Offline marklin 279
#1 Posted : 15 June 2019 21:00:41(UTC)
marklin 279
I have 3 foot sections of flexable K Tack is there any way to cut them? Thanks for any advice.
#2 Posted : 15 June 2019 21:17:31(UTC)
I have a page describing how I lay k-Track, including a section on how to cut it, at:
https://cabin-layout.mixmox.com/2005/07/laying-k-track.html
Offline marklin 279
#3 Posted : 15 June 2019 21:59:32(UTC)
marklin 279
Thanks for the info I really appreciate it.
Offline PMPeter
#4 Posted : 15 June 2019 22:07:31(UTC)
PMPeter
I use the Xuron 2175M which is specifically designed for Maerklin track. I have gone through 3 boxes of flex track where each piece needed cutting of at least one rail, usually both and this cutter is still as good as when I bought it.
thanks 2 users liked this useful post by PMPeter
#5 Posted : 16 June 2019 00:34:28(UTC)
In addition to the other contributions, there is also a leaflet below that originally came with K-flextrack showing cutting and rejoining - a pack of joiner peices was normally included with each new box of track.
Hope it helps
Offline applor
#6 Posted : 16 June 2019 02:29:34(UTC)
applor
Dremel with cut off disc No. 409
Beware that the 900mm flex tracks have one rail secured at each end. Therefore if you want a long sweeping curve you have to cut it off just after the rail tie, or it wont bend.
#7 Posted : 16 June 2019 19:37:29(UTC)
no, do not bother with those they just keep breaking. Buy the small diamond cutter disk and you will never look back.
correct
simply ensure that you do the cutting at the other end, leave the anchored end anchored.
Offline applor
#8 Posted : 17 June 2019 00:28:09(UTC)
applor
Well each to their own but you get 20 discs in the pack - more than enough for a large layout. Yes, they are fragile and can break but they do excellent thin cuts for isolation gaps and cut through rails effortlessly.
In my experience the disc diameter is more important as I have often needed to get as much reach as possible to achieve a vertical cut in situations where I haven't cut or been able to cut the rails before laying.
#9 Posted : 18 June 2019 13:41:33(UTC)
Sorry for being redundant, but; "-what applor said!"
K-track glitch (General MRR)
by Puttputtmaru 17/08/2025 19:17:50(UTC)
K-track, Flex track (H0-scale)
by Mjn2ts 29/12/2024 19:16:47(UTC)
Sudexpress EuroDual on K-track (H0-scale)
by jonas_sthlm 28/07/2024 23:24:13(UTC)
Contact track on K-track turnout? (H0-scale)
by DanK 03/04/2022 23:59:17(UTC)
K-track numbering meaning (H0-scale)
by Puttputtmaru 26/12/2021 00:26:29(UTC)
What runs good on Marklin k-tracks? (H0-scale)
by Puttputtmaru 26/03/2021 21:41:40(UTC)
K-Track Numbering (General MRR)
by Ranjit 08/08/2020 07:02:09(UTC)
Issue with K-track 2271 shorting out (H0-scale)
by DaleSchultz 21/05/2020 04:07:49(UTC)
Breakmodul for K-track (H0-scale)
by Pfalzbahn 25/10/2019 04:45:24(UTC)
The Geometry of Track, why C-Track and K-Track both missed an opportunity (H0-scale)
by Johnvr 24/10/2019 21:41:42(UTC)
K-track gap (H0-scale)
by Pfalzbahn 16/10/2019 02:34:49(UTC)
K-track bumper LED lights (General MRR)
by Pfalzbahn 05/10/2019 03:11:09(UTC)
K-track switches (points) - changes over time (H0-scale)
