Offline BenP
#1 Posted : 28 January 2026 15:31:36(UTC)
BenP
I got a 7286 turntable but no 7687 controller. I scoured the forum, but cannot find wiring that uses k/m84 to test the digital ready unit.
It has 6 colored wires; see pic. Black wire from control box has no equiv color. Trying Yellow and Orange did nothing. Anyone solved this?
Ben
Ben van der Pluijm--
#2 Posted : 28 January 2026 18:05:13(UTC)
Hi Ben
Here is the wiring diagram of a TT (7286) and its remote and the possible use of a K84 or M84
Now, controlling the TT using an M84 will take diodes and wiring and external 16 VAC to replicated the diodes and switches in the remote
The other aspect is the wiring at the back of the TT (If you still have it)
The three top plugs are for connecting the 3 rails of the rotating bridge
The three lower are to power the TT motor which is DC with a full wave rectified voltage from 16VAC
The voltage DC polarity will set the rotation direction
The other plug is to command the solenoid (and thus start the motor rotation untinl the next notch)
Note: as you know this TT was made by Fleischmann and adapted to Märklin for 3 rails and different AC voltage for accessories. So the resistor in series with the motor and located under the bridge is different. The DC voltage is made by a full wave rectifier located inside the remote (that you don't have) So either you provide DC as per the wiring diagram above or you add a full wave rectrifier
I hope this helps
PS I have such a 7286 turntable but I have installed a DSD 2010 set of decoders (DigitalBahn)
Offline BenP
#3 Posted : 28 January 2026 19:41:27(UTC)
BenP
Hi Ben
I hope this helps
Excellent. I have an analog controller. Strange that wire colors don't match, but maybe fleischman to marklin color codes differences. Now powers motor, but not turning. Probably dirty motor, so taking apart. 20260128_132749.jpg (1,259kb) downloaded 6 time(s).
Offline Ross
#4 Posted : 28 January 2026 21:23:15(UTC)
Ross
Hi Jean,
The source of the TT Wiring Diagram
Thanks for helping Ben.
Hi Ben
Ross
thanks 2 users liked this useful post by Ross
#5 Posted : 28 January 2026 21:30:53(UTC)
Just beware that there is a mechanical latch that is supposed to be unlatched (moved to the right of picture) before the motor turns
The unlatching is made by the solenoid that closes the motor contact at the same time
Note: the motor can only drive the bridge if:
- the border pieces / access tracks are installed
- if the spring (on the right) pushes the motor assembly against the pit border and its large teeth
Offline BenP
#6 Posted : 28 January 2026 21:38:12(UTC)
BenP
Got it turning both ways. but this little metal plate fell out when opening motor. Unit rotates, but does not stop at rail connects. Any idea where this sits inside motor?
B
Offline Ross
#7 Posted : 28 January 2026 22:04:57(UTC)
Ross
Hi Ben,
In Strange Bits Log 1
See pages 9-12 how to service the motor drive.
On my web site Ross' Marklin Site
Go to the Tips Section and search for 7686 for other articles on the turntable that maybe of interest to you.
PS the spring is for the locking bar and fits behind the large gear wheel and it fits into 2 thin slots.
Ross
#8 Posted : 29 January 2026 00:48:01(UTC)
Hi Ben
The rectangular thin plate its against the large teethed wheel on the inside and perpendicular to the bridge axis
It is there NOT to stop the motor but to increase the stopping precision by cancelling all play in gears.
Sorry no picture.
The motor is supposed to rotate at a very precise speed this is made by the voltage full wave rectification of 12 VAC (Fleischmann or 16 VAC (Märklin)
A wrong speed may cause an early stop or a "Ballistic overshoot" (you miss the track)
As explaned above, the locking bar under the bridge) is supposed to stop very abruptly the motor as its worm gear has also "wings" to allow brutal stopping
Check if the wings are broken or if the gear has been replaced with a "normal" one (for N scale locos)
Edited by user 29 January 2026 17:19:02(UTC)  | Reason: Not specified
#9 Posted : 30 January 2026 02:55:24(UTC)
Offline BenP
#10 Posted : 30 January 2026 17:27:30(UTC)
BenP
I got the unit refurbished and working with fantastic help from this community. An international effort.
The motor is a pretty frail construct with plastic gears that lock easily. The operation is fine now, continuous and 7.5 degree stops, but not robust enough for traveling club layout. We'll install with only track power, so that staged trains have working functions. Adding the roundhouse and access tracks makes for nice scenery.
Thx for the help.
