Offline kevwill
#1 Posted : 25 August 2016 12:41:26(UTC)
kevwill
I started collecting Marklin in around 2004/5. I have ten locomotives most of which have the very old fx decoder. I do have some mfx decoder locos as well.
Well due to a bad accident any plans to start my layout had to be put on hold. I now have recovered ,built my train hut in the garden and have the time to restart my layout, but obviously have dated stock nearly all that are still boxed never used.
I know these types of questions have been asked many times but could someone advise me on the following points
is it possible to update my locos to the newest decoders,
is it fairly easy to do if I can,
and if not do any of you know where I could send them to if its too complicated for the average user to do.
I live in the UK and I would really appreciate any guidance given
My wife, children, and all my friends, think as i'm into Model trains, i'm very boring and should grow up. NEVER NEVER!!!
#2 Posted : 25 August 2016 12:55:40(UTC)
If you know how to solder and have the equipment, and understand DC electrical theory, then you should be okay. The instructions from ESU are pretty good and my guess is that the instructions for the Marklin ones are just as good.
The thing about installing decoders is that you really need to make sure that the running gear is working perfectly before you start any upgrade work. Any tightness of the drivetrain will cause the decoder to overheat and destroy itself.
With the ESU decoders, you need an eCOS or a Lokprogrammer, while the latest Marklin decoders use a neat tool that hangs off a USB port.
Do some searching on this forum - there are lots of posts about decoder conversions.
Offline kevwill
#3 Posted : 25 August 2016 14:24:39(UTC)
kevwill
Thanks Adrian, I know how to solder so I will start converting them one at a time.
I'll have a good nosey on the forum for tips etc ,I just wanted to know it's possible and financially viable, the locos are very sentimental so I'll clean the running gear and re oil once I've found a tip on here how to do it properly.
Thanks again
#4 Posted : 25 August 2016 14:53:18(UTC)
Hi Kev,
Perhaps you need to ask yourself whether you actually need to replace the decoders? Decoders from 2004 onwards will probably have load regulation, acceleration and braking delay, etc and the performance will not be very different to current decoders.
Of course if you want to add sound functions to a loco that originally had no sound that is a different matter, but otherwise I would not bother.
More importantly I would think you should upgrade your controller, as that is more likely to have fallen behind current products. What controller are you using?
#5 Posted : 25 August 2016 15:20:09(UTC)
I agree with Ray,fx decoders are perfect,you have no need to replace them,it is a mistake to throw away your money.Keep the locomotives original and buy new when it is possible with mfx decoders.Update of controllers is a perfect idea too.Consider twice before you decide.BigGrin
Offline kevwill
#6 Posted : 25 August 2016 15:53:57(UTC)
kevwill
Thanks again
Thanks for your advice Ray and foumaro, I have just completed the train hut after getting planning permission from the wife. It's been up a couple of months and been painted inside and out and the electrics just gone in.The pictures above show the hut after I had reclaimed some land fron the existing flower garden in the negotiations . It's 5x3.5 metres.
Luckily I never bought a main controller but I was bought two handheld controllers in one of my main starter sets, I plan to buy a main controller when I've finished.
If you think the old decoders are good enough I will wait and see if I like them when the set comes to life, I do like the thought of having sound though.
Thanks again
thanks 2 users liked this useful post by kevwill
LS Modèles - Advice (H0-scale)
by Eddie7979 20/01/2024 11:53:01(UTC)
c-track geometry advice needed for my layout (H0-scale)
by fabstar68 08/01/2024 23:41:10(UTC)
Roco 7520006 Dm3 series advice (H0-scale)
by Puttputtmaru 08/01/2024 19:40:25(UTC)
Marklin my world 29340 debug and repair advice (Digital)
by NoOne 26/08/2023 06:39:36(UTC)
Advice/tip regarding event setup (Digital)
