Offline Carlos
#1 Posted : 28 July 2024 17:16:04(UTC)
Carlos
Helio to everyone,
I have not been using my CS3+ for the last 3 or 4 weeks, today when a turned on doesn't wors, I mean no power. What can be the reason and is there a way to fix this problem?
Thanks to all of you in advance, Regards
Carlos
Offline rhfil
#2 Posted : 28 July 2024 22:19:22(UTC)
rhfil
Do you have a multi-meter? I would first check power at the wall and then out the transformer. Then check to make sure the power plug is properly inserted into the CS3. Since the CS3 lacks an on/off switch how exactly did you turn it on?
#3 Posted : 28 July 2024 23:20:44(UTC)
.Hi Carlos
French user of 2 CS2s (60215) and one CS3 (60226)
The power supplies I have are 2 60041 (230 VAC 60 W) and one 60101 (230 VAC, 100W).
So rhfil suggestion to check if power is present on the plug is good (or thying from a different wall plug is also good)
The low voltage output on the CS2 and CS3 (same connector, same pin-out / pin assignment) is as follows (as viewed from the CS3 vewpoint)
This would allow you to check if your power supply provides 19.3 VAC.
Make sure you don't short-circuit the 2 pins as it would stop immediately your PSU and force you to unplug before restarting the measurement.
If the PSU does not provide power and if it is not under warranty then:
- Märklin won't repair them
- on TWO occasions it happened to me that a wire inside to connector plugged to the CS2 / CS3 was cut and all I had to do was to open the connector (rather difficult) and resolder the wire.
Here are the connector parts when opened
Offline rhfil
#4 Posted : 28 July 2024 23:42:42(UTC)
rhfil
Oh, when he said "no power" I assumed it was at the CS3 but he might have been talking about on the layout. Lol. As usual we need more information. He is in the U.S. so the wall socket would be 110/120. Anyone dealing with electricity should have a multi-meter and learn how to use it. They are inexpensive and can be used to identify and solve a lot of problems.
Offline Carlos
#5 Posted : 29 July 2024 01:56:21(UTC)
Carlos
.Hi Carlos
Hi Jean I used a multi-meter and according to the multimeter there is no problem I also plugged in another outlet and the problem still the same. I believe I'll need a new CS3+
Thank you for your help
Carlos
Offline Carlos
#6 Posted : 29 July 2024 02:05:49(UTC)
Carlos
I used the multimeter and according to this device the electricity is ok. I always turned on with the Central Station STOP button
Thank you for your help.
Carlos
Offline rhfil
#7 Posted : 29 July 2024 06:25:22(UTC)
rhfil
So you do nor actually remove power from the CS3. Do you do a "Shut Down"? Did you unplug the power cord from the CS3 and check the power at the end of the cord?
Any power surge from a lightning strike or generator glitch could fry it. I would unplug the transformer from the outlet, wait at least 10 minutes and plug it back in. I am not sure if the CS3 or the transformer have circuit breakers built in but that might reset them. It might also be that the stop button or bar is messed up. Press down on it, hold it down for a few seconds and then slowly release it. I have a power strip that my power suppliers plug into. After I do a "Shut Down" I turn off the power to everything.
#8 Posted : 29 July 2024 11:25:23(UTC)
When you don´t use CS3 you must follow Märklins recommendation by switch off the CS3 by click on the shut off in the system settings.
To push on the emergency button are not recommended.
#9 Posted : 29 July 2024 12:17:14(UTC)
I also have mine on a surge protector and power strip.
