Offline Coling
#1 Posted : 05 February 2025 09:00:12(UTC)
Coling
Sorry if this has been covered before, a very basic question . I have recently inherited my late fathers Marklin trains and track . I want to use it my self having transported it to my premises but do not know how to get power to the track so I need help in finding how to wire the track from the transformer to the M track so I can power the trains so Can any one help please , later will come questions about points and signals , but one thing at a time
thanks 3 users liked this useful post by Coling
#2 Posted : 05 February 2025 10:13:19(UTC)
Hi Coling
Thank you to join us in this great forum.
Looking into track pieces, you will probably find some with a brown and red wires. This is a rail feeder.
You may also have a Märklin transformer and - unless very old (prior to 1953) they have 3 outlets
- brown is the common ground
- red is the variable voltage for traction (7 to 13 VAC and 24 VAC overvoltage for direction change
- yellow is the accessory power (16 VAC)
Here is one good way to start with a simple notice on how to connect things
CatMarklin-Signaux_modeles 342 (1961).pdf (15,178kb) downloaded 38 time(s).
Greeting from cloudy Paris
Offline Coling
#3 Posted : 05 February 2025 10:27:14(UTC)
Coling
Many thanks. The marklin rails and trains date from 1960. When he lived in Berlin and are all m track. Nothing modern !
thanks 2 users liked this useful post by Coling
#4 Posted : 05 February 2025 18:19:00(UTC)
You will find a lot of the information you need in a PDF you can download from this link. Look for "Maerklin Miniature Railway Handbook" in the list of links.
2025 Holiday M track Winter Layout Project (Great layouts I have seen...)
by 5HorizonsRR 12/09/2025 20:27:12(UTC)
Why do alot of people use M track still? (General MRR)
by Train train 02/09/2025 14:41:22(UTC)
JOUEF wagons on M tracks ? (H0-scale)
by philippe99 17/08/2025 17:50:50(UTC)
M track with outlets/sockets (H0-scale)
by Conductor0179 27/11/2024 18:50:11(UTC)
Creating 54mm Track Spacing With HO C-Gleis (General MRR)
by Electrix 18/11/2024 10:46:35(UTC)
Is M track still being made? (H0-scale)
by Mr. Ron 18/09/2024 06:08:48(UTC)
Protocol error & Ghost with M track retro-signalisation (Digital)
by Olivier1967 14/09/2024 12:22:45(UTC)
M track (H0-scale)
by Mr. Ron 07/09/2024 03:03:09(UTC)
M tracks dimensions (H0-scale)
by Pmeeuwes 07/08/2024 00:09:05(UTC)
M Track Curved Turnout loco stops (H0-scale)
by Brian_BR96 20/07/2024 05:08:03(UTC)
Flooded M track and rolling stock (H0-scale)
by BenP 27/06/2024 21:27:07(UTC)
Marklin screws for M track (H0-scale)
by jimwallace1652 25/06/2024 22:18:28(UTC)
Track Screws for M yes M Track (H0-scale)
by frickwg 21/04/2024 20:19:36(UTC)
analog m track parts.. how to... (Model railroad wiring)
by lucasm54 21/04/2024 09:50:34(UTC)
Marklin M Track 5106 1/1 (H0-scale)
by MALAVIKA 18/02/2024 06:39:03(UTC)
M Track Switch Testing (H0-scale)
by baja463 01/02/2024 20:27:06(UTC)
Working with Marklin M track signals (General MRR)
by tandrschaefer 03/01/2024 21:41:00(UTC)
Speed on different types of M track (analogue) (H0-scale)
by Michael4 05/11/2023 17:30:21(UTC)
m track switch wiring question (H0-scale)
by heinrichhess 24/08/2023 12:04:59(UTC)
will m track fit Transfer Table (H0-scale)
by heinrichhess 20/08/2023 18:20:40(UTC)
odd numbered m track 36010 (H0-scale)
by heinrichhess 06/08/2023 12:29:08(UTC)
will Schicht runn on m track? (H0-scale)
by heinrichhess 21/07/2023 15:32:40(UTC)
M track (General MRR)
by Keim 24/05/2023 02:42:42(UTC)
Searching for info on this M track layout (H0-scale)
by Soylent73 30/04/2023 17:26:30(UTC)
Mixing C and M tracks - best tricks? (H0-scale)
by einotuominen 12/12/2022 17:53:29(UTC)
Compatible power supply for Marklin M Track? (General MRR)
by Skywalker646 10/12/2022 02:49:53(UTC)
Manual download for M track or vintage Marklin Accessories (H0-scale)
by tinroofrusted 12/10/2022 12:05:44(UTC)
Marvellous M track manufacture (H0-scale)
by Michael4 14/09/2022 11:52:27(UTC)
M Track (Digital)
by muhkau 21/08/2022 09:00:55(UTC)
M track points lights (Model railroad wiring)
by mitchnz 12/08/2022 02:56:16(UTC)
New M track layout (H0-scale)
by Mr. Ron 21/07/2022 18:48:27(UTC)
Marklin HO M track 1937-50s Electric Points Cat No 13600 WB (H0-scale)
by David240945 10/05/2022 18:18:59(UTC)
Mixing M track and C track (Model railroad wiring)
by PedroRyder 13/01/2022 16:35:36(UTC)
Connecting a Jagerndorfer ho cable car set with an ESU 56002 sound decoder to a CS3 from track power (Digital)
by marklinist5999 03/01/2022 20:36:33(UTC)
AC Wheels for Liliput and Piko Wagons-M track (Collector's Corner general)
by Philipj 28/12/2021 20:56:55(UTC)
Marklin M Track 5117 Points / Led Bulbs (H0-scale)
by fossie 28/11/2021 10:53:09(UTC)
eCoS to M track points to marklin k83 (Model railroad wiring)
by Ausipeet 26/09/2021 06:32:55(UTC)
M track Connections (H0-scale)
by Mr. Ron 08/09/2021 03:21:05(UTC)
Solid Third Rail M Track (General MRR)
by mike c 10/08/2021 04:52:31(UTC)
Catenary fabrication for M track (H0-scale)
by Mr. Ron 12/07/2021 21:49:21(UTC)
analog signal on digital M track section of siding spur (Digital)
by marklinist5999 12/07/2021 14:23:02(UTC)
HO 2-rail rolling stock on Marklin M track (H0-scale)
by Mr. Ron 08/06/2021 04:59:47(UTC)
M track Figure 8 layouts (H0-scale)
by A4Gresley 01/05/2021 09:52:05(UTC)
Long ICE cars rubbing turnouts semaphore m track (H0-scale)
by Victor Almeida 04/02/2021 02:56:37(UTC)
Two locos simultaneously on m tracks (H0-scale)
by Petros 08/01/2021 20:40:35(UTC)
Marklin M track vs C track (General MRR)
by Tracy 29/12/2020 22:03:50(UTC)
M Track planning SW (Model railroad software)
by Vitsing 20/12/2020 05:34:47(UTC)
Which Controller works best with old M Track? 6021 or MS2? (Digital)
by SteveK-O 08/12/2020 15:38:21(UTC)
Wireless control of M track accessories (Digital)
by joyofmarklin 22/11/2020 03:43:22(UTC)
Joining M track sections (H0-scale)
by Mr. Ron 14/11/2020 09:04:18(UTC)
This page was generated in 0.331 seconds.
