Offline greatrocks
#1 Posted : 15 December 2024 00:00:09(UTC)
greatrocks
Hello All,
First of all, Merry Christmas!. I have a nice size Marklin layout, 400 cm x 240 cm. I am using a CS3+ for the controller. Every so often, one or more of my engines will activate even though not being selected when I power on the controller. I have to go into the engine profile and select a feature, and it usually addresses the problem. In my layman's understanding of packet transport and digital addressing, it appears to be a bug in the controller S/W. I have updated to 2.5.2.6 but still the same random issues occurs.
Any suggestions most appreciated.
I have about 25 engines in various parts of the layout. I also have some random spots where an engine may stop. If I move it a little bit, it starts working again. I use C-Track.
Thanks!
Frank
thanks 1 user liked this useful post by greatrocks
Offline rhfil
#2 Posted : 15 December 2024 00:36:09(UTC)
rhfil
I learned that the engine decoder stores the information when last on the layout and operated. So the next time you place it on the layout all the functions will continue to be active including the speed unless you have turned all of them off. There is also a setting which restores all loco settings to their last known state. See page 33 of the online CS3+ manual.
#3 Posted : 15 December 2024 00:42:27(UTC)
Hi Frank
Merry Christmas to you too.
What you observe is the sign of wiring which needs improvements. It may be very nice looking but still have problems.
The key targets
- be as short as possible between the source (CS3+) and the feeding point
- there must be as few as possible connections (screw terminals, sockets, etc)
Here are some tips if I may:
- use 0.75 mm² gauge
- wire in a star-like manner starting from your CS3 ("Ringleitungen" are a stupidity for digital)
- wire permanently the ground return as no interruption is needed to locate a short-circuit. So no connectors / plugs of any kind needed there.
- avoid using Märklin / Brawa/ Viessann plugs as they offer resistance and have a tandancy to pop-out
- arrange your layout in zones whose center rail is isolated from other zones, thus allowing to find where a short is located. One method is to use a 5W lamp for cars is series to feed the "B" of the zone. They have a very low resistance and the one feeding a zone having a short, will lightup.
- arrange a separate wiring for all decoders and avoid embedded decoders plugged to the track (excellent for carpet trains but very poor for permanent layouts).
- you MUST chase all possible causes for temporary shorts (rather rare using C track but still may happen) as it pollutes the digital signal and may translate into fantom commands.
I am not more intelligent than others but rather I have experienced the effects you describe on certain zones of my layout and fixed the issues.
THERE ARE NO BUGS IN CS3 VERSIONS related to unwanted actions on locos. Wiring issues ONLY.
My layout uses a CS3 with a 100 W power supply, has 28 locos, has no insulated sections because Rocrail controls the stopping and speed of each loco (better for continuity and simplifiedf wiring. This also means that all locos are powered, all passenger cars are lit, lanterns are fed from the track
Here is my layout (at the time with a CS2 and 100 W PSU
https://www.youtube.com/watch?v=F6WnhXPcRqI
Offline greatrocks
#4 Posted : 15 December 2024 02:41:09(UTC)
greatrocks
Thanks! Very good information Jean!
cs3+ voltage output (Digital)
by fabstar68 10/11/2025 17:37:17(UTC)
CS3+ (Digital)
by bygger01 10/10/2025 17:14:04(UTC)
CS3+ + booster + L88 (Digital)
by BenP 09/07/2025 16:24:34(UTC)
60VA v 100VA for CS3+ (Digital)
by BenP 28/06/2025 22:50:45(UTC)
Help! CS3+ seems to be changing my turnout addresses when I add mfx device (Digital components and Software reviews)
