Offline ktsolias
#1 Posted : 10 May 2016 19:13:26(UTC)
ktsolias
Three weeks ago from an auction I bought a 3005
The Loco is in very good condition, was converted in the past to Delta with 66031 decoder. (no original reversing unit)
It's working perfectly, with the limitations of the motor (SFCM) and the decoder (no functions etc).
Here are a couple of pictures of the loco
I plan to convert the 3005 in Digital with HLA motor 60943 and mSD decoder and LED lights
I want the opinion of the forum if its right to do changes to the body and tender:
1. Add a smoke generator (need to drill 5mm hole in the smoke stack)
2. Add rear lights to the tender (drill two 3mm holes)
Do you think that the alterations will destroy the value of the 3005 as collectible item??
Generally I dont'n like to do any non reversable alterations to rare or limited edition models
Is the 3005 in this contision in this category
Thanks a lot
Costas
#2 Posted : 11 May 2016 08:39:51(UTC)
The loco is in perfect condition and for me it is not good to make holes to this nice classic.It is a not a high priced collector model,it is a common locomotive for many of us,but my opinion is that we have to respect the old ladies.If it was possible to make the upgrade without holes,no problem.Just my opinion.
thanks 4 users liked this useful post by foumaro
#3 Posted : 11 May 2016 15:00:53(UTC)
Hi Costas,
The 3005 is not a rare or valuable loco, so if you want to experiment it's probably a good model to choose.
I have one of these but I've decided to keep it in original condition in analogue. Instead I've bought one of the more recent Br23 models, digital, mfx, sound etc, so I don't need to mess about with the old classic.
#4 Posted : 11 May 2016 21:08:36(UTC)
Nice loco, I have had one since day one, when it appeared in the 1950's.
One little word of caution when converting to the 5 pole high performance motor: the brush holders will probably interfere with the roof/sides of the cab.
Be very careful , use some solid insulating tape before frying the decoder!!
Also mine has now 5 mm LEDs front and rear. The effect is stunning, and the model suddenly looked very contemporary. Yes I had to drill.
But this loco in real life was used often like a tank loco and would be seen travelling "backwards" , so installing lights in the tender is justifiable from an operational point of view.
But Ray is right, it might mean a slight decrease in value if that is a concern to you...but do you really care?
Good luck with the conversion
Offline ktsolias
#5 Posted : 12 May 2016 11:32:24(UTC)
ktsolias
Thank you my friends
for your valuable opinion
I know very well the value in money of the 3005 and other locos of the same category
So the question is not for the value in money but for the value of passion!!!!
Any way the economy of the conversion is against me
(30 motor+85 mSD +25 smoke generator + 5 LEDS etc =150 Euro !!!!)
But is the passion and creativity who pay for!!!!
I will start with the basics and on the way we see
I will inform you for the progress of the conversion
Thanks again all of you
Costas
#6 Posted : 12 May 2016 23:37:29(UTC)
Did you use cool white or warm white LEDs Jaques?
My gut feeling would be warm white ones would look better on an older type loco like this, cool white ones for modern locos with halogen headlights.
Offline ktsolias
#7 Posted : 13 May 2016 08:49:51(UTC)
ktsolias
Alan
I always use Warm White LEDS for Steam Locos and I adjust the resistor value so that the light is not very bright.
For modern Locos you can use Cool White LEDs according to the Loco and the ERA
Here is an example of the difference between WW and CW.
On the left is a V200 3021 with WW LED's and on the right A Re 460 3751 with CW LED's
Costas
#8 Posted : 13 May 2016 20:38:56(UTC)
BR 189 has LED lights that look rather cold while other prototype locos have LEDs that look rather warm.
For old locos (steamers or era III diesel or electric) I would recommend "Golden Sunset" LEDs.
For other locos with light bulbs in real life I prefer "Sunny White" LEDs.
The so-called "warm-white" LEDs have a neutral white that is not like light bulbs.
Here's a comparison (light bulb in top right corner, warm-white LED in bottom left corner):
https://www.marklin-user...aspx?g=posts&t=13162
All pictures taken with the same manual white balance setting.
