Offline bobhunt2
#1 Posted : 30 November 2010 02:44:27(UTC)
bobhunt2
My Central Station is the older one, which was upgraded a couple of years ago.
I have now lost the display on the panel - the controller powers up, and I have replaced the batteries but the screen is blank.
What should I do?
Bob
#2 Posted : 30 November 2010 08:17:09(UTC)
I had a problem with the screen on my CS1 not responding to touch input. The problem turned out to be a speck of dirt that had lodged itself under the screen surround and was permanently pressing down on the touch screen, which meant it would not respond to any input. Cleaning the surround fixed the problem.
Do you see the Marklin logo during the startup of your CS1? If not, you may have a defective screen, in which case it will have to go back to Marklin for repair.
#3 Posted : 30 November 2010 16:42:56(UTC)
Märklin no longer repair CS1s.
Bob,
When you connect your CS1 to a PC, you can get a screenshot in your web browser.
If it's a screen problem only, then you should see the normal "screen" in your browser.
If your CS was never connected to a PC, the test could be impossible because the LAN settings of the CS may need to be changed (which is rather difficult with a defective screen).
Märklin may offer you a new CS2 for a special price if you contact them as they no longer repair CS1s.
ESU would repair it for you if it had the CS1 reloaded update. So if everything's correct in the web browser, you could order and install the ESU update to qualify for an ESU repair.
It's about Euro 150 for the update and about Euro 99.50 for the repair (repair price taken from the current CS1 reloaded manual) - plus postages.
#4 Posted : 30 November 2010 16:56:32(UTC)
Rather than pay ESU for a repair I would take up any offer from Marklin and get the CS2 with its superior screen.
As David says perhaps you have something caught between the screen and the outer case.
Not too sure if Marklin wil make you an offer if ESU have uploaded their stuff to your CS1.
dave
Offline bobhunt2
#5 Posted : 01 December 2010 08:16:59(UTC)
bobhunt2
dave
Thanks everyone,
I will get to my dealer as the first step and see what we can do about a replacement - it seems that is the way I am headed.
Bob
Offline MHJ_63
#6 Posted : 15 November 2022 03:48:38(UTC)
MHJ_63
I just had the same issue. My CS1 stopped responding to the touchscreen. I found the solution here on the forum. I cleaned boarder of the screen with a small dental tool and viola everything works again. I love this forum. Thank you all.
thanks 1 user liked this useful post by MHJ_63
#7 Posted : 15 November 2022 13:10:50(UTC)
Why not consider upgrading to a CS3, if considering a CS2?
#8 Posted : 15 November 2022 13:59:41(UTC)
I would go for a CS3. The CS1 I had was terrible and ditched by Marklin fairly quickly. CS2 is also way better. Good however you are back running trains again.
Offline Copenhagen
#9 Posted : 15 November 2022 15:17:03(UTC)
Copenhagen
Be careful and look at the date when responding. Sometimes what one is responding to could be more than ten years old. :-)
thanks 4 users liked this useful post by Copenhagen
#10 Posted : 15 November 2022 23:07:05(UTC)
Indeed so. The original poster has not completed the thread with a result. My comments are for the new poster regarding up grading. When asking for advice I feel we should receive some form of conclusion.
