Offline Krish
#1 Posted : 13 August 2021 08:05:39(UTC)
Krish
India
Dear all
Although I have owned a Marklin starter set for a few years, I have not used it more than 3 times !. The last time I forgot to take out the batteries from my CS ( the first version, I think of cs) and the the CS was damaged beyond repair. SO I bought a new CS3 ( not a CS3+ ).
With the starter set, I got two turnout rails, which I operate manually. I want to know....
1) what hardware is needed to control the turnouts from my CS3
2) How to set it all up on CS3
3) where to get the hardware ( I live in Bangalore, India)
Thank you
Krish
thanks 1 user liked this useful post by Krish
#2 Posted : 13 August 2021 13:42:05(UTC)
Hi Krish, begin by downloading the CS3 quick start manual. I recently also got the big book, item # 030937. It's more comprehensive.
All you need for turnouts on a CS3 is an M83 decoder per 4 turnouts, or if you prefer a decoder in each turnout, you can do that. They are all mfx now, so auto. recognition. You then assign the turnouts to spots on your track plan, or on the screen in approx. positions.
#3 Posted : 13 August 2021 14:28:04(UTC)
I don't think you understood the question completely BigGrin
There is no such thing as "decoder in the turnout" or MFX for 1-gauge turnout decoders.
#4 Posted : 13 August 2021 14:42:58(UTC)
1: It depends on which type of turnouts; I guess it's the "old" original stainless Märklin type and not the newer "Hübner" type.
For the "old" Märklin 5976 or 5977 you need a "Turnout Mechanism", item no. 5926 for each turnout.
To control the turnout mechanisms from the CS3 you need a M83 per each 4 turnouts - the older K83 module or a Viessmann 5211 can also be used.
https://www.maerklin.de/...ts/details/article/5625/
2: Others know much better than me BigGrin
3: Same as #2............. LOL
#5 Posted : 13 August 2021 16:10:28(UTC)
Is he a 1 gague modeler? I did not read it in his question. If so, then he will also need the end circuit sets. They connect to the M83 output screws. One per turnout. Thye come two per set.
Krish, also wtch the Marklin digital yotube webinars by Curtis and Rick.
#6 Posted : 13 August 2021 16:16:02(UTC)
I think it will be safe to assume that Krish runs 1-gauge; since the question was posted in in the "Big scale" part of the forum........... BigGrin
#7 Posted : 13 August 2021 16:34:02(UTC)
He also mentioned that he has a G1 start set in the introduction forum.
#8 Posted : 13 August 2021 20:51:30(UTC)
That's what I get for reading posts whilst workng out. It's such an easy distraction though as my gym and layout are in a large shared space.
I any case. I gave Krish good points for connecting his points-frogs-turnouts. There are conflicting reccomendations from both Marklin and some dealers about the end circuit units.
They are only necessary for 1 gague DC/dcc, and not HO! Curtis and Rick emphasize this on the webinar regarding the M83 decoder.
An HO turnout doesn't have enough travel to facilitate setting a motion speed parameter on a CS3 I suspect.
I should also mention that I have two M83's powered from the track current which control 7 turnouts and an 8th. solenoid accessory. Two turnouts are 16 feet away from the M83, and perform flawlessly. On a very large layout with several M83's, a long distance cable from an M83 to a turnout or other solenoid accessory can tax the track current, so adding an external seperate power supply may be needed. The 1 gague or LGB power pack has mor amperage, so he can try long wiring first.
#9 Posted : 13 August 2021 22:24:41(UTC)
Honestly, I have no idea what you're talking about now ????
So far you haven't given any "good points", since except from mentioning the M83, the rest of your answers regarding the turnouts have been wrong Cool
Offline Krish
#10 Posted : 14 August 2021 06:50:37(UTC)
Krish
India
Thank you Purellum, Maklinist and Kiwialan.
I will start by acquiring a M83 and the turnout mechanisms. I will look at QuickStart too. Was going to buy the big book anyway ! :)
I am sure that I will have to seek your help many times in future.
