Offline jwmeara
#1 Posted : 07 September 2004 16:43:33(UTC)
jwmeara
Hi, I'm new to Maxi, I have Marklin HO for many years and just bought a starter Maxi for a garden RR. Are the Marklin track/ transformer / couplers compatible with US big scale , like LGB? Thanks.......
Offline perz
#2 Posted : 08 September 2004 22:32:15(UTC)
perz
I think Märklin Maxi is true scale 1 normal gauge, while LGB is a larger scale narrow gauge. LGB and Märklin scale 1 tracks have the same gauge but different "code" i.e. rail height. I don't know the details. I knew a web site that described the differences in detail, but unfortunately it has been closed down, so now all I can say is what I remember from it.
#3 Posted : 09 September 2004 15:15:39(UTC)
I can recommend http://www5a.biglobe.ne.jp/~popi/gauge1/index.htm as a good place to visit for good information.
We also own a Maxi set with extra bits including the Marklin bridge.. One day we will build the garden railway...
My recollection is that LGB is 22.5:1 (or G) scale.. This site http://www.lgb.de/english/index.htm has more info... They look much bigger than the Maxi... As Per mentioned the track is nearly the same, but the rail heights may be different.. I can't see on the LGB site any information about transformers. In any case it is unlikely that the Marklin Delta (in the Maxi) is compatible with the LGB system and the reverse...
Offline 7gauges
#4 Posted : 09 September 2004 17:53:41(UTC)
7gauges
LGB or incorrectly referred to as "G -scale" is actually II scale (or 2 scale, @ 1:20 to 1:26) and the gauge at 45mm is IIm - which coincidently is the same gauge as I gauge standard with a scale of 1:32.
Marklin track is not at all compatible with LGB track because of the railheight and treadway difference - aslo bear in mind that some Marklin / Maxi 1 cars and engines cannot handle the small Radii of LGB etc. tracks and switches.
I think the gauge on my normal II guage track is 64mm - I have some older Magnus II scale models (standard gauge) - and the size difference between say a 1 scale Omm gondola and the same car in II scale is astounding.
Maxi locos only need their electronics chipped switched, or dip switches reset (depends which Marklin engine you have) to run on the DC LGB system - these replacement chips are included with the Maxi engine.
Couplers are not compatible - but 3rd party companies do make an LGB coupler that is easily installed on all (recent) Marklin 1 gauge.
Offline jwmeara
#5 Posted : 10 September 2004 14:49:05(UTC)
jwmeara
To all, thanks for the good information!
Offline Tamrac
#6 Posted : 10 September 2004 21:45:02(UTC)
Tamrac
For those that don't know him or don't receive his monthly newletter,
Robert Frowenfeld has just posted pictures of his new Garden Railway.
Click on the link "My New Garden Railway" in the middle of the page.
Very niceCool
http://rjftrains.com/
Marklin Maxi - switching from analog to Delta control (Big scale)
by rainerborgmann1 17/12/2024 03:51:34(UTC)
How to replace Marklin Maxi F-7 couplers with kadee (Big scale)
by roddewr 16/11/2024 20:43:34(UTC)
Märklin maximum dimensions (General MRR)
by harold ramone 14/12/2023 21:10:33(UTC)
PLM 231 VS DRG BR 01 maximum speed (Prototype)
by I_love_Marklin_37538 08/11/2022 09:50:12(UTC)
Marklin Maxi 54212 (Big scale)
by johnmarklin 28/06/2022 15:35:40(UTC)
Marklin Maxi Sound Tender Magnets (Big scale)
by Adam Hazlett 22/07/2021 00:52:53(UTC)
Smoke Generators For Maxi Locomotives?? (Big scale)
by ErikNewland98 20/11/2020 07:16:17(UTC)
Maxi Collectors (Big scale)
by GPGodart 10/11/2020 19:22:36(UTC)
Maxi Technical Information (Big scale)
by Soest 17/10/2020 17:57:25(UTC)
