#1 Posted : 01 December 2018 21:35:53(UTC)
Was looking at LS Models coaches. They appear rather expensive. Any reason for this and are they better than other brands.
#2 Posted : 01 December 2018 22:54:21(UTC)
Yes they are excellent, and so are ACME and REE
The thing is that they are extremely well detailed, inside and out
But you need to make sure that they match with the minimum radii on your layout.
The Märklin KKK wont work without interference ;
I use ROCO "universal" at the end of the consist and ROCO KKK elsewhere
And always check wheel spacing.
I also have a few locos from REE and LSM.
All excellent details and beautiful running characteristics but more delicate than the usual Märklin
thanks 6 users liked this useful post by jvuye
Offline Dreadnought
#3 Posted : 03 December 2018 03:30:01(UTC)
Dreadnought
I have the LS Models “Nord” set in SNCF livery from Era 3. It is a three coach set that I got in Paris two years ago at Au Pullman. They have lovely colours. The lettering is very well done. They have excellent detail. They are beautiful models. I would even say works of art. They come with differnt ends you can put on to make one the last coach. The accordeon between coaches can be one folded back. There are also brake hoses that can be applied to replicate the last coach of the train. A realistic coupling hook can be set in place of the NEM coupler.
I also have a CIWL restaurant car from the same era. Again I am very impressed by the colours, the lettering, and fine details. My hope was to have all of them pulled by the Marklin SNCF 241 class I got last year.
On the negative side they are fragile. I have bits of buffers that have broken off. I have had a difficult time getting them the right couplers. I have used Rocco universals, and Marklin, though they still derail particularly on an S bend as they go through the right and left switch to the siding. Doing this, I suspect, has snapped some of the buffers. They are quite sensitive to any switch.
A suggestion made in this forum was to mix Rocco and Marklin couplers, such that a Rocco couples to a Marklin. I have yet to try that mix.
Another suggestion is to change the spacing on the wheels, the axel, to conform to Marklin.The wheels seem to catch on the frogs of the switches.
Changing that spacing is way beyond my skills. I have wondered about swapping the wheels out for Marklin ones. Again that is beyond my skills, and has not been recommended.
On the plus side, when I run them on R3 oval they are fine, and look superb. I just have to be careful not to try to take any switch other than strait.
thanks 1 user liked this useful post by Dreadnought
#4 Posted : 03 December 2018 04:02:57(UTC)
You can buy AC wheelsets from LSM, Roco or ACME that will fit any LSM coach. You just have to know the appropriate wheel diameter for that model.
As far as couplings, the problem that I have noted is that the coupling shafts often do not extend far enough for the coupler to clear the buffers. I have seen in some older (MG) models that when using Maerklin 7203, Roco's close coupler or even Fleischmann's profi coupler, that two coaches cannot properly couple. The Roco universal couplers have an extra mm in the length of the plug, which means that with those couplers, the couplers extend far enough to attach to the adjacent coupler. If one extra mm is enough, then you can connect one Roco Universal Coupler with a Maerklin 7203. If you need more space, you will have to use a pair of Roco Universal Couplers.
The other alternative is to use a single Roco Universal Coupler and a single Marklin loop coupler, which will also give you enough spacing to successfully couple.
I have also seen similar problems with certain coaches from Liliput (Bachmann), Heris and other brands.
I am very pleased with my LSM models. They are the nicest models out there at the moment.
What I do not like is the fact that spare parts are hard to come by, especially for older models that were made by Modern Gala or are "epuise" according to LSM.
I also do not like the fact that models like the SBB UIC-X were designed with steps that have to be glued in place, while similar DB and other coaches have those parts rendered as integral to the model.
I also do not like the fact that the packaging of most older models (foam) do not allow for the models to be stored with the couplings mounted. This has been corrected on most 2017 and 2018 releases, but is problematic for all models released between 2009 and 2017. I wonder if those 30cm inlays can be ordered as spare parts?
#5 Posted : 03 December 2018 13:20:33(UTC)
Thanks for the comments. Was thinking of a purchase but now not sure if the running is not great although it appears this can be corrected with various couplers.
