Offline Mailme
#1 Posted : 11 July 2024 03:53:39(UTC)
Mailme
Hi, I’m new to Marklin CS3, (used Ecos 5200), for several years. On 2 rail track. I have replaced all, with C-Track 3 rail! Since using my Cs3, I have found once programmed to 29 function DCC, when a loco is placed on the main layout track, my loco is added again as a 15 function, mfx model. My affected locos are all ESU Lok sound ver.4.0. My new Marklin locos are fine with mfx, because they have full 29+ functions.
My question is…………. Can I stop my CS3+ doing this and running these on DCC?
Because of the mfx situation my functions, are not only limited to 15, but they are mixed up, wrong icons and some just do not work.
Any solution will be gratefully received. Please don’t tell me to get rid of my ESU locos, this is not an option. Most of my purchases will be the latest additions and mfx+ is fine…………. Thanks
#2 Posted : 11 July 2024 11:27:51(UTC)
Hi Mailme (a first name would be great)
A warm welcome to this great forum where most of us provide an introduction ("Presentation"). This is not police stuff but rather to get better acquainted.
Here a Märklin fan from Ile de France (greater Paris) with HO, digital, Rocrail to control trains through a CS3.
A normal reaction of the CS3, when posing a loco on the rails, is to try connect using MFX (Top-most priority for Märklin) even if the loco is already connected using DCC.
Your choices:
- you may block the MFX protocol at the CS3 level (it would be a bad restriction on something very powerful). I authorise all 3 protocols
- you may block the MFX protocol at the loco level (depends on your decoder type). Märklin uses CV50 to block/authorise protocols. This helps barring the loco from any MFX registration
A CS3 works great with Märklin decoders where it is the MOST user-friendly (the right icon, all the used fonctions, etc).
Notes:
- recent versions of the CS3 (2.5.1 and 2.5.2) have created issues with non-Märklin decoders. So beware. Märklin says it changes the firmware, I fdon't know but one decoder I have ESU, Loksound5 micro has been "modified" by the CS3 and now I have no more headlights.
- I believe it is best to disable the unused protocols at the loco level (depending on which decoder brand you are using the disabling may change)
- remember that you cannot disable the protocol you are presently using to talk to the loco (so you may want to connect using DCC to disable the MFX protocol) and then delete to possibly created MFX registration.
- avoid using MFX on accessories like 60832, 60842, MFX signals because it is best to remain in charge of assigning all addresses
Here is my layout in operation with digital and Rocrail (at the timle with a CS2 but since 3 years with a CS3
https://www.youtube.com/watch?v=F6WnhXPcRqI
Offline rhfil
#3 Posted : 11 July 2024 11:49:39(UTC)
rhfil
I have never done this and so can not be certain of the result but you might try it with one loco and if it works do the same with the rest. First go into system and "track prototcol" and turn off mfx. Then go into loco edit mode and "add loco" and add a loco that is having the problem and give it a unique name and address (this possibly should be done on the programming track) and then go back and turn the mfx back on. Then check out the new registry to see if it solves the problem or creates new ones. You can always delete it. By the way, it is possible to change the icons on locos by entering the "set up" mode of the "edit icon".
But Jean's solution is probably more efficient if you dare change cvv's. Plus my solution may result in your having two registrations for the same loco.
#4 Posted : 11 July 2024 13:15:31(UTC)
No. you are absolutely right (and I have done it but forgotten). YES you must first disable (temporarily) the MFX protocol on the CS3. This is the only way to "talk to the loco" in DCC.
Then disable on the loco the MFX protocol, remove any possible MFX registration on the CS3
Finally you may authorise back the MFX protocol because on recent Märklin locos, it is so much more convenient.
Online kiwiAlan
#5 Posted : 11 July 2024 17:46:47(UTC)
Without knowing how old these decoders are it could be that they need a firmware update to handle more then 15 functions under mfx. Personally I would update each one to the current firmware level provided by the lokprogrammer.
Offline rhfil
#6 Posted : 20 July 2024 03:34:08(UTC)
rhfil
So rude of people to come in here asking for help and after we take the trouble to try and offer up a solution the response is crickets.
