M84
Offline Mille
#1 Posted : 25 April 2023 05:29:28(UTC)
Mille
Do i always need a m84 to
stop a train or is there a
another way?
Offline PeFu
#2 Posted : 25 April 2023 07:10:25(UTC)
PeFu
As I guess you are digital, you shouldn’t use a M84 (or a K84 or a signal) for abruptly stop your trains by simply cutting power. If you are using a CS3 or CS2 (or any other advanced control unit), my recommendation is that you
- use the action features included in the control unit (”good”), or
- use a PC software like Rocrail, TrainController or iTrain for controlling your trains (”better”).
If you are using a mobile station instead, an alternative would be using a ”brake module” for firmly stopping your trains. You can search for those in this forum. However, if you need and buy several commercial brake modules, this could be more expensive than buying a CS3 or 2nd hand CS2. There are though drawings for self-made brake modules on the net.
Smile
Edited by user 25 April 2023 12:51:50(UTC)  | Reason: Not specified
Offline Mille
#3 Posted : 25 April 2023 09:00:01(UTC)
Mille
Ok Thanks
Not sure i know how the trains would stop if im
Just using cs3
Offline PeFu
#4 Posted : 25 April 2023 11:00:16(UTC)
PeFu
Originally Posted by: Mille Go to Quoted Post
Ok Thanks
Just using cs3
There is a brake macro available for the CS3, here is a forum thread about it:
https://www.marklin-user...2441-CS3-new-BRAKE-macro
#5 Posted : 25 April 2023 12:05:48(UTC)
Ok Thanks
Just using cs3
The CS3 needs to know "When" , so it needs to have S88s (60881) and one Link 88 (60883) if you have a CS3 (60226)
The CS3 does not keep track of where is each loco, so for more than 2 or 3 locos, it needs the help of a train software like Rocrail, etc.
Before using Rocrail, I had a CS2 and tried using braking modules and the net result is:
- costly (you need one of those for every signal)
- heavy wiring (instead of one isolated section per signal you have 3)
- difficult to use in bi-directional blocks
After using Rocrail:
- no more stop sections
- no more brake modules
- no more signals unless needed for cosmetics
- any train can run reverse (loco pushing the train) and still stop at the right place (no need for an additional slider, slider inverter relay, conducting couplers
- any train slows down gently and starts smoothly even in hidden stations / in absence of signals
I suppose iTrain, TC and others have similar advantages.
Offline rhfil
#6 Posted : 25 April 2023 17:29:47(UTC)
rhfil
With a CS3/+ you can record an Event which uses timing to control a train. No other sensors are needed but it takes some effort to get correct. It is easier to use some kind of sensor on the layout, contact track, circuit track, or reed switch to initiate an event through a relay - Link S88 or S88 AC, depending on which CS you have.
Missing screw m83/m84 (General MRR)
by Goofy 23/11/2025 11:43:23(UTC)
About M84/M83 (Digital)
by ellim 03/10/2025 08:59:17(UTC)
60226, m84, 74391 and 74380 (Digital)
by Thewolf 09/09/2025 00:04:16(UTC)
Semaphores via M84/Rocrail? (Digital)
by JohnMishler 20/05/2025 21:49:51(UTC)
Marklin M84 with Viessmann 5100 (Digital)
by bgemski 16/05/2025 15:46:19(UTC)
Programming m84 (H0-scale)
by Alfred Bugeja 19/04/2025 05:31:37(UTC)
M84 Protocol (General MRR)
by Drongo 14/12/2024 22:37:28(UTC)
m83/m84 broken? (Digital)
by Goofy 15/11/2024 17:13:28(UTC)
