Offline morsing
#1 Posted : 25 October 2019 15:44:45(UTC)
morsing
What do people do with regards to clips for holding underboard wires and also how do you label wires? (Do you label them?)
Marklin C-track + CS3+
Offline Gregor
#2 Posted : 25 October 2019 16:55:50(UTC)
Gregor
I use a staple gun on low power setting to avoid piercing the insulation.
I don't label the wires, just the relevant connection points
Gregor
thanks 1 user liked this useful post by Gregor
Offline TEEWolf
#3 Posted : 25 October 2019 16:55:57(UTC)
40, 50 years ago we used cramps to connect the cables to the wooden plate. Today are easier fixing systems available.
Of course you should label all your cables and never forget to keep in line with the defined cable colours of Maerklin. Makes life easier searching faults in the electric.
https://www.maerklin.de/.../MM_Verkabelung_2013.pdf
usage of the Maerklin colour scheme
https://www.maerklin.de/...faq/Technik-Tipp-102.pdf
Even you do not speak German, you understand the pictures and cabling plans in the articles too.
#4 Posted : 25 October 2019 17:24:10(UTC)
I typically do not label the wires. They are color coded, and I mark where the boundaries are between booster sections.
Each S88 module is numbered so I see no point of labeling the wire plugged into port 5 of s88 module 4. It can only be s88 #53 (4-1)*16 + 5
I do give a letter to each big bundle of s88 sensor wires.
Similarly k83 wires come from a numbered port on a k83 module, either red or green.
I like to have some slack in the wires so that whatever they are connected to can be lifted if needed, and that gets in the way of neat clipping into place, so the end points do look a bit jumbled.
#5 Posted : 25 October 2019 22:33:39(UTC)
Some of the module builders I've watched use dabs of hot-glue to attache and route the wires under the layout bottoms. Others use the affordable book spine combs as conduit, others still use proper electrical conduit channels with lids, eg for areas exposed visibly.
For labeling color code on wires is a key first step. Then you can use a black marker to add lines/ticks to differentiate different wires in a same color bundle, or use tape labels or shrink tube printed with labels.
Like many things in life, what you do depends in part on what you are willing to spend, what you get some enjoyment out of doing generally, how much in life you have had to debug a wiring system and the mark it left on you....
#6 Posted : 26 October 2019 09:09:10(UTC)
I use copper wires at 0,75 mm square for the digital system while analog i use between 0,14-0,25 mm square.
Of course with difference color too.
There is a lot of variation to connect the wires.
With the digital i use clips to feed digital system by split it.
Offline morsing
#7 Posted : 28 October 2019 09:10:09(UTC)
morsing
Ok, thanks.
Colour coded wires are out the door. I have randomised green/red/blue/brown wires on all the tracks and it's too late to change now.
Stapling, yeah, just not easy if you want to move or replace cables. Hot glue, my experience is it's very weak and the wires will probably fall off.
Hmm... I will have a think.
I've spent most of my life debugging wiring on my old cars, so that part doesn't scare me.
Thank
thanks 1 user liked this useful post by morsing
Offline Danlake
#8 Posted : 28 October 2019 10:27:00(UTC)
Danlake
If you are using a wooden frame work for your baseboard you can simply drill holes through the horizontal frames for the wire bus.
For my s88 feedback cables, lots of them, i have bought cable trunks with self adhesive tape that runs underneath the base board.
I also uses these types of cable clips:
https://www.amazon.co.uk...ent-Holder/dp/B01MTYRVKQ
I don’t see any need for labelling the wires itself. The main labelling is on the individual decoders (K83/84).
Best Regards
Lasse
Offline PMPeter
#9 Posted : 28 October 2019 14:52:59(UTC)
PMPeter
I use eye screws spaced at regular intervals and usually have a column of 5 so that each screw holds the different purpose wiring - 1 for power red, 1 for return/ground brown, 1 for yellow lighting, 1 for grey sensor feedback, and 1 for solenoid and signal accessories.
thanks 2 users liked this useful post by PMPeter
Offline applor
#10 Posted : 30 October 2019 00:18:15(UTC)
applor
krone jumper rings
https://wbnetworks.com.a...120e257/5/3/53700133.jpg
I use stripped cat5 cable for my S88 wiring, gives 8 different colours which makes finding the right wire easy enough.
