Offline JoeB
#1 Posted : 18 March 2020 01:56:33(UTC)
JoeB
Is there a way to have multiple turnouts change at the same time. Basically I want to route my train to a certain path and instead of changing multiple turnouts individually I can change them with one click. I have the CS3.
Offline PMPeter
#2 Posted : 18 March 2020 03:17:38(UTC)
PMPeter
I have a CS2 and what you are describing is easily accomplished with the Memory screen. For every button on the screen(s) you can program the switch positions, signal positions, etc. for your desired route. When you push that button after it is programmed, it will sequence through the program list item by item and will indicate in green when the functions have all been carried out. The only caution is that you can only program a single device once. If for example you have a SW10 set to turnout, sequence through the whole route and then want to reset SW10 to straight, you will not have this SW10 in the turnout position when you start.
I assume the newer CS3 will have something similar.
Offline ktsolias
#3 Posted : 18 March 2020 09:06:13(UTC)
ktsolias
Of course you can do it with CS3.
Is very well documented in the CS3 manual page 15 and on
In General you can do "EVENTS" (scenarios) to include switches, signals, etc and you can activate them with a single button.
You can use the same solenoid item in many "events" etc
Is really very easy to program "events" and also you can edit them later
Costas
Offline rhfil
#4 Posted : 24 March 2020 14:31:14(UTC)
rhfil
Assuming that you have decoders and motors on them and some kind of control station that recognizes the decoders simply assign both decoders the same memory address.
Offline rbw993
#5 Posted : 24 March 2020 15:16:16(UTC)
rbw993
In olden times, for analogue control, I used to do it with diode matrixes. It is a lot easier with digital control stations and easier to modify if you add or remove a turnout.
Roger
#6 Posted : 25 March 2020 23:03:19(UTC)
It may be a "quick and dirty" solution. Later during operation one will find rapidly it is not convenient. Better using the memory feature on a divice like CS2, CS3, ECOS
LGB turnouts - Power routing? (Big scale)
by LA2019 18/12/2025 23:27:44(UTC)
Simple question about Rocrail, routes and turnouts (Model railroad software)
by SMC1957 06/11/2025 11:51:14(UTC)
C track turnouts working intermittently (Digital)
by Alex H 02/11/2025 10:27:47(UTC)
Trix Turnouts using Marklin 74462 Decoders (Digital)
by xxup 29/08/2025 06:34:34(UTC)
Märklin turnouts VS two rail turnouts expensive? (H0-scale)
by Goofy 14/07/2025 06:13:34(UTC)
How to clean old solenoid signals and turnouts (points) (General MRR)
by Aussie Susan 19/06/2025 07:44:46(UTC)
Clear and pure information about turnouts! (H0-scale)
by Goofy 30/03/2025 12:17:32(UTC)
Digitally operated turnouts / switches (Digital)
by osoraku 16/03/2025 16:52:36(UTC)
Digital equiped turnouts controlled digital or analog (Digital)
by Stefanio 26/02/2025 21:29:15(UTC)
1st Time Setting Up Marklin Turnouts (Model railroad wiring)
by Mtnbikr63 23/02/2025 00:56:54(UTC)
C track turnouts (General MRR)
by Giovanni Carboni 01/01/2025 18:08:16(UTC)
Train Stops on Märklin 24611 Turnouts – Need Help (H0-scale)
by ABM2020 25/12/2024 11:32:39(UTC)
