Offline Mr. Ron
#1 Posted : 08 July 2020 01:16:39(UTC)
Mr. Ron
After accumulating a good amount of used M track from E-bay, I have a few pieces of track that I don't know how they work. One is item 5146, (straight circuit track) and one straight track that is stamped 5106, but one rail has a slit at both ends and two jacks near the middle for a plug. I'm guessing it's a contact track; it's not shown or listed in the catalog. Also I have (4) - 7191 bumper stops. Where do the 3 wires that come from the bumper go to? I figure the wires from the turnouts go to the transformer via the 7072 control box. Is there a Marklin publication that explains how all the tracks go together that I can buy?
Offline orionstars
#2 Posted : 08 July 2020 01:49:21(UTC)
orionstars
Try here:
http://www.lctm.info/Sec...nes/Biblioteca/index.php
One link on that page is for annual catalogs the other books. Hopefully you’ll find more then you need!
Pete
thanks 1 user liked this useful post by orionstars
#3 Posted : 08 July 2020 15:17:45(UTC)
Hi Ron
The 5148 is a half-length straight which delivers one contact per direction when a slider-equipped vehicle crosses it.
The 5147 is a half-length curved (standard radius) which delivers one contact per direction when a slider-equipped vehicle crosses it.
The 5213 is a half-length curved (parallel track)) which delivers one contact per direction when a slider-equipped vehicle crosses it.
The 5106 is a full length straight (18 cm)
The 5105 is a full length straight with a contact section and 2 jacks in the middle (the one you mention)
In the English 1968 catalogue you will find all the answers Cat Marklin 1968 EN.pdf (18,945kb) downloaded 91 time(s). It is coming from the same website mentioned by Pete
Note: as most M track users, contact tracks 5104 (full-size curved contact track) and 5105 (full-size straight contact track) were disliked and directional contact tracks like 5147, 5148, 5213 are preferred because less likely to burn a coil because a train is parked on it and because of the direction-specific contact.
One old publication may help you designing layouts: Cat Marklin Gleisplane 0390 (1975).pdf (17,318kb) downloaded 88 time(s).
I love M track. Here is a temporary layout I did some 20 years ago
I hope this helps
m track (H0-scale)
by Coling 05/02/2025 09:00:12(UTC)
M track with outlets/sockets (H0-scale)
by Conductor0179 27/11/2024 18:50:11(UTC)
Creating 54mm Track Spacing With HO C-Gleis (General MRR)
by Electrix 18/11/2024 10:46:35(UTC)
Is M track still being made? (H0-scale)
by Mr. Ron 18/09/2024 06:08:48(UTC)
Protocol error & Ghost with M track retro-signalisation (Digital)
by Olivier1967 14/09/2024 12:22:45(UTC)
M track (H0-scale)
by Mr. Ron 07/09/2024 03:03:09(UTC)
M tracks dimensions (H0-scale)
by Pmeeuwes 07/08/2024 00:09:05(UTC)
M Track Curved Turnout loco stops (H0-scale)
by Brian_BR96 20/07/2024 05:08:03(UTC)
Flooded M track and rolling stock (H0-scale)
by BenP 27/06/2024 21:27:07(UTC)
Marklin screws for M track (H0-scale)
by jimwallace1652 25/06/2024 22:18:28(UTC)
Track Screws for M yes M Track (H0-scale)
by frickwg 21/04/2024 20:19:36(UTC)
analog m track parts.. how to... (Model railroad wiring)
by lucasm54 21/04/2024 09:50:34(UTC)
Marklin M Track 5106 1/1 (H0-scale)
