Offline countrylink
#1 Posted : 02 February 2012 09:22:37(UTC)
countrylink
Looking at buying starter set 29539 shortly and i would like know about whether i can use the tfafo that comes with the set
or will i have to buy one that's suitable for use in Australia.Any help would greatful.
Offline DigitalNZ
#2 Posted : 02 February 2012 09:41:36(UTC)
DigitalNZ
Looking at the specs of the set on http://www.eurorailhobbi...mp;sc=HO&stock=29539 I'd say that the transformer should be fine as it specifies a 230v / 36va transformer. Best to confirm it with your seller first if you are unsure!
We use 230v transformers in NZ and we share the same power system with everyone across the Tasman.
Kind regards,
Daniell
#3 Posted : 02 February 2012 10:40:29(UTC)
The only thing you will need to do is fit an Australian/NZ type 3 pin power plug to the transformer, as the transformer with come with a European 2 pin plug.
Offline Western Pacific
#4 Posted : 02 February 2012 11:02:01(UTC)
Western Pacific
Or even simpler, get one of these: Travel adaptor.
This one is sold in Sweden for SEK 99:- which is a bit over € 10:- and I'm sure you could find the same or similar in Australia or New Zealand.
Many years ago I was in Melbourne and in the hotel I realized where my adaptor for my PC was - at home in Sweden - and I found a new one in some store similar to Conrads in Germany or Radio Shack in the US or Dixon's (do they still exist?) or Clas Ohlson in the UK (and the Nordic countries).
Offline Dimi194
#5 Posted : 02 February 2012 11:32:51(UTC)
Dimi194
From experience, using adaptors seems to cause trouble; the voltages don't convert properly and the track looses power etc. I'd ring your local dealer (eg Train Traders) and ask them for one; they'll send you one free of charge I'd expect. Or that's what they did with me!
#6 Posted : 02 February 2012 14:57:56(UTC)
Western Pacific
  • First, DigitalNZ points out a European 230 V specified transformer works fine also with AUS/NZ 240 V.
  • Second, if a dealer would give you an AUS/NZ transformer for free then that would be the way to go (even if I would doubt it).
  • Third, the travel adaptor I showed doesn't convert voltage - it's just to connect a Europlug to an AUS/NZ wall outlet.
If going for the adaptor solution it all boils down to the quality of the adaptor in order avoid bad contact. Assuming that that the pins are of the right quality AND the outlet part has got proper spring function to press against the round pins of a Europlug, then there is no reason to fear either for the safety risks or for losing power to the tracks.
#7 Posted : 02 February 2012 15:47:48(UTC)
There's no transformer in the set, it comes with a switching-mode power supply of the "wall wart" type. It must work with input voltages up to 253 V.
Fitting a new plug won't be easy coz it's a wall wart. I'd try a travel adapter.
Offline countrylink
#8 Posted : 03 February 2012 08:21:37(UTC)
countrylink
Thanks gents for the help,i will look into all the ideas and see which one is best.
#9 Posted : 03 February 2012 09:12:26(UTC)
From what Tom (H0) is saying, you don't have a choice. You need a euro to aussie mains plug adapter to be able to use the power pack supplied with that starter set. It's a moulded plug, you can't change it.
It's what I did with a similar power pack I got. The adapter works well.
Offline countrylink
#10 Posted : 08 May 2012 09:54:39(UTC)
countrylink
Finally recieved my starter set 29539 from Germany today.After having to sell my last set and track it's good to be able to get back into it after a few years.
Looking forward to adding to the set and starting a layout.This set was a bargain at 151 euros.Only minor problem was a badly bent front cupler on the loco.
Edited by user 26 August 2012 02:03:41(UTC)  | Reason: Not specified
Offline Ian555
#11 Posted : 08 May 2012 10:34:43(UTC)
Ian555
Hi Peter,
Enjoy your new Set. ThumpUp
Ian.