LS Models EC SBB Gotthard Express Wagons (H0-scale)
by Eddie7979 27/01/2025 01:20:56(UTC)
LS Models Restaurant SBB Calanda Land EW1 (H0-scale)
by Eddie7979 24/12/2024 08:49:15(UTC)
LS Models Information (H0-scale)
by Eddie7979 26/05/2024 04:59:52(UTC)
LS Models (New Items Flyer/February 2024) (News from Märklin and others)
by mike c 08/02/2024 20:00:45(UTC)
LS Models MW1001 compatiblity with Marklin (H0-scale)
by Bahnhof fan 20/01/2024 14:27:38(UTC)
LS Models AC wheels (General MRR)
by Puttputtmaru 31/03/2023 16:29:12(UTC)
LS Models 47268 (H0-scale)
by David Dewar 28/08/2022 16:34:28(UTC)
LS Models SBB EWI Restaurant Coaches (Reviews of rolling stock)
by mike c 18/05/2022 06:42:39(UTC)
LS Models SBB EC Coaches (Reviews of rolling stock)
by mike c 27/05/2021 19:55:16(UTC)
Piko vs LS Models (SBB EW I Restaurant "Calanda Land" (Reviews of rolling stock)
by mike c 10/05/2021 07:40:07(UTC)
LS Models Production News (News from Märklin and others)
by mike c 04/02/2021 22:37:23(UTC)
LS Models Vectron New Flyer (News from Märklin and others)
by mike c 04/02/2021 22:33:54(UTC)
Roco vs ACME vs LS Models vs Piko (Eurofima) 1/87 Coaches (H0-scale)
by mike c 25/01/2021 02:15:15(UTC)
Latest Info from LS Models SBB EW I WR Restaurant Coaches (News from Märklin and others)
by mike c 26/11/2020 05:03:34(UTC)
LS Models SBB Vectron (193 XXX) (Südleasing and LokRoll) and Now BLS too (News from Märklin and others)
by mike c 14/10/2020 18:02:38(UTC)
BLS Models (H0-scale)
by mike c 06/03/2019 08:02:15(UTC)
LS Models News 2019 (News from Märklin and others)
by ciobitud 25/01/2019 19:12:25(UTC)
Austrian Night Train by LS Models/RailTop and ACME (Now with Photos) (Reviews of rolling stock)
by mike c 14/09/2017 08:51:48(UTC)
LS Models Passenger coaches (General MRR)
by Dreadnought 15/03/2017 00:18:29(UTC)
LS Models Passenger 2017 Brochure. (News from Märklin and others)
by steventrain 31/01/2017 10:21:15(UTC)
LS Models with big problems (H0-scale)
by hurricane.189 07/03/2016 21:45:42(UTC)
Finally some news from LS Models (News from Märklin and others)
by mike c 28/12/2015 19:41:34(UTC)
LS Models Bm4/4 (H0-scale)
by rbw993 26/05/2015 21:20:25(UTC)
LS Models WLABm 173.1 models and possible LSM Production Changes (H0-scale)
by mike c 08/04/2015 21:08:17(UTC)
LS Models Eurofirma coaches (Reviews of rolling stock)
by Rinus 18/01/2015 17:02:44(UTC)
LS Models WLAm T2S Livery (H0-scale)
by mike c 10/11/2014 20:17:05(UTC)
Reissue of OBB Double Deck Sleepers from LS Models (Memoba Exclusive) (News from Märklin and others)
by mike c 08/10/2014 08:30:39(UTC)
LS Models RAe TEE II (TEE Cisalpin) (Loco Reviews)
by mike c 26/04/2014 05:19:53(UTC)
Eurofima Models from LS Models (1/87) (News from Märklin and others)
by mike c 04/03/2014 05:55:12(UTC)
Heris/RailTop vs Roco vs LS Models SBB WLAm T2S Sleeping Car Models (Reviews of rolling stock)
by mike c 29/01/2014 06:30:12(UTC)
LS Models marklin-users.net sleeper (H0-scale)
by Rinus 25/11/2013 22:10:42(UTC)
LS Models CityNightLine Komet Set (News from Märklin and others)
by mike c 16/10/2013 06:52:28(UTC)
LS Models RAe Gottardo 1/87 (News from Märklin and others)
by mike c 02/07/2013 07:14:47(UTC)
LS Models Production List (not confirmed) (News from Märklin and others)
by mike c 22/01/2013 05:19:56(UTC)
LS Models - Bcmz 50-70/59-70 (Reviews of rolling stock)
by Rinus 20/01/2013 16:12:06(UTC)
LS Models 47214 and 47231 with Error (Resolved) (H0-scale)
by mike c 25/12/2012 02:42:20(UTC)
LS Models news november 2012 (H0-scale)
by Rinus 10/11/2012 09:34:11(UTC)
LS Models From Belgium (Collector's Corner general)
by Hirayama 11/08/2012 15:35:17(UTC)
New CAD drawings for SBB Bm 4/4 models from LS Models (News from Märklin and others)
by mike c 12/06/2012 19:48:21(UTC)
Final Prototype LS Models SBB Dms Baggage Coach (News from Märklin and others)
by mike c 04/04/2012 21:28:33(UTC)
by mike c 05/11/2011 18:35:04(UTC)
More LS Models SBB Models Released (H0-scale)
by mike c 31/08/2011 19:38:47(UTC)
LS Models SBB WRm and Coach Set (H0-scale)
by mike c 19/08/2011 04:39:57(UTC)
LS Models SBB RIC Coaches (Era IV/V/VI) (H0-scale)
by mike c 21/06/2011 15:53:36(UTC)
Updated: Company response to Customer Inquiry (Bravo LS Models) (H0-scale)
by mike c 27/04/2011 17:47:28(UTC)
New Final Prototype Photos of SBB Diner at LS Models.com (H0-scale)
by mike c 04/03/2011 22:49:01(UTC)
LS Models SBB WRm (General MRR)
by mike c 04/01/2011 20:04:08(UTC)
LS Models for the Marklin system (News from Märklin and others)
by dan67millie 21/11/2010 11:24:55(UTC)
LS Models vs ACME (H0-scale)
by mike c 13/11/2010 13:13:20(UTC)
LS Models News (H0-scale)
by mike c 15/09/2010 05:41:21(UTC)
This page was generated in 0.349 seconds.