Thank you all again.
#11 Posted : 14 August 2021 12:13:32(UTC)
You're quite welcome Krish! Others may also be of help. I found sorting out my confusion by reading the manuals, watching the webinars, and here as a process. Because Marklin translates to English, as any of us know how a few words get missed, or are wrong. Spell check auto correct can even goof.
One dealer I buy from even told me most Forum members don't know sheiza.
#12 Posted : 14 August 2021 14:12:37(UTC)
Did he also tell you to be leading by example ? LOL
#13 Posted : 14 August 2021 14:38:24(UTC)
No, because the example given me here to the question I asked him wasn't a good one!!!! He told me to call Marklin USA and ask if an insider coupon was still available for a certain model. Not to take at face value that I was told here only a limited number were lotteried out. He had the model, but I needed a club coupon for the lower price.
So, when I posted about the end citcuit units for the M83's, I wrote exactly as I read and heard. Read the Marklin site item descriptions. Most dealers copy and paste those as well.
I like what I see in the mirror.
#14 Posted : 14 August 2021 15:57:54(UTC)
Yes; but apparently you didn't understand what you read and heard.
I've read them several times, and it still doesn't make them work with the 1-gauge 5625 turnout mechanism - which is
the only Märklin turnout mechanism that fits the 5976 and 5977 turnouts delivered in the 1-gauge start sets.
Actually exactly as the Märklin description says, if you understand what you read Cool
You might be good looking; but you surely don't know anything about Märklin 1-gauge equipment LOL
#15 Posted : 14 August 2021 17:11:09(UTC)
Nothing about my looks. when someone needs a mirror, they are projecting what they accuse of. Mu dad had an LGB garden raiulway, so I do know a bit about ! gague, and I also have 2 rail D.C. ho trains. Maybe somebody crapped in your cereal this morning.
#16 Posted : 14 August 2021 17:50:32(UTC)
This topic is about 1-gauge Märklin, not LGB, which is G-scale, and not about 2 rail DC H0 trains............... BigGrin
Maybesomebody crapped in your cereal this morning.
Maybe you should just stop now.
Not only are you giving wrong information; but also being rude instead of accepting it.
#17 Posted : 14 August 2021 19:39:32(UTC)
You are muted!!
#18 Posted : 14 August 2021 19:58:53(UTC)
You are muted!!
https://www.bbc.co.uk/news/av/uk-55958195
#19 Posted : 14 August 2021 20:29:17(UTC)
Sure, I try, and I'm sorry for Krish; but I can't leave so much wrong information uncommented Cool
Märklin 1-gauge start sets have only been sold with 5976 and 5977 turnouts.
The only turnout mechanism build to be mounted on those turnouts are the 5625.
The 5625 is made of two electro magnets, which are to be supplied with 16 V AC or DC.
The 5625 can not be controlled by the end circuit units for the M83s, since they are for turnout mechanisms with DC motors.
Having watched a webinar with "Curtis and Rick" or having watched your daddy's 1:22,5 scale train run in the garden
surely doesn't make anybody an expert in Märklin 1:32 accessories; we've just seen proof of that BigGrin
And I haven't even commented on this one:
LOL Laugh LOL
#20 Posted : 15 August 2021 00:33:39(UTC)
That's OK, it wasn't you I was commenting on ... BigGrin
Offline Krish
#21 Posted : 15 August 2021 05:54:40(UTC)
Krish
India
thank you all
Purellum, can I assume that my turnouts ( 5976 and 5977) will work with just an M83, CS3 and a couple of 5625 turnout mechanisms ? Or do I need anything more ?
Thanks in advance
#22 Posted : 15 August 2021 09:11:14(UTC)
Yes, this is correct, you don't need anything more.