Offline rhfil
#10 Posted : 29 July 2024 14:32:24(UTC)
rhfil
Actually the Marklin recommendation is to do a system shutdown which also puts the CS3 in a "Stop mode. My understanding of pressing the "Stop" bar only turns off power from going out of the CS3. It does not stop power from going into the CS3. From the occasional times that I have accidentally left my CS3 in that status overnight I can state that it immediately came back on the next day so was only in a sleep mode the entire time.
thanks 3 users liked this useful post by rhfil
Offline Carlos
#11 Posted : 30 July 2024 03:09:04(UTC)
Carlos
Yes finally I believe that it may be very possible that the reason could be that I had a power surge the morning before I decided to turn on the CS3. I will end up buying a new CS3+😡
Offline rhfil
#12 Posted : 30 July 2024 12:09:53(UTC)
rhfil
I would contact Rick Sinclair at rick@marklinrepairs.com and describe the problem and the probable power surge and ask if the CS3 is repairable. He is great. I would like to think that the CS3 has a surge protection device which could be reset or at least replaced and at the very worst the power chip could be replaced for less than the cost of a new CS3+ but don't know.
Also, unless you plan on using a CS3 as a slave or already have the cheaper S88 which uses the CS3+ as a power supply you don't really need to buy a CS3+ thus saving a bit of money. I have a CS3+ but bought it before I really had learned the advantages of it.
Offline Carlos
#13 Posted : 31 July 2024 03:20:01(UTC)
Carlos
Yes, finally I decided to send the power surge and the CS 3 to Ajckids located in Texas for service repair. Will see what happens.
Carlos
thanks 1 user liked this useful post by Carlos
Offline rhfil
#14 Posted : 31 July 2024 14:11:43(UTC)
rhfil
Let us know what the result is. I am curious whether Marklin built in some surge protection in the CS3's. And if it worked.
#15 Posted : 05 August 2024 20:35:49(UTC)
The US digital club sent out a newsletter today and said that a small CS 3 update was sent by Marklin but they haven't tested it. It contains a power supply update for the 60014 to allow the CS 3 to operate at a lower voltage and safely shutdown and restart. Also a small MS 2 update. More will be discussed in the next webinar.
cs3+ voltage output (Digital)
by fabstar68 10/11/2025 17:37:17(UTC)
CS3+ (Digital)
by bygger01 10/10/2025 17:14:04(UTC)
CS3+ + booster + L88 (Digital)
by BenP 09/07/2025 16:24:34(UTC)
60VA v 100VA for CS3+ (Digital)
by BenP 28/06/2025 22:50:45(UTC)
Help! CS3+ seems to be changing my turnout addresses when I add mfx device (Digital components and Software reviews)
by tgj 04/05/2025 19:44:59(UTC)
IP address of two CS3+ (Digital)
by Capitole 03/04/2025 09:43:46(UTC)
CS3+ with a CS3 slave (Digital)
by rhfil 21/03/2025 22:53:17(UTC)
issue with locos that doesn't stop on cs3+ (Digital)
by Adrian666 11/03/2025 13:31:25(UTC)
Other digital brands on cs3+ marklin system (Digital)
by Adrian666 10/03/2025 19:09:40(UTC)
S88 Events via UDP CAN Gateway für CS3+ und Rocrail (Digital)
by rinderkn 09/02/2025 16:55:55(UTC)
CS3+ (Digital)
by greatrocks 15/12/2024 00:00:09(UTC)
Locomotive (mfx) not showing up in list on CS3+ (Digital)
