Offline ice 1
#1 Posted : 03 January 2015 10:55:39(UTC)
ice 1
Hello
I have questions in relation to the Central Station
(1)If you wanted to run a D/C Fleischmann track in my layout can the Central Station run that to like the ESU ECOS.
(2)For a layout that will be about 8ft by 9ft is there need for a Central Station as i would prob have a max of 10 points but would be handy to have them under digital control as i might spend all my time changing points by hand.
(3)The shuttle control feature sounds interesting to me so a loco or Railcar can go from point A to point B stop at a certain spot at point B and how is this spot set and return to point A again or can it go on to Point C and stop and then back to point B again etc.
(4)Starter Sets appear tobe the cheapest way to get a Central Station esp when i need track etc for a new layout has the starter set29463 got the latest central station with the Firmware VERSION 2.5 or higher for running the loco 39850 C152
(5)Are updates for the Central Station only really needed on a yearly basis.
Would be grateful for your help
#2 Posted : 03 January 2015 11:16:02(UTC)
Almost like the ECoS. ECoS supports RailCom, RailCom+, SX, and DCC with up to 29 functions per loco. CS2 supports DCC (up to 16 functions per loco using the UI), no SX, no RailCom.
Assuming the locos you want to run have DCC decoders they will work with the CS2.
Three-rail track or two-rail track - the digital controllers are the same nowadays.
An MS2 would be enough to control those turnouts, but it's more comfortable with a CS2.
You can combine analogue turnout operation with digital train operation - turnouts with a motor, but without a decoder.
You can run the train from A via B, C, D, E, F to G and have it return.
Basically there is a start contact, an end contact, and a middle contact. The middle contact can be used for as many middle stations you need.
Many dealers sell CS2s, track sets, trains &c. from split starter sets. If you only need the CS2 and the tracks, you can get them without buying a complete starter set.
Any CS2 can be updated to the latest software version, so it doesn't really matter which version is pre-installed at the factory.
That depends on your needs. Some folks install every new version, some didn't upgrade for years.
Offline ice 1
#3 Posted : 03 January 2015 11:32:09(UTC)
ice 1
Many Thanks
So the Central Station can Bring Power to my future Marklin Ho Layout and i can bring another power cable to the D/C track in the layout to from the CS2.
The Shuttle function and the contacts etc do they come with the CS2 or are they extra can i also Use the Shuttle feature on my D/C digital layout or does that just work on Marklin Digital locos.
So basically what i want to know is will the CS2 bring power to the A/C track and also the D/C Track at the same time and give me the shuttle operation function in both as i have 5 or 6 Fleischmann Railcars with sound so i can be running both the A/C layout and the D/C digital track all at the one time with the CS2
#4 Posted : 03 January 2015 11:39:13(UTC)
Yes. You will need feedback detectors to make it work.
If you want to stick to Märklin, you can get the 60883 and combine it with 60881 (three-rail only) and 60882 (two-rail and three-rail).
Some folks prefer current detectors like the 60882 even for three-rail operation because using the 60881 can lead to increased contact problems with three-rail operation.
You will need decoders for your turnouts and other accessories (60831) and to control lights &c. (60841).
So there will be some expenses beyond the starter set.
Offline ice 1
#5 Posted : 03 January 2015 12:20:18(UTC)
ice 1
Im not very teckno minded but it sounds great the shuttle feature.
So basically all your trains could be running themselves and you just sit back n watch and they could stop at a station and pull away again etc
I suppose the only thing to watch is point settings etc and ive noticed even if the point is set against the locos direction it will still go through the point okay its only when its comming back again that of course it will then go off in the other direction to the way the point is set if you know what i mean so if it was a loop the loco was running you could always leave that point set against the loco if it suited another loco or railcar goin in the other direction in a shuttle run.
I suppose the power cable from your CS2 to D/C layout is extra to but dont mind as long as you can bring power to both at the one time and then just to make sure its the right type of plug or pin to fit the track used.
Maybe im goin to far here but with them Marklin Digital Signals if a train approaches them and the light is red do they automatically stop the train just thought by there price that would be the case and is there any inbuilt collision avoidance warning built into the CS2 to warn you etc of a possible smash im sure 2 Locos even going at half there full speed would be well damaged in a smash or again im i goin to far.
#6 Posted : 03 January 2015 19:11:26(UTC)
The signal can turn track power near the signal off. The train will stop abruptly with lights and sounds off.
You can add braking modules (#72442) to have digital locomotives stop slowly and with lights and sounds on.
The CS2 does not know the exact layout plan nor the positions of the locos.
If you go for full PC control, the software in the PC will know the complete layout and the position of each loco and will prevent them from colliding.
If you go that way, you won't need braking modules - but you will need more feedback modules.
Offline ice 1
#7 Posted : 03 January 2015 23:16:25(UTC)
ice 1
Thanks for your help HO
I hope you work for Marklin you know so much.
Full PC control sounds interesting i suppose you buy a Marklin software package etc.
I see that the big layout in Berlin is all PC Control but im sure both have there plus and minus points.