MAXI Master List - Sad Request (Big scale)
by Johnh 20/09/2020 06:55:02(UTC)
Digital decoder for MAXI locos (Big scale)
by MikeR 17/09/2020 18:53:57(UTC)
Märklin MAXI Kran 54990 / 54991 (Big scale)
by pa-pauls 16/08/2020 21:03:40(UTC)
Marklin 54407 Maxi Set - Wheel Brush Housing is Brittle (Big scale)
by xxup 22/12/2018 07:58:38(UTC)
Who else enjoys the Maxi line of gauge 1? (Big scale)
by artfull dodger 09/11/2018 22:48:50(UTC)
Marklin maximum voltage for passenger/freight cars LED lighting (H0-scale)
by seanshintaro 10/05/2018 13:33:52(UTC)
MAXI digital upgrade (Big scale)
by kaybee6 05/03/2018 23:48:33(UTC)
Trouble with my MAXI (Model railroad wiring)
by Skiman_61 23/12/2017 18:28:20(UTC)
Maxi general catalogue? (Big scale)
by NS1200 13/07/2017 22:19:19(UTC)
My wife's new Maxi F7's on battery power (Big scale)
by artfull dodger 05/06/2017 23:42:18(UTC)
Märklin Maxi 54523 (Big scale)
by Rocca 11/03/2017 14:40:26(UTC)
Märklin 1 Maxi item 54715 (Personenwagen) (Big scale)
by Rocca 23/02/2017 17:22:05(UTC)
Controlling maximum speed via loco's CV parameters (H0-scale)
by baggio 13/12/2016 14:06:40(UTC)
Starter Set Maxi 441-54402 (Big scale)
by WESeffens 28/02/2016 21:29:12(UTC)
Falling for Maxi/Gauge 1 over my LGB (Big scale)
by artfull dodger 28/02/2016 16:04:37(UTC)
Connecting cable for Maxi 54301 and 54302? (Big scale)
by jdpb63 18/02/2016 03:37:34(UTC)
MAXI Buffers (Collector's Corner general)
by Eurobahnfan 21/09/2015 18:29:14(UTC)
Maxi product overview. (Big scale)
by NS1200 31/07/2015 13:28:39(UTC)
Maxi realistic couplings? (Big scale)
by NS1200 07/11/2014 20:35:49(UTC)
What is the absolute maximum % for tracks incline? (H0-scale)
by Janne75 05/07/2014 22:25:24(UTC)
Locomotive and passenger cars maximum permissible speeds (Prototype)
by Janne75 29/04/2014 10:57:04(UTC)
Marklin MAXI USA Prototype (Big scale)
by ckreling 04/11/2013 00:04:04(UTC)
KPF Zeller Rollenstand Spur H0 Maxi, SpeedCat and Roto-Fix H0 (Accessories reviews)
by xxup 24/03/2013 06:37:38(UTC)
Supplying power to Maxi/gauge 1 passenger cars/caboose (Big scale)
by Thewhip1970 23/02/2013 16:19:42(UTC)
USA EMD A and B units maximum? (Prototype)
by NS1200 19/02/2013 07:29:52(UTC)
Maxi 5454 Central Pacific Locomotive - Electrical Issues (Big scale)
by Thewhip1970 25/01/2013 21:33:56(UTC)
32v maxi transformer (Big scale)
by Mad151 26/12/2012 06:38:24(UTC)
MAXI radius & Sound (Big scale)
by pjsiemer 03/10/2012 00:23:46(UTC)
Spur 1: Maxi and now to 55024 (Berlin commuter set) set: issues (Collector's Corner general)
by barrister2u 04/08/2012 14:00:29(UTC)
Marklin "Maxi" (Big scale)
by HRSHistorian 03/07/2012 10:54:54(UTC)
Maxi motor and decoder (Digital)
by tommyheadleycox 23/02/2012 15:27:49(UTC)
Märklin 54212 DB 110 MAXI "Gauge 1", Help! (Digital)
by derekstan 08/02/2012 11:09:19(UTC)
Danish Maxi Beer Cars (Big scale)
by Markus Schild 26/01/2012 16:09:33(UTC)
Marklin Maxi Power Question (Big scale)
by mapper65 02/01/2012 17:25:30(UTC)
Homemade VW Railbus (Drasine) G1/Maxi (Big scale)
by cookee_nz 17/10/2011 11:37:09(UTC)
Nitwit question about maximum current (Digital)
by Oscar 11/09/2011 09:24:10(UTC)
Bachmann G scale track compatible with Marklin Maxi (General MRR)
by drsmith751 19/12/2010 04:08:53(UTC)
Scale 1 and Maxi outside (Big scale)
by dirk66 16/05/2010 11:40:09(UTC)
stereo pic MAXI loc (Model railroad photography)
by wim hoppenbrouwers 18/03/2010 12:35:38(UTC)
stereo pic MAXI wagon (Model railroad photography)
by wim hoppenbrouwers 14/03/2010 14:31:21(UTC)
new Maxi collector. (Collector's Corner general)
by wim hoppenbrouwers 17/02/2010 15:47:10(UTC)
This page was generated in 0.684 seconds.
