Offline Mr. Ron
#1 Posted : 25 December 2021 23:32:37(UTC)
Mr. Ron
I'm not sure if I had asked this question before or not, but here goes. I watch model railroad videos, especially those of European railroads because they use catenary more than we here in the U.S. do. I see layouts with extensive catenary arrays, but they are running their electrics with the pantographs down, meaning they are not using the cat wire for power pickup. Is there a reason for this? I thought it may be because of DCC that would render catenary not needed any longer. Sorry if I asked this before.
I did ask this question before, See next reply.
thanks 1 user liked this useful post by Mr. Ron
Offline Mr. Ron
#2 Posted : 25 December 2021 23:57:21(UTC)
Mr. Ron
I discovered a post by River 6109 that answered all my concerns. i realize it can be difficult to add catenary especially on gauges less than O gauge. There is limited space to work with between the track and overhead wire, especially so with N gauge. But! Catenary does add an extra measure of authenticity and more positive control. I am building my Marklin layout and want to include catenary, but I want it to be operational, not dummy. Seeing as commercial catenary components are expensive, I'm making my own using brass rods and code 70 rail respectively for my masts and overhead contact. I guess the only reason why I asked this question was to get any negative reasons for not using catenary.
#3 Posted : 26 December 2021 06:38:06(UTC)
Originally Posted by: Mr. Ron Go to Quoted Post
I'm not sure if I had asked this question before or not, but here goes. I watch model railroad videos, especially those of European railroads because they use catenary more than we here in the U.S. do. I see layouts with extensive catenary arrays, but they are running their electrics with the pantographs down, meaning they are not using the cat wire for power pickup. Is there a reason for this? ...
Hello Ronald and a Merry Christmas to you,BigGrin
Yes this has been discussed before, but don’t be discouraged from asking questions.Smile
The answer is not at all specific and indeed extraordinarily eclectic.
Some folk on our group are passionate vintage Märklineers and model in analogue with the original bent-to-the curves Märklin catenary. I understand, respect and appreciate their pursuit of the original vintage and admire it. They can run their analogue locos powered from the track (pukos) or from the overhead (where they have the added joy of seeing the electric sparks from the pantograph-running wire contacts and also of inhaling the wonderful ozone) thus doubling the number of (electric pantograph) locos immediately controllable on a particular track power section. Cool
In the digital world most power their locos (including the electrics) from the track. This may be because early in the digital era Märklin declared that the digital signal was more reliable from the track than the overhead wire. However, our much-esteemed member from Perth, Western Australia, river6109, has conclusively shown on his very large layout that you can run many digital locos off the overhead wire without any problems.
Some folk run their digital electrics off the track because they have a mode of scenery wherbye they have all the masts and equipment etc to display the overhead catenary – all except the actual catenary wireOhMyGod . From what I have perceived of their interesting posts, this seems because they feel that even the thinnest model catenary wires currently made (e.g. by Sommerfeldt) are still much thicker in relative perspective ("scale") than the prototype. Some of these folk run their electric locos without the overhead wire but with their pantographs up. We should note that there are a number of extremely large commercial layouts in Europe that do the same – run their electrics with some pantograph elevation but with no actual running wire to the catenary, whilst having all the associated overhead-power paraphernalia.
Another group of folk have the full catenary wire but run their electric locos with the pantographs down or not fully raised (i.e. just short in height of contacting the running wire). My understanding is that they do this to avoid either wear of the pantograph, or of greater concern, prangs to raised pantographs exposed to unintentional obstruction and other hazards.
My opinion is but a drop in the bucket of our groups’ overall wealth of experience; I have full catenary (Sommerfeldt) and a digital layout but tend to run my electic locos powered from the track pukos with pantographs down to avoid the occasional (but expensive) prangLaugh – but fully up for forum photos and video, however !Blushing .