Ben
thanks 4 users liked this useful post by BenP
How the 7286 turntable actually works... (H0-scale)
by DaleSchultz 14/08/2025 04:57:05(UTC)
Upgrading the 7286 turntable (H0-scale)
by DaleSchultz 14/08/2025 04:48:05(UTC)
Marklin 7286 turntable voltage problem (H0-scale)
by Dirtboy 26/01/2025 00:23:25(UTC)
Marklin 7286 Turntable (H0-scale)
by guardman1 15/07/2024 01:27:14(UTC)
Alterative controller for Marklin 7286 turntable (General MRR)
by rustya 02/05/2023 02:19:02(UTC)
Advice needed for Marklin 7286 Turntable (H0-scale)
by marklin61 20/07/2022 00:48:22(UTC)
7286 Turntable activates empty shed contact tracks. (H0-scale)
by luckas 15/06/2022 11:02:54(UTC)
7286 Turntable motor straining and power question (Digital)
by luckas 15/04/2021 13:47:40(UTC)
7286 turntable with LDT TT-DEC - CS2 step turn doesn't work properly (Digital)
by applor 29/12/2020 22:56:15(UTC)
Marklin 7286 Turntable Woes (H0-scale)
by compatty 22/12/2020 13:06:13(UTC)
Intellibox, 7286 Turntable & 7687 decoder (General MRR)
by jbblunck 25/11/2019 19:11:26(UTC)
by springboard 15/11/2019 23:30:10(UTC)
Marklin 7286 turntable track height issue and no stepping (H0-scale)
by applor 17/04/2018 01:55:15(UTC)
by Twisterdodger 11/10/2017 18:57:18(UTC)
Marklin 7286 Turntable & C Track (General MRR)
by chrisisrang 04/10/2017 01:51:24(UTC)
Märklin 7286 Turntable (Digital)
by Cargodog 31/05/2017 13:22:31(UTC)
Connecting 7286 turntable to 7687 decoder and CS2 (Digital)
by sgbrail 09/08/2016 22:34:10(UTC)
7286 turntable coil question (Digital)
by Hackcell 04/04/2016 21:31:20(UTC)
Problem with a Märklin 7286 Turntable (H0-scale)
by Brakeman 24/01/2016 01:45:23(UTC)
7286 turntable (Digital)
by Alexwaning 17/10/2015 14:51:02(UTC)
Parts for 7286 Turntable (General MRR)
by Shamu 02/09/2015 03:42:46(UTC)
7286 turntable do I need 7687 (Digital)
by jlopez 22/06/2015 00:14:25(UTC)
7286 Turntable. (Digital)
by charles Sharpe 03/03/2014 14:27:08(UTC)
7286 turntable with sound? (Digital)
by Hackcell 14/02/2014 21:37:03(UTC)
Trouble configuring 7286 Turntable with ECoS 50200 using 7687 Decoder (Digital)
by Richard_Pymble 01/09/2013 08:35:34(UTC)
Marklin 7186 & 7286 Turntables (H0-scale)
by trainsman2001 27/02/2013 19:01:18(UTC)
Anyone Played Around with the 7286 Turntable? troubleshooted one? (H0-scale)
by 5HorizonsRR 20/04/2010 00:37:20(UTC)
7286 Turntable pit depth? (H0-scale)
by Writhdar 12/04/2009 17:59:39(UTC)
Reposting: 7286 Turntable with 7.5 deg spacing (General MRR)
by jvuye 17/01/2009 12:44:55(UTC)
Marklin 7286 turntable. (H0-scale)
by steventrain 23/03/2008 11:34:44(UTC)
by Macfire 21/01/2007 10:09:29(UTC)
Manual for 7286 turntable (H0-scale)
by huttel 09/09/2006 18:47:02(UTC)
7286 Turntable problems (Digital)
by obb_taurus 15/08/2006 18:31:39(UTC)
7286 Turntable and decoder problems (Digital)
by obb_taurus 22/06/2006 18:00:59(UTC)
Programming 7286 Turntable + Intellibox (Digital)
by obb_taurus 04/06/2006 19:17:56(UTC)
What's up with the 7286 turntable? (H0-scale)
by Martin T 24/01/2006 15:19:28(UTC)
7286 turntable internal wiring (H0-scale)
by Mikael 23/09/2005 17:48:59(UTC)
Digital Decoder for 7286 turntable (Digital)
by robertrt 17/07/2005 01:19:24(UTC)
How to - 7286 Turntable (H0-scale)
by Eisenhower 10/02/2005 19:57:46(UTC)
Broken 7286 turntable (H0-scale)
by RDRBerry 31/03/2004 02:48:06(UTC)
This page was generated in 0.381 seconds.