Problem whit CS3 and M84 (H0-scale)
by Siluc94 03/11/2024 19:44:53(UTC)
m84 and switches (Digital)
by TashTrain 30/01/2024 10:51:17(UTC)
rotary Crane,CS3+,M84 (Digital components and Software reviews)
by ULI1944 10/12/2023 20:34:57(UTC)
M84 Decoder & Signals (H0-scale)
by Eddie7979 18/10/2023 02:57:41(UTC)
M84 with 8 adresses (Digital)
by Mille 30/05/2023 09:45:14(UTC)
My cs3 dont find my New m84 (Digital)
by Mille 10/05/2023 10:03:36(UTC)
M84 hissing sound (Digital)
by einotuominen 30/12/2022 10:50:45(UTC)
CS1 and m84 (Digital)
by pmgsr 22/05/2022 21:23:46(UTC)
M84 AC flickering led lights (Digital)
by Mbjerre 28/03/2022 13:06:41(UTC)
M84 Decoder, Cs3+, Minitrix Turntable (General MRR)
by Ngauging21 03/05/2021 08:36:17(UTC)
M83 M84 and S88 wire sizes (Model railroad wiring)
by Demch 28/12/2020 21:42:23(UTC)
How to connect Marklin M84 Decoder with Marklin 75491(turnout actuator) (Digital)
by nugroho2312 23/11/2020 09:39:37(UTC)
M84 (Digital)
by eurotrain 24/09/2020 15:43:03(UTC)
Configure M84 to Act as an M83 (Digital)
by rrf 15/12/2019 14:44:45(UTC)
M84 signal connector (General MRR)
by Minitrix&MärklinHen 14/09/2019 15:16:53(UTC)
Decoder m84 / decoupler track (H0-scale)
by dconner@freenet.de 22/08/2019 18:21:55(UTC)
Debugging New M84 (Digital)
by rrf 12/05/2019 16:56:18(UTC)
m84 screen questions (General MRR)
by rhfil 04/04/2019 15:57:51(UTC)
Lamp post connection to M84? (Digital)
by Harvey 09/03/2019 23:54:15(UTC)
Signal light on a M84 ,feedback from circuit track (Digital)
by geir 02/03/2019 23:29:37(UTC)
M84 and M83 (Model railroad wiring)
by Thewolf 17/02/2019 20:14:07(UTC)
M84 wiring (Digital)
by rhfil 13/02/2019 21:12:13(UTC)
Problem with M83, M84 & Universal Power Supply (Digital)
by rrf 01/02/2019 22:53:38(UTC)
mfx m84 and tortoise motor (Digital)
by Goofy 21/09/2018 17:12:28(UTC)
m84 strange behaviour (Digital)
by marklin61 12/09/2018 00:01:40(UTC)
m84 units short circuiting (Digital)
by Drongo 20/08/2018 12:50:09(UTC)
Bug on M84 switch setting ? (Digital)
by budi@ups4.com 01/08/2018 05:00:31(UTC)
M84 - 60842 (General MRR)
by ae66green 06/02/2018 18:40:41(UTC)
Marklin M84 (General MRR)
by ae66green 25/01/2018 22:38:33(UTC)
60822 universal power supply / 66367 power pack for M83/M84 (H0-scale)
by ae66green 17/01/2018 17:08:46(UTC)
Using a m84 for switching track current on and off (Digital)
by garben 13/01/2018 00:06:03(UTC)
M84 60842 (General MRR)
by ae66green 11/01/2018 17:35:32(UTC)
60841 m84 decoder availability? (General MRR)
by Joe Meiring 06/06/2017 13:41:20(UTC)
M84 & Hobby signal (H0-scale)
by Rwill 17/01/2017 21:28:06(UTC)
Now that the new m83/m84 are coming in 2017... whats the difference again? (H0-scale)
by Minok 14/01/2017 00:01:46(UTC)
FYI: 66361<66365> to be replaced with 66360<66367> (PowerSupply for MS2, L88, m83(opt), m84(opt) ..) (News from Märklin and others)
by clapcott 13/10/2016 20:59:52(UTC)
scheme of connections M84-74391 marklin (H0-scale)
by Thewolf 21/07/2016 23:43:07(UTC)
L88 and M84 - waiting for Marklin to ship to US (General MRR)
by Harvey 15/06/2016 03:11:22(UTC)
K84 and M84 decoders (Digital)
by sjbartels 19/03/2016 18:41:27(UTC)
M84 and signal V4011 (Viessmann) (Digital)
by Thewolf 02/10/2015 17:49:22(UTC)
Use of Decoders M83 M84 (Digital)
by Huco 09/09/2015 10:05:56(UTC)
M84 decoder question (Digital)
by Hackcell 07/06/2015 22:29:18(UTC)
This page was generated in 0.362 seconds.