I just hope all them contacts for shuttle control are easy to wire up etc and to get it working as im no teckno genius and dont want miles of wire or worse again not enough as i want all my control boxes etc in one spot everything nice and easy with good clear English instructions
Help with missing functions - Windows Central Station (for CS2) (Digital)
Belarus Jarle 18/02/2025 21:20:04(UTC)
Central Station 60212 (Digital)
by jameskwan88 09/02/2025 07:09:28(UTC)
New Central Station 3 owner help! (Digital)
by stevenh905 24/11/2024 03:46:00(UTC)
Lost cables for Central Station 1 (Digital)
by johnhendry 06/11/2024 22:18:14(UTC)
Central Station 2 factory reset (Digital)
by einotuominen 12/10/2024 13:52:44(UTC)
Märklin Central Station 3 / 3 plus - does production date matter? (Digital)
by Torbjorn 01/10/2024 12:53:07(UTC)
Central Station 3 Plus, nightmare no go (Digital components and Software reviews)
by mattj70 01/05/2024 07:03:18(UTC)
Central Station 2 stuck on STOP (Digital)
Belarus mattj70 25/02/2024 12:58:53(UTC)
Mobile station vs. Central Station - and new C track layout application (Digital)
by bpitchkites 19/02/2024 17:42:29(UTC)
New software: TrainControl for Marklin Central Station 2 and 3 (Model railroad software)
by moman2 10/11/2023 23:20:03(UTC)
Central Station CS2 (General MRR)
by gbrendem 13/10/2023 19:52:37(UTC)
Belarus dave55uk 21/09/2023 22:23:59(UTC)
Marklin Central Station 60215 (Digital)
by Jim Purvis 30/08/2023 23:54:16(UTC)
Central station 2 (Digital)
by Antonio21 16/03/2023 16:50:54(UTC)
Central Station plus (News from Märklin and others)
by fvelazdem 05/01/2023 12:23:26(UTC)
MU Consist on Central Station 2 (H0-scale)
by Jan Havenga 03/11/2022 18:47:05(UTC)
Central Station CS2 (Digital)
by Rolando 31/08/2022 13:19:36(UTC)
Central Station 3 transformer compatibility 6002 (Digital)
by vandermerwe 26/07/2022 12:35:09(UTC)
Central Station, Mobile Station & 32 Volt controller not working? (General MRR)
by mattj70 06/04/2022 05:43:05(UTC)
Marklin Central Station update problem (Digital)
by KNed_ 12/01/2022 08:58:52(UTC)
Märklin Central Station 60212 (Digital)
by Harlov 02/12/2021 08:38:33(UTC)
Central Station 2 (Digital)
by Barby & Stan 15/08/2021 23:07:02(UTC)
Coupling 2 central station 3+, can cable needed? (Digital)
by bask185 04/06/2021 10:56:21(UTC)
TCP ports in the Central Station 2/3 (Digital)
by fosuna 18/02/2021 07:27:43(UTC)
Configuration save on your Ecos / Central Station (Digital)
by michelvr 16/02/2021 15:34:18(UTC)
Central Station replacement (Digital)
by Rwill 11/02/2021 20:27:28(UTC)
New hear- Central Station 2 and my 1 gauge locomotives (Big scale)
by Simone458 26/09/2020 02:23:22(UTC)
Connecting Maerklin 7686 Turntable / Decoder to CS3+ Central Station (Digital)
by HellO 08/06/2020 12:03:20(UTC)
by Emin Evrankaya 04/04/2020 16:33:13(UTC)
New Central Station (Digital)
by oranda 30/03/2020 14:46:05(UTC)
Solved - Will a Central station 2 or 3 automatically recognize a Loksound V 4.0 decoder (General MRR)
by river6109 11/03/2020 03:57:58(UTC)
Is it worth adding layout to Central Station? (Digital)
by morsing 22/05/2019 12:28:39(UTC)
Another central station 60212 question (Digital)
Belarus DB Fan 10/03/2019 22:29:00(UTC)
Central Station 60212 question (Digital)
by DB Fan 06/03/2019 05:38:16(UTC)
Marklin Central Station 60215 busted? (General MRR)
by mattj70 01/03/2019 20:25:33(UTC)
connection K83 - Marklin central station (old) - Ecos2 > M-Keyboard (Digital)
by PkMärklin 05/02/2019 21:07:10(UTC)
Automation on G scale with Central Station 3 (Digital)
by PCRail 18/01/2019 21:21:16(UTC)
Network access for the Central Station CS3 plus (Digital)
by John Ferguson 08/09/2018 16:51:41(UTC)
RocRail softCentral Station CS3 plus (Digital)
by John Ferguson 29/08/2018 15:15:29(UTC)
Running Trains Digitally with the Central Station 3 (Accessories reviews)
by michelvr 11/11/2017 21:22:15(UTC)
by Michael Jervis 14/10/2017 13:56:31(UTC)
central station 2 for DCC 2 rail (Digital)
by daafies 18/09/2017 20:27:01(UTC)
by Twisterdodger 27/07/2017 19:54:23(UTC)
Central Station 3 (H0-scale)
by Torrid 06/05/2017 18:31:28(UTC)
What can the Central Station do? (Digital)
by morsing 08/04/2016 20:44:32(UTC)
Central Station1 programming track (Digital)
by magload 23/01/2016 14:26:31(UTC)
Central Station and PCs (Digital)
by nitramretep 30/12/2015 15:37:42(UTC)
Marklin Central Station Parts (Digital)
by chrisisrang 17/08/2015 04:42:40(UTC)
Central Station Question (Digital)
by sedgar2 09/08/2015 00:11:51(UTC)
Central Station Update - CS2 v4.0.1(3) available (Digital)
by Carlos 22/07/2015 20:07:07(UTC)
This page was generated in 0.788 seconds.
