Offline wsscott
#1 Posted : 27 November 2013 17:49:29(UTC)
wsscott
I have the original Mobile Station and the 66185 power supply which is 16 VA. I have a large oval track ( ie. about 14')and use feeder wiring. When I'm running one loco with cars on the track it seems fine, but when I add a second loco with cars which also have lighted features in them, they both are very sluggish. Is it because my power supply is only 16 VA? If a larger one is recommended, which one would work/interface properly with the Mobile Station? Thanks.
Offline Hoffmann
#2 Posted : 27 November 2013 17:59:41(UTC)
Hoffmann
HI,
Your Mobilstation 1 has a max output of 1.2 Amps. A larger Transformer will not fix your current problem. There was also a Mobilstaion 1 with 1.9 Amp output.
This being said 2 Locomotives should have no problem running with a Mobilstaion 1. Try switching of the lights on your locomotives and see if that solves your problem. It could be that your locomotives need to be serviced (clean Motor and lubricate ).
How many Cars have Lights? That is most likely your problem.
Martin
marklin-eh
Offline wsscott
#3 Posted : 27 November 2013 18:08:25(UTC)
wsscott
Its the King Ludwig set with 2 additional cars in the series. So its 5 cars plus the loco.
#4 Posted : 27 November 2013 18:21:45(UTC)
The power supply has 18 VA, so it's good for 1 A output. The Mobile Station has either 1.2 A or 1.9 A (you should be able to find out when you flip through the INFO screens of the MS1 - I forgot the letters you have to look for, but look for "1.2" or "1.9" (but AP: 1.2 is not the max. output)).
Some of the 1.9 A Mobile Stations can even show the track current.
The power supply is not stabilized, so voltage will drop under load. This could be the problem. A switching-mode power supply (with stable output voltage) would help in that case.
How many feeder tracks are there? This could also be a problem. More feeder wires should reduce or solve the problem.
In case of overload, the MS1 will go to STOP mode and will show a flash symbol on the display. Do you get the flash symbol when you run both trains?
Offline wsscott
#5 Posted : 27 November 2013 18:54:48(UTC)
wsscott
I"ve run the feeder wires about every 3 meters. I've never had it go into STOP mode or seen a symbol.
Offline Hoffmann
#6 Posted : 27 November 2013 18:59:05(UTC)
Hoffmann
Well your Problem is the 5 Carset with Lights. Since these are regular Lightbulbs ( no LED's ). You will see if you just run the 2 locomotives without the cars that
your Mobilstation will work as it should.
Martin
marklin-eh
Offline wsscott
#7 Posted : 27 November 2013 19:06:59(UTC)
wsscott
Any suggestions for a solution? Thanks for your help.
Offline Hoffmann
#8 Posted : 27 November 2013 19:48:03(UTC)
Hoffmann
The solution would be to get a better Digital Controller (# 6021, Mobilstation 2, CS1, CS2, Ecos and so on ).
Of course you would also need a more powerfull TRANSFORMER/POWERSUPPLY.
Martin
P.S. A Delta Controller with a transformer #6001 or #6646 could be used as a Booster as well.
Digital is Fun is it notScared
marklin-eh
#9 Posted : 27 November 2013 21:07:53(UTC)
Try a switching-mode power supply.
The track output from an MS1 with stabilized power supply should be as good as that of an MS2 or CS2.
Did you flip through the pages under OPTIONS => INFO in your MS1?
The version with 1.2 A will be too weak for a third train. Getting an MS2 with the appropriate power supply will get you stable track voltage with reserves for a third train.
If you happen to have a switching-mode power supply with a suitable plug, you could give it a try to see if trains run better. If they do, you can still get a power supply (from Märklin or somewhere else). If they don't run better, then we'll have to search another potential cause.
Offline BrandonVA
#10 Posted : 27 November 2013 22:39:44(UTC)
BrandonVA
Views messages in topic : 2,533
You could also consider retrofitting the coaches with LEDs. I am not sure what style Bubls these coaches have. In some cases you csn get LED bulbs as adirect replacement that will plug/screw into the bulb sockets with no additional wiring or changes. I am not in a place where i can look up the bulb numbers right now, but sometumes you can find direct LED replacements for the Marklin bulb part number on Ebay or with Google.
-Brandon
Offline waorb
#11 Posted : 28 November 2013 12:37:00(UTC)
waorb
Brazil
My 2 cents.
Try this website:
http://www.trainaidsa.com/
Look for 'components+leds' link. They have a lot of options, inclusive Märklin style of positive/negative inverted bulbs.
