Offline flyboyaviator
#1 Posted : 01 January 2021 21:09:45(UTC)
flyboyaviator
Just purchase a vintage Marklin Model #2975, unfortunately it came with wiring. Is an HO the analog transformer is a 10VA with 3 holes yellow, red and brown I think. Can some one help me find replacement place that can supply these items. I want to give this to my grandson.s. Thanking you for any help you can redner
Offline PMPeter
#2 Posted : 02 January 2021 00:03:10(UTC)
PMPeter
I assume you mean it came without wiring. However, are you saying that you opened up the transformer and there is no internal wiring to the yellow, brown and red terminal posts or are you asking what external wiring needs to be added to power the track? I assume you mean the external wiring, but since you are asking for replacement wiring to supply the terminals, it is better to ask what you mean.
#3 Posted : 02 January 2021 01:12:47(UTC)
flyboyaviator
the wiring that is needed to connect the transformer to the track.
Offline phils2um
#4 Posted : 02 January 2021 09:31:51(UTC)
phils2um
red and brown connect to the track. The ac voltage (train speed) is controlled by the knob. Actually brown is a common ground on these old transformers. Yellow and brown are fixed ac voltage of about 15V. It is used for lights and to power accessories like switches, signals, uncoupler tracks, etc. through the appropriate control box(s).
Phil S.
#5 Posted : 02 January 2021 10:45:01(UTC)
One of the straight tracks should contain a red and a brown wire soldered to it. Check the contents again...
The brown wire goes to the metal trackbed/ballast.
The red goes to the centerstrip of pukos.
The yellow connector is not used in this case.
Normally you can do these connections yourself, but if it is a gift to a child, you might want to get replacement items #5111, #5131, #5103.
Either should be fairly easy to come by..
#6 Posted : 02 January 2021 16:24:47(UTC)
flyboyaviator
Thanks PMpeter, Phils2um, hxmeisa for your help,I'll getting busy trying to buys these parts, thank you very much, Happy New Year.
Offline PMPeter
#7 Posted : 02 January 2021 17:35:27(UTC)
PMPeter
Please note that you only need one of those feeder tracks recommended, not all 3. Also if you ever plan on going digital you would not want the feeder track 5131 because you would need to cut out the supplied capacitor.
Also if you have a good soldering iron and soldering skills you could always make your own feeder track. Since you live in California you should have access to a Frys electronics store and could obtain a small pack of #22AWG stranded red and stranded brown (or black if brown is not available) wire, solder the red underneath a piece of track to the centre rail and the brown (or black) to the outer rail metal. (assuming you have M track, not K or C) The other end then is connected to the corresponding red and brown terminals of your transformer.
#8 Posted : 02 January 2021 18:06:55(UTC)
flyboyaviator
Thanks PMPeter, I should clarify that the Hollywood I live is in Florida, one more question , the tracks don't seem to have any attachment points for the wires.
Offline PMPeter
#9 Posted : 02 January 2021 18:59:29(UTC)
PMPeter
Oh. Nice place and good hamburgers at "Le Tub"!
No you don't have a Frys in Florida as far as I know, but you should have other electronics stores that sell small gauge wire. Radio Shack perhaps.
Assuming you are talking about the all metal M track, then no there are no connection points. You just have to solder the brown wire to any part of the metal except for the black centre rail. For the centre rail you can solder the red to any part of it or at the centre connector at either end.
#10 Posted : 02 January 2021 19:12:16(UTC)
Yes, it is like PMPeter says; You only need ONE feeder track for this start set.
The soldering can easily be done by yourself, though. Like this;
https://images.hattons.co.uk/products/5111-U_3222069_Qty1_2.jpg
#11 Posted : 02 January 2021 19:14:12(UTC)
flyboyaviator
Thanks for all that info, I do have a welding rod and going to try that way, thanks.
Offline PMPeter
#12 Posted : 03 January 2021 01:53:21(UTC)
PMPeter
I certainly hope by welding rod you mean soldering iron. An actual welding rod hooked to a welding machine would destroy your piece of track and the wire you are trying to attach.
#13 Posted : 03 January 2021 14:36:41(UTC)
flyboyaviator
Soldering Iron is what I meant.
