Offline Bondijohn
#1 Posted : 18 March 2018 01:26:04(UTC)
Bondijohn
I'm hoping some of my knowledgeable colleagues can assist a novice. I am trying to run c-track around a preformed Noch layout "Salzburg" which is presenting a couple of problems with the track geometry. However at the moment I need help with connecting curved points 24672 and a double slip switch 24624 to my CS 2.
I would like to know what is needed to connect both pieces to the CS2, whether I need another transformer, and what wires connect to which apparatus.
Thanks in advance.
Bondijohn
Offline Crazy Harry
#2 Posted : 18 March 2018 02:20:53(UTC)
Crazy Harry
Thanks in advance.
Bondijohn
The curved points 24672 are manual so you would need a 74491 turnout mechanism and a 74461 decoder. There is also an optional latern kit for these points 74470.
The double slip switch 24624 already has an electric mechanism so it only needs a 74461 decoder.
All the product numbers above are links to the Marklin pages, so you can see the descriptions. On the Marklin pages there are links to the manuals for most of the items so you can see how they are installed. Everything installs below the switches including the wire connections so there is no additional wiring or transformers required. You just need to set some dip swithes and do some programming with the CS2.
Hope this helps,
Harold.
MrB32
#3 Posted : 18 March 2018 02:30:36(UTC)
You need a motor and and decoder for your points. Do you have these?
https://www.maerklin.de/...ts/details/article/74491 for your 24672s. The 24624 should have one already.
https://www.maerklin.de/...ts/details/article/74461
If you do it is a matter of setting the right address on the decoder as per manual (https://static.maerklin.de/damcontent/5f/60/5f606a769d08c7d6d6463a0f102c1fba1504008312.pdf), you'll then be able to control them from the keyboard page on the CS2.
No wires or transformer needed
Offline Bondijohn
#4 Posted : 18 March 2018 22:49:12(UTC)
Bondijohn
Thanks for the response. I’ve had a look at the 24672 which has a factory fitted 74491. So it would appear I only need to fit a 74461. Thank for the tip about fitting a light.
I’ll check 24624 next weekend to see what I need to buy.
Thanks again for the help.
thanks 1 user liked this useful post by Bondijohn
C-track 24624 DKW double slip, issues with tounges not closing enough (H0-scale)
by LeoArietis 09/02/2024 11:16:49(UTC)
Can Marklin signals work with the c-track from Trix? (General MRR)
by Sniklz 25/01/2024 23:35:50(UTC)
c-track geometry advice needed for my layout (H0-scale)
by fabstar68 08/01/2024 23:41:10(UTC)
Three way turnout (c-Track) with Viessmann 4568 (Digital)
by Puttputtmaru 07/01/2024 23:29:44(UTC)
Experiences painting and or ballasting C-Track (General MRR)
by egonzinc 31/12/2023 22:10:40(UTC)
Platform for standard Marklin C-track 77.5mm distance ? (H0-scale)
by fabstar68 23/12/2023 16:01:44(UTC)
Faller compatibility with Marklin c-tracks (H0-scale)
by fabstar68 19/12/2023 15:23:05(UTC)
C-Track and spade adapters (Model railroad software)
by Richard Joint 19/12/2023 04:59:24(UTC)
74470 Led light for C-track turnout (H0-scale)
by Flupke 16/12/2023 19:32:25(UTC)
C-track TurnTable not working propperly (Digital)
by fvelazdem 20/11/2023 12:24:40(UTC)
C-track road crossing (H0-scale)
by revmox 19/05/2023 07:20:37(UTC)
Roco AC Sound locomotives running SLOW on analog C-track (General MRR)