by Spokanesteve 20/06/2019 03:24:03(UTC)
K-track marklin (General MRR)
by Thewolf 15/06/2019 04:40:29(UTC)
K-Track 2160 DoubleSlip - Point Blade design change? (H0-scale)
by cookee_nz 14/01/2018 06:48:00(UTC)
Marklin K-track program (H0-scale)
by Guest 20/09/2017 20:07:29(UTC)
K-track lantern woes (General MRR)
by Robert Davies 03/08/2017 22:27:38(UTC)
Blending C-Track and Merkur bedded K-Track Flextrack (H0-scale)
by Minok 23/03/2017 00:07:21(UTC)
Marklin K-tracks 21xx and 22xx compatibility (H0-scale)
by fje 04/01/2017 22:29:20(UTC)
Using 7186 turn table in digital k-track layout (H0-scale)
by dennisb 26/11/2016 11:12:29(UTC)
Thank you Magnus for helping me ballasting my K-tracks! (H0-scale)
by Martin T 13/05/2016 11:23:35(UTC)
REVISITED Marklin 2275 - Double Slip Switch K-Track design flaw (H0-scale)
by michelvr 02/05/2016 15:35:29(UTC)
Is it possible to buy boxes of K-Track (General MRR)
by scraigen 23/04/2016 20:09:11(UTC)
Marklin K-track - Make a Y (H0-scale)
by geireklund 08/06/2015 13:52:08(UTC)
the K-track switching track will be something of the past (H0-scale)
by river6109 08/05/2015 08:42:25(UTC)
BERNHARD STEIN methods for K-tracks (General MRR)
by christos563 09/04/2014 15:02:04(UTC)
DC to AC or two rail to three rail conversions and K-track conversion? (General MRR)
by Mark5 13/03/2013 18:30:05(UTC)
Point indicator for K-track double slip (General MRR)
by Robert Davies 22/12/2011 13:44:21(UTC)
K-track versus C-track (H0-scale)
by Robert Davies 16/12/2010 22:37:56(UTC)
Servo's & K-track switches - your experience (General MRR)
by Rinus 13/02/2010 13:26:59(UTC)
K-track long turnouts, advice needed (H0-scale)
by Trainee 12/02/2009 23:12:26(UTC)
Erratic Running on K-Track (General MRR)
by dpg001 30/10/2008 09:44:52(UTC)
Adapting old M-track catenary masts to K-track (H0-scale)
by Marty 22/10/2008 21:31:52(UTC)
K-Track Rumor (H0-scale)
by leesauer 28/08/2008 03:59:20(UTC)
Connecting C-Track to K-Track (General MRR)
by renevoorburg 11/08/2008 23:48:55(UTC)
High-Speed Turnouts and more for K-Track (H0-scale)
by weichen-walter 16/06/2008 17:31:59(UTC)
K-track anatomy (H0-scale)
by tekin65 21/04/2008 15:28:19(UTC)
2100 series and 2200 series K-track (General MRR)
by Peter Neumann 27/02/2008 16:07:12(UTC)
Crossing with long K-track turnouts (H0-scale)
by laalves 05/02/2008 01:38:39(UTC)
Rust on K-track studs? (H0-scale)
by DaleSchultz 10/11/2007 20:40:07(UTC)
Soldering on k-track (H0-scale)
by Voller 27/07/2007 21:48:53(UTC)
Dual AC and DC operations on K-tracks (H0-scale)
by PierreGILLARD 02/05/2007 16:01:48(UTC)
Connecting K-track (H0-scale)
by jocoyn 14/03/2007 15:38:51(UTC)
Wiring for K-track feeder track (H0-scale)
by wsscott72 02/02/2007 15:50:51(UTC)
New k-tracks... (News from Märklin and others)
by Goofy 06/01/2007 18:47:35(UTC)
K-Track, but 1/1 scale ! (Prototype)
by PierreGILLARD 04/12/2006 00:49:40(UTC)
K-track switch trouble. (H0-scale)
by MartinB 13/11/2006 23:25:14(UTC)
K-track curved turnouts (H0-scale)
by jte 23/09/2006 13:34:56(UTC)
How to handle your K-Track turnouts ! (Prototype)
by PierreGILLARD 23/06/2006 04:10:40(UTC)
K-track switching track problem (H0-scale)
by hmsfix 09/06/2006 00:37:40(UTC)
This page was generated in 0.713 seconds.