This is because I have only one electric loco that remains analogue and not converted to digital (a beautiful old 3015) because I felt it sacrilegious to convert it to digital - so I run this loco as analogue using the overhead wire on my digital layout with a common "earth/ground/negative" via the outer rails.
Just my opinion, as I noted there is a wide variety of point of view on this wonderful group forum.BigGrin
PJ
thanks 14 users liked this useful post by PJMärklin
#4 Posted : 26 December 2021 08:21:31(UTC)
I've noticed 99% of model layouts have catenary but as mentioned with the pantograph down., it can be a bit costly when you ruin a pantograph but for me its a learning curve and by that I mean you adjust your wires so it will not happen again., it doesn't take long to errect the proper catenary (Sommerfeldt or other recongnized manufacturers) and you will have the enjoyment of saying: "I've done it", as menationed in my previous posts running electrics from the overhead system gives me most the time 1 more axle which a.) I can add another axle with rubber tyres, b.) another powered axle or 2., however lately manufacturers have altered the composition of materials from metal to plastic, protoypical pantographs but Märklin has kept pantographs sturdy so they can be operated via the overhead system or just have their pantographs up.
for me it is sad to see pantographs being made out of plastic and very flimsy and yes it leads to ruined pantographs but this is not the end of the road, for me anyhow, replacing them with a better product doesn't cost an arm and a leg., I save money on other projects or when I buy a loco or 2, so the cost of a new pantograph is not the end of the world, although we live on the end of the world and getting things posted to Western Australia takes time.
Edited by user 26 December 2021 17:10:38(UTC)  | Reason: Not specified
thanks 6 users liked this useful post by river6109
#5 Posted : 26 December 2021 12:53:17(UTC)
Hello Ronald,
Good questions.
Like Philip (PJMärklin) said, there are many valid approaches to using/pretending catenary.
I encourage anyone with time and patience to erect catenary, because as you say it lends a certain authenticity.
Thankfully with Märklin engines the pantographs are very robust, and with my occasional accidental hook-up between catenary and engine the pantograph always survives.
Sometimes with a little bit of re-assembly.
The hook-up does not happen often if you follow the manufacturers catenary erection instructions faithfully.
By the way I use Märklin catenary (latest productions) suited to C track.
#6 Posted : 26 December 2021 17:17:07(UTC)
Another issue is getting used to the overheadsystem as it restricts your access to the track considerable, taken trains or locos off the track can also be difficult, all in all we've got used to it and after a while your brain adjust itself, yes there is an overhead wire., wires don't get damaged but getting trains off the track or remove them from the track isn't that simple any more., also cleaning tracks is more difficult but on our layout there is very little dirt or grime on the track and yes it would take more time to clean them but I reckon it would take a lot of dirt and grime to stop a train.
Offline 1borna
#7 Posted : 26 December 2021 19:51:32(UTC)
1borna
Croatia
And I have already written about the use of pantographs and contact networks, with small layouts that we use occasionally, it is not difficult to control driving with raised pantographs. On large layouts (especially those for visitors) this is almost impossible and that is why they mostly drive with the pantographs lowered or even better fixed imperceptibly under the net. As locomotives cover long distances on these layouts, the upper part of the pantograph would be cut regardless of the polygonal guidance.
thanks 5 users liked this useful post by 1borna
#8 Posted : 27 December 2021 00:14:39(UTC)
Another issue is getting used to the overheadsystem as it restricts your access to the track considerable, taken trains or locos off the track can also be difficult,....
Hi John,
absolutely.
Track cleaning and removal of stock is certainly more difficult even on my small layout.
But as you say you get used to it.
Offline Michael4
#9 Posted : 27 December 2021 10:51:39(UTC)
Michael4
I use the 'old' Marklin catenary on M track, it is all analogue with bent wires going round corners, posts leaning on gradients etc etc. I'm nevertheless quite content.
Things go wrong when catenary gets tangled in clothing. More than once I have lifted an arm away and caused all sorts of mayhem to catenary and the track to which it is clipped by getting a sleeve caught on something.