jmri, minimal wiring and block detection (Digital)
by nite 10/10/2025 15:09:26(UTC)
Wiring Diagram/Schematic For the New BR 24 aka 36240/41/42/43 (H0-scale)
by 5HorizonsRR 19/07/2025 19:25:40(UTC)
Wire gauge Crocodile wiring inside (Small scale)
by Chas 04/07/2025 19:17:37(UTC)
Is it a problem ? Wiring the "B" and "O" the wrong way around (Digital)
by Johnvr 21/06/2025 11:36:09(UTC)
Digital wiring - (Digital)
by Twinrover1965 09/01/2025 13:50:02(UTC)
What is the Purple Wire in Marklin Digital Wiring? (Accessory decoder) (Digital)
by 5HorizonsRR 07/12/2024 02:50:00(UTC)
Marklin 3013.1, SEH 800 Wiring Image Or Photo Request (Model railroad wiring)
Belarus Roman 05/12/2024 06:17:18(UTC)
Track End Bumper with LED Wiring (H0-scale)
by Ace Wickwire 17/11/2024 03:21:15(UTC)
Wiring a model railroad (General MRR)
by Mr. Ron 27/10/2024 04:50:51(UTC)
BR55 37550 wiring question? (Digital)
by LA2019 27/08/2024 21:25:17(UTC)
Info on wiring Viessman coach lighting decoder 5077 (Digital)
by fabstar68 20/08/2024 19:30:02(UTC)
Digital wiring (Digital)
by Mjn2ts 09/04/2024 00:45:26(UTC)
Wiring 3 way turnout - 24630 (H0-scale)
by Alex H 14/01/2024 14:28:17(UTC)
Semaphore signal 89403 wiring (Model railroad wiring)
by MikeEK 19/11/2023 10:30:18(UTC)
Wiring problems (H0-scale)
by Allan2805 13/11/2023 01:49:46(UTC)
Point motor wiring help needed (General MRR)
by Model Railway shed D 07/11/2023 15:39:34(UTC)
Hiding wiring (H0-scale)
by Mr. Ron 01/10/2023 00:38:47(UTC)
Marklin wiring manual (Digital)
by Jay 23/09/2023 19:31:43(UTC)
Ideas for wiring of turnout lighting and lighting in general (General MRR)
by Luna 23/09/2023 01:07:47(UTC)
3071 Wiring (H0-scale)
by kpallund 05/09/2023 16:38:56(UTC)
Wiring two levels (Digital)
by Mille 05/09/2023 08:08:37(UTC)
Wiring a new layout (Digital)
by Alex H 26/08/2023 11:58:17(UTC)
m track switch wiring question (H0-scale)
by heinrichhess 24/08/2023 12:04:59(UTC)
Marklin 7192/7193 Wiring Problem?? (H0-scale)
Belarus OMAC 05/03/2023 09:07:03(UTC)
C track wiring for DCC (H0-scale)
by Alex H 24/01/2023 21:35:17(UTC)
Switch wiring (Model railroad wiring)
by Norton1972 18/01/2023 00:00:43(UTC)
Wiring Joystick to Marklin 7051 (General MRR)
by mjborelli 31/12/2022 19:01:44(UTC)
Request Help with Wiring Joystick to Marklin 7051 Crane (General MRR)
by mjborelli 26/12/2022 01:42:54(UTC)
Wiring up Hobby signals without decoder or 72751 box. (H0-scale)
by Kaspar 24/11/2022 15:30:49(UTC)
Z scale 8589 wiring instructions (Model railroad wiring)
by hennabm 18/09/2022 14:54:35(UTC)
Wiring a 60975 (Digital)
by Keyser 16/07/2022 20:16:39(UTC)
Wiring instruction books? (General MRR)
by Rarpos 12/06/2022 05:46:17(UTC)
Requirements and wiring for 'cosmetic only' signals (Model railroad software)
by luckas 10/06/2022 17:06:17(UTC)
New to digital conversion- seeking guidance on wiring (Digital)
by BurritoJoe 10/06/2022 04:44:16(UTC)
3631 Diesel - Decoder chip wiring (Digital)
by Willem99 27/01/2022 21:21:25(UTC)
Wiring for shuttle trains. (Model railroad wiring)
by IBtrain 22/11/2021 20:46:29(UTC)
Wiring my layout for future booster (Model railroad wiring)
by IBtrain 22/11/2021 20:23:43(UTC)
3663 Alaska Set Wiring Connections (H0-scale)
by mb300e4m 17/10/2021 01:10:08(UTC)
Woodland Scenic's just plug wiring (Model railroad wiring)
by tinroofrusted 10/10/2021 03:45:46(UTC)
Buss wiring (H0-scale)
by Mr. Ron 08/09/2021 03:11:11(UTC)
Wiring (General MRR)
by joyofmarklin 07/08/2021 23:52:18(UTC)
How to route wiring (General MRR)
by Mr. Ron 01/08/2021 23:45:13(UTC)
Marklin c-track wiring for z21 (Model railroad wiring)
by Lusito 22/04/2021 15:05:16(UTC)
Layout wiring (General MRR)
by Mr. Ron 05/03/2021 19:34:46(UTC)
Help with Wiring (Small scale)
by Ricinport 26/02/2021 11:16:10(UTC)
Wiring micro SMDs (Model railroad wiring)
by morsing 02/02/2021 06:47:36(UTC)
Marklin 1 Gauge 66020 Decoder wiring (Digital)
by hennebror 31/01/2021 20:01:47(UTC)
Wiring 7209/72090 Distributor Strips to Marklin AC Transformer (General MRR)
by mjborelli 18/01/2021 00:24:06(UTC)
layout wiring options (Model railroad wiring)
by biswasg 13/01/2021 21:46:39(UTC)
wiring diagram for a Marklin layout (Model railroad wiring)
by biswasg 06/01/2021 21:34:10(UTC)
This page was generated in 0.548 seconds.
