Offline Kyrannosaurus
#1 Posted : 26 July 2018 02:18:42(UTC)
Kyrannosaurus
I am very new to the hobby, it started when I found out about an old starter kit my Dad had back in the late 70's. Would really like to expand on the stuff and make a layout using M track as I can get access to lots of it for a cheaper price than c track and I haven't considered K track as the locomotives are centre rail run. So far I like M track as it's made of good metal (and I have heard about c track cracking), and can be ballasted to look pretty realistic with a bit of work. My only issue is that due to the rail profile, I am wondering if the wear the M track will cause on the locomotive wheels is significant. How much better is c track for decreased model wear? I am not interested in stuff like c track is quieter and smoother, I'm only interested in the potential wear to the loco's.
Cheers.
Edited by user 08 August 2018 11:02:28(UTC)  | Reason: Not specified
Offline analogmike
#2 Posted : 26 July 2018 03:08:59(UTC)
analogmike
Cheers.
Don't worry about it. I've been running M track for 50 years and the wheels don't wear.
Mikey
Offline applor
#3 Posted : 26 July 2018 04:08:10(UTC)
applor
and I haven't considered K track as the locomotives are centre rail run. with a bit of work.
K track has a centre stud as well.
Cheers.
Only the really early C track from the 90's suffered from that. M track can look OK but C track is far better in all ways. 2nd hand M track will likely have rust issues too.
You won't have wear issues on either but you may have running/derailment issues on the old M track and rust issues on 2nd hand track.
thanks 4 users liked this useful post by applor
#4 Posted : 26 July 2018 04:25:02(UTC)
Kyrannosaurus
Cheers guys. Most helpful.
#5 Posted : 26 July 2018 04:34:33(UTC)
Kyrannosaurus
Cheers.
That's great news! I've always liked k track for it's looks (don't like the integrated roadbed) but didn't think it was going to be an option. Anything else I need to know that is specific to running analogue loco's on k track? Were the derailment issues on m track due to the fact that it doesn't connect as well as c or k track?
#6 Posted : 26 July 2018 05:03:59(UTC)
The M-track derailment is overstated.. Any poorly laid track will cause derailment.. I have used m-track for decades and it works great on my computer controlled layout. The last derailment problem was actually caused by a HAMO loco that was converted to three rail the cheap way.. It also derailed on c-track.. I simply replaced the front bogie with the proper marklin part and, hey presto, no more derailment. Just don't do anything stupid like lay turnouts on an angle up a hill or use lots of s bends, and you will not have any serious problems.
As for rust... It is usually caused by a past owner using sandpaper to clean the tracks and removing the plating.. The tracks I bought new in 2000 never rust.. It can be more problematic if you live close to the coast - salt air.. I use a product on the rails called xxxxxxxxx (find it's name later), but the best way to keep the tracks clean is to keep running the trains - this is especially true for the center rail..
#7 Posted : 26 July 2018 06:44:50(UTC)
You won't have any issues if your M track is in near new condition, and it isn't to hard to come by in that condition.
Half of my layout is M track, the other half is C and there are no differences in wear and tear on locos from either track type.
I did replace all of my turnouts that had the large light with newer turnouts that have the smaller light, as the longer (27cm and above) passenger cars can clip the bigger light fitting and derail.
Any other derailing issues on M track is normally caused by older track pieces that have had a hard life, hence my recommendation to get pieces that are relatively new.
Offline 60904
#8 Posted : 26 July 2018 15:01:28(UTC)
60904
Cheers.
C Track until 2004 suffers from the disease. Best is to buy C Track with only the last 3 number printed, e.g. 130 instead of 24130.
Greetings
Martin
#9 Posted : 27 July 2018 12:12:24(UTC)
I use some older M-track in hidden areas, and I am regretting that.
In the automatic shaddow-stations, I have had to substitute the M-track for K-track, in order to have better detection. (It is so easy to isolate one of the rails on K-track, but almost impossible with M-track).
I dont have any C-track, but would definatly prefer that to M-track. M-track -especially older pieces WILL give you problems, if u want to run newer rolling stock, or rolling stock from other brands.
Even perfectly laid M-track can cause problems, especially over curved switches and scissor cross-overs...
If you plan to use VERY OLD M-track, take care that the switch-lanterns may conflict with longer rolling stock. (Not enough clearance)
#10 Posted : 27 July 2018 14:45:56(UTC)
This discussion comes up at least once a month!
I used to have M-track, some new and some old, on my layout. About 10-12 years ago I took advantage of having obtained some C-track in a couple of starter sets and changed over to C-track.
In terms of running qualities there is no comparison. Trains on C-track run much more quietly and smoothly. The tracks go together very positively and accurately, and gaps almost disappear, both on the base and the rails themselves, giving a much more seamless run, so that trains look much steadier than the same trains on M-track. C-track turnouts are a delight for all Marklin trains, and for all non-Marklin with the correct wheels.
As to wheel wear, I have been running trains for all of my life and have never seen significant wear on loco or wagon wheels.
The only negatives are the brittle nature of very early C-track and the poor reliability of the turnout motors (but they can be improved by by-passing the end cut-off micro-switches).
I cannot comment on K-track as I have never used it.
Offline dickinsonj
#11 Posted : 28 July 2018 17:03:29(UTC)
I have been replacing all of my older C Track with the stuff made after 2004, and I have not yet had a single problem with breakage in the track with the newer plastic formulation.
I have only recently moved past M Track and although C track can be a bit noisy I find that my trains run much more smoothly on it. I have never used K track but I agree that it looks very nice. I most likely have too much invested in all of my C track to change at this point, but I were just starting again, K track would be very tempting to me as well.
