Offline jacqvw
#1 Posted : 26 November 2013 03:55:07(UTC)
jacqvw
On my layout I have a few turnouts which are showing a different state between the CS2 keyboard and the layout. The keyboard state is the correct one.
On the photo "3 Kruis Tr4" and "4 Kruis Tr4" show curved on the keyboard (which is correct) and straight in the layout (which is wrong)
These turnouts are wired to a K83. But I also have two others with an internal Marklin decoder and with the same problem.
Does anybody has any suggestions how to correct this?
I tried:
- deleting the turnouts in the layout and redefining them
- deleting the turnouts in the layout, switching them to the other position and redefining them in the layout
but it doesn't help. They continue to give different positions.
THANKS FOR ANY HELP.
jacqvw attached the following image(s):
Marklin C 110m on 500 x 200 cm; CS2; North America era III
Offline jacqvw
#2 Posted : 26 November 2013 18:41:48(UTC)
jacqvw
The problem seems to be with keyboard addresses 15, 16 and 27, 28. Whatever accessory I connect, there is always a difference between keyboard and layout.
#3 Posted : 26 November 2013 18:48:45(UTC)
Did you set dip switches(k83) in correct way...?
Yours keyboard stand as number 1,which means 1-16 turnouts in correct way.
Offline jacqvw
#4 Posted : 26 November 2013 19:16:35(UTC)
jacqvw
Yes I checked and rechecked the dip switches. They are set correctly. I even changed out the K83, but the problem persists.
Would it be possible that those addresses in my CS2 60214, latest software version, are faulty??
#5 Posted : 26 November 2013 19:33:41(UTC)
Yours pic is from ipad?
I´m not right sure if you have problem with android and app...
Offline jacqvw
#6 Posted : 26 November 2013 19:39:50(UTC)
jacqvw
I used the iPad only to make the screen picture. The problem is also on the CS2. Keyboard says straight, layout screen says turn and vice versa, for the turnouts at addresses 15, 16 and 27 and 28.
Offline waorb
#7 Posted : 26 November 2013 20:07:18(UTC)
waorb
Brazil
Hello!
Did you try to invert the cables (blue wires) with red and green plugs that are connected to the K83?
Walter
#8 Posted : 26 November 2013 22:54:09(UTC)
Hello!
Walter
I wonder that too...
Seems good point here.
Offline jacqvw
#9 Posted : 27 November 2013 01:40:55(UTC)
jacqvw
The turnout is connected correctly, because switching with the keyboard is correct. The keyboard shows correct positions, red is straight on the turnout and green is left turn on the turnout. So nothing wrong there.
BUT.... If you look at the layout screen, it's just opposite! How can keyboard and layout be different?
How can I correct this?
#10 Posted : 27 November 2013 05:22:25(UTC)
Well, this isn't right, the turnout cables are not connected correctly.
green is straight and red is turning. what has been suggested before your wires are blue and your plugs are green and red. you've got 2 options just switch the plugs over or change the plugs from red to green and green to red.
your keyboard shows the correct position but your turnout cables are back to front.
regards.,
Offline jacqvw
#11 Posted : 29 November 2013 01:53:50(UTC)
jacqvw
Cables are not the problem. A turnout with an internal decoder shows exactly the same problem.
Switching with the keyboard is correct, but switching in the layout is just opposite.
Testing the turnout on a program track (of the CS2) didn't correct the problem either.
Just wanted to know if somebody else had the same experience and what to do to correct it.
Deleting my layout and define everything again, seems a bit far fetched, but maybe it is a solution.
Jack
Offline bo
#12 Posted : 12 December 2013 14:55:02(UTC)
bo
Ukraine
Jack
Hi Jack!
Probably this link might help to solve your problem!
I had the same issue, but I can't call to mind...
#13 Posted : 12 December 2013 15:37:27(UTC)
On the layout screen, click the wrench, click the turnout, then change type from left turnout to right turnout.
