Offline drnodk
#1 Posted : 06 June 2017 02:28:21(UTC)
drnodk
When I connected my 3 point turnout to my cs2 it occupied 2 positions since it has 2 decoders but I can't seem to properly connect it to my cs3.
Please advise.
Bill
#2 Posted : 06 June 2017 23:18:36(UTC)
Hi Bill,
Not sure where your problem is:
- creating a new position is easy on the CS3, it needs two consecutive addresses, the left turn-out being the fist address and right turn-out being the secong or higher one.
- Marklin Decoders are:
. + older general purpose 6031 decoders
. + newer general pupose 60831 decoders
. + triple point specific decoders 74465 décodeurs
the CS2 shows for each type the switch programming for Marklin decoders
For other brands, you have to find on the decoder documentation the way to set-up. Of course both decoders must receive the digital current and connect to the 2 switch motors.
Note: the order of decoders must be checked for correctness (one chance on 2 to be mistaken BigGrin )
So where is the problem in your case?
#3 Posted : 06 June 2017 23:28:26(UTC)
Bill,
Can you please elaborate on the actual symptoms.
Also, please define the decoder(s) involved and if you have them set for intelligent switching of the two addresses
And confirm the protocol being used is the same for decoder and CS3*.
As with the CS2, the addresses for the turnout mechanism must be consecutive with the lower one representing the left fork
and the upper address representing the right fork.
I am aware that there are issue with the CS3* UI as it relates to the handling of multiple items (inadvertently or otherwise) set up on the same address
(there is a warning, but it is in German and allows you to proceed anyway)
The result however may be the inability to switch in one direction.
I would suggest editing the item to see if the address is "red" indicating a conflict.
This does not represent a conflict of the 2nd address however, so temporarily edit the value up one and again check for a conflict (Red).
If either is red, you need to resolve the conflict by deleting/moving the item(s) address until not red.
P.S. could you please offer a more meaningful subject description for this thread.
Offline drnodk
#4 Posted : 08 June 2017 02:32:23(UTC)
drnodk
Thanks I believe I resolved the problem with the 3 point turnout but I have one normal right turnout that only operates in one position (the right) When I touch the screen on my cs3 for it to turn straight nothing happens.
Don't know if it is the decoder or the motor HELP
Bill
Offline PMPeter
#5 Posted : 08 June 2017 04:28:31(UTC)
PMPeter
Bill
Most likely the micro-switch in the actuator. There are numerous posts in this forum regarding this problem and how to short out the micro-switch.
Wire Marklin turnouts 8561 to Rokuhan RC-03 (Small scale)
by dmazyn 22/01/2024 16:47:19(UTC)
Use of M-turnout motors in C-turnouts (General MRR)
by gimo49 20/01/2024 12:27:07(UTC)
Problems with turnouts (H0-scale)
by Arnstein 11/12/2023 11:00:30(UTC)
C track curved turnouts - single track to four (H0-scale)
by einotuominen 31/10/2023 07:38:03(UTC)
Turnouts (General MRR)
by sudibarba 20/08/2023 04:09:21(UTC)
Marklin turnouts are not power-routing (General MRR)
by Yoginath 06/07/2023 14:26:26(UTC)
Wide turnouts (General MRR)
by river6109 29/06/2023 10:17:13(UTC)
m83 decoder wire length to turnouts (Digital)
by swisslocofan 27/05/2023 04:16:19(UTC)
Use AC HO Marklin turnouts with DC power supply? (H0-scale)
by Yigal 14/05/2023 07:41:52(UTC)
Pickup shoe short circuit Turnouts (24771/2)? (H0-scale)
