Offline bygger01
#1 Posted : 10 October 2025 17:14:04(UTC)
bygger01
When I start up my CS3+, it often happens that a single mfx locomotive has its decoder reloaded.
Is there a specific known reason for this?
Jørgen St. from Herning in DK
H0 / Märklin K track / CS3+ / full digital / Epoke III +/-
thanks 1 user liked this useful post by bygger01
Offline rhfil
#2 Posted : 10 October 2025 19:03:35(UTC)
rhfil
I have seen it happen with our club CS3+ but no other and have used two other CS3+. mfx locomotives have a DCC address and a mfx one. The mfx one must be unique as the CS3 assigns it. I wonder if your mfx loco has the same DCC address as another loco? Our club CS3+ has well over 200 locos registered so a duplicate DCC address is a possibility. It is possible to list locos by address but not sure if you can soecify DCC address. Perhaps if you turn off the mfx feature.
Offline bygger01
#3 Posted : 11 October 2025 09:32:54(UTC)
bygger01
Thanks for hearing your theory!
I will try to note the locomotives that are reloaded, and then we can see if there are any "hits" (there are about 40 in total, some of which are on the track).
#4 Posted : 11 October 2025 11:46:22(UTC)
Why needing to register anew ?
This is typical of an MFX loco not fully registered (other protocols MM2 and DCC do not have registration)
What to do about it?
Simple: you pose your loco on the programming track and let it register fully and you are done.
Once the loco is registered anew, (at the begin of the loco list with a red oval symbol instead of a full one) Switch to edit loco mode, select the loco and start editing - changing parameters) and after a while validate. The loco should now return to its normal position in the list and the red oval tage (low center screen) is now ful / plain). The loso is not anymore listed at the list's begin but where it belongs (sorting by address or by name)
Notes
In the Märklin world MFX has the top priority and with default factory settings the CS3 will use MFX protocol with MFX capable locos and simply ignore other protocols.
Märklin decoders will also ignore other protocols (your CS3 is multi-protocols by default) if MFX signal is present and if the MFX protocol has not been inhibited on your loco.
A good practice for all new locos is to make their registration on the programming track as on large layouts with many locos and long cabling, the registration may be not so effective.
The use of the Ethernet plug (I use Rocrail with a lot of data exchange) may pollute a clean registration so unplugging it during the registration may help
Offline rhfil
#5 Posted : 11 October 2025 13:28:28(UTC)
rhfil
When we operatw the club layout though over 200 locos are registered on the CS3+ there will be at most five at one time on it. And they may be five which until that day had never been registered on the CS3+. We never use the programming track to register. In fact until fairly recently only one member who showed up regularly when the layout was operating even knew there was a programming track.
Offline bygger01
#6 Posted : 11 October 2025 14:24:56(UTC)
bygger01
Hi Jean
First I must admit that with a new mfx locomotive, in recent years I have simply placed it in front of the place with CS3 and let the registration happen there and not on the registration track!
And I have even made small adjustments with sound and such in the same session.
Since you always provide good, well-thought-out advice, the following happens:
In the future I will change that so that everything happens on the registration track but with my age etc. there will be many more draft animals for the system.
There is actually only one planned, and it is a Frichs Firkant with a Loksound 5 decoder, which also works as mfx.
So in the future I will try to follow your recommendations to use registration tracks when it comes to:
• A new locomotive
• When a "random" locomotive is updated when CS3 is started, it is now via registration track
• When there are changes to the decoder
And then I have to start noting which mfxs have been that way, to see that there are no repeats. But it takes time, so it will probably take 6-12 months, so I have to remember to come back…….
