Offline joyofmarklin
#1 Posted : 07 August 2021 23:52:18(UTC)
joyofmarklin
I have completed my first stage of my layout, which has 12 turnouts and 4 signals. However the wiring looks like “a dogs dinner!” So it is time to tidy it up and take the wiring underneath. Tried to search, as sure this has been covered before? So should I drill holes and have the connectors underneath (seems tidier) or do I have the connections on the surface to make removal easier?
Thinking of using stick on clips underneath and mounting the block connectors on the wooden supports.
Also need to get much more wires to make them uniform?
Advice on best practice as am hesitant on starting?
Many thanks
Online David Dewar
#2 Posted : 07 August 2021 23:56:36(UTC)
At my age I ensure that wiring is easy to get at and at the same time not easily seen. Crawling about under a layout is not always a great idea.
Connectors etc can be placed under buildings and wire covered with scatter material.
Offline applor
#3 Posted : 08 August 2021 02:22:33(UTC)
applor
holes for the wires with the connectors underneath. If you find yourself needing to remove a turnout, the small bit of effort to remove the connectors is no big deal.
Offline michelvr
#4 Posted : 08 August 2021 16:07:12(UTC)
michelvr
A good question needs a good answer!
Call it what it is, A dogs dinner, a bowl of spaghetti, a birds nest, just to name a few of these wires going here, there and everywhere!
My solution was an easy one since most of the electrical cabinets at work had these so I thought why not use them on my layout. I’m referring to wire ways! At work they were metal and so I sourced the plastic ones.
I’ve been creating and making model railroads for quite some time and these wire ways are in my opinion a necessity. For about $15.00 you can buy a 1 1/2” X 2” X 96” plastic wire way from your favourite electronics store. With the wire way you can put it in any orientation, cut it to length and best of all have, all your wires will be in a convenient location for that potential and inevitable trouble shooting time under the table!
thanks 5 users liked this useful post by michelvr
#5 Posted : 08 August 2021 16:19:37(UTC)
Many thanks
Hello
Solution depends on your shape (how easy you can crawl under the layout), your goals (simple wiring of complex one caused by automation), feedback technology (S88 or conventional contacts.
So my solution is one of many and consists of:
- using large staples used for construction (roof insulation). This leave a large buckle where it is easy to have wires supported.
- this allows easy changes and tracking of cables
- this allows the wiring to be not too dense (to avoid mutual induction) between feedback wires and high-current feeders
- this method is not costly: electrical or mechanical stapler and staples.
#6 Posted : 14 August 2021 05:38:44(UTC)
joyofmarklin
Many thanks for all the advice
Offline Br502362
#7 Posted : 14 August 2021 09:39:55(UTC)
Br502362
I wired my analogue layout under table like this.
Easy to reach and easy to find problem spots if something happens.
I hope this helps you Smile
Åke
thanks 10 users liked this useful post by Br502362
#8 Posted : 14 August 2021 11:06:21(UTC)
A work of art, Åke!
Just like the Marklin factory built layouts.
Offline Michael4
#9 Posted : 14 August 2021 12:23:29(UTC)
Michael4
My wiring looks like the sort of thing you would find behind the dashboard of an old Alfa Romeo. The dog would turn his nose up at it.
I don't use my layout in the summer but when winter starts to draw in I can be found lying under the layout trying to remember what the hell it was all for.
I have finally grasped the concept of colour coding but it is far from universal and what on earth was orange for anyway????
#10 Posted : 14 August 2021 12:28:57(UTC)
Those plastic wire ways are great! I made stick on labels for each turnout run, decoder, etc. And wrapped them around the bundles. That way you know which bundle is which underneath. I hid topside labels under landscape that can easily lift up. Even using red, Brown, green, blue, black and yellow wiring, it gets to look complex. The more you multiplex lighting to save wire use, the more so it gets.
Then even though several bundle runs are concealed carry in the channel ways, if the exit areas are labeled, there is no confusion.