But is still very satisfying and adjusting coach lighting while the train is in motion is an added feature.
There are all sorts of other tricks to consider. For example one can dispense with the services of the reversing switch in the loco by wiring the loco so that it goes in one direction on catenary power and the other way via track power.
Why bother?
Because I can!
thanks 4 users liked this useful post by Michael4
#10 Posted : 27 December 2021 16:37:44(UTC)
Hi Ron
This is exactly my case: not using the catenary for pick-up and having the electrics with a down pantograph.
Why not using the catenary? Because with digital, it has only drawbacks (digital quality of power feed through a pantograph is much lower, leading to ignored commands. Another reason, it adds noise to the operation while the only noise we want to hear is the prototype's real noise and not a wire scratching. Another reason is to be able to control other types of locos (Diesels, Steamers)
Why not having the electric with the pantographs UP? Because they wear rapidly and because each loco has a specific pantograph. Because you have periodic accidents with the catenary Pantograph getting stuck and torn off. Some modellists modify the pantograph so they are half up but not touching the catenary.
Just the opinion of an European modeller from France
Of course, in analogue operation, the catenary allows to operate 2 locos independently on the same trck but with significant additional wiring.
Offline Crazy Harry
#11 Posted : 27 December 2021 21:27:01(UTC)
Crazy Harry
Catenary installation is expensive and fiddly along with the drawbacks of accessing the tracks and getting clothing caught on it or the masts. But it does look impressive! There are travel limiters for the pantographs so that they are raised but are just below the catenary - this avoids catenary accidents and noise and still gives some realism to the movement of the electric locomotives.
Harold.
thanks 3 users liked this useful post by Crazy Harry
Offline Copenhagen
#12 Posted : 28 December 2021 11:10:53(UTC)
Copenhagen
I mostly have diesel and steam locomotives and I don't want a too modern looking environment on my layout (in my country electric trains - apart from S-bahn in Copenhagen - didn't really became a thing until a small stretch in the 80's and much later elsewhere). But I have aquired a few modern, electric locomotives that can run some modern cargo and passenger trains. I think it looks fine without catenary and I wouldn't want the hassle and looks of catenary all over the layout.
I fully respect people who want catenary of course.
thanks 2 users liked this useful post by Copenhagen
Offline TrainIride
#13 Posted : 28 December 2021 12:12:56(UTC)
TrainIride
The main thing is to have fun watching your trains running !
Everyone has their own rules about it.
For me, who runs very old models most often, the old low priced and reliable catenary is perfect (the catenary is powered in analog mode).
I have a few digital models now (track powered) without any problem to run with the pantograph raised up (catenary not powered).
All the layout is covered with catenary, more than 100 masts, so more than 100 catenary parts even in all tunnels without a problem.
Best Regards
Joël
thanks 9 users liked this useful post by TrainIride
#14 Posted : 28 December 2021 12:21:31(UTC)
ThumpUp
#15 Posted : 28 December 2021 14:27:37(UTC)
Harold.
I haven't noticed any extra noise not with my catenary maybe the Märklin catenary with its wider(thicker) overheadwires creates a noise.
Catenary has far reaching applications and everyone has their own concept to use it or not to use it.
Edited by user 29 December 2021 15:00:04(UTC)  | Reason: Not specified
Offline Mr. Ron
#16 Posted : 28 December 2021 20:32:56(UTC)
Mr. Ron
I am fabricating my own catenary components as I cannot afford Sommerfeldt or Marklin parts. I use 3/32"(.794mm) brass wire for masts, 1/16" (1.588mm) brass wire for messengers and code 70 nickel silver rail for the contact wire. I made jigs so all the components come out the same. The code 70 rail is positioned with the rail head facing down, so rail joiners don't contact the pantograph. The ends of the masts are threaded to secure them through the layout base. The construction is pretty robust so I don't think I will have any trouble with them. At the moment, I'm finalizing my layout before erecting the catenary. I will be using catenary only on part of the layout where electrics will be run.
thanks 3 users liked this useful post by Mr. Ron
Offline jcrtrains
#17 Posted : 28 December 2021 23:14:35(UTC)
jcrtrains
There are a lot of good points in this thread. My only suggestion is to add the catenary close to the end of the scenery cycle. If you are ballasting or weathering track, do the catenary after. While it sounds robust, constantly doing scenery and other elements around installed catenary typically leads to an accidental bump of something that creates catenary rework.
