Offline Varunvpawar
#1 Posted : 28 December 2024 19:27:08(UTC)
Varunvpawar
Makes this weird noise. Please see video attached IMG_7704.mov (15,384kb) downloaded 37 time(s).
#2 Posted : 28 December 2024 20:53:59(UTC)
Can you record a video close up (Hold your phone sideways)? Also, can you tell if the noise is coming from the tender (rear) or from the motor (locomotive).
If it comes from the tender, it may be a short on the circuit board. If it comes from the locomotive, it is likely an issue with the motor/wiring.
I did notice that no light comes on when powered.
Can you also post a bigger photo of the tender showing the decoder/PC board and the bogies?
Can you also explain whether you are powering up the track or attempting to reverse the direction?
Offline Varunvpawar
#3 Posted : 28 December 2024 21:19:39(UTC)
Varunvpawar
Attaching more videos and pictures. I am powering up the engine and the noise starts immediately. I suspect a short circuit somewhere. IMG_7708.jpegIMG_7707.jpeg IMG_7705.mov (15,583kb) downloaded 20 time(s).
#4 Posted : 28 December 2024 21:34:21(UTC)
I haven't listened to the video, but could almost guarantee your problem is the engine needs a drop of oil on the motor bearings. A tiny trace on the gears and axles as well will help the running.
Offline RudiC
#5 Posted : 29 December 2024 10:57:10(UTC)
RudiC
Does the motor turn at all? Are the brushes / coals OK?
Rüdiger (Rudi)
Offline ocram63_uk
#6 Posted : 29 December 2024 11:56:20(UTC)
ocram63_uk
looking at the magnet's level of corrosion I agree with KiwiAlan. A drop of oil on the motor and on the axles.
I would also check that all cables are soldered properly, corroded solder points aren't good for circuits
#7 Posted : 29 December 2024 13:59:09(UTC)
Surely, as it appears to have been ina damp environment.
need help to reset viessmann multiplexer signals (Digital)
by fabstar68 19/04/2025 17:46:44(UTC)
Train Stops on Märklin 24611 Turnouts – Need Help (H0-scale)
by ABM2020 25/12/2024 11:32:39(UTC)
Need help with Cs2 and k83 (Digital)
by oliver 12/10/2024 16:53:52(UTC)
Need help in identifying this french SNCF loco in the music video (Big scale)
by Bill L 31/05/2024 05:38:03(UTC)
Need help with Marklin 2668 - Lufthunsa Airport set with BR103 (General MRR)
by obb_taurus 18/05/2024 03:54:07(UTC)
Need help identifying a 1 gauge locomotive from my grandfather's collection (Big scale)
by stevenh905 06/03/2024 22:51:19(UTC)
Need help for M3656 spare part (H0-scale)
by harris19 02/10/2023 06:22:02(UTC)
Need Help Please (H0-scale)
by alehrfeld 30/06/2023 22:54:42(UTC)
Need help upgrading CS2 (Digital)
by nelson77 17/06/2022 18:06:58(UTC)
Need help understanding the different controllers (Digital)
by GenDemo 08/10/2021 13:33:09(UTC)
Need help with CCC 72021 and lighting kit 73400 (H0-scale)
by jausten54 25/03/2021 00:19:28(UTC)
Need Help/Advise - Marklin 344, 341, 343 Series Coaches (Collector's Corner general)
by analogmike 24/01/2021 03:09:48(UTC)
Need help with odd 4x8 track plan please (Track plans)
by artfull dodger 15/01/2021 18:15:28(UTC)
Need help identifying (General MRR)
by nick1bum 18/04/2020 23:29:55(UTC)
Need Help Please (General MRR)
by Shelton 04/04/2020 17:59:48(UTC)