Standardised/universal colours for power bus and for lighting bus.
thanks 3 users liked this useful post by applor
#11 Posted : 30 October 2019 03:09:28(UTC)
same here...
Step by step stages, with pictures, of s88 wiring using bundled cable at
https://cabin-layout.mixmox.com/2014/08/s88-cable.html
#12 Posted : 30 October 2019 11:57:30(UTC)
My wiring is certainly not a model but rather a living thing. I keep on adding things and improvements.BigGrin
I use long staples (for roof insulation) with an electric stapler. Staples are not inserted with full strength that way it gives a nice loop to have wires through them allowing later additions and changes.
Because I still have some flat cable for S88 (6088 and 60880) it is kept away from other cables to avoid perturbing signals
As said before color coding is important (I mean observing Märklin color codes) and adding new colors for specific purposes (LED lighting, DC for Car System, etc). I get most colors from a flat multicolor cable.
Digital power (5 Amps) is distributed through 2.5 mm² cables (for loudspeakers) and then feeders (approx. .75 mm² distribute power to rail sections.
At present I have made a mistake of mixing the wiring of rail and decoders so I need to change this.
I have added LED lights for warning (e.g.: Car System Stop solenoid activation, car System "Rollende Landstrasse" release coils) and thermal components in series with solenoids (they switch off solenoids when temperature is above 70°C and below have a resistor of a fraction of ohm.
Other LEDs are there for signalling logic (e.g.: detection of truck that mut go a different route).
#13 Posted : 13 November 2019 00:16:30(UTC)
Personally, I'm really drawn to these plastic clips which hold the wires in neat tidy parallel runs, and remind me very much of the method used by M. for their factory built layouts - you can always tell one by this method.
What I'd like to know is how many different manufacturers make clips of this type and whether anyone has found any that are really good value on the likes of AliExpress etc?
This deal offered here might actually be quite good, works out at about $25 - $30 NZD or about $1 per strip but i really like them.
Seems to me they would be cheap to produce and real easy to fit and work with.
Just wondering also who else might have used or tried them out and how they perform?
https://www.ebay.com/itm...Railway-H1-/332477559886
Image added below also for when the auction expires
I found these also.....
http://www.modellbahn-al...-holder-25-slots-10-pcs, same seller has packs of 25, 50 & 100 and seems to work out between .40 - .50 Eurocents per strip
And a couple of other sellers but I can't tell who the actual manufacturer of these is. It's the sort of thing you might expect from Noch or Brawa, Viessman etc?
I found more similar items from further searching including Noch item 60160, but in yellow, perhaps they also make the clear ones?
Auction Image 25 pcs
Detail image
Noch 60160
Viessmann 6809
SCHNEIDER 5120 BY FAR THE BEST DEAL - around .11 Eurocents each !! but that may come at a trade-off in quality - anyone used them? I'm not sure that they are as flexible as the others and not as wide as some of the others
http://schneider-feinwer...e/Kabelhalter-100-Stueck
Is it a problem ? Wiring the "B" and "O" the wrong way around (Digital)
by Johnvr 21/06/2025 11:36:09(UTC)
Digital wiring - (Digital)
by Twinrover1965 09/01/2025 13:50:02(UTC)
What is the Purple Wire in Marklin Digital Wiring? (Accessory decoder) (Digital)
by 5HorizonsRR 07/12/2024 02:50:00(UTC)
Marklin 3013.1, SEH 800 Wiring Image Or Photo Request (Model railroad wiring)
by Roman 05/12/2024 06:17:18(UTC)
Track End Bumper with LED Wiring (H0-scale)