As a cheaper alternative to the M83, you can also use a K83 or a Viessman 5211. ( Several others also exists )
I will take a look later today; I think I have the parts you need BigGrin
#23 Posted : 15 August 2021 13:05:54(UTC)
A "long distance cable" to a solenoid (or DC point motor) would use LESS current from the power supply, as the electric resistance of the cable grows with length. The solution in that case would be to use a thicker cable with less internal resistance.
It's not a taxing on the current, but a drop in the voltage (two different things!). Even a perfect power-supply with no other job than to drive the point motor, could have this problem. Would you then raise the voltage to overcome the drop in the long cable? (hint; the answer is NO, you should not use more than the prescribed voltage)
In this thread you have let so much nonsense out, repeatedly, that you shouldn't really mute anybody when they alert you to this repeated nonsense.
If anybody should be muted, then... (!) ;-)
Offline Krish
#24 Posted : 15 August 2021 13:15:13(UTC)
Krish
India
Hi Purellum,
i can guess that the turnout mechanism is connected to the M83 ( or K83) decoder. But how is the M83 ( or K83 connected to the CS3? or is it connected to the track ? Excuse my ignorance !!
#25 Posted : 15 August 2021 15:31:32(UTC)
Track power Krish, unless you have several. I have no problem with two on track current. I wasn't sure I'd need the auxiliary power supply and a seperate small switched mode power pack for that, but it all worked.
I don't think I told you any nonsense, just that some things are different for 2 rail, AC and DC. I didn't know at first what system you use. All digital is esssentially DC current. The AC current is rectified by decoders, control units, or a convertor.
I appologise to you for any confusion. The turnout end circuit units are to allow parameter speed adjustment of the turnout solenoids. An M83 decoder is basically a switching device.
It is the digital equivalent to a relay.
#26 Posted : 15 August 2021 16:17:17(UTC)
Ohm's law is the same, the M83 / K83 units are the same, and the turnout mechanisms are electro magnets in all relevant Märklin accessories.
More nonsense BigGrin
It is not possible to adjust the speed of solenoids, the ( 60821 ) end circuit units are to adjust the speed of motors.
#27 Posted : 15 August 2021 16:24:40(UTC)
But how is the M83 ( or K83 connected to theCS3? or is it connected to the track
To the track power, which means you can connect them either directly at the track, or at the wires going from the CS3 to the tracks.
Probably in your case the easiest place to connect wires for the M83 / K83 would be at the CS3, in the same plug where you take your power to the track.
From the "track power" you get both the digital signal to control the M83 / K83 and the power to drive the turnout mechanisms.
If you choose e.g. the Viessmann 5211, you can add the power supply from a different source, so you don't use valuable "track power";
but I'm sure that in your setup it will not be needed, you have enough power from your CS3 to power the turnouts also. BigGrin
Offline Krish
#28 Posted : 16 August 2021 06:46:30(UTC)
Krish
India
Thank you both, Marklinsit and Purellum.
Yes, I have the big power supply the 60101. So I think track power should be enough. I have to hunt for M83/K83 and the 5625s now :)
I have rigged up my aeromodelling gear to operate the turnouts for the present....but only till I get the correct gear. ( am using the transmitter, receiver and 2 servos from aeromodelling gear to operate right now).
Thak you again.
Smile
Krish
#29 Posted : 16 August 2021 10:15:05(UTC)
You're quite welcome Krish! You sound well knowledgeable on electronics. I wouldn't know how to do anything with aeromodeling!
#30 Posted : 16 August 2021 10:58:39(UTC)
Don't buy anything yet BigGrin
Offline Krish
#31 Posted : 16 August 2021 11:02:08(UTC)
Krish
India
ok purellum, I'll wait for your post
#32 Posted : 16 August 2021 13:50:38(UTC)
I'm a Gumba too!!! Abruzzi and Sicilian, second generation. Being retired from the produce business I knew the local "Godfather" cartel. Cusmano, Furitano, Genovessi, Jaiccaloni, Tocco, etc. Offer it up!!!!! Drink from the chalace, break bread with, and watch your P's and Q's. The retirement plan is good, but you have to stay alive!