Question about Marklin M-track 3600 switches (turnouts) (H0-scale)
by Howard1975 08/11/2024 16:55:31(UTC)
two turnouts to work together (Digital)
by Pabbi 15/09/2024 13:47:55(UTC)
Wire Marklin turnouts 8561 to Rokuhan RC-03 (Small scale)
by dmazyn 22/01/2024 16:47:19(UTC)
Use of M-turnout motors in C-turnouts (General MRR)
by gimo49 20/01/2024 12:27:07(UTC)
Problems with turnouts (H0-scale)
by Arnstein 11/12/2023 11:00:30(UTC)
C track curved turnouts - single track to four (H0-scale)
by einotuominen 31/10/2023 07:38:03(UTC)
Turnouts (General MRR)
by sudibarba 20/08/2023 04:09:21(UTC)
Marklin turnouts are not power-routing (General MRR)
by Yoginath 06/07/2023 14:26:26(UTC)
Wide turnouts (General MRR)
by river6109 29/06/2023 10:17:13(UTC)
m83 decoder wire length to turnouts (Digital)
by swisslocofan 27/05/2023 04:16:19(UTC)
Use AC HO Marklin turnouts with DC power supply? (H0-scale)
by Yigal 14/05/2023 07:41:52(UTC)
Pickup shoe short circuit Turnouts (24771/2)? (H0-scale)
by flyhalf 22/01/2023 20:55:12(UTC)
Märklin Wide Radius Turnouts geometry (H0-scale)
by Patrik 01/09/2022 14:32:38(UTC)
Marklin 3600 WB Remote Operated Turnouts (Collector's Corner general)
by mb300e4m 01/08/2022 21:55:58(UTC)
Rocrail and threeway K turnouts (Model railroad software)
by pmgsr 17/05/2022 21:20:37(UTC)
Intermittent switching of turnouts (Digital)
by IBtrain 03/02/2022 06:34:02(UTC)
DCCNext and M turnouts (Model railroad wiring)
by IBtrain 14/01/2022 20:13:45(UTC)
turnouts (Big scale)
by Krish 13/08/2021 08:05:39(UTC)
Sticky turnouts (Digital)
by Rwill 12/06/2021 14:04:05(UTC)
MS2 Controlling Digital Turnouts in Analog Mode (General MRR)
by Joao Zilio 15/04/2021 19:29:53(UTC)
by Mr. Ron 07/03/2021 19:21:05(UTC)
Turnouts numbering (General MRR)
by Mr. Ron 01/03/2021 23:15:28(UTC)
7270 and C turnouts (H0-scale)
by carlos.rivas16752 13/02/2021 20:34:51(UTC)
Layout issues using a 6021 and 6001 with multiple Turnouts (Digital)
by waterslip 05/02/2021 03:38:34(UTC)
Long ICE cars rubbing turnouts semaphore m track (H0-scale)
by Victor Almeida 04/02/2021 02:56:37(UTC)
Peco turnouts code 100 (H0-scale)
by Harlov 18/12/2020 19:14:22(UTC)
M turnouts 5117, 5140, 5137 5202 for long coaches (H0-scale)
by 60904 25/11/2020 22:13:54(UTC)
Marklin Switches/turnouts/points - contact cleaning (Small scale)
by Poor Skeleton 17/10/2020 20:42:30(UTC)
2265 and 2266 turnouts and 75491 solenoid (H0-scale)
by Harvey 01/09/2020 20:12:41(UTC)
M track turnouts (H0-scale)
by Benders 16/08/2020 10:30:02(UTC)
Blue Transformers to Control Turnouts in Digital Ambient (Digital)
by Joao Zilio 28/05/2020 22:34:50(UTC)
Controlling 2 turnouts with 1 button (H0-scale)
by Brian_BR96 23/05/2020 02:16:48(UTC)
Marklin 88166/7 railbus and turnouts (Small scale)
by ajayrav 15/05/2020 17:18:55(UTC)
CS3 Track Diagram, Turnouts, etc (Digital)
by Twisterdodger 08/05/2020 16:52:08(UTC)
m83 - 2 turnouts with single address (Digital)
by bzzi 30/04/2020 01:23:00(UTC)
Marklin c track curves turnouts not reaching final position (H0-scale)
by Br01 26/02/2020 13:15:39(UTC)
Using a Transformer and 7210 Switches rather than Decoders on each turnouts. (H0-scale)
by Richard Joint 07/01/2020 03:33:52(UTC)
Inverted turnouts + random stop on locos (Digital)
by denis81 17/08/2019 23:16:30(UTC)
This page was generated in 0.268 seconds.
