Offline muhkau
#1 Posted : 21 August 2022 09:00:55(UTC)
muhkau
Hi, I have 2 oval tracks powered separately by 2 transformers. I am not able to get them operating independently? For example if I set transformer 2 to zero, the track is still powered by transformer 1. Any advice would be greatly appreciated
Offline BenP
#2 Posted : 21 August 2022 12:37:45(UTC)
BenP
Your two ovals must be connected, and not power isolated. With turnout perhaps? Isolate middle rail at connection(s) and use two feeder tracks. (Or, transformers are connected, which can be hazardous)
Edited by user 22 August 2022 18:32:04(UTC)  | Reason: Not specified
#3 Posted : 22 August 2022 06:36:32(UTC)
Sounds like you have no track isolation between the 2 ovals, which is dangerous and quite frankly rather stupid because as Ben points out the two transformers are connected and if you unplug one of them you will have 240v appear on that plug.
You need to isolate at every point where the ovals are connected - use a thin piece of cardboard and slip that in between the two centre tongues at the connecting join so that neither tongue touches the other.
I hope I'm not being too harsh on you, that's not my intention. However, there are mistakes that don't result in much damage, there are those that can kill you. This is one that can kill you.
(excuse the spelling - should read 'Isolator')
I suggest you download and read the following manual from Marklin - Connecting Electric Railways Connecting_Electric_Railways.pdf (3,092kb) downloaded 505 time(s).
Edited by user 22 August 2022 10:43:59(UTC)  | Reason: Not specified
2025 Holiday M track Winter Layout Project (Great layouts I have seen...)
by 5HorizonsRR 12/09/2025 20:27:12(UTC)
Why do alot of people use M track still? (General MRR)
by Train train 02/09/2025 14:41:22(UTC)
JOUEF wagons on M tracks ? (H0-scale)
by philippe99 17/08/2025 17:50:50(UTC)
m track (H0-scale)
by Coling 05/02/2025 09:00:12(UTC)
M track with outlets/sockets (H0-scale)
by Conductor0179 27/11/2024 18:50:11(UTC)
Creating 54mm Track Spacing With HO C-Gleis (General MRR)
by Electrix 18/11/2024 10:46:35(UTC)
Is M track still being made? (H0-scale)
by Mr. Ron 18/09/2024 06:08:48(UTC)
Protocol error & Ghost with M track retro-signalisation (Digital)
by Olivier1967 14/09/2024 12:22:45(UTC)
M track (H0-scale)
by Mr. Ron 07/09/2024 03:03:09(UTC)
M tracks dimensions (H0-scale)
by Pmeeuwes 07/08/2024 00:09:05(UTC)
M Track Curved Turnout loco stops (H0-scale)
by Brian_BR96 20/07/2024 05:08:03(UTC)
Flooded M track and rolling stock (H0-scale)
by BenP 27/06/2024 21:27:07(UTC)
Marklin screws for M track (H0-scale)
by jimwallace1652 25/06/2024 22:18:28(UTC)
Track Screws for M yes M Track (H0-scale)
by frickwg 21/04/2024 20:19:36(UTC)
analog m track parts.. how to... (Model railroad wiring)
by lucasm54 21/04/2024 09:50:34(UTC)
Marklin M Track 5106 1/1 (H0-scale)
by MALAVIKA 18/02/2024 06:39:03(UTC)
M Track Switch Testing (H0-scale)
by baja463 01/02/2024 20:27:06(UTC)
Working with Marklin M track signals (General MRR)
by tandrschaefer 03/01/2024 21:41:00(UTC)
Speed on different types of M track (analogue) (H0-scale)
by Michael4 05/11/2023 17:30:21(UTC)
m track switch wiring question (H0-scale)
by heinrichhess 24/08/2023 12:04:59(UTC)
will m track fit Transfer Table (H0-scale)
by heinrichhess 20/08/2023 18:20:40(UTC)
odd numbered m track 36010 (H0-scale)
by heinrichhess 06/08/2023 12:29:08(UTC)
will Schicht runn on m track? (H0-scale)
by heinrichhess 21/07/2023 15:32:40(UTC)
M track (General MRR)
by Keim 24/05/2023 02:42:42(UTC)
Searching for info on this M track layout (H0-scale)
by Soylent73 30/04/2023 17:26:30(UTC)
Mixing C and M tracks - best tricks? (H0-scale)
by einotuominen 12/12/2022 17:53:29(UTC)
Compatible power supply for Marklin M Track? (General MRR)
by Skywalker646 10/12/2022 02:49:53(UTC)
Manual download for M track or vintage Marklin Accessories (H0-scale)
by tinroofrusted 12/10/2022 12:05:44(UTC)
Marvellous M track manufacture (H0-scale)
by Michael4 14/09/2022 11:52:27(UTC)
M track points lights (Model railroad wiring)
by mitchnz 12/08/2022 02:56:16(UTC)
New M track layout (H0-scale)
by Mr. Ron 21/07/2022 18:48:27(UTC)
Marklin HO M track 1937-50s Electric Points Cat No 13600 WB (H0-scale)
by David240945 10/05/2022 18:18:59(UTC)
Mixing M track and C track (Model railroad wiring)
by PedroRyder 13/01/2022 16:35:36(UTC)
Connecting a Jagerndorfer ho cable car set with an ESU 56002 sound decoder to a CS3 from track power (Digital)
by marklinist5999 03/01/2022 20:36:33(UTC)
AC Wheels for Liliput and Piko Wagons-M track (Collector's Corner general)
by Philipj 28/12/2021 20:56:55(UTC)
Marklin M Track 5117 Points / Led Bulbs (H0-scale)
by fossie 28/11/2021 10:53:09(UTC)
eCoS to M track points to marklin k83 (Model railroad wiring)
by Ausipeet 26/09/2021 06:32:55(UTC)
M track Connections (H0-scale)
by Mr. Ron 08/09/2021 03:21:05(UTC)
Solid Third Rail M Track (General MRR)
by mike c 10/08/2021 04:52:31(UTC)
Catenary fabrication for M track (H0-scale)
by Mr. Ron 12/07/2021 21:49:21(UTC)
analog signal on digital M track section of siding spur (Digital)
by marklinist5999 12/07/2021 14:23:02(UTC)
HO 2-rail rolling stock on Marklin M track (H0-scale)
by Mr. Ron 08/06/2021 04:59:47(UTC)
M track Figure 8 layouts (H0-scale)
by A4Gresley 01/05/2021 09:52:05(UTC)
Long ICE cars rubbing turnouts semaphore m track (H0-scale)
by Victor Almeida 04/02/2021 02:56:37(UTC)
Two locos simultaneously on m tracks (H0-scale)
by Petros 08/01/2021 20:40:35(UTC)
Marklin M track vs C track (General MRR)
by Tracy 29/12/2020 22:03:50(UTC)
M Track planning SW (Model railroad software)
by Vitsing 20/12/2020 05:34:47(UTC)
Which Controller works best with old M Track? 6021 or MS2? (Digital)
by SteveK-O 08/12/2020 15:38:21(UTC)
Wireless control of M track accessories (Digital)
by joyofmarklin 22/11/2020 03:43:22(UTC)
Joining M track sections (H0-scale)
by Mr. Ron 14/11/2020 09:04:18(UTC)
This page was generated in 0.271 seconds.