I know the difference from a motor and a solenoid, but technical terms vary by dialect, etc. Marklin calls an HO turnout solenoid a motor. Some call a Loco motor an engine.
Living by exact words can be confusing.
#33 Posted : 16 August 2021 15:15:00(UTC)
In that case I believe one of the marklin options will drive servo motors. If it is mfx it may even provide position feedback. But I am not familiar with the most recent Marklin decoders for this purpose, so can't offer more advice.
But it may be easier to do that than attempting to track down old (and possibly now rather expensive because of rarity) solenoid actuators.
but Per is more of an expert than me on G1.
#34 Posted : 16 August 2021 16:04:17(UTC)
No, they call it a "Electric Turnout Mechanism": https://www.maerklin.de/...s/details/article/74492/
And you forgot that you have muted me............... LOL Laugh
#35 Posted : 16 August 2021 16:22:03(UTC)
It's actually a very good idea, if Krish already have spare servos ThumpUp
I don't know any Märklin equipment able to drive servos; but I know ESU has the "51832 Switchpilot" made to control 8 servos.
http://www.esu.eu/en/pro...lot/switchpilot-3-servo/
At least two sellers have them on Ebay.de and ship worldwide:https://www.ebay.de/sch/i.html?_from=R40&_trksid=p2334524.m570.l1313&_nkw=switchpilot+51832&_sacat=0&LH_TitleDesc=0&_odkw=switchpilot&_osacat=0
Buying one of these will definitely be cheaper than even my offer, and it can control 8 servos.
Krish, I think you should consider this solution, if you have spare servos at home - please let us know when you've made a decision BigGrin
For further advise on the 51832 Switchpilot, you should make a new topic in the digital section of this forum - I'm not familiar with this.
#36 Posted : 16 August 2021 17:13:49(UTC)
Even if he doesn't have spare ones they are cheap as chips on eBay.
Offline Krish
#37 Posted : 17 August 2021 06:15:21(UTC)
Krish
India
Hi Purellum, KiwiAlan and Marklinist
I will certainly take a look at the references that you have given me. I will decide which way to go in a few days.
Having said that, my spare servos are Futaba servos used for controlling model aircraft control surfaces like rudder, elevator, throttle etc. I am not sure if they can be directly used....I may have to do some tinkering.
Thank you all again for your friendly supportSmile
Krish
#38 Posted : 17 August 2021 16:57:57(UTC)
Krish
The ESU decoder that Per mentioned is designed to have a mode for driving these servos. They have become an almost ubiquitous defacto standard for servos.
Offline Krish
#39 Posted : 18 August 2021 06:48:03(UTC)
Krish
India
Thank you KiwiAlan.
I have started a new thread " Mixing ESU hardware with Marklin systems....".
I hope to get some help through that.
Thanx again
Krish
Offline phils2um
#40 Posted : 18 August 2021 07:10:28(UTC)
phils2um
Since you already have the turnouts setup to be operated by servos I would also recommend the ESU SwitchPilot 3. Here is a link to more info: http://www.esu.eu/en/pro...lot/switchpilot-3-servo/
MD Electronics also make a suitable decoder that can be used to operate two servos using DCC switch addressing which is compatible with the CS3. I am using many MD electronics decoder devices myself with my CS3 and can endorse the MD Electronics. Here is a a link: https://www.md-electroni...ent/MD%20mXion%20KBM.pdf
Phil S.
Offline Krish
#41 Posted : 18 August 2021 07:34:19(UTC)
Krish
India
Hello Phils2um
Thank you for your suggestion. What is DCC switch addressing ? how to do it ? it there link to read and learn DCC switch addressing?