Walter
Offline wsscott
#12 Posted : 30 November 2013 20:25:13(UTC)
wsscott
I also have a 6646 Transformer, and wondered if I could use it with the Mobile Station ver. 1? Would that work to solve my problem. Thanks
#13 Posted : 30 November 2013 22:01:05(UTC)
As has already been said, the problem is with your Mobile Station not having the capacity to supply more power to the track, so pairing it with a larger transformer may not fix your issue.
You should
- Check the Info on your MS1 (as Tom has already told you to do), to see whether you have the 1.2amp or the 1.9amp MS1 version. If you have the 1.9amp version, then a larger transformer will help. If the 1.2amp version, then it won't.
- Reduce the number of coaches with lights on the track. Replace lights with LED's (as has already been suggested).
- Try a stabilised power supply (as Tom has already suggested)
- Buy a MS2, CS2, Ecos, or a 2nd hand 6021 (as Martin and Tom have already suggested).
You already have been given your solutions, I suggest you go try them, and tell us which one worked for you.
Offline wsscott
#14 Posted : 01 December 2013 13:56:29(UTC)
wsscott
Thanks. I'll let everyone know.
Offline BrandonVA
#15 Posted : 02 December 2013 16:27:00(UTC)
BrandonVA
While as mentioned it won't solve the immediate problem, you can use this to power streetlights and accessories, keeping load off your MS1. They can use a common ground and isolated power feeds.
-Brandon
Offline wsscott
#16 Posted : 15 December 2013 20:37:45(UTC)
wsscott
Sorry to take so long to get back. I'm running just the King Ludwig Tristan loco with the tinder and 3 cars. If I add the extra 2 cars to it, it seems too much weight for the Tristan loco. I don't have the other loco and cars on the set, so Tristan is all that's being operated. The speed seems the same whether the lights in the cars are on or off. The MobileStation is 60652. The Info shows the following information while Tristan is running:
HW:1.04010
BL:1.0
AP:1.04010
U:00027995
UT:18.5-18.9 V
UD:17.9-18.2V
OVC:1.2A
Do these numbers seem ok? I'm assuming that the last 3 items are probably the most relevant to my initial question for the forum. Thanks for your time.
#17 Posted : 15 December 2013 20:45:37(UTC)
IIRC there was a gear problem with that loco. I don't have that set, but I think other forum members will have more information.
If the MS was overloaded, it would switch to STOP automatically. Therefore I think another power supply will not improve the situation.
#18 Posted : 15 December 2013 21:13:25(UTC)
I have a few questions while we're at it.
From what I understand, the current generation of controllers now have AC adapters that convert AC to low voltage DC.
Is track voltage delivered in AC (19V) or is it now DC?
Which controllers still deliver AC (MS1, CS1)?
While we are on the topic of power supply and controllers, the MS2 has a special connection track for C Track. How would I connect such a controller to K or M Track?
Regarding the original question, if you can replace the older light bulb type coach lighting with LED lighting, this will reduce the consumption of each train, which will allow you to operate the two or three trains without problem.
#19 Posted : 15 December 2013 21:51:41(UTC)
Digital track current is neither AC nor DC, it's "digital current": constant voltage (as constant as the power supply allows), but alternating polarity with a frequency around 5000 Hz.
This applies to all Märklin digital controllers from 6020 through 60215.
The MS2 track box comes with spade connectors for either C track or I gauge track. You can cut the spade connectors off to connect it to M track, K track, N gauge track or whatever.