by micknudsen 24/11/2024 12:49:35(UTC)
Can Marklin CS3+ connect with servo? (Digital)
by Solar007 27/09/2024 11:22:36(UTC)
CS3+ (Digital)
by Mailme 11/07/2024 03:53:39(UTC)
CS3/cs3+ update 2.5.2 (Digital)
by Flupke 22/06/2024 20:05:21(UTC)
CS3+ S88 Arduino connection (Digital components and Software reviews)
by Tue Albertsen 26/03/2024 17:15:21(UTC)
CS3+ automation macros examples & documentation (Digital)
by fabstar68 18/03/2024 15:04:49(UTC)
CS3+ Locomotive data pictures (Digital)
by MSanches 27/02/2024 10:48:24(UTC)
do the lok data cards - 60135 - work with CS3+? (Digital)
by roedj 10/01/2024 12:14:32(UTC)
Cs3+ (H0-scale)
by bobgiam 16/12/2023 01:17:51(UTC)
rotary Crane,CS3+,M84 (Digital components and Software reviews)
by ULI1944 10/12/2023 20:34:57(UTC)
CS3+ update using USB stick. (Digital)
by Flupke 13/11/2023 16:33:07(UTC)
Backdating a CS3+ (Digital)
by Drongo 22/08/2023 12:40:28(UTC)
CS3+ Help: cannot create "areas" on layout (Digital)
by plg 03/06/2023 21:00:28(UTC)
Use old 6083 (K83) and 6084 (K84) with CS3+? (Digital)
by Feelixen 18/05/2023 14:45:27(UTC)
CS3+ Events (Digital)
by Drongo 27/04/2023 07:40:50(UTC)
Loco speed in RocRail and CS3+ (Digital)
by Tue Albertsen 15/04/2023 17:30:21(UTC)
CS3+ Track Current Monitor (Digital)
by kolabuzlu 25/02/2023 18:58:12(UTC)
CS3+ and DCC (Digital)
by roedj 16/02/2023 12:35:52(UTC)
Resetting CS3+ (Digital)
by Carlos 20/12/2022 20:04:27(UTC)
CS3+ & Lenz LS150 (Digital)
by bygger01 18/12/2022 12:38:09(UTC)
Registering decoders on three way points on CS3+ and CS2 and other problems (Digital)
by DV 11/08/2022 10:30:31(UTC)
CS3+ VNC Viewer not working (Digital)
by Diesel2000 23/07/2022 23:54:31(UTC)
Update Of Old/Early CS3+ (Digital)
by bugsmasher 26/06/2022 02:36:48(UTC)
Update CS3+ v.2.4.0 (Digital)
by fhp2 22/03/2022 08:58:32(UTC)
GUI and GFP in the CS3/CS3+ (Digital)
by fosuna 04/03/2022 07:33:06(UTC)
CS3/ CS3+ (Digital)
by bgemski 01/03/2022 16:00:15(UTC)
Locomotives controlled by CS3+ loose settings (light, sound ...) after restart of CS3+ & speedchange (Digital)
by HaraldOnline 24/01/2022 09:05:57(UTC)
How to run CS3+ events at a specific time of the day? (Digital)
by Nick1150 22/01/2022 11:43:05(UTC)
ITrain, CS3+ and manual control (Model railroad software)
by Puttputtmaru 17/01/2022 00:17:56(UTC)
CS3+ cannot find locos based on mfx protocol (Digital)
by eldar760 12/01/2022 03:30:09(UTC)
Motor 74491 decoder 60831 and CS3+ (Digital)
by Rolando 31/12/2021 11:05:22(UTC)
Sound on CS3 and CS3+ (Digital)
by Joakim_B 10/12/2021 23:11:13(UTC)
Märklin CS3+ & Web interface problem (Digital)
by BOOMerCH 25/09/2021 20:40:05(UTC)
Can I mix a CS3+ with an EcoS (Digital)
by Drongo 08/08/2021 12:40:19(UTC)
CS3+ S88 contact track event (Digital)
by marklinist5999 03/08/2021 15:11:05(UTC)
M84 Decoder, Cs3+, Minitrix Turntable (General MRR)
by Ngauging21 03/05/2021 08:36:17(UTC)
CS3+ and PSX circuit breakers (Digital)
by trentschler 14/04/2021 18:05:01(UTC)
Changing cs3+ from main to auxiliary control (H0-scale)
by Umesh 23/02/2021 15:04:37(UTC)
CS3+ and Event Logging (Digital)
by magicmushroom 17/01/2021 20:35:43(UTC)
This page was generated in 0.520 seconds.