Track Screws for M yes M Track (H0-scale)
by frickwg 21/04/2024 20:19:36(UTC)
analog m track parts.. how to... (Model railroad wiring)
by lucasm54 21/04/2024 09:50:34(UTC)
Marklin M Track 5106 1/1 (H0-scale)
by MALAVIKA 18/02/2024 06:39:03(UTC)
M Track Switch Testing (H0-scale)
by baja463 01/02/2024 20:27:06(UTC)
Working with Marklin M track signals (General MRR)
by tandrschaefer 03/01/2024 21:41:00(UTC)
Speed on different types of M track (analogue) (H0-scale)
by Michael4 05/11/2023 17:30:21(UTC)
m track switch wiring question (H0-scale)
by heinrichhess 24/08/2023 12:04:59(UTC)
will m track fit Transfer Table (H0-scale)
by heinrichhess 20/08/2023 18:20:40(UTC)
odd numbered m track 36010 (H0-scale)
by heinrichhess 06/08/2023 12:29:08(UTC)
will Schicht runn on m track? (H0-scale)
by heinrichhess 21/07/2023 15:32:40(UTC)
M track (General MRR)
by Keim 24/05/2023 02:42:42(UTC)
Searching for info on this M track layout (H0-scale)
by Soylent73 30/04/2023 17:26:30(UTC)
Mixing C and M tracks - best tricks? (H0-scale)
by einotuominen 12/12/2022 17:53:29(UTC)
Compatible power supply for Marklin M Track? (General MRR)
by Skywalker646 10/12/2022 02:49:53(UTC)
Manual download for M track or vintage Marklin Accessories (H0-scale)
by tinroofrusted 12/10/2022 12:05:44(UTC)
Marvellous M track manufacture (H0-scale)
by Michael4 14/09/2022 11:52:27(UTC)
M Track (Digital)
Belarus muhkau 21/08/2022 09:00:55(UTC)
M track points lights (Model railroad wiring)
by mitchnz 12/08/2022 02:56:16(UTC)
New M track layout (H0-scale)
by Mr. Ron 21/07/2022 18:48:27(UTC)
Marklin HO M track 1937-50s Electric Points Cat No 13600 WB (H0-scale)
by David240945 10/05/2022 18:18:59(UTC)
Mixing M track and C track (Model railroad wiring)
by PedroRyder 13/01/2022 16:35:36(UTC)
Connecting a Jagerndorfer ho cable car set with an ESU 56002 sound decoder to a CS3 from track power (Digital)
by marklinist5999 03/01/2022 20:36:33(UTC)
AC Wheels for Liliput and Piko Wagons-M track (Collector's Corner general)
by Philipj 28/12/2021 20:56:55(UTC)
Marklin M Track 5117 Points / Led Bulbs (H0-scale)
by fossie 28/11/2021 10:53:09(UTC)
eCoS to M track points to marklin k83 (Model railroad wiring)
by Ausipeet 26/09/2021 06:32:55(UTC)
M track Connections (H0-scale)
by Mr. Ron 08/09/2021 03:21:05(UTC)
Solid Third Rail M Track (General MRR)
by mike c 10/08/2021 04:52:31(UTC)
Catenary fabrication for M track (H0-scale)
by Mr. Ron 12/07/2021 21:49:21(UTC)
analog signal on digital M track section of siding spur (Digital)
by marklinist5999 12/07/2021 14:23:02(UTC)
HO 2-rail rolling stock on Marklin M track (H0-scale)
by Mr. Ron 08/06/2021 04:59:47(UTC)
M track Figure 8 layouts (H0-scale)
by A4Gresley 01/05/2021 09:52:05(UTC)
Long ICE cars rubbing turnouts semaphore m track (H0-scale)
by Victor Almeida 04/02/2021 02:56:37(UTC)
Two locos simultaneously on m tracks (H0-scale)
by Petros 08/01/2021 20:40:35(UTC)
Marklin M track vs C track (General MRR)
by Tracy 29/12/2020 22:03:50(UTC)
M Track planning SW (Model railroad software)
by Vitsing 20/12/2020 05:34:47(UTC)
Which Controller works best with old M Track? 6021 or MS2? (Digital)
by SteveK-O 08/12/2020 15:38:21(UTC)
Wireless control of M track accessories (Digital)
by joyofmarklin 22/11/2020 03:43:22(UTC)
Joining M track sections (H0-scale)
by Mr. Ron 14/11/2020 09:04:18(UTC)
M Track (H0-scale)
by Mr. Ron 11/10/2020 22:40:36(UTC)
M track alignment (H0-scale)
by Mr. Ron 11/10/2020 20:22:47(UTC)
Safe distance from the edge of baseboard cleance fror M track (H0-scale)
by nzrabbitty 06/10/2020 06:05:52(UTC)
M TRACK CATERNARY (H0-scale)
by frickwg 28/08/2020 23:22:56(UTC)
Damaged M TRACK (H0-scale)
by Francios 25/08/2020 18:34:24(UTC)
M track, catenary and helixes (or helices) (H0-scale)
by Michael4 25/08/2020 15:30:16(UTC)
M track turnouts (H0-scale)
by Benders 16/08/2020 10:30:02(UTC)
M Track Uncoupler and Light Post (H0-scale)
by sharples 10/08/2020 19:21:31(UTC)
who says M track is not true to reallity (Prototype)
by dominator 09/08/2020 23:04:39(UTC)
Testing M Track for Current (H0-scale)
by sharples 11/07/2020 06:43:38(UTC)
M track (H0-scale)
by Mr. Ron 08/07/2020 01:16:39(UTC)
My Layout - w/ SCARM Track Planning help (Track plans)
by HokieCE70 27/05/2020 06:54:14(UTC)
This page was generated in 1.054 seconds.