Help with missing functions - Windows Central Station (for CS2) (Digital)
by Jarle 18/02/2025 21:20:04(UTC)
Central Station 60212 (Digital)
by jameskwan88 09/02/2025 07:09:28(UTC)
New Central Station 3 owner help! (Digital)
by stevenh905 24/11/2024 03:46:00(UTC)
Lost cables for Central Station 1 (Digital)
by johnhendry 06/11/2024 22:18:14(UTC)
Central Station 2 factory reset (Digital)
by einotuominen 12/10/2024 13:52:44(UTC)
Märklin Central Station 3 / 3 plus - does production date matter? (Digital)
by Torbjorn 01/10/2024 12:53:07(UTC)
Central Station 3 Plus, nightmare no go (Digital components and Software reviews)
by mattj70 01/05/2024 07:03:18(UTC)
Central Station 2 stuck on STOP (Digital)
by mattj70 25/02/2024 12:58:53(UTC)
Mobile station vs. Central Station - and new C track layout application (Digital)
by bpitchkites 19/02/2024 17:42:29(UTC)
New software: TrainControl for Marklin Central Station 2 and 3 (Model railroad software)
by moman2 10/11/2023 23:20:03(UTC)
Central Station CS2 (General MRR)
by gbrendem 13/10/2023 19:52:37(UTC)
by dave55uk 21/09/2023 22:23:59(UTC)
Marklin Central Station 60215 (Digital)
by Jim Purvis 30/08/2023 23:54:16(UTC)
Central station 2 (Digital)
by Antonio21 16/03/2023 16:50:54(UTC)
Central Station plus (News from Märklin and others)
by fvelazdem 05/01/2023 12:23:26(UTC)
MU Consist on Central Station 2 (H0-scale)
by Jan Havenga 03/11/2022 18:47:05(UTC)
Central Station CS2 (Digital)
by Rolando 31/08/2022 13:19:36(UTC)
Central Station 3 transformer compatibility 6002 (Digital)
by vandermerwe 26/07/2022 12:35:09(UTC)
Central Station, Mobile Station & 32 Volt controller not working? (General MRR)
by mattj70 06/04/2022 05:43:05(UTC)
Marklin Central Station update problem (Digital)
by KNed_ 12/01/2022 08:58:52(UTC)
Märklin Central Station 60212 (Digital)
by Harlov 02/12/2021 08:38:33(UTC)
Central Station 2 (Digital)
by Barby & Stan 15/08/2021 23:07:02(UTC)
Coupling 2 central station 3+, can cable needed? (Digital)
by bask185 04/06/2021 10:56:21(UTC)
TCP ports in the Central Station 2/3 (Digital)
by fosuna 18/02/2021 07:27:43(UTC)
Configuration save on your Ecos / Central Station (Digital)
by michelvr 16/02/2021 15:34:18(UTC)
Central Station replacement (Digital)
by Rwill 11/02/2021 20:27:28(UTC)
New hear- Central Station 2 and my 1 gauge locomotives (Big scale)
by Simone458 26/09/2020 02:23:22(UTC)
Connecting Maerklin 7686 Turntable / Decoder to CS3+ Central Station (Digital)
by HellO 08/06/2020 12:03:20(UTC)
by Emin Evrankaya 04/04/2020 16:33:13(UTC)
New Central Station (Digital)
by oranda 30/03/2020 14:46:05(UTC)
Solved - Will a Central station 2 or 3 automatically recognize a Loksound V 4.0 decoder (General MRR)
by river6109 11/03/2020 03:57:58(UTC)
Is it worth adding layout to Central Station? (Digital)
by morsing 22/05/2019 12:28:39(UTC)
Another central station 60212 question (Digital)
by DB Fan 10/03/2019 22:29:00(UTC)
Central Station 60212 question (Digital)
by DB Fan 06/03/2019 05:38:16(UTC)
Marklin Central Station 60215 busted? (General MRR)
by mattj70 01/03/2019 20:25:33(UTC)
connection K83 - Marklin central station (old) - Ecos2 > M-Keyboard (Digital)
by PkMärklin 05/02/2019 21:07:10(UTC)
Automation on G scale with Central Station 3 (Digital)
by PCRail 18/01/2019 21:21:16(UTC)
Network access for the Central Station CS3 plus (Digital)
by John Ferguson 08/09/2018 16:51:41(UTC)
RocRail softCentral Station CS3 plus (Digital)
by John Ferguson 29/08/2018 15:15:29(UTC)
Running Trains Digitally with the Central Station 3 (Accessories reviews)
by michelvr 11/11/2017 21:22:15(UTC)
by Michael Jervis 14/10/2017 13:56:31(UTC)
central station 2 for DCC 2 rail (Digital)
by daafies 18/09/2017 20:27:01(UTC)
by Twisterdodger 27/07/2017 19:54:23(UTC)
Central Station 3 (H0-scale)
by Torrid 06/05/2017 18:31:28(UTC)
What can the Central Station do? (Digital)
by morsing 08/04/2016 20:44:32(UTC)
Central Station1 programming track (Digital)
by magload 23/01/2016 14:26:31(UTC)
Central Station and PCs (Digital)
by nitramretep 30/12/2015 15:37:42(UTC)
Marklin Central Station Parts (Digital)
by chrisisrang 17/08/2015 04:42:40(UTC)
Central Station Question (Digital)
by sedgar2 09/08/2015 00:11:51(UTC)
Central Station Update - CS2 v4.0.1(3) available (Digital)
by Carlos 22/07/2015 20:07:07(UTC)
This page was generated in 0.416 seconds.