cs3+ voltage output (Digital)
by fabstar68 10/11/2025 17:37:17(UTC)
CS3+ (Digital)
by bygger01 10/10/2025 17:14:04(UTC)
CS3+ + booster + L88 (Digital)
by BenP 09/07/2025 16:24:34(UTC)
60VA v 100VA for CS3+ (Digital)
by BenP 28/06/2025 22:50:45(UTC)
Help! CS3+ seems to be changing my turnout addresses when I add mfx device (Digital components and Software reviews)
by tgj 04/05/2025 19:44:59(UTC)
IP address of two CS3+ (Digital)
by Capitole 03/04/2025 09:43:46(UTC)
CS3+ with a CS3 slave (Digital)
by rhfil 21/03/2025 22:53:17(UTC)
issue with locos that doesn't stop on cs3+ (Digital)
by Adrian666 11/03/2025 13:31:25(UTC)
Other digital brands on cs3+ marklin system (Digital)
by Adrian666 10/03/2025 19:09:40(UTC)
S88 Events via UDP CAN Gateway für CS3+ und Rocrail (Digital)
by rinderkn 09/02/2025 16:55:55(UTC)
CS3+ (Digital)
by greatrocks 15/12/2024 00:00:09(UTC)
Locomotive (mfx) not showing up in list on CS3+ (Digital)
by micknudsen 24/11/2024 12:49:35(UTC)
Can Marklin CS3+ connect with servo? (Digital)
by Solar007 27/09/2024 11:22:36(UTC)
CS3+ (Digital)
by Carlos 28/07/2024 17:16:04(UTC)
CS3/cs3+ update 2.5.2 (Digital)
by Flupke 22/06/2024 20:05:21(UTC)
CS3+ S88 Arduino connection (Digital components and Software reviews)
by Tue Albertsen 26/03/2024 17:15:21(UTC)
CS3+ automation macros examples & documentation (Digital)
by fabstar68 18/03/2024 15:04:49(UTC)
CS3+ Locomotive data pictures (Digital)
by MSanches 27/02/2024 10:48:24(UTC)
do the lok data cards - 60135 - work with CS3+? (Digital)
by roedj 10/01/2024 12:14:32(UTC)
Cs3+ (H0-scale)
by bobgiam 16/12/2023 01:17:51(UTC)
rotary Crane,CS3+,M84 (Digital components and Software reviews)
by ULI1944 10/12/2023 20:34:57(UTC)
CS3+ update using USB stick. (Digital)
by Flupke 13/11/2023 16:33:07(UTC)
Backdating a CS3+ (Digital)
by Drongo 22/08/2023 12:40:28(UTC)
CS3+ Help: cannot create "areas" on layout (Digital)
by plg 03/06/2023 21:00:28(UTC)
Use old 6083 (K83) and 6084 (K84) with CS3+? (Digital)
by Feelixen 18/05/2023 14:45:27(UTC)
CS3+ Events (Digital)
by Drongo 27/04/2023 07:40:50(UTC)
Loco speed in RocRail and CS3+ (Digital)
by Tue Albertsen 15/04/2023 17:30:21(UTC)
CS3+ Track Current Monitor (Digital)
by kolabuzlu 25/02/2023 18:58:12(UTC)
CS3+ and DCC (Digital)
by roedj 16/02/2023 12:35:52(UTC)
Resetting CS3+ (Digital)
by Carlos 20/12/2022 20:04:27(UTC)
CS3+ & Lenz LS150 (Digital)
by bygger01 18/12/2022 12:38:09(UTC)
Registering decoders on three way points on CS3+ and CS2 and other problems (Digital)
by DV 11/08/2022 10:30:31(UTC)
CS3+ VNC Viewer not working (Digital)
by Diesel2000 23/07/2022 23:54:31(UTC)
Update Of Old/Early CS3+ (Digital)
by bugsmasher 26/06/2022 02:36:48(UTC)
Update CS3+ v.2.4.0 (Digital)
by fhp2 22/03/2022 08:58:32(UTC)
GUI and GFP in the CS3/CS3+ (Digital)
by fosuna 04/03/2022 07:33:06(UTC)
CS3/ CS3+ (Digital)
by bgemski 01/03/2022 16:00:15(UTC)
Locomotives controlled by CS3+ loose settings (light, sound ...) after restart of CS3+ & speedchange (Digital)
by HaraldOnline 24/01/2022 09:05:57(UTC)
How to run CS3+ events at a specific time of the day? (Digital)
by Nick1150 22/01/2022 11:43:05(UTC)
ITrain, CS3+ and manual control (Model railroad software)
by Puttputtmaru 17/01/2022 00:17:56(UTC)
CS3+ cannot find locos based on mfx protocol (Digital)
by eldar760 12/01/2022 03:30:09(UTC)
Motor 74491 decoder 60831 and CS3+ (Digital)
by Rolando 31/12/2021 11:05:22(UTC)
Sound on CS3 and CS3+ (Digital)
by Joakim_B 10/12/2021 23:11:13(UTC)
Märklin CS3+ & Web interface problem (Digital)
by BOOMerCH 25/09/2021 20:40:05(UTC)
Can I mix a CS3+ with an EcoS (Digital)
by Drongo 08/08/2021 12:40:19(UTC)
CS3+ S88 contact track event (Digital)
by marklinist5999 03/08/2021 15:11:05(UTC)
M84 Decoder, Cs3+, Minitrix Turntable (General MRR)
by Ngauging21 03/05/2021 08:36:17(UTC)
CS3+ and PSX circuit breakers (Digital)
by trentschler 14/04/2021 18:05:01(UTC)
Changing cs3+ from main to auxiliary control (H0-scale)
by Umesh 23/02/2021 15:04:37(UTC)
CS3+ and Event Logging (Digital)
by magicmushroom 17/01/2021 20:35:43(UTC)
This page was generated in 0.451 seconds.