by egonzinc 22/04/2023 16:02:25(UTC)
C-Track threeway turnout short circuit (Digital)
by einotuominen 30/03/2023 10:53:07(UTC)
C-track spacing (General MRR)
by Edmielck 20/02/2023 23:34:55(UTC)
Info on Rivarossi AC Locomotives on Marklin C-track (H0-scale)
by egonzinc 08/01/2023 05:46:21(UTC)
Modular Layout with C-track (H0-scale)
by Uwe 10/12/2022 02:25:06(UTC)
C-Track with a flex (H0-scale)
by Puttputtmaru 02/12/2022 22:33:52(UTC)
by MartinWalkabout 02/09/2022 15:34:19(UTC)
C-track turnout mechanism stops working (H0-scale)
by Wirring 27/06/2022 22:37:24(UTC)
Operating "snags" on C-track (H0-scale)
by JDennis 01/05/2022 21:14:33(UTC)
Wheels for Non-Marklin Wagons and Coaches on C-Track (H0-scale)
by AlanC 28/04/2022 09:00:37(UTC)
c-track contact track ends touching (H0-scale)
by trainbuff 10/04/2022 00:32:52(UTC)
Running HAG on Marklin C-Track (H0-scale)
by mchesla 08/04/2022 21:56:59(UTC)
Esu wagon on Trix C-Track (H0-scale)
by tabacaru.mvlad 22/02/2022 00:11:33(UTC)
Found the culprit that snaps off all my C-Track turnout Lanterns (H0-scale)
by Dave Banks 05/07/2021 10:37:48(UTC)
Newly discovered C-Track Issue (H0-scale)
by mike c 24/06/2021 21:12:36(UTC)
30000 shorts on some C-track curves (H0-scale)
by xxup 25/05/2021 23:14:39(UTC)
Marklin c-track wiring for z21 (Model railroad wiring)
by Lusito 22/04/2021 15:05:16(UTC)
C-Track and Rolling Stock (H0-scale)
by Ace Wickwire 26/02/2021 16:49:18(UTC)
Early C-track? (H0-scale)
by CGuy 29/11/2020 03:15:14(UTC)
Need for bus wires using C-Track (Great layouts I have seen...)
by Richard Joint 03/08/2020 20:59:21(UTC)
A verified C-track wye configuration (H0-scale)
by BobG100 20/06/2020 09:14:28(UTC)
Trix C-track (H0-scale)
by BobG100 31/05/2020 00:20:33(UTC)
Turntable 7286/7686 with C-track (H0-scale)
by MartinS 27/05/2020 11:47:03(UTC)
COVID-19 The good, the bad & the ugly - aka Marklin rediscovered, where did time go & damn C-track (General MRR)
by black_pete 16/05/2020 16:51:44(UTC)
Marklin c-track turnout lever (H0-scale)
by STE-BM 07/03/2020 21:11:07(UTC)
Modell Tannhofen 8068 from M-track to C-track (General MRR)
by JohnyH 05/01/2020 21:48:18(UTC)
The Geometry of Track, why C-Track and K-Track both missed an opportunity (H0-scale)
by Johnvr 24/10/2019 21:41:42(UTC)
Soldering C-track connectors (Model railroad wiring)
by morsing 12/06/2019 18:37:50(UTC)
Marklin C-track uncoupler wiring (Model railroad wiring)
by Twisterdodger 29/04/2019 16:15:23(UTC)
Translate M-tracks to C-tracks (H0-scale)
by mauel 05/01/2019 22:32:38(UTC)
Roco/ACME/Rocky-Rail Wagons on Marklin C-track (H0-scale)
by nomad777 05/01/2019 17:50:25(UTC)
Connecting a C-Track layout to a 6646 Transformer (H0-scale)
by waterslip 02/01/2019 00:46:37(UTC)
First attempt at trackplan Märklin C-track (Track plans)
by miccar 07/12/2018 21:01:26(UTC)
Running with DC Wheels on AC C-Track? (General MRR)
by mgbeck_98 14/09/2018 17:07:22(UTC)
My World tracks - Are they compatible with C-Track? (H0-scale)
by rglasinovic 25/05/2018 19:37:43(UTC)
C-Track Isolation/Insulator Question (H0-scale)
by Justatool 13/05/2018 22:25:10(UTC)
Running a Fleischmann H0 car on C-Track - wheelset changes questions (H0-scale)
by Minok 12/04/2018 22:56:55(UTC)
Make your own Märklin C-track Contact Track (General MRR)
by Thewolf 06/03/2018 17:55:40(UTC)
Professional layout using C-track: Oktorail in Essen (H0-scale)
by Minok 18/02/2018 21:52:18(UTC)
This page was generated in 0.608 seconds.
