Oil
Offline Rwill
#1 Posted : 13 November 2020 13:38:22(UTC)
Rwill
My little pot of Marklin oil - 7149 it nearly finished. I was a little shocked at the price. Is it really something special or can other hobby oils be used without messing things up?
#2 Posted : 13 November 2020 14:41:01(UTC)
Less oil, longer lives your motor and brushes
#3 Posted : 13 November 2020 15:10:41(UTC)
Faller also sell light oil in a dispenser with a syringe type tip, ideal for oiling locomotives.
any light oil such as sewing machine oil will do, but for worm gears and the like the teflon based grease that is sold under the Trix branding should be used, although this Faller item may be suitable also.
Offline Michael4
#4 Posted : 13 November 2020 17:49:58(UTC)
Michael4
In the UK you should be able to find: 'J.D Windle's 'Tried and Trusted' CLOCK OIL' or 'Priory Clock Oil' on Ebay. I use the medium viscosity mineral version on locos etc, also old cameras...and even clocks.
It is clear and quite light.
thanks 3 users liked this useful post by Michael4
#5 Posted : 13 November 2020 20:06:32(UTC)
Alan mentioned this Faller synthetic Teflon oil product...
That is what I have used for all model railroad gear lubrication for many years now, both metal & plastic, and I think it's the best thing ever since sliced bread... BigGrin
I also use it for squeaky door hinges, power tools and even door/car locks that have gone quirky (instead of graphite oil/spray)... In fact, the only lubricant used at home.
I'm sure other makers like Labelle have a similar product in the US. But since I live in Europe, Faller is easier to get over here...
If it moves, use Faller Teflon oil - If it doesn't move, use WD-40... BigGrin LOL
thanks 8 users liked this useful post by Webmaster
Offline applor
#6 Posted : 14 November 2020 04:41:51(UTC)
applor
Yes Faller also sell this one which is what I use:
https://www.faller.de/gb...cator-25-ml-sid9750.html
thanks 4 users liked this useful post by applor
Offline dominator
#7 Posted : 14 November 2020 09:44:00(UTC)
dominator
A mate of mine gave me a litre bottle of fully synthetic 5w-40 engine oil. I think I have enough for many generations.
I converted an old ink jet refill bottle for the purpose.
Dereck
Northland. NZ
thanks 3 users liked this useful post by dominator
#8 Posted : 14 November 2020 15:14:47(UTC)
Hi Rwill
Given that you need to use very very small quantities of oil, I have transferred the small quantity of Märklin oil into a disposable small syringe.
A small Märklin bottle is good for years and a very tiny drop is used at lubrication.
Because of a huge variety of oils, I prefer not to mix them (aka: I use Märklin oil and grease on Märklin stuff).
I don't know if this is the reason but I never a single time had a case of a solid frozen loco because of hardened oil on more than 100 locos some of them being over 70 years old
Faller oil is perfect for plastics as it does not attack the plastic.
I use Rocrail which also keep tracks of operating hours for each loco to signal when a maintenance is due on a loco. This avoids forgetting or over servicing locos.
Offline HO Collector
#9 Posted : 14 November 2020 22:59:17(UTC)
HO Collector
Never new that Marklin sell oil, I have always used light oil for home use like the '3 in 1' that can be found in B&Q. Never had a problem.