by MALAVIKA 18/02/2024 06:39:03(UTC)
M Track Switch Testing (H0-scale)
by baja463 01/02/2024 20:27:06(UTC)
Working with Marklin M track signals (General MRR)
by tandrschaefer 03/01/2024 21:41:00(UTC)
Speed on different types of M track (analogue) (H0-scale)
by Michael4 05/11/2023 17:30:21(UTC)
m track switch wiring question (H0-scale)
by heinrichhess 24/08/2023 12:04:59(UTC)
will m track fit Transfer Table (H0-scale)
by heinrichhess 20/08/2023 18:20:40(UTC)
odd numbered m track 36010 (H0-scale)
by heinrichhess 06/08/2023 12:29:08(UTC)
will Schicht runn on m track? (H0-scale)
by heinrichhess 21/07/2023 15:32:40(UTC)
M track (General MRR)
by Keim 24/05/2023 02:42:42(UTC)
Searching for info on this M track layout (H0-scale)
by Soylent73 30/04/2023 17:26:30(UTC)
Mixing C and M tracks - best tricks? (H0-scale)
by einotuominen 12/12/2022 17:53:29(UTC)
Compatible power supply for Marklin M Track? (General MRR)
by Skywalker646 10/12/2022 02:49:53(UTC)
Manual download for M track or vintage Marklin Accessories (H0-scale)
by tinroofrusted 12/10/2022 12:05:44(UTC)
Marvellous M track manufacture (H0-scale)
by Michael4 14/09/2022 11:52:27(UTC)
M Track (Digital)
by muhkau 21/08/2022 09:00:55(UTC)
M track points lights (Model railroad wiring)
by mitchnz 12/08/2022 02:56:16(UTC)
New M track layout (H0-scale)
by Mr. Ron 21/07/2022 18:48:27(UTC)
Marklin HO M track 1937-50s Electric Points Cat No 13600 WB (H0-scale)
by David240945 10/05/2022 18:18:59(UTC)
Mixing M track and C track (Model railroad wiring)
by PedroRyder 13/01/2022 16:35:36(UTC)
Connecting a Jagerndorfer ho cable car set with an ESU 56002 sound decoder to a CS3 from track power (Digital)
by marklinist5999 03/01/2022 20:36:33(UTC)
AC Wheels for Liliput and Piko Wagons-M track (Collector's Corner general)
by Philipj 28/12/2021 20:56:55(UTC)
Marklin M Track 5117 Points / Led Bulbs (H0-scale)
by fossie 28/11/2021 10:53:09(UTC)
eCoS to M track points to marklin k83 (Model railroad wiring)
by Ausipeet 26/09/2021 06:32:55(UTC)
M track Connections (H0-scale)
by Mr. Ron 08/09/2021 03:21:05(UTC)
Solid Third Rail M Track (General MRR)
by mike c 10/08/2021 04:52:31(UTC)
Catenary fabrication for M track (H0-scale)
by Mr. Ron 12/07/2021 21:49:21(UTC)
analog signal on digital M track section of siding spur (Digital)
by marklinist5999 12/07/2021 14:23:02(UTC)
HO 2-rail rolling stock on Marklin M track (H0-scale)
by Mr. Ron 08/06/2021 04:59:47(UTC)
M track Figure 8 layouts (H0-scale)
by A4Gresley 01/05/2021 09:52:05(UTC)
Long ICE cars rubbing turnouts semaphore m track (H0-scale)
by Victor Almeida 04/02/2021 02:56:37(UTC)
Two locos simultaneously on m tracks (H0-scale)
by Petros 08/01/2021 20:40:35(UTC)
Marklin M track vs C track (General MRR)
by Tracy 29/12/2020 22:03:50(UTC)
M Track planning SW (Model railroad software)
by Vitsing 20/12/2020 05:34:47(UTC)
Which Controller works best with old M Track? 6021 or MS2? (Digital)
by SteveK-O 08/12/2020 15:38:21(UTC)
Wireless control of M track accessories (Digital)
by joyofmarklin 22/11/2020 03:43:22(UTC)
Joining M track sections (H0-scale)
by Mr. Ron 14/11/2020 09:04:18(UTC)
M Track (H0-scale)
by Mr. Ron 11/10/2020 22:40:36(UTC)
M track alignment (H0-scale)
by Mr. Ron 11/10/2020 20:22:47(UTC)
This page was generated in 0.503 seconds.