3054 digital conversion and magnet mount problem (Digital)
by lpesce 05/05/2024 00:30:07(UTC)
Digital conversion of 4-6-2 steam loco from 1961 (Digital)
by Bcur 28/02/2024 17:56:38(UTC)
Digital Conversion of a Delta Ae 8/14 - PC Board Part #? (Digital)
by 5HorizonsRR 06/02/2024 20:39:15(UTC)
ICE 3370 or 3770 digital conversion (H0-scale)
by StanN 21/12/2023 22:59:50(UTC)
Hag digital conversion (General MRR)
by mvd71 06/05/2023 05:58:50(UTC)
Digital conversion of Märklin 3511 (Digital)
by Martti Mäntylä 04/12/2022 17:36:42(UTC)
New to digital conversion- seeking guidance on wiring (Digital)
by BurritoJoe 10/06/2022 04:44:16(UTC)
Analog to Digital Conversion Marathon (Digital)
by Paul24 02/02/2022 23:27:03(UTC)
Digital conversion of 89 series (Digital)
by Jay 11/06/2021 19:17:52(UTC)
Digital Conversion: Part list needed (Digital)
by madhu.gn.71 30/03/2021 11:47:44(UTC)
Digital conversion of 3060 Santa Fe with mfx60760 (H0-scale)
by Spirre 15/02/2021 21:48:54(UTC)
Digital Conversion (H0-scale)
by fossie 06/02/2021 18:45:33(UTC)
Better digital conversion BR128 (Digital)
by siroljuk 05/02/2021 09:52:32(UTC)
Help with Digital Conversion (Digital)
by waterslip 05/12/2020 03:49:42(UTC)
digital conversions (Digital)
by MHJ87 05/07/2020 02:56:05(UTC)
3046 digital conversion (Digital)
by MHJ87 31/05/2020 07:55:48(UTC)
by MHJ87 08/05/2020 02:33:56(UTC)
A simple little trick to make your digital conversion easier (Digital)
by Johnvr 27/04/2020 12:57:43(UTC)
Minitrix ICE 3 Digital Conversion (Digital)
by thanos339 16/04/2020 22:07:12(UTC)
analog to digital conversion (Digital)
by hangle718 09/04/2020 01:31:26(UTC)
Märklin 3462 EMD F7 "ALASKA" Digital conversion (Digital)
by ktsolias 27/03/2020 12:16:26(UTC)
BR80 digital conversion (Big scale)
by mvd71 26/02/2020 06:42:32(UTC)
Advice sought for digital conversion / upgrading (Digital)
by Martti Mäntylä 24/10/2019 16:32:18(UTC)
digital conversion newbie help (Digital)
by quarkhirad 05/09/2019 08:24:48(UTC)
Märklin 3111 Digital Conversion with 60906 Decoder (Digital)
by ktsolias 28/05/2019 11:16:31(UTC)
3015 Digital Conversion & Lighting Tips? (H0-scale)
by 5HorizonsRR 11/02/2019 16:24:15(UTC)
3074 digital conversion issue (Digital)
by Donb 31/12/2018 19:18:02(UTC)
by poppa-7 17/11/2018 04:26:00(UTC)
Digital Conversion Märklin 3448 E 70 21 (Digital)
by ktsolias 09/11/2018 11:26:46(UTC)
Digital Conversion Question: Marklin Z Class 50 Steam Loco (Small scale)
by JD3 01/06/2018 21:46:25(UTC)
60760 digital conversion kits (Digital)
by Bryan 11/03/2018 20:39:09(UTC)
Märklin 3031 BR 81 Digital Conversion (Digital)
by ktsolias 02/03/2018 11:29:53(UTC)
3074 Digital conversion, motor buzzy (Digital)
by db60 15/01/2018 00:44:30(UTC)
Why do the digital conversion sets include the Chokes ? (Digital)
by Johnvr 29/10/2017 19:42:20(UTC)
3046/3047 BR 44 Digital Conversion- Keeping the smoke unit? (Digital)
by 5HorizonsRR 20/10/2017 02:25:14(UTC)
Using Original Motor Plate During Digital Conversion-ESU 54631 Kit (Digital)
by 5HorizonsRR 05/09/2017 01:48:27(UTC)
Märklin 3309 DB BR 85 Digital Conversion (Digital)
by ktsolias 23/05/2017 10:03:11(UTC)
more digital conversions (Digital)
by river6109 03/05/2017 04:40:33(UTC)
Please, help for digital conversion. (Digital)
by airsoftrc 27/03/2017 23:05:54(UTC)
Märklin 3352 Ce 6/8 Crocodile, Digital Conversion (Digital)
by ktsolias 01/03/2017 11:03:08(UTC)
by Pierrenicolas 28/01/2017 03:00:53(UTC)
3048 Digital Conversion (Digital)
by ktsolias 05/12/2016 19:26:33(UTC)
Trouble shoot 3041 digital conversion (Digital)
by EDWARD MCNALLY 17/11/2016 23:27:18(UTC)
Digital Conversions worth the cost and Hassle? (Digital)
by Collector 31/08/2016 13:26:45(UTC)
digital conversion 3028, 3428 Br 515 (Digital)
by river6109 27/08/2016 07:03:24(UTC)
6 digital conversions (Digital)
by river6109 24/08/2016 15:05:29(UTC)
Marklin 3147 Digital Conversion (Digital)
by MKOpSeattle 09/07/2016 06:33:05(UTC)
Märklin DB BR 85 digital conversion adventure (Digital)
by river6109 15/06/2016 14:49:06(UTC)
another digital conversion DSB My 1134 (Digital)
by river6109 11/06/2016 13:02:48(UTC)
Marklin 3075 digital conversion (Digital)
by fossie 18/05/2016 14:18:25(UTC)
This page was generated in 0.573 seconds.