Thanks again
Krish
Offline phils2um
#42 Posted : 18 August 2021 08:18:02(UTC)
phils2um
The CS3 can operate both MM and DCC switch devices. The 03092 CS3 book has some limited discussion. The latest update may give more info. I have not seen it yet. In any case, LGB and Trix both used DCC switch addressing as native protocols prior to Märklin taking over. The CS3 thus supports DCC switch decoders just like it supports DCC loco decoders. DCC addressing actually allows you to control more devices, 2048 vice MM which is limited to 384. The DCC protocol and address is selected when you set up the device. I've not tried using the CS3 to modify DCC switch decoder settings yet. I've always used a Massoth decoder programmer to change DCC switch addresses from the default address. Now that you are asking I'll do some experimenting and let you know how it goes. In any case I'm using DCC addressing exclusively. I think both MM and DCC switch addressing can be used simultaneously from what the Märklin Dudes have said but can not confirm. I do have 4 new LGB mfx single channel switch decoders but found it simpler myself to set them for DCC only so I can determine their address rather than have one assigned by the CS3 when the decoder registers itself via mfx.
Phil S.
Offline Krish
#43 Posted : 18 August 2021 08:40:27(UTC)
Krish
India
Thank you Phils2um.
I am still exploring what to get. Should I decide on MD, then I will certainly need your help.
Krish
Offline phils2um
#44 Posted : 19 August 2021 04:23:17(UTC)
phils2um
Krish,
It is very easy to set up the CS3 to recognize and operate DCC switch protocol devices. You only need to add the device to your device list, change the protocol from MM to DCC and set the correct DCC address for the device. This works. The difficulty is making changes to a MD Electronics SWD decoder CV settings.
I did some experimenting today with my CS3 and a MD Electronics SWD decoder/servo point motor. I hooked the SWD to the prog track output of the CS3. What I was trying to do was change the DCC switch address using the configuration tab on the CS3. Despite many attempts I was not successful. The CS3 always came back with an error message and failed to read the SWD decoder's CV values.
I am able to write CV values using my Massoth decoder programming device. However, like the CS3, the Massoth programmer cannot read the SWD decoder CV values either. It returns meaningless numbers. I do not have a MD Electronics programming device which no doubt works fine modifying MD decoders just like the Massoth programmer works with Massoth decoders and the ESU LokProgrammer works with ESU decoders.
I'm pretty sure the inability of the CS3 and Massoth Programmer to read the MD decoder CVs is technical and related to not getting expected feedback after trying to access a CV.
For my purposes I change the MD decoder's address CV blindly using my Massoth programmer. The Massoth programmer will write to a DCC decoder's CVs without requiring feedback. I just can't verify the change by reading it back. To do this I first do a complete decoder reset by writing into MD decoder CV7 the value 16, then 11 and finally 33. 16 resets the programming lock if it was on. 11 resets the basic settings, and finally, 33 resets the function settings. This makes sure I'm starting from the known default CV settings. After resetting the decoder I enter my desired DCC switch address (the default address is 1) into decoder's switch address CVs, CV121 and, if necessary, CV120. (CV120 only needs to be changed for switch addresses 257-2048.) I then verify the decoder operation on the CS3. This is a cumbersome process but is workable for me with only a few CVs to change.
I had both the mfx(MM switch) protocol and DCC protocol enabled on my CS3 when I was testing today. I'm going to try again with CS3 set for DCC protocol only to see if it makes any difference with programming MD DCC switch decoders.
Lest you get lost in the above, what I'm trying to do is modify the MD servo decoder CV settings without using a separate programmer other than the CS3. You will need to be able to do this yourself if you want to avoid buying a separate programming device or finding someone to do the decoder programming for you. You will need change the decoder switch address CVs and also the servo endpoint CVs. This is true for both the MD decoders and also the ESU SwitchPilot servo decoder.
I do have an ESU LokProgrammer. I use ESU loco decoders in addition to Massoth DCC and Märklin mfx decoders on my garden RR. The LokProgrammer makes it very easy to modify any ESU decoder's CV settings.
One reason I'm emphasizing MD Electronics is because their DCC devices are about 1/2 to 2/3 the cost of ESU or Märklin equivalents. I'm actually using three different types of MD decoder devices and am very pleased with their performance so far.
Phil S.