cs3+ voltage output (Digital)
by fabstar68 10/11/2025 17:37:17(UTC)
CS3+ + booster + L88 (Digital)
by BenP 09/07/2025 16:24:34(UTC)
60VA v 100VA for CS3+ (Digital)
by BenP 28/06/2025 22:50:45(UTC)
Help! CS3+ seems to be changing my turnout addresses when I add mfx device (Digital components and Software reviews)
by tgj 04/05/2025 19:44:59(UTC)
IP address of two CS3+ (Digital)
by Capitole 03/04/2025 09:43:46(UTC)
CS3+ with a CS3 slave (Digital)
by rhfil 21/03/2025 22:53:17(UTC)
issue with locos that doesn't stop on cs3+ (Digital)
by Adrian666 11/03/2025 13:31:25(UTC)
Other digital brands on cs3+ marklin system (Digital)
by Adrian666 10/03/2025 19:09:40(UTC)
S88 Events via UDP CAN Gateway für CS3+ und Rocrail (Digital)
by rinderkn 09/02/2025 16:55:55(UTC)
CS3+ (Digital)
by greatrocks 15/12/2024 00:00:09(UTC)
Locomotive (mfx) not showing up in list on CS3+ (Digital)
by micknudsen 24/11/2024 12:49:35(UTC)
Can Marklin CS3+ connect with servo? (Digital)
by Solar007 27/09/2024 11:22:36(UTC)
CS3+ (Digital)
by Carlos 28/07/2024 17:16:04(UTC)
CS3+ (Digital)
by Mailme 11/07/2024 03:53:39(UTC)
CS3/cs3+ update 2.5.2 (Digital)
by Flupke 22/06/2024 20:05:21(UTC)
CS3+ S88 Arduino connection (Digital components and Software reviews)
by Tue Albertsen 26/03/2024 17:15:21(UTC)
CS3+ automation macros examples & documentation (Digital)
by fabstar68 18/03/2024 15:04:49(UTC)
CS3+ Locomotive data pictures (Digital)
by MSanches 27/02/2024 10:48:24(UTC)
do the lok data cards - 60135 - work with CS3+? (Digital)
by roedj 10/01/2024 12:14:32(UTC)
Cs3+ (H0-scale)
by bobgiam 16/12/2023 01:17:51(UTC)
rotary Crane,CS3+,M84 (Digital components and Software reviews)
by ULI1944 10/12/2023 20:34:57(UTC)
CS3+ update using USB stick. (Digital)
by Flupke 13/11/2023 16:33:07(UTC)
Backdating a CS3+ (Digital)
by Drongo 22/08/2023 12:40:28(UTC)
CS3+ Help: cannot create "areas" on layout (Digital)
by plg 03/06/2023 21:00:28(UTC)
Use old 6083 (K83) and 6084 (K84) with CS3+? (Digital)
by Feelixen 18/05/2023 14:45:27(UTC)
CS3+ Events (Digital)
by Drongo 27/04/2023 07:40:50(UTC)
Loco speed in RocRail and CS3+ (Digital)
by Tue Albertsen 15/04/2023 17:30:21(UTC)
CS3+ Track Current Monitor (Digital)
by kolabuzlu 25/02/2023 18:58:12(UTC)
CS3+ and DCC (Digital)
by roedj 16/02/2023 12:35:52(UTC)
Resetting CS3+ (Digital)
by Carlos 20/12/2022 20:04:27(UTC)
CS3+ & Lenz LS150 (Digital)
by bygger01 18/12/2022 12:38:09(UTC)
Registering decoders on three way points on CS3+ and CS2 and other problems (Digital)
by DV 11/08/2022 10:30:31(UTC)
CS3+ VNC Viewer not working (Digital)
by Diesel2000 23/07/2022 23:54:31(UTC)
Update Of Old/Early CS3+ (Digital)
by bugsmasher 26/06/2022 02:36:48(UTC)
Update CS3+ v.2.4.0 (Digital)
by fhp2 22/03/2022 08:58:32(UTC)
GUI and GFP in the CS3/CS3+ (Digital)
by fosuna 04/03/2022 07:33:06(UTC)
CS3/ CS3+ (Digital)
by bgemski 01/03/2022 16:00:15(UTC)
Locomotives controlled by CS3+ loose settings (light, sound ...) after restart of CS3+ & speedchange (Digital)
by HaraldOnline 24/01/2022 09:05:57(UTC)
How to run CS3+ events at a specific time of the day? (Digital)
Belarus Nick1150 22/01/2022 11:43:05(UTC)
ITrain, CS3+ and manual control (Model railroad software)
by Puttputtmaru 17/01/2022 00:17:56(UTC)
CS3+ cannot find locos based on mfx protocol (Digital)
by eldar760 12/01/2022 03:30:09(UTC)
Motor 74491 decoder 60831 and CS3+ (Digital)
by Rolando 31/12/2021 11:05:22(UTC)
Sound on CS3 and CS3+ (Digital)
by Joakim_B 10/12/2021 23:11:13(UTC)
Märklin CS3+ & Web interface problem (Digital)
by BOOMerCH 25/09/2021 20:40:05(UTC)
Can I mix a CS3+ with an EcoS (Digital)
by Drongo 08/08/2021 12:40:19(UTC)
CS3+ S88 contact track event (Digital)
by marklinist5999 03/08/2021 15:11:05(UTC)
M84 Decoder, Cs3+, Minitrix Turntable (General MRR)
by Ngauging21 03/05/2021 08:36:17(UTC)
CS3+ and PSX circuit breakers (Digital)
by trentschler 14/04/2021 18:05:01(UTC)
Changing cs3+ from main to auxiliary control (H0-scale)
by Umesh 23/02/2021 15:04:37(UTC)
CS3+ and Event Logging (Digital)
by magicmushroom 17/01/2021 20:35:43(UTC)
This page was generated in 0.306 seconds.
