Offline eurotrain
#1 Posted : 24 September 2020 15:43:03(UTC)
eurotrain
I have a new M84 that i want to change to 16 switches for train crossing lights etc. I can toggle the first address to green/red no problem, but when i want to change
cv79 I can't even find that CV in the list. I only have CV 1-6. When I go to the program function, I can only see the 60841 option for the Confused older version CS2 and it will load another 16 CV values but still no CV79. I can't find the option Confused for CS3. and 60482
Perhaps my 2.0 CS3 update didn't register completely?
I can't even find the new M84 when i ask the system to look for new MFX devises?
What is the problem?
Offline franciscohg
#2 Posted : 24 September 2020 17:30:22(UTC)
franciscohg
Chile
Hello
Just unpacked and installed one.
Set an adress with DIPs with DCC on.
Then connected it to the track,, used the discover mfx item function, and then select the keep adress option.
It was succesfully discovered and registered.
In the solenoids page of CS3 items then appeared in edit mode the 4 switches icon and a m84 icon, editing the latter i was able to access CV79 and output configuration with no problems.
Hope this helps
Offline franciscohg
#3 Posted : 24 September 2020 21:18:55(UTC)
franciscohg
Chile
And, if you want 8 adresses, after programming that, you must delete and rediscover the item. That way the CS3 recognize them automatically
Missing screw m83/m84 (General MRR)
by Goofy 23/11/2025 11:43:23(UTC)
About M84/M83 (Digital)
by ellim 03/10/2025 08:59:17(UTC)
60226, m84, 74391 and 74380 (Digital)
by Thewolf 09/09/2025 00:04:16(UTC)
Semaphores via M84/Rocrail? (Digital)
by JohnMishler 20/05/2025 21:49:51(UTC)
Marklin M84 with Viessmann 5100 (Digital)
by bgemski 16/05/2025 15:46:19(UTC)
Programming m84 (H0-scale)
by Alfred Bugeja 19/04/2025 05:31:37(UTC)
M84 Protocol (General MRR)
by Drongo 14/12/2024 22:37:28(UTC)
m83/m84 broken? (Digital)
by Goofy 15/11/2024 17:13:28(UTC)
Problem whit CS3 and M84 (H0-scale)
by Siluc94 03/11/2024 19:44:53(UTC)
m84 and switches (Digital)
by TashTrain 30/01/2024 10:51:17(UTC)
rotary Crane,CS3+,M84 (Digital components and Software reviews)
by ULI1944 10/12/2023 20:34:57(UTC)
M84 Decoder & Signals (H0-scale)
by Eddie7979 18/10/2023 02:57:41(UTC)
M84 with 8 adresses (Digital)
by Mille 30/05/2023 09:45:14(UTC)
My cs3 dont find my New m84 (Digital)
by Mille 10/05/2023 10:03:36(UTC)
M84 (Digital)
by Mille 25/04/2023 05:29:28(UTC)
M84 hissing sound (Digital)
by einotuominen 30/12/2022 10:50:45(UTC)
CS1 and m84 (Digital)
by pmgsr 22/05/2022 21:23:46(UTC)
M84 AC flickering led lights (Digital)
by Mbjerre 28/03/2022 13:06:41(UTC)
M84 Decoder, Cs3+, Minitrix Turntable (General MRR)
by Ngauging21 03/05/2021 08:36:17(UTC)
M83 M84 and S88 wire sizes (Model railroad wiring)
by Demch 28/12/2020 21:42:23(UTC)
How to connect Marklin M84 Decoder with Marklin 75491(turnout actuator) (Digital)
by nugroho2312 23/11/2020 09:39:37(UTC)
Configure M84 to Act as an M83 (Digital)
by rrf 15/12/2019 14:44:45(UTC)
M84 signal connector (General MRR)
by Minitrix&MärklinHen 14/09/2019 15:16:53(UTC)
Decoder m84 / decoupler track (H0-scale)
by dconner@freenet.de 22/08/2019 18:21:55(UTC)
Debugging New M84 (Digital)
by rrf 12/05/2019 16:56:18(UTC)
m84 screen questions (General MRR)
by rhfil 04/04/2019 15:57:51(UTC)
Lamp post connection to M84? (Digital)
by Harvey 09/03/2019 23:54:15(UTC)
Signal light on a M84 ,feedback from circuit track (Digital)
by geir 02/03/2019 23:29:37(UTC)
M84 and M83 (Model railroad wiring)
by Thewolf 17/02/2019 20:14:07(UTC)
M84 wiring (Digital)
by rhfil 13/02/2019 21:12:13(UTC)
Problem with M83, M84 & Universal Power Supply (Digital)
by rrf 01/02/2019 22:53:38(UTC)
mfx m84 and tortoise motor (Digital)
by Goofy 21/09/2018 17:12:28(UTC)
m84 strange behaviour (Digital)
by marklin61 12/09/2018 00:01:40(UTC)
m84 units short circuiting (Digital)
by Drongo 20/08/2018 12:50:09(UTC)
Bug on M84 switch setting ? (Digital)
by budi@ups4.com 01/08/2018 05:00:31(UTC)
M84 - 60842 (General MRR)
by ae66green 06/02/2018 18:40:41(UTC)
Marklin M84 (General MRR)
by ae66green 25/01/2018 22:38:33(UTC)
60822 universal power supply / 66367 power pack for M83/M84 (H0-scale)
by ae66green 17/01/2018 17:08:46(UTC)
Using a m84 for switching track current on and off (Digital)
by garben 13/01/2018 00:06:03(UTC)
M84 60842 (General MRR)
by ae66green 11/01/2018 17:35:32(UTC)
60841 m84 decoder availability? (General MRR)
by Joe Meiring 06/06/2017 13:41:20(UTC)
M84 & Hobby signal (H0-scale)
by Rwill 17/01/2017 21:28:06(UTC)
Now that the new m83/m84 are coming in 2017... whats the difference again? (H0-scale)
Belarus Minok 14/01/2017 00:01:46(UTC)
FYI: 66361<66365> to be replaced with 66360<66367> (PowerSupply for MS2, L88, m83(opt), m84(opt) ..) (News from Märklin and others)
by clapcott 13/10/2016 20:59:52(UTC)
scheme of connections M84-74391 marklin (H0-scale)
by Thewolf 21/07/2016 23:43:07(UTC)
L88 and M84 - waiting for Marklin to ship to US (General MRR)
by Harvey 15/06/2016 03:11:22(UTC)
K84 and M84 decoders (Digital)
by sjbartels 19/03/2016 18:41:27(UTC)
M84 and signal V4011 (Viessmann) (Digital)
by Thewolf 02/10/2015 17:49:22(UTC)
Use of Decoders M83 M84 (Digital)
by Huco 09/09/2015 10:05:56(UTC)
M84 decoder question (Digital)
by Hackcell 07/06/2015 22:29:18(UTC)
This page was generated in 0.603 seconds.