by tgj 04/05/2025 19:44:59(UTC)
IP address of two CS3+ (Digital)
by Capitole 03/04/2025 09:43:46(UTC)
CS3+ with a CS3 slave (Digital)
by rhfil 21/03/2025 22:53:17(UTC)
issue with locos that doesn't stop on cs3+ (Digital)
by Adrian666 11/03/2025 13:31:25(UTC)
Other digital brands on cs3+ marklin system (Digital)
by Adrian666 10/03/2025 19:09:40(UTC)
S88 Events via UDP CAN Gateway für CS3+ und Rocrail (Digital)
by rinderkn 09/02/2025 16:55:55(UTC)
Locomotive (mfx) not showing up in list on CS3+ (Digital)
by micknudsen 24/11/2024 12:49:35(UTC)
Can Marklin CS3+ connect with servo? (Digital)
by Solar007 27/09/2024 11:22:36(UTC)
CS3+ (Digital)
by Carlos 28/07/2024 17:16:04(UTC)
CS3+ (Digital)
by Mailme 11/07/2024 03:53:39(UTC)
CS3/cs3+ update 2.5.2 (Digital)
by Flupke 22/06/2024 20:05:21(UTC)
CS3+ S88 Arduino connection (Digital components and Software reviews)
by Tue Albertsen 26/03/2024 17:15:21(UTC)
CS3+ automation macros examples & documentation (Digital)
by fabstar68 18/03/2024 15:04:49(UTC)
CS3+ Locomotive data pictures (Digital)
by MSanches 27/02/2024 10:48:24(UTC)
do the lok data cards - 60135 - work with CS3+? (Digital)
by roedj 10/01/2024 12:14:32(UTC)
Cs3+ (H0-scale)
by bobgiam 16/12/2023 01:17:51(UTC)
rotary Crane,CS3+,M84 (Digital components and Software reviews)
by ULI1944 10/12/2023 20:34:57(UTC)
CS3+ update using USB stick. (Digital)
by Flupke 13/11/2023 16:33:07(UTC)
Backdating a CS3+ (Digital)
by Drongo 22/08/2023 12:40:28(UTC)
CS3+ Help: cannot create "areas" on layout (Digital)
by plg 03/06/2023 21:00:28(UTC)
Use old 6083 (K83) and 6084 (K84) with CS3+? (Digital)
Belarus Feelixen 18/05/2023 14:45:27(UTC)
CS3+ Events (Digital)
by Drongo 27/04/2023 07:40:50(UTC)
Loco speed in RocRail and CS3+ (Digital)
by Tue Albertsen 15/04/2023 17:30:21(UTC)
CS3+ Track Current Monitor (Digital)
by kolabuzlu 25/02/2023 18:58:12(UTC)
CS3+ and DCC (Digital)
by roedj 16/02/2023 12:35:52(UTC)
Resetting CS3+ (Digital)
by Carlos 20/12/2022 20:04:27(UTC)
CS3+ & Lenz LS150 (Digital)
by bygger01 18/12/2022 12:38:09(UTC)
Registering decoders on three way points on CS3+ and CS2 and other problems (Digital)
by DV 11/08/2022 10:30:31(UTC)
CS3+ VNC Viewer not working (Digital)
by Diesel2000 23/07/2022 23:54:31(UTC)
Update Of Old/Early CS3+ (Digital)
by bugsmasher 26/06/2022 02:36:48(UTC)
Update CS3+ v.2.4.0 (Digital)
by fhp2 22/03/2022 08:58:32(UTC)
GUI and GFP in the CS3/CS3+ (Digital)
by fosuna 04/03/2022 07:33:06(UTC)
CS3/ CS3+ (Digital)
by bgemski 01/03/2022 16:00:15(UTC)
Locomotives controlled by CS3+ loose settings (light, sound ...) after restart of CS3+ & speedchange (Digital)
by HaraldOnline 24/01/2022 09:05:57(UTC)
How to run CS3+ events at a specific time of the day? (Digital)
by Nick1150 22/01/2022 11:43:05(UTC)
ITrain, CS3+ and manual control (Model railroad software)
by Puttputtmaru 17/01/2022 00:17:56(UTC)
CS3+ cannot find locos based on mfx protocol (Digital)
by eldar760 12/01/2022 03:30:09(UTC)
Motor 74491 decoder 60831 and CS3+ (Digital)
by Rolando 31/12/2021 11:05:22(UTC)
Sound on CS3 and CS3+ (Digital)
by Joakim_B 10/12/2021 23:11:13(UTC)
Märklin CS3+ & Web interface problem (Digital)
by BOOMerCH 25/09/2021 20:40:05(UTC)
Can I mix a CS3+ with an EcoS (Digital)
by Drongo 08/08/2021 12:40:19(UTC)
CS3+ S88 contact track event (Digital)
by marklinist5999 03/08/2021 15:11:05(UTC)
M84 Decoder, Cs3+, Minitrix Turntable (General MRR)
by Ngauging21 03/05/2021 08:36:17(UTC)
CS3+ and PSX circuit breakers (Digital)
by trentschler 14/04/2021 18:05:01(UTC)
Changing cs3+ from main to auxiliary control (H0-scale)
by Umesh 23/02/2021 15:04:37(UTC)
CS3+ and Event Logging (Digital)
by magicmushroom 17/01/2021 20:35:43(UTC)
This page was generated in 0.537 seconds.
