west that funnily enough we call the West Island, but others might call it Australia (or some such funny name).
There is provision in the Constitution of Australia for NZ to join the Australian Commonwealth as another state of Australia, but we rather like the idea of Aussie being one of the islands of NZ.
Some on this forum like to refer to NZ as the East Island of Australia, but that just shows off their ignorance. There are three islands to NZ, not sure how they work it out that they are all the East Island. But then, inhabitants of Australia were never known for being of high intellect, given that they're descendants of Convicts from Mother England (i.e. POME - Prisoners of Mother England)
No, not as yet. I'll wait till next year maybe before getting a CS3+.
Edited by user 17 October 2016 05:52:34(UTC)  | Reason: Not specified
#49 Posted : 16 October 2016 13:43:55(UTC)
Some on this forum like to refer to NZ as the East Island of Australia, but that just shows off their ignorance. There are three islands to NZ, not sure how they work it out that they are all the East Island. But then, inhabitants of Australia were never known for being of high intellect, given that they're descendants of Convicts from Mother England.
When my wife and I were moving from NZ to the UK in 1997, we traveled on the Trans-Manchurian train. As part of this we did a side trip into Mongolia, where we had an opportunity to do a trip to the site of an ancient monastery. One of the guides there picked up that we were from NZ, and the conversation went like this: -
guide: NZ? is that like Australia?
wife (quick as a flash): No that is like saying Mongolia is part of China.
guide: Ahh, I understand!!!
Offline TEEWolf
#50 Posted : 18 October 2016 03:30:32(UTC)
Thanks for the explanation and it is unbelievable.Mad
Perhaps we should offer Maerklin somebody, who is a native English speaker. BigGrin
Weather Maerklin will trust and believe him?Laugh Cool
CS3 & X-track with 2 engines (Digital)
by bygger01 26/04/2024 13:24:25(UTC)
CS3 audio output (Digital)
by rhfil 23/04/2024 16:35:50(UTC)
CS3 run time event (Digital)
by QQQ1970 15/04/2024 14:44:37(UTC)
Using an Intellibox with a CS3 (Digital)
by rschaffr 09/04/2024 23:23:07(UTC)
CS3 Failure to Read and thus Write to DCC Decoder. (Digital)
by nikdog 06/04/2024 00:45:33(UTC)
CS3+ S88 Arduino connection (Digital components and Software reviews)
by Tue Albertsen 26/03/2024 17:15:21(UTC)
CS3 2.5.2. update older decoder FW (Digital)
by jonas_sthlm 25/03/2024 10:55:37(UTC)
Mobile station 1 and CS3plus compatibility (Digital)
by biswasg 25/03/2024 10:00:10(UTC)
CS3+ automation macros examples & documentation (Digital)
by fabstar68 18/03/2024 15:04:49(UTC)
CS3 with it's new update 2.5.2. & ESU Loksound 5 (mfx) (Digital)
by bygger01 14/03/2024 20:11:58(UTC)
CS3 and mfx locos in maintenance mode (Digital)
by rhfil 27/02/2024 23:23:05(UTC)
CS3+ Locomotive data pictures (Digital)
by MSanches 27/02/2024 10:48:24(UTC)
CS3 events, IF macro inside a loop... how is it supposed to work? (Digital)
by dodi 22/02/2024 18:37:15(UTC)
CS3 Cannot edit control boards when connected via Browser (Digital)
by malsnake 17/02/2024 03:51:24(UTC)
Decoder Read Message CS3Plus (Digital)
by mzecchi70 12/02/2024 03:21:12(UTC)
do the lok data cards - 60135 - work with CS3+? (Digital)
by roedj 10/01/2024 12:14:32(UTC)
Mouse not working with CS3 (Digital)
by Uwe 04/01/2024 02:34:04(UTC)
CS3 Update Issue (Model railroad software)
by Eddie7979 22/12/2023 05:57:46(UTC)
CS3 connexion with a smartphone (Digital)
by JohnjeanB 20/12/2023 10:49:42(UTC)
Cs3+ (H0-scale)
by bobgiam 16/12/2023 01:17:51(UTC)
SUSI CV Menu in CS3 (Digital)
by Diesel2000 14/12/2023 18:19:52(UTC)
CS2 upgrade to CS3 (Digital)
by rhfil 11/12/2023 00:39:07(UTC)
rotary Crane,CS3+,M84 (Digital components and Software reviews)
by ULI1944 10/12/2023 20:34:57(UTC)
CS3 deleted actions (Digital)
by petestra 07/12/2023 15:15:04(UTC)
CS3 loco history (Digital)
by rhfil 04/12/2023 19:04:12(UTC)
CS3 and Wifi camera (Digital)
by jonas_sthlm 03/12/2023 11:12:11(UTC)
CS3+ update using USB stick. (Digital)
by Flupke 13/11/2023 16:33:07(UTC)
S88 contact and Track Diagram CS3 (Digital)
by fvelazdem 13/11/2023 13:50:14(UTC)
CS2/CS3 multiprotocol Wave form (Digital)
by peter_moulin 07/11/2023 12:43:12(UTC)
CS3 and loco photo (Digital)
by fvelazdem 19/10/2023 13:44:39(UTC)
CS3 layout editing (Digital)
by rytter 30/09/2023 23:50:31(UTC)
CS3 and ethernet connection (Digital)
by Luna 20/09/2023 05:47:45(UTC)
Breakmodule vs CS3 (Digital)
by Mille 10/09/2023 09:11:20(UTC)
CS3 Trackplan (Digital)
by henna 31/08/2023 06:56:08(UTC)
Backdating a CS3+ (Digital)
by Drongo 22/08/2023 12:40:28(UTC)
7687 and 6040 keyboard vs Marklin CS3 (Digital)
by brauer.jim 09/08/2023 22:50:40(UTC)
CS3 Auto Addition of Locomotives (Digital)
by Eddie7979 30/07/2023 08:28:35(UTC)
CS3/CS2 - same loco different photos (Digital)
by twmarklinfan 26/07/2023 00:51:29(UTC)
Using the macro BLOCK on the Märklin CS3. Questions (Digital)
by JohnjeanB 08/07/2023 15:31:28(UTC)
CS3 Overload Error (Digital)
by Roland 04/07/2023 02:16:06(UTC)
22560 Santa Fe with CS3 (Big scale)
by Pkimbrough 17/06/2023 23:31:19(UTC)
CS3+ Help: cannot create "areas" on layout (Digital)
by plg 03/06/2023 21:00:28(UTC)
Use old 6083 (K83) and 6084 (K84) with CS3+? (Digital)
by Feelixen 18/05/2023 14:45:27(UTC)
Resetting cs3 (Digital)
by Mille 14/05/2023 10:56:38(UTC)
My cs3 dont find my New m84 (Digital)
by Mille 10/05/2023 10:03:36(UTC)
CS3+ Events (Digital)
by Drongo 27/04/2023 07:40:50(UTC)
Loco speed in RocRail and CS3+ (Digital)
by Tue Albertsen 15/04/2023 17:30:21(UTC)
CS3 new update 2.4.1.0 (Digital)
by gamolina 15/04/2023 02:58:14(UTC)
Steps to add CS3 into a system running MS2 (Digital)
by Cmondialo 15/04/2023 01:09:17(UTC)
editing a 76496 mfx home/exit signal time on CS3 (Digital)
by marklinist5999 11/04/2023 14:25:20(UTC)
2 Pages12>
This page was generated in 1.871 seconds.