Wire Marklin turnouts 8561 to Rokuhan RC-03 (Small scale)
by dmazyn 22/01/2024 16:47:19(UTC)
Use of M-turnout motors in C-turnouts (General MRR)
by gimo49 20/01/2024 12:27:07(UTC)
Problems with turnouts (H0-scale)
by Arnstein 11/12/2023 11:00:30(UTC)
C track curved turnouts - single track to four (H0-scale)
by einotuominen 31/10/2023 07:38:03(UTC)
Turnouts (General MRR)
by sudibarba 20/08/2023 04:09:21(UTC)
Marklin turnouts are not power-routing (General MRR)
by Yoginath 06/07/2023 14:26:26(UTC)
Wide turnouts (General MRR)
by river6109 29/06/2023 10:17:13(UTC)
m83 decoder wire length to turnouts (Digital)
by swisslocofan 27/05/2023 04:16:19(UTC)
Use AC HO Marklin turnouts with DC power supply? (H0-scale)
by Yigal 14/05/2023 07:41:52(UTC)
Pickup shoe short circuit Turnouts (24771/2)? (H0-scale)
by flyhalf 22/01/2023 20:55:12(UTC)
Märklin Wide Radius Turnouts geometry (H0-scale)
by Patrik 01/09/2022 14:32:38(UTC)
Marklin 3600 WB Remote Operated Turnouts (Collector's Corner general)
by mb300e4m 01/08/2022 21:55:58(UTC)
Rocrail and threeway K turnouts (Model railroad software)
by pmgsr 17/05/2022 21:20:37(UTC)
Intermittent switching of turnouts (Digital)
by IBtrain 03/02/2022 06:34:02(UTC)
DCCNext and M turnouts (Model railroad wiring)
by IBtrain 14/01/2022 20:13:45(UTC)
turnouts (Big scale)
by Krish 13/08/2021 08:05:39(UTC)
Sticky turnouts (Digital)
by Rwill 12/06/2021 14:04:05(UTC)
MS2 Controlling Digital Turnouts in Analog Mode (General MRR)
by Joao Zilio 15/04/2021 19:29:53(UTC)
Turnouts (Model railroad wiring)
by Mr. Ron 07/03/2021 19:21:05(UTC)
Turnouts numbering (General MRR)
by Mr. Ron 01/03/2021 23:15:28(UTC)
7270 and C turnouts (H0-scale)
by carlos.rivas16752 13/02/2021 20:34:51(UTC)
Layout issues using a 6021 and 6001 with multiple Turnouts (Digital)
by waterslip 05/02/2021 03:38:34(UTC)
Long ICE cars rubbing turnouts semaphore m track (H0-scale)
by Victor Almeida 04/02/2021 02:56:37(UTC)
Peco turnouts code 100 (H0-scale)
by Harlov 18/12/2020 19:14:22(UTC)
M turnouts 5117, 5140, 5137 5202 for long coaches (H0-scale)
by 60904 25/11/2020 22:13:54(UTC)
Marklin Switches/turnouts/points - contact cleaning (Small scale)
by Poor Skeleton 17/10/2020 20:42:30(UTC)
2265 and 2266 turnouts and 75491 solenoid (H0-scale)
by Harvey 01/09/2020 20:12:41(UTC)
M track turnouts (H0-scale)
by Benders 16/08/2020 10:30:02(UTC)
Blue Transformers to Control Turnouts in Digital Ambient (Digital)
by Joao Zilio 28/05/2020 22:34:50(UTC)
Controlling 2 turnouts with 1 button (H0-scale)
by Brian_BR96 23/05/2020 02:16:48(UTC)
Marklin 88166/7 railbus and turnouts (Small scale)
by ajayrav 15/05/2020 17:18:55(UTC)
CS3 Track Diagram, Turnouts, etc (Digital)
by Twisterdodger 08/05/2020 16:52:08(UTC)
m83 - 2 turnouts with single address (Digital)
by bzzi 30/04/2020 01:23:00(UTC)
by JoeB 18/03/2020 01:56:33(UTC)
Marklin c track curves turnouts not reaching final position (H0-scale)
by Br01 26/02/2020 13:15:39(UTC)
Using a Transformer and 7210 Switches rather than Decoders on each turnouts. (H0-scale)
by Richard Joint 07/01/2020 03:33:52(UTC)
Inverted turnouts + random stop on locos (Digital)
by denis81 17/08/2019 23:16:30(UTC)
Controlling turnouts: Mobile Station or Control Box (Model railroad wiring)
by fstrobel 12/03/2019 21:53:20(UTC)
Physical button to control turnouts with decoder (Digital)
by denis81 06/03/2019 23:06:13(UTC)
CS2 not controlling turnouts. (Digital)
by franciscohg 25/09/2018 18:40:15(UTC)
Märklin M-track turnouts with solenoids versus K & C track (General MRR)
by river6109 25/06/2018 12:46:02(UTC)
turnouts wired to bus wiring (H0-scale)
by Primo -23K 21/12/2017 04:33:54(UTC)
Incorporating Marklin 24771 and 24772 -C-Track Right and Left Wide Radius Curved Turnouts (H0-scale)
by michelvr 10/12/2017 15:15:27(UTC)
I know they tell you not to...but why? Signals, turnouts etc etc (Model railroad wiring)
by Michael4 09/12/2017 18:29:14(UTC)
SNCF 241-A and outer curve of 24671 turnouts (H0-scale)
by db60 17/10/2017 21:34:30(UTC)
please help with turnouts and uncoupling (H0-scale)
by serge360 20/07/2017 16:16:27(UTC)
Turnouts (Digital)
by Don Morris 17/07/2017 09:15:53(UTC)
Shortcircuit in Peco turnouts (Big scale)
by Jaime 11/06/2017 14:41:34(UTC)
by drnodk 07/06/2017 18:38:44(UTC)
turnouts (Digital)
by drnodk 06/06/2017 02:28:21(UTC)
This page was generated in 0.706 seconds.