#11 Posted : 16 August 2021 04:57:04(UTC)
joyofmarklin
A good analogy Italian wiring! A good fix, thank you
thanks 1 user liked this useful post by joyofmarklin
Offline Timnomads
#12 Posted : 16 August 2021 11:10:05(UTC)
Timnomads
Hi All
We have identified a problem if you run wires together in a conduit. They have to each be shielded otherwise the digital information travelling in each wire can be corrupted.
This can cause some weird bugs
Huh
Tim
thanks 1 user liked this useful post by Timnomads
#13 Posted : 16 August 2021 13:20:05(UTC)
I've used 20 avg pvc 30mm wire. I don't know if it's shielded, but I have no problems. Rather than conduit, I have wring clipped in 3M Command light clips. I spaced them out about every 3 to 4 ft. The loops are big enough to carry 4 to 6 30mm wires. They can be removed with a tug on the adhesive tab anbd moved and reused.
Offline dickinsonj
#14 Posted : 19 August 2021 03:34:01(UTC)
We have identified a problem if you run wires together in a conduit...
Thanks Tim - that makes sense and would explain some strange bugs that I had in my system after I cleaned up my wiring by bundling things up.
Luckily next up for me is a whole new layout and I will have to avoid doing that again.
There are so many subtle ways to break a modern MRR layout. I just need to learn to be happy when it all at least appears to work. BigGrin
#15 Posted : 01 September 2021 02:48:26(UTC)
joyofmarklin
All good advice! I want to label the wires any suggestions how to and what I write, ie turnout 1.
Has been suggested that I drill the holes and turn the table on it’s side. However not able to, so under the table I go! Will tKe my time!
Many thanks
#16 Posted : 01 September 2021 11:09:39(UTC)
I labeled turnouts with stickers. Numbers or alpha numeric. I used m83 decoders vs. One in each turnout, so those have a,b,c. Turnouts labeled according to the terminals connected to on the decoder. A1, etc. I wrapped each bundle run with sticky long peel off labels. I used colored tape on wires which are red or black, connected to turnout blue, brown, or yellow wires to identify the ends at the decoders. Write down a log of your wiring colors and their routes.
I use a separate power supply for my building lighting. Too many to connect to my CS3 with m84 decoders. Some are 16 volt a/c motor driven accessories. An inexpensive train transformer has both fixed 12 and16 volt outputs. Incandescent bulbs can use either. Led lights depending on the resistors. Some are brighter using 16 v.
#17 Posted : 01 September 2021 17:42:13(UTC)
joyofmarklin
Many thanks
#18 Posted : 01 September 2021 18:59:50(UTC)
The problem with labeling things, is that when you change something you also have to change the label.
That second step seldom happens.
So I work with the following principles:
Color code wires as much as possible.
  • Red = digital signal
  • Brown or Black = common ground
  • Yellow (thick) = 16V AC bus
  • White = 12V DC bus
  • Gray then Multicolor strands - s88 sensor
  • Blue (thin) = turnout motor return
  • yellow (thin) = turnout power
I then only label the big things that are extremely unlikely to change, for example, each big multi-strand bundle of s88 wires are labeled A, B, C, D, etc. but there is no point in labelling the colored wires inside as they all have unique colors. Thus bundle R red+white identifies a specific wire to a sensor without ambiguity.
I have labeled my power districts/boosters 1, 2, 3.
K83 type modules and s88 modules get numbered consecutively.
With this simple approach I can know what any wire is.
If it is a turnout, which K83 is it connected to ? Easy. The individual posts on each K83 are already labeled 1- 4
If it is a signal, which signal module is it connected to ? Easy. Output ports are all labeled at the factory.
See https://cabin-layout.mixmox.com/2016/01/Installing-signals.html
Track wires are either red or brown/black.
Sensor wires are gray and then connect to a wire in a bundle, follow the wire to the sensor or back to the bundle and you know what it is.