Offline Krish
#45 Posted : 19 August 2021 06:04:22(UTC)
Krish
India
Hello Phils2um,
I was completely lost with all that you wrote Smile .
I think the ESU switchPilot option seems attractive to me.
What is CV ? ( don't laugh !)
I have a vague idea about device addresses. I think the manual will tell me how to add a device to the device list. And also to change the protocol.
The fact that I have many ( over a dozen) futaba servos, makes it attractive to go for ESU switchPilot.
Is there a facility ( on the "switchPilot 3" ) to change the address with a button or something like that ? How do I make it k83 compatible ? or is that automatic ?
Thank you for all the trouble you are taking to help me.
Krish
Offline phils2um
#46 Posted : 19 August 2021 07:35:35(UTC)
phils2um
No shame in ignorance! We all stated at zero! I suggest you start here:
https://en.wikipedia.org.../Digital_Command_Control
CV is short for Configuration Variable There are a number of these in every model railway digital decoder. The values stored in the CVs determine a decoder's behavior. Some CVs are standardized as to what they do. Others are used by each manufacturer modify the behavior of their particular decoders. Each manufacturer, Märklin, ESU, Lenz, Massoth, MD Electronics, etc. usually has a proprietary decoder programmer available to make changing the CVs on their decoders easy.
Most digital control central stations such as the CS3, can also do CV programming but it is often much more difficult and requires more hoops to jump through. Especially when the decoder is made by different firm.
I had not read the actual description of the SwitchPilot 3 Servo until now! It does seem the ideal solution for you. It can be completely set up without the need of a separate programming device. You may need to puzzle through the manual a bit. The digital model RR part is new to you but you clearly have a leg up on a lot of us with your knowledge and experience using servos.
The SwitchPilot 3 does not need to be k83 compatible. It needs to be compatible with the CS3. Which it is.
Phil S.
Guest (10)
LGB turnouts - Power routing? (Big scale)
by LA2019 18/12/2025 23:27:44(UTC)
Simple question about Rocrail, routes and turnouts (Model railroad software)
by SMC1957 06/11/2025 11:51:14(UTC)
C track turnouts working intermittently (Digital)
by Alex H 02/11/2025 10:27:47(UTC)
Trix Turnouts using Marklin 74462 Decoders (Digital)
by xxup 29/08/2025 06:34:34(UTC)
Märklin turnouts VS two rail turnouts expensive? (H0-scale)
by Goofy 14/07/2025 06:13:34(UTC)
How to clean old solenoid signals and turnouts (points) (General MRR)
by Aussie Susan 19/06/2025 07:44:46(UTC)
Clear and pure information about turnouts! (H0-scale)
by Goofy 30/03/2025 12:17:32(UTC)
Digitally operated turnouts / switches (Digital)
by osoraku 16/03/2025 16:52:36(UTC)
Digital equiped turnouts controlled digital or analog (Digital)
by Stefanio 26/02/2025 21:29:15(UTC)
1st Time Setting Up Marklin Turnouts (Model railroad wiring)
by Mtnbikr63 23/02/2025 00:56:54(UTC)
C track turnouts (General MRR)
by Giovanni Carboni 01/01/2025 18:08:16(UTC)
Train Stops on Märklin 24611 Turnouts – Need Help (H0-scale)
by ABM2020 25/12/2024 11:32:39(UTC)
Question about Marklin M-track 3600 switches (turnouts) (H0-scale)