Edited by user 29 December 2021 15:51:59(UTC)  | Reason: Grammar
thanks 5 users liked this useful post by jcrtrains
Offline michelvr
#18 Posted : 29 December 2021 03:53:17(UTC)
michelvr
ThumpUp
ThumpUp ThumpUp
Offline Mr. Ron
#19 Posted : 29 December 2021 17:47:21(UTC)
Mr. Ron
Thanks for the advice; sounds good.
Offline ccranium
#20 Posted : 29 December 2021 23:28:43(UTC)
ccranium
"Greenberg's Model Railroading with Marklin HO" in paperback has an extensive section on homemade catenary. There are copies for sale on Amazon and likely on eBay.
I'm installing M-track catenary throughout on my analog M-track layout. Yes, it's fiddly, especially since I'm also using analog signals to control the puko and catenary block sections. I do a trial install, remove the bent and correct-length wires from the masts, secure tracks & masts, test tracks and turnouts using the pukos, then landscape the ground level with ballast/grass/"asphalt" paint/"concrete" paint, then reinstall wires. The final and most fiddly part is installing the darn 7503 feeder wires before installing the block sections' wires. Lots of satisfaction for my desires for the 70's vintage look layout, but certainly slows the build! Especially in the eyes of my 7-yo granddaughter!!!
thanks 4 users liked this useful post by ccranium
Offline Darren W
#21 Posted : 31 December 2021 20:22:59(UTC)
Darren W
Another approach now is to 3D print the catenary.
thanks 6 users liked this useful post by Darren W
Offline Mr. Ron
#22 Posted : 06 January 2022 02:51:01(UTC)
Mr. Ron
I've watched a lot of model railroad videos, mainly of European layouts. The majority of them have a complete catenary system erected, but not being used. Why does a huge layout erect a complicated catenary system and then not use it? It takes a lot of planning, money and work to install a catenary system.
#23 Posted : 06 January 2022 03:43:04(UTC)
because:
a) putting it up in hidden areas adds even more cost.. and hassle.
b) Catenary does not add anything to digital running beyond the visual aspect of it. It used to add the ability of adding additional analog control circuits.
c) maintaining running trains is enough of a task as it is without adding another layer of complexity for no functional advantage.
The reasons for doing it are similar to the reasons that we don't always interlock signals with turnouts, we typically don't insist of having track ahead of a stopping area clear of any train before bringing a train into a station, we don't electrify the Indusi magnets, etc. etc. The tradeoff between the effort and the visual result are just not worth it to most people.
Try it.
Offline jcrtrains
#24 Posted : 06 January 2022 03:57:01(UTC)
jcrtrains
because:
Try it.
Mine is purely visual. At one point, I was going to run off of it, but the risk of damage is too high. I actually have power into it, but do not use it.
I am very pleased with the visual aspect alone, in short it was worth it. However, have a look at Martin’s 3D print video, as that is a much cheaper approach than what I have done.
thanks 1 user liked this useful post by jcrtrains
#25 Posted : 06 January 2022 10:54:50(UTC)
It certainly adds realism! I haven't any. It isn't inexpensive either. I think if you don't add it in hidden areas, a pantograph can spring up higher, then catch the next wire hanger and cause a crash.
A dilemma for me would be installing it on a 5 metre double track bridge.
I haven't also ballasted the C track. I need to be able to lift a section up for connecting feeder wires.