DC power supply (Digital)
by Bernd 08/12/2023 16:58:22(UTC)
Need a 15v AC power supply recommendation for 89401 signal (Small scale)
by Bilge Rat 07/06/2023 19:42:05(UTC)
Use AC HO Marklin turnouts with DC power supply? (H0-scale)
by Yigal 14/05/2023 07:41:52(UTC)
MS2 replacement power supply (H0-scale)
by revmox 23/01/2023 23:30:41(UTC)
Compatible power supply for Marklin M Track? (General MRR)
by Skywalker646 10/12/2022 02:49:53(UTC)
Power supply (Small scale)
by Snowfun 30/12/2021 09:08:30(UTC)
Power supply socket (General MRR)
by Rwill 21/02/2021 11:09:48(UTC)
Arduino, 60113 box with MFX additional power supply (Digital)
by NicoNumberFour 07/12/2020 12:26:42(UTC)
Power supply of digital 11/5000 locomotives (H0-scale)
by Garoux 15/07/2020 15:00:23(UTC)
digital and classic power supply from transfo (General MRR)
by Garoux 15/07/2020 14:43:52(UTC)
m83 power supply + Viess. Signals (Digital)
by kehdi737w 27/06/2020 10:37:38(UTC)
Marklin Decoder m83, 60832, and external power supply (Digital)
by ocram63_uk 28/10/2019 09:15:30(UTC)
design of power supply wires (Model railroad wiring)
by Thewolf 28/08/2019 14:36:35(UTC)
Power supply problem? (General MRR)
by Sir Timbo 03/04/2019 06:20:39(UTC)
power supply 60822 (General MRR)
by Thewolf 03/02/2019 02:10:39(UTC)
Problem with M83, M84 & Universal Power Supply (Digital)
by rrf 01/02/2019 22:53:38(UTC)
Intellibox II Transformer/Power Supply (Digital)
by jbblunck 15/02/2018 16:54:40(UTC)
60822 universal power supply / 66367 power pack for M83/M84 (H0-scale)
by ae66green 17/01/2018 17:08:46(UTC)
Repairing a 60061 Power Supply (Digital)
by Bigdaddynz 21/10/2017 11:46:01(UTC)
Power Supply for CS3 (Digital)
by compatty 08/10/2017 14:11:45(UTC)
Connecting power supply common wires (H0-scale)
by Donb 04/05/2017 18:18:43(UTC)
M83 power supply via booster (Digital)
by antazio 28/04/2017 20:51:41(UTC)
Power Supply (H0-scale)
by Twisterdodger 27/04/2017 15:41:34(UTC)
Nielsenr - CS2 Power Supply For Large Scale Trains (Big scale)
by Nielsenr 07/03/2017 16:59:18(UTC)
S88 and power supply (Digital)
by Harvey 08/01/2017 17:12:45(UTC)
Power supply layout.... the bulshitt (General MRR)
by Thewolf 09/09/2016 16:49:58(UTC)
MÄRKLIN 60657 Mobile Station with Junction box 60116 + Power supply 66361 (Digital)
by Barton 04/08/2016 21:57:53(UTC)
Märklin Safety Power Supply 66470 vs. 6631 (General MRR)
by sjlauritsen 02/08/2016 15:23:17(UTC)
A Power supply for new M83. Is a 60822 needed? (Digital)
by frickwg 19/03/2015 22:30:36(UTC)
Power Supply / Transformer for CS2: 60055 vs. 60065 (Digital)
by cwp_marklin 02/03/2015 21:29:07(UTC)
Power Supply for MS 2 - Anyone using 66185 for MS 2? (Digital)
by SAK 19/02/2015 08:07:17(UTC)
Power Supply for Accessories other than 6646 (Digital)
by stlcards54 13/02/2015 17:43:53(UTC)
Suitable replacement for the 18VA power supply (Small scale)
by nevw 29/11/2014 23:52:19(UTC)
Power Supply inside wagon (Digital)
by sevs 28/07/2014 10:06:00(UTC)
CS2 & 60065 power supply (50 VA) rare behavior (Digital)
by eduard71 12/03/2014 20:30:50(UTC)
MS2 with own power supply and 6002 for accessories on M-track (Digital)
by timvenn20183 03/03/2014 19:24:24(UTC)
Power Supply Mobile Station 2 (Digital)
by mike c 12/01/2014 02:05:39(UTC)
29486 Set, which 120V Power Supply? (H0-scale)
by mike c 07/01/2014 05:29:49(UTC)
12 V DC power supply to Viessmann 5211 (Digital)
by DaleSchultz 10/11/2013 17:21:36(UTC)
Power supply for analog BR 89 3000 (H0-scale)
by Bagrym 17/12/2012 10:38:19(UTC)
Secondary power supply for switches, decoders etc. (Digital)
by Semaphore 13/10/2012 19:30:53(UTC)
PC Lap top power supply for digital train? (Digital)
by wurttemberg 09/05/2012 10:22:10(UTC)
Ecosboost 8amp power supply - variable or not. (Digital)
by diesel 28/04/2012 14:02:33(UTC)
ECoS power supply replacement (Digital)
by GSRR 13/01/2012 18:36:54(UTC)
accessory power supply (H0-scale)
by Shintaro 28/10/2011 07:53:41(UTC)
Power supply for k83 decoders (Digital)
by ChrisP 21/10/2011 09:20:21(UTC)
New power supply & booster (Digital)
by Drongo 08/06/2011 07:06:24(UTC)
Switching Power supply (Digital)
by James 01/03/2011 15:18:52(UTC)
Marklin Switched Mode Power Supply (General MRR)
by GSRR 19/01/2011 18:32:38(UTC)
DON'T use car batteries as power supply. (Digital)
by Purellum 27/10/2010 21:53:17(UTC)
This page was generated in 0.733 seconds.
