Offline Jack_Peters
#1 Posted : 19 December 2018 02:50:21(UTC)
Jack_Peters
Converting a 70 meter analog mixed K-track / M-track to digital control with a CS3. Prior analog control was with 3 blue transformers, #1 - level tracks, #2 - uphill tracks, and #3 - downhill tracks. This was done to get a constant speed for consists as much as possible. Also had about 25 or so red power wires distributed to the various sections of the 70 meters of track.
Step 1 - turn of all power, disconnect and remove all transformers.
Step 2 - disconnect all "red" power wires that were joined in common to each individual transformer.
Step 3 - create three (3) new insulated master section of the 70 meters of track to separate the power from the CS3 and the two (2) new boosters. Used new # 7522 insulators and # 385580 pickup shoe deflectors to separate the 3 areas. The # 385580 are used to prevent the power pickup shoe from momentarily bridging a point where the CS3 and a booster "short" the digital signal. The Marklin 385580 I identified as # 8993 which is a z-track item. There are 5 to a pack, the same piece with work for K-track and M-track.
Step 4 - Only hook up the CS3 to one of the newly created power sections, run a loco to make sure the wiring is OK, join up all the required (of the 25 or so red power) wires to complete the 1/3 of the 70 meters between the digitally isolated section. Place the loco on other sections to make sure there are no errant or hidden power wires still powering parts of the other 2/3 of the track.
Step 5 - Hook up booster "A", check for overloads, etc., to the next section and again, join up all the required (of the 25 or so red power) wires to complete the next 1/3 of the 70 meters between the digitally isolated section. Place the loco on other sections to make sure there are no errant or hidden power wires still powering parts of the last 1/3 of the track.
Step 6 - Hook up booster "B", check for overloads, etc., to the next section and again, join up all the required (of the 25 or so red power) wires to complete the last 1/3 of the 70 meters between the digitally isolated section.
Now you should be able to run the entire track with the CS3, run the loco at a very slow speed to see if there are any sections that have weak voltage, or are still isolated. I have put the # 585580 on two front tracks for easy install, but have now found that all the locos that run less than 1/3 speed, hiccup, when going across the isolation point. I will need to move the isolation points into a tunnel.
In the next few months I will convert the main station which is M-track to K-track for better performance. Will also start adding in approx 18 "blocks" with signals to convert the 70 meter single track to "block" control with the aim of running approx 14 locos at once.
Edited by user 03 March 2019 00:06:46(UTC)  | Reason: Not specified
thanks 2 users liked this useful post by Jack_Peters
Varios conversions (Digital)
by Issus 24/03/2024 00:14:04(UTC)
Conversion of Jägerndorfer loco (H0-scale)
by km90 08/03/2024 15:26:14(UTC)
Marklin 5713 BR 55 3964 Conversion (Big scale)
by JordanG1 06/03/2024 20:27:15(UTC)
Digital conversion of 4-6-2 steam loco from 1961 (Digital)
by Bcur 28/02/2024 17:56:38(UTC)
Digital Conversion of a Delta Ae 8/14 - PC Board Part #? (Digital)
by 5HorizonsRR 06/02/2024 20:39:15(UTC)
NEM coupler conversion (H0-scale)
by revmox 07/01/2024 23:20:56(UTC)
ICE 3370 or 3770 digital conversion (H0-scale)
by StanN 21/12/2023 22:59:50(UTC)
Coupler conversion for old Märklin reefers (H0-scale)
by einotuominen 17/08/2023 09:30:02(UTC)
NA two rail conversion to three rail? (H0-scale)
by einotuominen 08/07/2023 14:56:30(UTC)