by Howard1975 08/11/2024 16:55:31(UTC)
two turnouts to work together (Digital)
by Pabbi 15/09/2024 13:47:55(UTC)
Wire Marklin turnouts 8561 to Rokuhan RC-03 (Small scale)
by dmazyn 22/01/2024 16:47:19(UTC)
Use of M-turnout motors in C-turnouts (General MRR)
by gimo49 20/01/2024 12:27:07(UTC)
Problems with turnouts (H0-scale)
by Arnstein 11/12/2023 11:00:30(UTC)
C track curved turnouts - single track to four (H0-scale)
by einotuominen 31/10/2023 07:38:03(UTC)
Turnouts (General MRR)
by sudibarba 20/08/2023 04:09:21(UTC)
Marklin turnouts are not power-routing (General MRR)
by Yoginath 06/07/2023 14:26:26(UTC)
Wide turnouts (General MRR)
by river6109 29/06/2023 10:17:13(UTC)
m83 decoder wire length to turnouts (Digital)
by swisslocofan 27/05/2023 04:16:19(UTC)
Use AC HO Marklin turnouts with DC power supply? (H0-scale)
by Yigal 14/05/2023 07:41:52(UTC)
Pickup shoe short circuit Turnouts (24771/2)? (H0-scale)
by flyhalf 22/01/2023 20:55:12(UTC)
Märklin Wide Radius Turnouts geometry (H0-scale)
by Patrik 01/09/2022 14:32:38(UTC)
Marklin 3600 WB Remote Operated Turnouts (Collector's Corner general)
by mb300e4m 01/08/2022 21:55:58(UTC)
Rocrail and threeway K turnouts (Model railroad software)
Belarus pmgsr 17/05/2022 21:20:37(UTC)
Intermittent switching of turnouts (Digital)
by IBtrain 03/02/2022 06:34:02(UTC)
DCCNext and M turnouts (Model railroad wiring)
by IBtrain 14/01/2022 20:13:45(UTC)
Sticky turnouts (Digital)
by Rwill 12/06/2021 14:04:05(UTC)
MS2 Controlling Digital Turnouts in Analog Mode (General MRR)
by Joao Zilio 15/04/2021 19:29:53(UTC)
by Mr. Ron 07/03/2021 19:21:05(UTC)
Turnouts numbering (General MRR)
by Mr. Ron 01/03/2021 23:15:28(UTC)
7270 and C turnouts (H0-scale)
by carlos.rivas16752 13/02/2021 20:34:51(UTC)
Layout issues using a 6021 and 6001 with multiple Turnouts (Digital)
by waterslip 05/02/2021 03:38:34(UTC)
Long ICE cars rubbing turnouts semaphore m track (H0-scale)
by Victor Almeida 04/02/2021 02:56:37(UTC)
Peco turnouts code 100 (H0-scale)
by Harlov 18/12/2020 19:14:22(UTC)
M turnouts 5117, 5140, 5137 5202 for long coaches (H0-scale)
by 60904 25/11/2020 22:13:54(UTC)
Marklin Switches/turnouts/points - contact cleaning (Small scale)
by Poor Skeleton 17/10/2020 20:42:30(UTC)
2265 and 2266 turnouts and 75491 solenoid (H0-scale)
by Harvey 01/09/2020 20:12:41(UTC)
M track turnouts (H0-scale)
by Benders 16/08/2020 10:30:02(UTC)
Blue Transformers to Control Turnouts in Digital Ambient (Digital)
by Joao Zilio 28/05/2020 22:34:50(UTC)
Controlling 2 turnouts with 1 button (H0-scale)
by Brian_BR96 23/05/2020 02:16:48(UTC)
Marklin 88166/7 railbus and turnouts (Small scale)
by ajayrav 15/05/2020 17:18:55(UTC)
CS3 Track Diagram, Turnouts, etc (Digital)
by Twisterdodger 08/05/2020 16:52:08(UTC)
m83 - 2 turnouts with single address (Digital)
by bzzi 30/04/2020 01:23:00(UTC)
by JoeB 18/03/2020 01:56:33(UTC)
Marklin c track curves turnouts not reaching final position (H0-scale)
by Br01 26/02/2020 13:15:39(UTC)
Using a Transformer and 7210 Switches rather than Decoders on each turnouts. (H0-scale)
by Richard Joint 07/01/2020 03:33:52(UTC)
Inverted turnouts + random stop on locos (Digital)
by denis81 17/08/2019 23:16:30(UTC)
This page was generated in 1.151 seconds.