Tunnels are tricky as well. I have a curved one on a corner, under a mountain. Because of the R 3 radii parallel double track for clearance of 303 mm coaches, it is unpritotypically high, and wide. Longer cars passing through can still rub and derail on occasion, thus I'm even more aprhensive.
I don't have room between the tracks for masts, and may only on the inside curve.
Perhaps it was poor planning n my part, but I wanted the Mountain for a television tower and cable car. When I install that, a castle is moving to the back inside corner.
It has been said in the past that an avid modeler builds three layouts in a lifetime. My current is my second. I don't know if there will be a third, but it is conceived.
I would eliminate the double 4x8' horse shoe and make it a large L. Having 12 feet in one parade route would give more space to ascend to a higher grade, and accommodate a hidden staging yard.
#26 Posted : 06 January 2022 14:37:49(UTC)
or pick an era that predates electrics...
#27 Posted : 06 January 2022 14:58:56(UTC)
Yes Dale, but many of us like Electric Locs. and trains. Most of what I have, but I do have steam, diesel, and I mix era's anyhow.
#28 Posted : 06 January 2022 15:53:29(UTC)
yup me too, so I put up the catenary poles but no wires.
Offline petestra
#29 Posted : 06 January 2022 17:56:57(UTC)
Views messages in topic : 5,863
I use the old style Maerklin Catenary. One can still find many pieces on ebay. I ,too, have a mix of the three Lok types with electrics being in the
majority. Some of the newer electrics have delicate pantographs and even though my catenary is well set up it's just safer to run these newer loks
with the pantos down. Regarding the masts, I have taken the base part off all masts that clip under the track so all my masts are screwed down. Yes,
I know some day they'll probably not be worth much for resale but I prefer this method as it makes the C/M tracks with less of a bump underneath
where the base would have been. A catenary system, I feel, really adds depth to the railway. Cheers. Peter. Cool
thanks 5 users liked this useful post by petestra
Märklin Z-Scale 8930 Toporama Catenary Part 2 (Small scale)
by Fluegelmeister 14/08/2025 00:14:38(UTC)
Two rail catenary operation (H0-scale)
by einotuominen 06/02/2025 07:08:40(UTC)
Catenary for trasfer and turntables (H0-scale)
Belarus quarkhirad 03/11/2024 20:28:29(UTC)
Faller Viaduct - Catenary Intallation (H0-scale)
by Eddie7979 29/05/2024 12:23:09(UTC)
CS2 and catenary analogue (General MRR)
by Bryan 12/04/2024 23:50:12(UTC)
Catenary Transition for Shadow Station to Tunnel (H0-scale)
by sforugby 22/03/2024 21:05:18(UTC)
Starting with catenary. (H0-scale)
by dave55uk 21/01/2024 12:09:40(UTC)
Paint Colour required for Marklin Catenary (H0-scale)
by marklin61 04/12/2023 20:45:38(UTC)
3015 didn’t work from catenary (H0-scale)
by Hematite 13/06/2023 19:25:59(UTC)
Catenary Set Up - Curve Combinations (H0-scale)
by Eddie7979 04/01/2023 06:01:00(UTC)
Transfer table 7294 catenary (General MRR)
by Boydrlhome 21/11/2022 16:09:09(UTC)
Using Block signal #89391 with Catenary system (Small scale)
by veloboldie 06/10/2022 21:40:31(UTC)