Hag digital conversion (General MRR)
by mvd71 06/05/2023 05:58:50(UTC)
Help Identifying Motor for Conversion (Digital)
by bfriedland@cox.net 01/05/2023 17:48:35(UTC)
Trix 22148 2 rail to 3 rail conversion problem (Digital)
by thing fish 03/03/2023 20:57:47(UTC)
Hornby class 37 conversion to 3 rail and DCC (General MRR)
by Kanga 28/02/2023 17:07:47(UTC)
Conversion of 3093 and alternative decoders? (Digital)
by einotuominen 13/01/2023 13:20:51(UTC)
3 pole to 5 pole conversion (H0-scale)
by Mjn2ts 11/01/2023 21:09:33(UTC)
Digital conversion of Märklin 3511 (Digital)
by Martti Mäntylä 04/12/2022 17:36:42(UTC)
Conversion of the snow plow with recent loksound decoder (Digital)
by French_Fabrice 20/11/2022 18:16:17(UTC)
HAG RE 4/4I Digital Lighting Conversion- Swiss Headlight Changeover? (Digital)
by 5HorizonsRR 19/11/2022 21:58:09(UTC)
First mLD3 conversion - electricity issues (Digital)
by einotuominen 08/11/2022 13:29:42(UTC)
Roco DC Coaches - Conversion to Marklin AC (H0-scale)
by Eddie7979 03/10/2022 03:14:41(UTC)
5700 BR80 DC conversion? are there parts to do this? (Big scale)
by artfull dodger 12/08/2022 18:28:06(UTC)
Conversion cable (Digital)
by Graham HO 06/08/2022 11:44:24(UTC)
Trix 21523 Conversion to DCC (General MRR)
by iwltsgdom 21/06/2022 07:36:21(UTC)
New to digital conversion- seeking guidance on wiring (Digital)
by BurritoJoe 10/06/2022 04:44:16(UTC)
60760 conversion set decoder (Digital)
by BenP 25/04/2022 02:15:14(UTC)
Analog to Digital Conversion Marathon (Digital)
by Paul24 02/02/2022 23:27:03(UTC)
BR 3366 conversion with decoder 60906 (Digital)
by Donb 26/01/2022 18:55:52(UTC)
29146 conversion - Delta to digital? (H0-scale)
by The Crocodile 26/12/2021 13:29:12(UTC)
Loco conversions to digital (Digital)
by CVI 24/11/2021 11:56:01(UTC)
MARKLIN 3015 CROCODILE CONVERSION TO DIGITAL (Digital)
by lvfocus 20/11/2021 04:59:46(UTC)
Analogue to Delta (6603) Conversion- Solder Points on the motor? (Digital)
by 5HorizonsRR 04/11/2021 04:42:05(UTC)
47760: Tin plate US box cars set - Conversion to DC (H0-scale)
by Chrome58 06/10/2021 18:00:51(UTC)
Roco AE 8/14 conversion from DC to AC? (H0-scale)
by 5HorizonsRR 20/09/2021 18:27:40(UTC)
Issue when converting a HAG-143 Analog DC model - issue fixed- conversion photos (Digital)
by French_Fabrice 17/08/2021 10:42:04(UTC)
Digital conversion of 89 series (Digital)
by Jay 11/06/2021 19:17:52(UTC)
43873 coach set conversion to LED (H0-scale)
by dominator 22/05/2021 03:54:41(UTC)
Noch Cortina - Conversion from Manual to Automatic Signal Train control (Small scale)
by CBFasi 02/04/2021 12:05:30(UTC)
Digital Conversion: Part list needed (Digital)
by madhu.gn.71 30/03/2021 11:47:44(UTC)
Conversion challenge (H0-scale)
by Timnomads 28/02/2021 12:36:27(UTC)
Digital conversion of 3060 Santa Fe with mfx60760 (H0-scale)
by Spirre 15/02/2021 21:48:54(UTC)
Digital Conversion (H0-scale)
by fossie 06/02/2021 18:45:33(UTC)
Better digital conversion BR128 (Digital)
by siroljuk 05/02/2021 09:52:32(UTC)
Help with Digital Conversion (Digital)
by waterslip 05/12/2020 03:49:42(UTC)
Marklin 60760 conversion kit compatible loks (General MRR)
by carlostau 29/10/2020 13:35:09(UTC)
3 rail to 2 rail conversion. (General MRR)
by SJN 28/10/2020 00:43:24(UTC)
Bachmann 3524 Santa Fe Conversion Attempts (Digital)
by HerrDoktorBD 29/08/2020 17:56:17(UTC)
digital conversions (Digital)
by MHJ87 05/07/2020 02:56:05(UTC)
3046 digital conversion (Digital)
by MHJ87 31/05/2020 07:55:48(UTC)
by MHJ87 08/05/2020 02:33:56(UTC)
A simple little trick to make your digital conversion easier (Digital)
by Johnvr 27/04/2020 12:57:43(UTC)
This page was generated in 0.543 seconds.