Need help - Crocodile not working (Digital)
by Keyes43 26/12/2019 01:31:06(UTC)
Need Help-New LGB F7A on CS#+ front trucks Motor not working (Big scale)
by ReelfootJim 22/12/2019 01:21:34(UTC)
Need Help With 3089 (H0-scale)
by SteamNut 09/08/2019 00:22:42(UTC)
Newbee need help - S88 (60881) to CS2 (60215) using a 60884 cabel (Digital)
by jorwes 23/10/2018 21:56:51(UTC)
Need help updating MS2 to latest version (Digital)
by ShannonN 04/09/2018 14:01:50(UTC)
Need Help With Marklin 4228 (H0-scale)
by SteamNut 15/05/2018 08:29:32(UTC)
Need Help Finding Märklin Part (General MRR)
by skeeterbuck 25/03/2018 17:56:23(UTC)
Need help with Marklin crossing gate number 7390 (H0-scale)
by Marklin67 22/03/2018 02:38:24(UTC)
Need Help With Idendification (H0-scale)
by SteamNut 12/03/2018 00:28:55(UTC)
Creating new layout - Need help. (H0-scale)
by Hics 15/02/2018 13:20:26(UTC)
Need help with my marklin Ho steam locomotive (H0-scale)
by Marklin67 05/02/2018 01:49:12(UTC)
Need help getting Marklin Z 8885 , BR 03 to run !?? (Small scale)
by MarklTedII 23/07/2017 15:38:16(UTC)
Need help Model # 3097 (H0-scale)
by HO Collector 24/05/2017 22:51:17(UTC)
Need help on Java code (Digital)
by hwestl 05/05/2017 19:43:16(UTC)
Need help with my marklin 8899 br38 steamer. (Small scale)
by Artologic 25/02/2017 17:27:39(UTC)
New to forum and need help if possible (H0-scale)
by jamante 26/01/2017 02:22:03(UTC)
Getting started - need help :) (H0-scale)
by Gunter 13/08/2016 15:54:51(UTC)
I have a briefcase set that I think is pre 1960. NEED HELP. (General MRR)
by Brendan Flake 11/04/2016 03:05:18(UTC)
Need help with p/n's of parts for wagon 4207 (General MRR)
by Cabegye 11/02/2016 05:40:40(UTC)
Need help with a switchpilot 51800 - Need help from ECOS2 and ESU people on here please (Digital)
by Chris6382chris 01/01/2015 20:12:11(UTC)
Need Help like MS2 for Dummies (solved Maybe) (Digital)
by nevw 07/12/2014 02:30:31(UTC)
Need help aligning the gears Z scale steamer... (Small scale)
by Chad0x78 06/10/2014 04:01:05(UTC)
Need help, 3 way wye turnout control with CS2 and signals (Digital)
by BrianM 26/08/2014 20:50:20(UTC)
Need help with 4228 (H0-scale)
by SteamNut 19/06/2014 05:55:31(UTC)
Need help on the height of the bumpers of Marklin 1 gauge trains (Big scale)
by Harun 05/06/2014 16:34:12(UTC)
Need help on dimensions of Marklin Gauge 1 track (Big scale)
by Harun 03/06/2014 20:57:45(UTC)
Loksound Select Micro #73800 need help (Digital)
by Dave Banks 13/03/2014 22:25:25(UTC)
Need help connecting 74460 decoder (Turnout) to MS2 Controller (Digital)
Belarus bronco 07/02/2014 05:38:12(UTC)
I need help programming my MS (Digital)
by Wildrose-Wally 28/12/2013 20:02:25(UTC)
Guys, need help_MS2 doesn't recognize T3 _37141. (Digital)
by FMS 20/10/2013 21:23:51(UTC)
I need help Z scale (General MRR)
by rustylk42 30/04/2013 19:57:51(UTC)
Need Help with Marklin 36871 MS adress. (H0-scale)
by FMS 20/01/2013 14:58:45(UTC)
New to digital, need help (Digital)
by Helge B 01/11/2012 16:01:14(UTC)
Need help identifying... (Small scale)
by hgk 10/10/2012 00:50:50(UTC)
Need Help Locating a Roco AC Loco: 68638 AE 8/14 (H0-scale)
by 5HorizonsRR 09/09/2012 23:15:20(UTC)
This page was generated in 0.399 seconds.
