Offline Joseph Meiring
#1 Posted : 22 August 2010 23:24:02(UTC)
Joseph Meiring
Hi everyone
As you all prob know, I only run analogue, M track. If I wanted to venture into the digital world, what is the best route? A complete digital starter set?, or individual bits n pieces?
I'm thinking of having a layout "next to" my analogue layout. So the 2 will be completely separate. Is it possible to convert some of my locos to digital - 3003 (1973), 3309 (1985),3021(1975) - or are they too old? And then would C track obviously be the best?
Thanx in advance
M track Joe
#2 Posted : 22 August 2010 23:48:16(UTC)
Almost any old loco can be converted to digital, the ones you mention are a "breeze" since there are conversion sets available from Märklin for all these... However, there is a cost associated with the sets and there are other ways to rebuild the motor and use cheaper decoders.
Regarding track, if you are going to build a separate track with new track pieces C would be the best option. However, there is nothing wrong with eg M-track in digital if you happen to have a lot of them.
If you want to make a "fresh start", a digital starter set with a controller, digital train(s) and C-track is more viable regarding getting into digital from a finacial point of view if you want to get the "feel" of it in a quick way.
Offline applor
#3 Posted : 23 August 2010 01:40:45(UTC)
applor
If you want to upgrade to digital on the cheap, just buy a 6021 controller. I'm sure you'd have a suitable power supply. They can be had very cheap and work very well and reliably!
All your locos can be upgraded to digital. Cheapest way is to buy the appropriate permanent magnet and buy a lokpilot decoder or similar. Also very cheap.
#4 Posted : 23 August 2010 01:45:20(UTC)
A Start Set is a useful way to enter the digital world. There is a reduction compared to the individual items. If you cannot find a start set that interests you, then you may wish to buy the elements separately. You can also likely find broken up start set elements on eBay and at some retailers.
If you intend to operate it alongside your existing M Track layout, you can consider the larger radii 4 and 5, which would allow for you to set up a mainline arond your existing setup. My plan was to do something along these lines, with the larger radii representing a (potentially high speed) main line, with trains like the TGV, ICN, IC2000, etc and have the interior tracks used for local and short trains. You could still set up a common bahnhof for the two sets of tracks as the focal point of your new layout.
#5 Posted : 23 August 2010 02:04:33(UTC)
Yes, a starter set is ideal to get started in the digital world. I started off with a 29845 mega starter set. The current mega starter sets are quite expensive (1500 euro - about twice what I paid for my set), but include a Central Station 2 and 2 locomotives, track and trains. Other cheaper starter sets include the Mobile Station, which is a good controller to get started with, and can be used as a remote controller with the Central Station 2, should you opt to get a CS2 later.
You can also get conversion tracks that will connect your M track to C track, if you wanted to expand that way.
Time to go digital? (Digital)
by MtrackJai 23/06/2023 18:00:31(UTC)
29146 conversion - Delta to digital? (H0-scale)
by The Crocodile 26/12/2021 13:29:12(UTC)
Marklin 86582 - Is this digital? (H0-scale)
by Karl 19/10/2019 14:46:35(UTC)
[Question] How to convert Märklin 3021 to digital? (Digital)
by Dino 03/08/2019 17:57:23(UTC)
Block control - stay with relays or use digital? (Digital)
by fynrfin 19/03/2019 18:53:37(UTC)
Digital? (General MRR)
by jeffd 25/12/2018 15:40:48(UTC)
Converting an old analog loco with Telex to digital? (Digital)
by Jabez 05/11/2016 22:21:46(UTC)
Silence information about digital? (Digital)
by Goofy 27/03/2016 17:51:36(UTC)
Märklin 5713 DB BR 55 3964 analog or digital? (Big scale)
by Janne75 30/11/2014 10:42:23(UTC)
Roco on Marklin Digital? (H0-scale)
by morsing 17/08/2014 10:54:05(UTC)
MTH 3E+ HO locomotives running on Marklin Digital? (Digital)
by StuartA 25/05/2013 20:06:43(UTC)
RAPTOR DIGITAL? (Digital)
by 1spur 20/01/2013 17:31:25(UTC)
Going digital? (Digital)
by BrandonVA 02/02/2012 16:36:09(UTC)
ID locomotive/convert to digital? (Collector's Corner general)
Belarus dpetersen 08/01/2012 05:47:47(UTC)
Quality of household electricity - does it matter for digital? (Digital)
by kimballthurlow 31/10/2011 22:11:17(UTC)
Lux cleaning car conversion to digital? (Digital)
by eduard71 07/05/2011 15:22:28(UTC)
Analog locos, old, to digital?? (Digital)
by Joseph Meiring 09/04/2011 17:32:16(UTC)
Going Digital? (General MRR)
by Joseph Meiring 01/02/2011 21:57:00(UTC)
Marklin 3371 ICE or digital? (H0-scale)
by rhobson1968 10/07/2009 02:13:21(UTC)
Converting 3015 to digital? (Digital)
by TroyYang 22/05/2009 04:33:00(UTC)
Help- MAXI Engine- Digital? Delta? or DC Only? (Digital)
by steameng8 02/02/2009 23:56:21(UTC)
Convertering 2868 to digital? (Digital)
by amalongi 05/01/2009 21:45:53(UTC)
make a 3005 digital? (H0-scale)
by obxbill 02/01/2009 04:29:41(UTC)
New user dilemma: classic or digital? (H0-scale)
by hansbos 04/08/2008 01:46:52(UTC)
How to convert a Ma 3658 to newer digital? (Digital)
by meina222 27/02/2007 02:55:25(UTC)
how to dive into digital? (Digital)
by tekin65 16/10/2006 01:36:59(UTC)
can analogue be used with digital? (Digital)
by zand 1985 13/12/2005 16:50:33(UTC)
Problems converting a 3434 to digital? (Digital)
by Mikael 03/11/2005 14:05:35(UTC)
#3149 engine...convert to digital? (H0-scale)
by littledragon 28/07/2005 20:11:32(UTC)
How big a transformer for digital? (Digital)
by elsleuth 05/01/2005 20:33:23(UTC)
At what point did you decide to go digital? (Digital)
by jocoyn 30/01/2004 15:11:34(UTC)
What are the stages/strategies for Digital? (Digital)
by streetmagick 28/02/2003 21:45:42(UTC)
This page was generated in 0.384 seconds.