Reviving 1990s Analog Starter Set (H0-scale)
by 2hip2bking 30/11/2024 18:22:44(UTC)
Differences between Märklin starter sets 29243 and 29244 (H0-scale)
by christosbouk 15/10/2024 11:29:27(UTC)
Double-track Starter sets such as 81830 (Small scale)
by Poor Skeleton 12/10/2024 21:34:27(UTC)
Starter Set Plug Packs (Small scale)
by xxup 21/04/2024 04:01:35(UTC)
Problem with Märklin starter set (H0-scale)
by km90 12/02/2024 18:47:13(UTC)
29821 digital mega starter set (H0-scale)
by mike@complexplastics 15/01/2024 18:41:40(UTC)
Track Numbers included with Starter Set 8182 (Small scale)
by RDOWDALL 16/06/2023 22:41:28(UTC)
Opinions on Starter Set 29625 (BR 41 + 5 freight cars, 2000 circa) (H0-scale)
by andytrain 12/02/2023 03:44:45(UTC)
Märklin my world - "TGV" Starter Set 29306 - MS2? (Digital)
by mramstedt 29/10/2022 19:17:41(UTC)
Starter Set Problems (H0-scale)
by roothaan 02/09/2022 17:34:58(UTC)
Märklin Starter Set 29540 with MS2? (Digital)
by mramstedt 13/02/2022 10:33:45(UTC)
Does Märklin 29652 Starter set work with MS2? (Model railroad wiring)
by mramstedt 19/11/2021 20:16:27(UTC)
Analogue Marklin Starter Set (H0-scale)
by Airfix05 03/04/2021 15:13:52(UTC)
3126 Starter Set (Collector's Corner general)
by ps121912 27/03/2021 20:24:07(UTC)
where to buy parts for Marklin 8800 that comes in the starter set? (Small scale)
by cfauvel 04/02/2021 20:56:53(UTC)
Marklin starter set, do they still produce it? (Big scale)
by Clipperpan 02/11/2020 20:20:21(UTC)
Marklin Big Boy 4013 from 29848 starter set (H0-scale)
by johnmarklin 30/08/2020 18:28:30(UTC)
Adding Smoke Generator to Starter set Loco? (H0-scale)
by SBB_CFF_FFS 03/01/2020 02:32:44(UTC)
Add Headlights Cab End to the starter set locomotive 29479 (Digital)
by Pasquiles 25/12/2019 14:52:46(UTC)
Marklin Tank Loco (included with the 55031 Premier Starter Set) (Big scale)
by SST 22/12/2019 02:20:36(UTC)
Br01 1060 from a 29010 digital starter set (General MRR)
by aos 18/11/2019 13:40:17(UTC)
V160 from starter set 29845 (H0-scale)
by fossie 14/07/2019 23:30:10(UTC)
"Jim Button" Starter Set (General MRR)
by Montfort 03/04/2019 15:29:22(UTC)
Looking at Marklin Z scale Is there a starter set?????? (Small scale)
by tommysus 28/02/2019 13:33:46(UTC)
Marklin 29051 Starter set (H0-scale)
by Drjoe11 18/02/2019 14:25:27(UTC)
Instruction Manual for Starter Set 29166 (H0-scale)
by Sam III 21/01/2019 21:42:53(UTC)
Can i add sounds to my loco from starter set ? (General MRR)
by harris19 20/11/2018 08:51:56(UTC)
Starter set 29529 and 29255 spare parts (H0-scale)
by anthpao 11/11/2018 18:53:43(UTC)
Box #24 - Mysterious Wooden Starter Set Boxes in NZ (Collector's Corner general)
by cookee_nz 09/01/2018 00:57:43(UTC)
Märklin 29487 SBB Starter set review (Loco Reviews)
by Bart 03/01/2018 12:49:15(UTC)
Lidl Marklin starter set in Ireland. (H0-scale)
by steventrain 30/11/2017 21:24:55(UTC)
Small "operation upgrade" to Starter Sets 29184 and 29323 (General MRR)
by Vasco 05/09/2017 12:16:09(UTC)
Question on accessories for Freight Train Digital Starter Set (General MRR)
by Vasco 02/09/2017 15:21:20(UTC)
29000 Starter Set (Accessories reviews)
by SteamNut 25/09/2016 18:17:11(UTC)
Question on Marklin 29000 starter set (H0-scale)
by SteamNut 16/09/2016 23:48:00(UTC)
Starter set 29680 Loco manuals (H0-scale)
by rbw993 13/09/2016 21:05:54(UTC)
Digital starter set problems! (Digital)
by locogr 04/09/2016 16:10:26(UTC)
A idea for Starter Sets (General MRR)
by SteamNut 24/08/2016 02:34:30(UTC)
Starter set 29752 and loco discovery problem (Digital)
by stakyr_7 17/08/2016 07:54:37(UTC)
What is your first Marklin Starter set? (General MRR)
by steventrain 24/07/2016 22:42:17(UTC)
Restoring a RS865/4 starter set box (Collector's Corner general)
by Tiki734 25/06/2016 10:11:56(UTC)
Mega Premium Starter Sets (General MRR)
by Bigdaddynz 09/06/2016 12:17:30(UTC)
Marklin Special 29542 and 29544 Starter set. (News from Märklin and others)
by steventrain 04/05/2016 18:50:57(UTC)
Starter Set Maxi 441-54402 (Big scale)
by WESeffens 28/02/2016 21:29:12(UTC)
Marklin Starter Set ID# 29253 (Digital)
by d_marklin 07/02/2016 07:38:43(UTC)
Hornby Junior Battery starter set. (General MRR)
by steventrain 26/01/2016 18:48:06(UTC)
N scale - thinking of buying a starter set - suggestions? (Small scale)
by baggio 03/12/2015 02:05:48(UTC)
Power for H0 MS2 starter set (Digital)
by rshimada 07/11/2015 04:39:02(UTC)
Digital Starter Set 29710 (Digital)
by MKOpSeattle 21/02/2015 03:42:16(UTC)
First Starter Set (Small scale)
by mkbkiwi 02/02/2015 12:01:43(UTC)
This page was generated in 0.582 seconds.