by geir 07/04/2023 14:02:01(UTC)
Advice needed for Marklin 7286 Turntable (H0-scale)
by marklin61 20/07/2022 00:48:22(UTC)
Replacing connecting rods - any advice (H0-scale)
by Rob11966 24/06/2022 14:10:27(UTC)
Please advice me to fix 28.2cm car (General MRR)
by Moto 15/01/2022 15:04:59(UTC)
Tunnel portal advice requested (General MRR)
by mountainroads 28/11/2021 06:17:26(UTC)
Can use advice (H0-scale)
by DasBert33 21/11/2021 15:01:15(UTC)
Newbie Advice (H0-scale)
by KyleGamble 05/06/2021 11:57:34(UTC)
Need advice for controller use (Track plans)
by wildstix 26/05/2021 11:10:26(UTC)
Newby to HO wants some advice please (H0-scale)
by Alex H 21/02/2021 14:57:40(UTC)
Consist advice (H0-scale)
by Timnomads 16/02/2021 09:28:25(UTC)
Advice on this collection? (Collector's Corner general)
by jeffw9 09/02/2021 19:44:01(UTC)
6647/6648 HO Transformer advice (Digital)
by ShannonN 14/12/2020 08:54:34(UTC)
I just put together my 25 year old track, and looking for advices (H0-scale)
by KyneSilverhide 11/08/2020 16:44:52(UTC)
Rules / advice for creating "blocks" (Digital)
by Ewillis 26/06/2020 05:04:16(UTC)
Aux/FX Light Grounding a HAG w/Lokpilot 2.0, Advice Needed (Digital)
by 5HorizonsRR 05/04/2020 21:04:12(UTC)
European parcel van trains advice wanted (H0-scale)
by danmarklinman 18/03/2020 23:38:40(UTC)
I need advice with Märklin E115737 current conducting close couplers NEM 72020 / 72021 (H0-scale)
by Janne75 06/02/2020 22:55:18(UTC)
Advice for short coaches (H0-scale)
by LongHairedDavid 30/12/2019 13:04:33(UTC)
LGB/Marklin 55029 advice please (Digital)
by gcanton 26/11/2019 12:01:09(UTC)
Advice sought for digital conversion / upgrading (Digital)
by Martti Mäntylä 24/10/2019 16:32:18(UTC)
Wheel Quartering advice (Small scale)
by Poor Skeleton 16/07/2019 22:08:23(UTC)
advice needed = connecting MS2 to peco 2 rail track for DCC operation (Digital)
by ShannonN 05/06/2019 13:21:09(UTC)
Advice on this Lok (H0-scale)
by LongHairedDavid 01/04/2019 15:13:21(UTC)
What decoder - advice please (Digital)
by Philh58 02/02/2019 01:09:45(UTC)
Advice on Passenger Coaches (H0-scale)
by LongHairedDavid 27/01/2019 21:17:14(UTC)
Advice needed with poor speed! (H0-scale)
by Br502362 28/12/2018 18:28:19(UTC)
Help / Advice needed with start up kit (H0-scale)
by LocoNewbie 25/12/2018 15:18:06(UTC)
Advice need on intended new purchase of steam Loco with smoke etc (H0-scale)
by ShannonN 18/12/2018 09:40:36(UTC)
I need advice and help with Scarm (Model railroad software)
by ShannonN 20/10/2018 05:38:02(UTC)
Help/Advice needed for restoration (Steam engines)
by johnmarklin 02/10/2018 20:02:47(UTC)
Looking for advice on what decoder to use for these 3 locos (Digital)
by Russell423 21/05/2018 03:17:52(UTC)
Advice on converting a 1955 TT800 to digital (Digital)
by johnpatrickwack 31/03/2018 01:16:47(UTC)
Another DC-AC Conversion in Need of Advice: Rivarossi SBB Ae 3/5 Electric (Digital)
by 5HorizonsRR 26/03/2018 15:50:55(UTC)
Ready to dive into software control - any last advice? (Digital)
by johnpatrickwack 07/02/2018 17:14:02(UTC)
Insurance for my trains-Advice/Thoughts? (General MRR)
by analogmike 03/10/2017 12:58:59(UTC)
Help/advice how to Replace / Convert Marklin BR24 (3003) Delta (Digital)
by itzik 05/09/2017 10:16:11(UTC)
S88 advice (Digital)
by Harvey 19/06/2017 03:19:10(UTC)
USA centric advice needed - glues and paints for kits (Model kits & layout details, kitbashing and such)
by Minok 13/12/2016 22:17:01(UTC)
Technical advice required! (H0-scale)
by Ramprasad S.V.R. 04/12/2016 14:37:03(UTC)
New CS3 General Advice (Digital)
by garben 28/11/2016 21:41:51(UTC)
Heat Issues on Crocodile decoder from 31100 Loco set- Advice? (Digital)
by 5HorizonsRR 12/09/2016 17:35:16(UTC)
Looking for advice about passenger cars (H0-scale)
by Chris Dunn 20/06/2016 02:13:57(UTC)
C track advice (H0-scale)
by Rwill 15/06/2016 13:48:41(UTC)
Help required with some advice on simple soldering technique (General MRR)
by Ausipeet 30/03/2016 23:55:44(UTC)
5140 turnout advice (H0-scale)
by thomas buckley 11/03/2016 20:45:31(UTC)
Glue advice (Model kits & layout details, kitbashing and such)
by Timnomads 24/11/2015 12:37:45(UTC)
This page was generated in 0.403 seconds.