See https://cabin-layout.mixmox.com/2014/08/s88-cable.html
#19 Posted : 02 September 2021 02:32:52(UTC)
joyofmarklin
Thank you very interesting
#20 Posted : 02 September 2021 13:51:56(UTC)
It's nice to use all corresponding color wire, however, I find it easier for myself to use double strand wire which is only available in two and of certain colors. Three strand wire is even more rare, unless it's too thin. I also don't like stiff wire that holds it's bent shapes. It's also brittle, and can break if stretched, or bent too often. A wrap of yellow tape on the end of a red wire and I know what it is. I do it for each connection.
The Marklin plugs and sockets can also be used that way, but I don't prefer the new style so much. It's hard to tell the plugs from the sockets in dim lighting, and I've stripped a few screws. They must be of lesser quality than the old ones.
Offline Mr. Ron
#21 Posted : 05 September 2021 23:59:25(UTC)
Mr. Ron
Wiring is usually once finished, "out-of-sight, out-of-mind". I use telephone wire cable which consists of 4-paired wires of 22 gauge. It is used only for turnout control. Each turnout uses a common wire that connects to a buss and the solenoid control to the 2 wire pair in the cable. Each cable can accomodate 4 turnouts that helps keep the wiring simple. A black and white wire (14 ga) is used as a buss to distribute track power. I don't like to work under the bench due to age, but this minimizes that. I am working on a catenary system that will keep wiring simple. All poles and the wires are brass and have a common polarity, so only one wire is needed. Lightning can be accomplished using surface wiring covered with tape, as I'm using low voltage LED lamps. The tape can be covered by scenery.. My layout is a "plan-as-you-go", so it's back and forth between the layout and Autocad software on my computer. At my age (86), it's imperative that I keep everything simple and readily accessible. Underneath benchwork is not in my plans. As I progress, I am discovering and inventing ways to make the wiring process as painless as possible. Since I am going straight analog wiring, I won't have a problem with cross wiring interference. Once I get it completed, I will update how it's done.
thanks 1 user liked this useful post by Mr. Ron
#22 Posted : 07 September 2021 02:19:35(UTC)
joyofmarklin
Interesting thank you
Wiring Piko Siba Semaphore Signals. (H0-scale)
by dave55uk 20/01/2026 13:01:18(UTC)
Marklin 74043 signal wiring on digital layout (Model railroad wiring)
by kaybee6 18/01/2026 07:15:51(UTC)
jmri, minimal wiring and block detection (Digital)
by nite 10/10/2025 15:09:26(UTC)
Wiring Diagram/Schematic For the New BR 24 aka 36240/41/42/43 (H0-scale)
by 5HorizonsRR 19/07/2025 19:25:40(UTC)
Wire gauge Crocodile wiring inside (Small scale)
by Chas 04/07/2025 19:17:37(UTC)
Is it a problem ? Wiring the "B" and "O" the wrong way around (Digital)
by Johnvr 21/06/2025 11:36:09(UTC)
Digital wiring - (Digital)
by Twinrover1965 09/01/2025 13:50:02(UTC)
What is the Purple Wire in Marklin Digital Wiring? (Accessory decoder) (Digital)
by 5HorizonsRR 07/12/2024 02:50:00(UTC)
Marklin 3013.1, SEH 800 Wiring Image Or Photo Request (Model railroad wiring)
by Roman 05/12/2024 06:17:18(UTC)
Track End Bumper with LED Wiring (H0-scale)
by Ace Wickwire 17/11/2024 03:21:15(UTC)