Catenary pole spacing (General MRR)
by Mr. Ron 17/01/2022 10:34:42(UTC)
by Ausipeet 18/08/2021 05:13:57(UTC)
Catenary fabrication for M track (H0-scale)
by Mr. Ron 12/07/2021 21:49:21(UTC)
Catenary Function (H0-scale)
by Ranjit 23/06/2021 15:06:10(UTC)
Lowering the Catenary (Small scale)
by Ricinport 07/03/2021 11:43:26(UTC)
How to isolate catenary circuits at a crossing? (H0-scale)
by ccranium 25/01/2021 21:57:31(UTC)
711.1 Catenary service vehicle catches fire and becomes run-away - July 9 2020 (Prototype)
by Minok 05/01/2021 00:22:19(UTC)
Looking for a source for a, Marklin 03902 ”Catenary Handbook” (H0-scale)
by frickwg 10/12/2020 19:18:01(UTC)
Catenary (H0-scale)
by Mr. Ron 16/11/2020 00:29:02(UTC)
39940 Unimog Catenary Maintenance Locomotive (Loco Reviews)
by xxup 08/11/2020 09:04:06(UTC)
M track, catenary and helixes (or helices) (H0-scale)
by Michael4 25/08/2020 15:30:16(UTC)
kato catenary 5-052 (General MRR)
by sonra 30/04/2020 16:23:44(UTC)
Dapol catenary masts (H0-scale)
by PeFu 24/03/2020 08:56:51(UTC)
Märklin gauge 1 catenary wires (Big scale)
by aclassifier 17/01/2020 10:30:22(UTC)
Searching for catenary manual (General MRR)
by Bertl 09/01/2020 17:25:06(UTC)
Sommerfeldt catenary (General MRR)
by Nuno 11/11/2019 20:59:59(UTC)
Marklin 88564 catenary issue (Small scale)
by husafreak 25/08/2019 08:08:36(UTC)
My world under catenary? (General MRR)
by hennabm 08/03/2019 21:27:11(UTC)
Bent catenary masts...and wires (H0-scale)
by Michael4 31/01/2019 10:44:10(UTC)
39970 Catenary Railcar Coupling (H0-scale)
by cookee_nz 28/01/2019 05:39:24(UTC)
Buying catenary for marklin ho (H0-scale)
by quarkhirad 10/12/2018 18:57:49(UTC)
Electric Locos with or without catenary (H0-scale)
by Jabez 16/10/2018 21:24:37(UTC)
by Kyrannosaurus 08/08/2018 11:01:16(UTC)
Overhead wiring with Sommerfeldt catenary (Model railroad wiring)
by river6109 10/07/2018 12:39:47(UTC)
Bundesbahn Catenary Safety Film (Prototype)
by analogmike 26/07/2017 02:30:24(UTC)
Brawa KLv 60.9001 Catenary Test Coach - Sound and Light mod (H0-scale)
by Moritz-BR365 28/06/2017 15:05:41(UTC)
Catenary (yet again, sorry!) (H0-scale)
by Michael4 24/06/2017 18:32:01(UTC)
Tunnel Portals for M-track w/catenary (H0-scale)
by AtlanticMan 21/05/2017 19:19:49(UTC)
Catenary mast question (H0-scale)
by DB Fan 07/05/2017 05:47:15(UTC)
Catenary Lengths and M-track (H0-scale)
by AtlanticMan 23/03/2017 21:01:18(UTC)
constructing a Sommerfeldt catenary (General MRR)
by river6109 08/03/2017 05:15:34(UTC)
Catenary and M-track (H0-scale)
by AtlanticMan 10/02/2017 20:40:26(UTC)
Catenary for M-track (H0-scale)
by AtlanticMan 07/02/2017 02:26:20(UTC)
AC operations with catenary (H0-scale)
by Leitner 19/10/2016 13:28:19(UTC)
z scale catenary (Small scale)
by thomas buckley 28/09/2016 03:22:03(UTC)
Marklin M Track catenary: Which screw type is needed? (H0-scale)
by Slider 05/09/2016 14:34:01(UTC)
old style catenary questions (H0-scale)
by thomas buckley 30/05/2016 17:53:03(UTC)
Old-Style Marklin Catenary- Wire Material and Conductive Weathering Treatments? (Painting & Weathering)
by 5HorizonsRR 09/05/2016 22:43:46(UTC)
This page was generated in 0.858 seconds.
