Offline bobgiam
#1 Posted : 16 December 2023 01:17:51(UTC)
bobgiam
I have connected a mouse to one of the USB ports on the back of the CS3+. The CS3+ does not recognize the mouse. Is there something I have to do to setup the mouse?
thanks 1 user liked this useful post by bobgiam
Offline PerR
#2 Posted : 16 December 2023 07:58:53(UTC)
PerR
One of the USB ports are for charging only. Try to move the mouse to one of the other ones.
Per
thanks 1 user liked this useful post by PerR
Offline Copenhagen
#3 Posted : 16 December 2023 12:42:12(UTC)
Copenhagen
It is possible that the CS3 may not recognise the mouse, even in the right port. When I attached a mouse to my CS3 I tried a couple that I had lying around and at least one of them wouldn't work.
Edited by user 17 December 2023 00:16:22(UTC)  | Reason: Not specified
#4 Posted : 16 December 2023 21:07:22(UTC)
Yep, I agree. I would not be trying any of those 27 button gaming mice. A simple Logitec mouse (e.g. a G203) should be fine.
Offline Flupke
#5 Posted : 16 December 2023 21:10:59(UTC)
Flupke
I bought a simple cheap Logitech mouse at Target and plugged it in and it started working right away.
thanks 2 users liked this useful post by Flupke
Online rhfil
#6 Posted : 17 December 2023 11:06:30(UTC)
rhfil
I agree with the plug and play. No mouse of mine ever failed to work with the CS3+ but I do remember when one had to load a driver to work with the mouse. Apparently those days are gone.
cs3+ voltage output (Digital)
by fabstar68 10/11/2025 17:37:17(UTC)
CS3+ (Digital)
by bygger01 10/10/2025 17:14:04(UTC)
CS3+ + booster + L88 (Digital)
by BenP 09/07/2025 16:24:34(UTC)
60VA v 100VA for CS3+ (Digital)
by BenP 28/06/2025 22:50:45(UTC)
Help! CS3+ seems to be changing my turnout addresses when I add mfx device (Digital components and Software reviews)
by tgj 04/05/2025 19:44:59(UTC)
IP address of two CS3+ (Digital)
by Capitole 03/04/2025 09:43:46(UTC)
CS3+ with a CS3 slave (Digital)
by rhfil 21/03/2025 22:53:17(UTC)
issue with locos that doesn't stop on cs3+ (Digital)
by Adrian666 11/03/2025 13:31:25(UTC)
Other digital brands on cs3+ marklin system (Digital)
by Adrian666 10/03/2025 19:09:40(UTC)
S88 Events via UDP CAN Gateway für CS3+ und Rocrail (Digital)
by rinderkn 09/02/2025 16:55:55(UTC)
CS3+ (Digital)
by greatrocks 15/12/2024 00:00:09(UTC)
Locomotive (mfx) not showing up in list on CS3+ (Digital)
by micknudsen 24/11/2024 12:49:35(UTC)
Can Marklin CS3+ connect with servo? (Digital)
by Solar007 27/09/2024 11:22:36(UTC)
CS3+ (Digital)
by Carlos 28/07/2024 17:16:04(UTC)
CS3+ (Digital)
by Mailme 11/07/2024 03:53:39(UTC)
CS3/cs3+ update 2.5.2 (Digital)
by Flupke 22/06/2024 20:05:21(UTC)
CS3+ S88 Arduino connection (Digital components and Software reviews)
by Tue Albertsen 26/03/2024 17:15:21(UTC)
CS3+ automation macros examples & documentation (Digital)
by fabstar68 18/03/2024 15:04:49(UTC)
CS3+ Locomotive data pictures (Digital)
by MSanches 27/02/2024 10:48:24(UTC)
do the lok data cards - 60135 - work with CS3+? (Digital)
by roedj 10/01/2024 12:14:32(UTC)
rotary Crane,CS3+,M84 (Digital components and Software reviews)
by ULI1944 10/12/2023 20:34:57(UTC)
CS3+ update using USB stick. (Digital)
by Flupke 13/11/2023 16:33:07(UTC)
Backdating a CS3+ (Digital)
by Drongo 22/08/2023 12:40:28(UTC)
CS3+ Help: cannot create "areas" on layout (Digital)
by plg 03/06/2023 21:00:28(UTC)
Use old 6083 (K83) and 6084 (K84) with CS3+? (Digital)
by Feelixen 18/05/2023 14:45:27(UTC)
CS3+ Events (Digital)
by Drongo 27/04/2023 07:40:50(UTC)
Loco speed in RocRail and CS3+ (Digital)
by Tue Albertsen 15/04/2023 17:30:21(UTC)
CS3+ Track Current Monitor (Digital)
by kolabuzlu 25/02/2023 18:58:12(UTC)
CS3+ and DCC (Digital)
by roedj 16/02/2023 12:35:52(UTC)
Resetting CS3+ (Digital)
by Carlos 20/12/2022 20:04:27(UTC)
CS3+ & Lenz LS150 (Digital)
by bygger01 18/12/2022 12:38:09(UTC)
Registering decoders on three way points on CS3+ and CS2 and other problems (Digital)
by DV 11/08/2022 10:30:31(UTC)
CS3+ VNC Viewer not working (Digital)
by Diesel2000 23/07/2022 23:54:31(UTC)
Update Of Old/Early CS3+ (Digital)
by bugsmasher 26/06/2022 02:36:48(UTC)
Update CS3+ v.2.4.0 (Digital)
by fhp2 22/03/2022 08:58:32(UTC)
GUI and GFP in the CS3/CS3+ (Digital)
by fosuna 04/03/2022 07:33:06(UTC)
CS3/ CS3+ (Digital)
by bgemski 01/03/2022 16:00:15(UTC)
Locomotives controlled by CS3+ loose settings (light, sound ...) after restart of CS3+ & speedchange (Digital)
by HaraldOnline 24/01/2022 09:05:57(UTC)
How to run CS3+ events at a specific time of the day? (Digital)
by Nick1150 22/01/2022 11:43:05(UTC)
ITrain, CS3+ and manual control (Model railroad software)
by Puttputtmaru 17/01/2022 00:17:56(UTC)
CS3+ cannot find locos based on mfx protocol (Digital)
by eldar760 12/01/2022 03:30:09(UTC)
Motor 74491 decoder 60831 and CS3+ (Digital)
by Rolando 31/12/2021 11:05:22(UTC)
Sound on CS3 and CS3+ (Digital)
by Joakim_B 10/12/2021 23:11:13(UTC)
Märklin CS3+ & Web interface problem (Digital)
by BOOMerCH 25/09/2021 20:40:05(UTC)
Can I mix a CS3+ with an EcoS (Digital)
by Drongo 08/08/2021 12:40:19(UTC)
CS3+ S88 contact track event (Digital)
by marklinist5999 03/08/2021 15:11:05(UTC)
M84 Decoder, Cs3+, Minitrix Turntable (General MRR)
by Ngauging21 03/05/2021 08:36:17(UTC)
CS3+ and PSX circuit breakers (Digital)
by trentschler 14/04/2021 18:05:01(UTC)
Changing cs3+ from main to auxiliary control (H0-scale)
by Umesh 23/02/2021 15:04:37(UTC)
CS3+ and Event Logging (Digital)
by magicmushroom 17/01/2021 20:35:43(UTC)
This page was generated in 0.267 seconds.