Wiring a model railroad (General MRR)
by Mr. Ron 27/10/2024 04:50:51(UTC)
BR55 37550 wiring question? (Digital)
by LA2019 27/08/2024 21:25:17(UTC)
Info on wiring Viessman coach lighting decoder 5077 (Digital)
by fabstar68 20/08/2024 19:30:02(UTC)
Digital wiring (Digital)
by Mjn2ts 09/04/2024 00:45:26(UTC)
Wiring 3 way turnout - 24630 (H0-scale)
by Alex H 14/01/2024 14:28:17(UTC)
Semaphore signal 89403 wiring (Model railroad wiring)
by MikeEK 19/11/2023 10:30:18(UTC)
Wiring problems (H0-scale)
by Allan2805 13/11/2023 01:49:46(UTC)
Point motor wiring help needed (General MRR)
by Model Railway shed D 07/11/2023 15:39:34(UTC)
Hiding wiring (H0-scale)
by Mr. Ron 01/10/2023 00:38:47(UTC)
Marklin wiring manual (Digital)
by Jay 23/09/2023 19:31:43(UTC)
Ideas for wiring of turnout lighting and lighting in general (General MRR)
by Luna 23/09/2023 01:07:47(UTC)
3071 Wiring (H0-scale)
by kpallund 05/09/2023 16:38:56(UTC)
Wiring two levels (Digital)
by Mille 05/09/2023 08:08:37(UTC)
Wiring a new layout (Digital)
by Alex H 26/08/2023 11:58:17(UTC)
m track switch wiring question (H0-scale)
by heinrichhess 24/08/2023 12:04:59(UTC)
Marklin 7192/7193 Wiring Problem?? (H0-scale)
by OMAC 05/03/2023 09:07:03(UTC)
C track wiring for DCC (H0-scale)
by Alex H 24/01/2023 21:35:17(UTC)
Switch wiring (Model railroad wiring)
by Norton1972 18/01/2023 00:00:43(UTC)
Wiring Joystick to Marklin 7051 (General MRR)
by mjborelli 31/12/2022 19:01:44(UTC)
Request Help with Wiring Joystick to Marklin 7051 Crane (General MRR)
by mjborelli 26/12/2022 01:42:54(UTC)
Wiring up Hobby signals without decoder or 72751 box. (H0-scale)
by Kaspar 24/11/2022 15:30:49(UTC)
Z scale 8589 wiring instructions (Model railroad wiring)
by hennabm 18/09/2022 14:54:35(UTC)
Wiring a 60975 (Digital)
by Keyser 16/07/2022 20:16:39(UTC)
Wiring instruction books? (General MRR)
by Rarpos 12/06/2022 05:46:17(UTC)
Requirements and wiring for 'cosmetic only' signals (Model railroad software)
by luckas 10/06/2022 17:06:17(UTC)
New to digital conversion- seeking guidance on wiring (Digital)
by BurritoJoe 10/06/2022 04:44:16(UTC)
3631 Diesel - Decoder chip wiring (Digital)
by Willem99 27/01/2022 21:21:25(UTC)
Wiring for shuttle trains. (Model railroad wiring)
by IBtrain 22/11/2021 20:46:29(UTC)
Wiring my layout for future booster (Model railroad wiring)
by IBtrain 22/11/2021 20:23:43(UTC)
3663 Alaska Set Wiring Connections (H0-scale)
by mb300e4m 17/10/2021 01:10:08(UTC)
Woodland Scenic's just plug wiring (Model railroad wiring)
by tinroofrusted 10/10/2021 03:45:46(UTC)
Buss wiring (H0-scale)
by Mr. Ron 08/09/2021 03:11:11(UTC)
How to route wiring (General MRR)
by Mr. Ron 01/08/2021 23:45:13(UTC)
Marklin c-track wiring for z21 (Model railroad wiring)
by Lusito 22/04/2021 15:05:16(UTC)
Layout wiring (General MRR)
by Mr. Ron 05/03/2021 19:34:46(UTC)
Help with Wiring (Small scale)
by Ricinport 26/02/2021 11:16:10(UTC)
Wiring micro SMDs (Model railroad wiring)
by morsing 02/02/2021 06:47:36(UTC)
Marklin 1 Gauge 66020 Decoder wiring (Digital)
by hennebror 31/01/2021 20:01:47(UTC)
Wiring 7209/72090 Distributor Strips to Marklin AC Transformer (General MRR)
by mjborelli 18/01/2021 00:24:06(UTC)
layout wiring options (Model railroad wiring)
by biswasg 13/01/2021 21:46:39(UTC)
This page was generated in 1.012 seconds.