by flyhalf 22/01/2023 20:55:12(UTC)
Märklin Wide Radius Turnouts geometry (H0-scale)
by Patrik 01/09/2022 14:32:38(UTC)
Marklin 3600 WB Remote Operated Turnouts (Collector's Corner general)
by mb300e4m 01/08/2022 21:55:58(UTC)
Rocrail and threeway K turnouts (Model railroad software)
by pmgsr 17/05/2022 21:20:37(UTC)
Intermittent switching of turnouts (Digital)
by IBtrain 03/02/2022 06:34:02(UTC)
DCCNext and M turnouts (Model railroad wiring)
by IBtrain 14/01/2022 20:13:45(UTC)
turnouts (Big scale)
by Krish 13/08/2021 08:05:39(UTC)
Sticky turnouts (Digital)
by Rwill 12/06/2021 14:04:05(UTC)
MS2 Controlling Digital Turnouts in Analog Mode (General MRR)
by Joao Zilio 15/04/2021 19:29:53(UTC)
Turnouts (Model railroad wiring)
by Mr. Ron 07/03/2021 19:21:05(UTC)
Turnouts numbering (General MRR)
by Mr. Ron 01/03/2021 23:15:28(UTC)
7270 and C turnouts (H0-scale)
by carlos.rivas16752 13/02/2021 20:34:51(UTC)
Layout issues using a 6021 and 6001 with multiple Turnouts (Digital)
by waterslip 05/02/2021 03:38:34(UTC)
Long ICE cars rubbing turnouts semaphore m track (H0-scale)
by Victor Almeida 04/02/2021 02:56:37(UTC)
Peco turnouts code 100 (H0-scale)
by Harlov 18/12/2020 19:14:22(UTC)
M turnouts 5117, 5140, 5137 5202 for long coaches (H0-scale)
by 60904 25/11/2020 22:13:54(UTC)
Marklin Switches/turnouts/points - contact cleaning (Small scale)
by Poor Skeleton 17/10/2020 20:42:30(UTC)
2265 and 2266 turnouts and 75491 solenoid (H0-scale)
by Harvey 01/09/2020 20:12:41(UTC)
M track turnouts (H0-scale)
by Benders 16/08/2020 10:30:02(UTC)
Blue Transformers to Control Turnouts in Digital Ambient (Digital)
by Joao Zilio 28/05/2020 22:34:50(UTC)
Controlling 2 turnouts with 1 button (H0-scale)
by Brian_BR96 23/05/2020 02:16:48(UTC)
Marklin 88166/7 railbus and turnouts (Small scale)
by ajayrav 15/05/2020 17:18:55(UTC)
CS3 Track Diagram, Turnouts, etc (Digital)
by Twisterdodger 08/05/2020 16:52:08(UTC)
m83 - 2 turnouts with single address (Digital)
by bzzi 30/04/2020 01:23:00(UTC)
by JoeB 18/03/2020 01:56:33(UTC)
Marklin c track curves turnouts not reaching final position (H0-scale)
by Br01 26/02/2020 13:15:39(UTC)
Using a Transformer and 7210 Switches rather than Decoders on each turnouts. (H0-scale)
by Richard Joint 07/01/2020 03:33:52(UTC)
Inverted turnouts + random stop on locos (Digital)
by denis81 17/08/2019 23:16:30(UTC)
Controlling turnouts: Mobile Station or Control Box (Model railroad wiring)
by fstrobel 12/03/2019 21:53:20(UTC)
Physical button to control turnouts with decoder (Digital)
by denis81 06/03/2019 23:06:13(UTC)
CS2 not controlling turnouts. (Digital)
by franciscohg 25/09/2018 18:40:15(UTC)
Märklin M-track turnouts with solenoids versus K & C track (General MRR)
by river6109 25/06/2018 12:46:02(UTC)
turnouts wired to bus wiring (H0-scale)
by Primo -23K 21/12/2017 04:33:54(UTC)
Incorporating Marklin 24771 and 24772 -C-Track Right and Left Wide Radius Curved Turnouts (H0-scale)
by michelvr 10/12/2017 15:15:27(UTC)
I know they tell you not to...but why? Signals, turnouts etc etc (Model railroad wiring)
by Michael4 09/12/2017 18:29:14(UTC)
SNCF 241-A and outer curve of 24671 turnouts (H0-scale)
by db60 17/10/2017 21:34:30(UTC)
please help with turnouts and uncoupling (H0-scale)
by serge360 20/07/2017 16:16:27(UTC)
Turnouts (Digital)
by Don Morris 17/07/2017 09:15:53(UTC)
Shortcircuit in Peco turnouts (Big scale)
by Jaime 11/06/2017 14:41:34(UTC)
by drnodk 07/06/2017 18:38:44(UTC)
Controlling M track turnouts with a 'piano'? (H0-scale)
by Michael4 11/05/2017 14:40:47(UTC)
This page was generated in 0.455 seconds.