thanks 3 users liked this useful post by HO Collector
smoke oil substitute (H0-scale)
by heinrichhess 10/06/2023 17:32:43(UTC)
Lubrication and magnet coil (H0-scale)
by Pika_HO 11/04/2023 10:01:12(UTC)
Boiler Feed Pump (Steam engines)
by Valiantsteam 07/11/2022 12:44:42(UTC)
Lubricating oil (General MRR)
by Mr. Ron 18/05/2021 19:10:03(UTC)
ZIMO MX decoder and Märklin AC (Coil) Motor ? (Digital)
by fje 08/03/2021 21:33:31(UTC)
Oil and grease for new locos (H0-scale)
by husafreak 03/06/2020 02:33:13(UTC)
Oiling Marklin Z scale locos (Small scale)
by ajayrav 18/05/2020 17:50:26(UTC)
Delta P8 Running Only 1 direction, how to diagnose decoder/coil? (Digital)
by 5HorizonsRR 13/04/2020 03:26:25(UTC)
Oiled loc with 7149 - lost traction power (H0-scale)
by MarcelV 29/03/2020 03:13:17(UTC)
Congealed/hardened oil (Small scale)
by Trainiac 22/02/2019 21:32:35(UTC)
How to Coal and Oil a Steam Locomotive for a long run. (Training and Instructional)
by ShannonN 15/01/2019 02:39:13(UTC)
Cleaning Gears and Oiling(CM800) (Collector's Corner general)
by rg1911 30/11/2018 23:38:44(UTC)
Oily Elephant (H0-scale)
by Rwill 05/06/2018 13:07:15(UTC)
Smoke generator fluids - scented no oil? (General MRR)
by Minok 14/04/2018 23:23:05(UTC)
HOW TO COAL & OIL A STEAM LOCOMOTIVE FOR A LONG RUN - VINTAGE STEAM FILM (Prototype)
by ShannonN 11/03/2017 13:04:24(UTC)
Oil and newer Märklin locos (H0-scale)
by MaerklinLife 30/11/2016 17:32:40(UTC)
7286 turntable coil question (Digital)
by Hackcell 04/04/2016 21:31:20(UTC)
Dutch oil. (Prototype)
by NS1200 18/03/2016 21:24:21(UTC)
Lubricating oil (Collector's Corner general)
by lmedberry 18/05/2015 07:09:28(UTC)
Question about oiling (H0-scale)
by arcanjo 14/11/2014 12:42:33(UTC)
Diesel Oil Tanks (General MRR)
by MACER 05/09/2014 16:13:45(UTC)
oiling my 8104 locomotive (Small scale)
by yvonbug 25/08/2014 12:25:43(UTC)
Type of oil for lubrication (General MRR)
by Irish Rail 02/04/2014 11:28:31(UTC)
Horst Günther oil tender conversion for 3047 (Model kits & layout details, kitbashing and such)
by biedmatt 21/01/2014 13:46:17(UTC)
Relex Uncoupling Coil (H0-scale)
by Dick's mate 14/11/2013 20:35:13(UTC)
ARE THESE RULES GENERALLY CORRECT for OILING Marklin HO locomotives? (H0-scale)
by Larry 26/08/2013 06:56:18(UTC)
Coil overheat after digital conversion (Digital)
by Martin T 31/07/2013 21:04:41(UTC)
Engines swimming in oil and WD40 (H0-scale)
by Iamnotthecrazyone 25/07/2013 15:21:04(UTC)
Loco oiling - 40 hrs?! (H0-scale)
by Joseph Meiring 23/09/2012 18:56:48(UTC)
Topsoil VS hobby underlay (General MRR)
by Goofy 12/08/2012 09:33:40(UTC)
Crocodile field coils (Digital)
by biedmatt 21/06/2012 13:35:26(UTC)
Fixing Oil-Bound Gears – Better Ways?? (General MRR)
by DumbGuy 10/01/2012 01:37:09(UTC)
Stationstoilet "Krakow" (Model kits & layout details, kitbashing and such)
by Goofy 09/11/2011 19:08:43(UTC)
29500 BR50 doesn't move after oiling (H0-scale)
by Elukka 13/10/2011 14:58:10(UTC)
Oil sponge? (H0-scale)
by kbvrod 20/02/2011 21:28:14(UTC)
Marklin oil vs. synthetic oil (General MRR)
by Kevin Weis 14/01/2011 03:02:17(UTC)
spoiled or not being spoiled (General MRR)
by river6109 09/01/2011 05:37:29(UTC)
Oil or WD40? (General MRR)
by Drongo 29/11/2010 11:25:09(UTC)
Oil? (General MRR)
by Joseph Meiring 13/03/2010 17:47:33(UTC)
oil media (H0-scale)
by sudibarba 13/03/2010 07:05:50(UTC)
Wrong boilers in Märklin models? (H0-scale)
by grr_1954 21/12/2009 22:34:35(UTC)
39608 Chemoil (H0-scale)
by alonso231gery 21/08/2009 17:39:32(UTC)
Silver "rings" on BR 23 boiler... (Prototype)
by mjrallare 15/07/2009 16:41:22(UTC)
What are best practices in oiling Marklin HO loco? (H0-scale)
by Larry 12/06/2009 08:11:15(UTC)
New loc without oil (H0-scale)
by hemau 10/06/2009 19:48:41(UTC)
Best way to oil the wheel bearings for wagons/cars (H0-scale)
by gachar001 19/05/2009 00:35:45(UTC)
Removing cap from S 3/6 boiler (H0-scale)
by Armando 02/02/2009 21:12:14(UTC)
How do you oil "scarcely"? (General MRR)
by Caplin 19/06/2008 19:18:51(UTC)
Have you tried to install lights @ Etoile du Nord? (General MRR)
by lokbraz 03/04/2008 11:43:12(UTC)
Another flop? Mä 39401 SNCF 40100/Etoile du Nord (General MRR)
by lokbraz 04/03/2008 03:45:10(UTC)
This page was generated in 0.515 seconds.