by Ace Wickwire 17/11/2024 03:21:15(UTC)
Wiring a model railroad (General MRR)
by Mr. Ron 27/10/2024 04:50:51(UTC)
BR55 37550 wiring question? (Digital)
by LA2019 27/08/2024 21:25:17(UTC)
Info on wiring Viessman coach lighting decoder 5077 (Digital)
by fabstar68 20/08/2024 19:30:02(UTC)
Digital wiring (Digital)
by Mjn2ts 09/04/2024 00:45:26(UTC)
Wiring 3 way turnout - 24630 (H0-scale)
by Alex H 14/01/2024 14:28:17(UTC)
Semaphore signal 89403 wiring (Model railroad wiring)
by MikeEK 19/11/2023 10:30:18(UTC)
Wiring problems (H0-scale)
by Allan2805 13/11/2023 01:49:46(UTC)
Point motor wiring help needed (General MRR)
by Model Railway shed D 07/11/2023 15:39:34(UTC)
Hiding wiring (H0-scale)
by Mr. Ron 01/10/2023 00:38:47(UTC)
Marklin wiring manual (Digital)
by Jay 23/09/2023 19:31:43(UTC)
Ideas for wiring of turnout lighting and lighting in general (General MRR)
by Luna 23/09/2023 01:07:47(UTC)
3071 Wiring (H0-scale)
by kpallund 05/09/2023 16:38:56(UTC)
Wiring two levels (Digital)
by Mille 05/09/2023 08:08:37(UTC)
Wiring a new layout (Digital)
by Alex H 26/08/2023 11:58:17(UTC)
m track switch wiring question (H0-scale)
by heinrichhess 24/08/2023 12:04:59(UTC)
Marklin 7192/7193 Wiring Problem?? (H0-scale)
by OMAC 05/03/2023 09:07:03(UTC)
C track wiring for DCC (H0-scale)
by Alex H 24/01/2023 21:35:17(UTC)
Switch wiring (Model railroad wiring)
by Norton1972 18/01/2023 00:00:43(UTC)
Wiring Joystick to Marklin 7051 (General MRR)
by mjborelli 31/12/2022 19:01:44(UTC)
Request Help with Wiring Joystick to Marklin 7051 Crane (General MRR)
by mjborelli 26/12/2022 01:42:54(UTC)
Wiring up Hobby signals without decoder or 72751 box. (H0-scale)
by Kaspar 24/11/2022 15:30:49(UTC)
Z scale 8589 wiring instructions (Model railroad wiring)
by hennabm 18/09/2022 14:54:35(UTC)
Wiring a 60975 (Digital)
by Keyser 16/07/2022 20:16:39(UTC)
Wiring instruction books? (General MRR)
by Rarpos 12/06/2022 05:46:17(UTC)
Requirements and wiring for 'cosmetic only' signals (Model railroad software)
by luckas 10/06/2022 17:06:17(UTC)
New to digital conversion- seeking guidance on wiring (Digital)
by BurritoJoe 10/06/2022 04:44:16(UTC)
3631 Diesel - Decoder chip wiring (Digital)
by Willem99 27/01/2022 21:21:25(UTC)
Wiring for shuttle trains. (Model railroad wiring)
by IBtrain 22/11/2021 20:46:29(UTC)
Wiring my layout for future booster (Model railroad wiring)
by IBtrain 22/11/2021 20:23:43(UTC)
3663 Alaska Set Wiring Connections (H0-scale)
by mb300e4m 17/10/2021 01:10:08(UTC)
Woodland Scenic's just plug wiring (Model railroad wiring)
by tinroofrusted 10/10/2021 03:45:46(UTC)
Buss wiring (H0-scale)
by Mr. Ron 08/09/2021 03:11:11(UTC)
Wiring (General MRR)
by joyofmarklin 07/08/2021 23:52:18(UTC)
How to route wiring (General MRR)
by Mr. Ron 01/08/2021 23:45:13(UTC)
Marklin c-track wiring for z21 (Model railroad wiring)
by Lusito 22/04/2021 15:05:16(UTC)
Layout wiring (General MRR)
by Mr. Ron 05/03/2021 19:34:46(UTC)
Help with Wiring (Small scale)
by Ricinport 26/02/2021 11:16:10(UTC)
Wiring micro SMDs (Model railroad wiring)
by morsing 02/02/2021 06:47:36(UTC)
Marklin 1 Gauge 66020 Decoder wiring (Digital)
by hennebror 31/01/2021 20:01:47(UTC)
Wiring 7209/72090 Distributor Strips to Marklin AC Transformer (General MRR)
by mjborelli 18/01/2021 00:24:06(UTC)
layout wiring options (Model railroad wiring)
by biswasg 13/01/2021 21:46:39(UTC)
wiring diagram for a Marklin layout (Model railroad wiring)
by biswasg 06/01/2021 21:34:10(UTC)
Wiring (Model railroad wiring)
by flyboyaviator 01/01/2021 21:09:45(UTC)
Märklin G1 locomotive 55900 decoder wiring (Big scale)
by prba4650 19/12/2020 09:56:47(UTC)
Help with Wiring (General MRR)
by Drongo 10/12/2020 04:42:40(UTC)
This page was generated in 0.602 seconds.
