Offline MartinWalkabout
#1 Posted : 02 September 2022 15:34:19(UTC)
MartinWalkabout
Hello Everyone,
I've been building a 15' x 5' layout for the last 3 years and am now going to connect it to a second 4' x 8' layout using C-Track through out. Both layout tables are on wheels so if needed I can move them around.
The two layouts will be connected with a single rail line and I'm trying to figure out how to connect two C-Track rails at the junction point so I can move the two layouts apart if ever needed.
Has anyone ever tried this and is there a simple way of doing it? Some kind of home-made magnetic connector? Or is this a problem that has no simple solution.
I've never posted here before but have gained a lot of guidance from the many dedicated members. Any help or input would be greatly appreciated!
#2 Posted : 02 September 2022 15:57:43(UTC)
Hi Martin
Welcome to the Forum
I suggest you centralise the power wires of each layout independently and - when assembled to gether - have the joining track insulated on one side and both layouts connected by (large) plugs to the digital command station or the transformer.
Better use 0.5 mm² (AWG 20) or thicker wire
#3 Posted : 02 September 2022 23:55:30(UTC)
Originally Posted by: MartinWalkabout Go to Quoted Post
Hello Everyone,
....how to connect two C-Track rails at the junction point so I can move the two layouts apart if ever needed.
Hello Peter,
The generally workable idea for physically joining portable layout tracks is to use a single piece of standard track as the joiner.
End the tracks on both baseboard sections a distance from the baseboard edge.
The combined distance between baseboard tracks has to be equal to the length of your joiner.
You will be best to figure out what standard section of C track you will use as joiner and how to end each section of track on the baseboards to suit.
When you join up the baseboards you insert the joiner.
This suggestion takes no account of what other electrical and physically compatabilities you might need.
I suggest you go to a local model railway show, and you will see plenty of examples of joining arrangements in the layout displays.
#4 Posted : 03 September 2022 00:25:29(UTC)
The process listed by Kimball is how Marklin do their display layout that they take to all the shows to display new products. The only part of the problem I see is that the track needs to be 'bent' when dismantling it (as illustrated in the C track booklet) to get the plastic clips to disengage, otherwise they break off. But in some ways it would be good to break them off on the joining piece and the end pieces on each module, then use rail joiners to connect the track pieces together. Marklin do sell packets of rail joiners for C track, I suspect for exactly this purpose.
But the other question is how are you going to align the two modules? The modules will need to be accurately alighed each time you set them up, and to do this I would recommend you get what are called 'pattern makers dowels' (often available from traders at MRR exhibitions here in the UK. They come in two styles (as evidenced by these particular eBay offerings): -
This is one version which I don't like as I suspect it will be too easy to get the hole in the wood at an angle and they won't mate properly when the modules are pushed together.
I prefer these ones which require a recess in the end of the module so the faces of the plates are flush with the end of the modules.
The modules are then held together by bolts through other holes in the modules.
#5 Posted : 07 September 2022 10:38:01(UTC)
MartinWalkabout
Hi Martin
Merci for the reply Jean! I had the same idea of creating independent power sections. Will experiment with that!
#6 Posted : 07 September 2022 10:40:53(UTC)
MartinWalkabout
Hello Everyone,
Hello Peter,
Thanks Kimball, this is something I've been experimenting with as well. Since it's only one track that's being connected over 4 feet I need to find an easy way to slide the sections together smoothly and seamlessly. Thanks for the response.
#7 Posted : 07 September 2022 10:44:37(UTC)
MartinWalkabout
Thanks Alan. I've actually tried breaking off the connecting clips and that has so far worked well. The precise alignment is the challenge to avoid the metal conductors from breaking off but these EBAY connectors may do the trick. Thanks for the response! Peter
#8 Posted : 07 September 2022 10:52:28(UTC)
Jeans idea of having both sides of the layout as individual layouts and insulate the joining track for me would be the best solution. As you only need to join on C track should not be difficult to line up the two sections.
Offline rhfil
#9 Posted : 07 September 2022 15:29:57(UTC)
rhfil
Our ETE-ENE club layout consists of a number of independently wired modules which when connected have male plug wires connecting the sections and providing all the power sources. The modules have metal male and female plugs to align them properly and clamps to hold them together. It is not a perfect solution but has worked successfully for many years. Oh, the legs have adjusters to compensate for uneven floors. This has allowed the layout to be shown, over the years, at well over 100 different shows. The design also allows the modules to be changed out.
C-track platforms for 3D printing (H0-scale)
by phildc 19/08/2025 19:00:43(UTC)
Help with a C-track plan (Track plans)
by km90 13/08/2025 20:24:25(UTC)
Intermittent Turnout Decoder Issues with Märklin C-Track (Digital)
by tgj 01/05/2025 10:36:49(UTC)
Setting Up Märklin 76393 Signals with CS3 and C-Track (Digital)
by tgj 27/04/2025 16:29:13(UTC)
Modular C-Track, an alternative to C-Trak. (Track plans)
Belarus EB421 11/04/2025 00:15:56(UTC)
Locomotives stalling on c-track switches - any ideas how to fix? (H0-scale)
by fynrfin 10/03/2025 19:39:36(UTC)
C-track 24624 DKW double slip, issues with tounges not closing enough (H0-scale)
by LeoArietis 09/02/2024 11:16:49(UTC)
Can Marklin signals work with the c-track from Trix? (General MRR)
by Sniklz 25/01/2024 23:35:50(UTC)
c-track geometry advice needed for my layout (H0-scale)
by fabstar68 08/01/2024 23:41:10(UTC)
Three way turnout (c-Track) with Viessmann 4568 (Digital)
by Puttputtmaru 07/01/2024 23:29:44(UTC)
Experiences painting and or ballasting C-Track (General MRR)
by egonzinc 31/12/2023 22:10:40(UTC)
Platform for standard Marklin C-track 77.5mm distance ? (H0-scale)
by fabstar68 23/12/2023 16:01:44(UTC)
Faller compatibility with Marklin c-tracks (H0-scale)
by fabstar68 19/12/2023 15:23:05(UTC)
C-Track and spade adapters (Model railroad software)
by Richard Joint 19/12/2023 04:59:24(UTC)
74470 Led light for C-track turnout (H0-scale)
by Flupke 16/12/2023 19:32:25(UTC)
C-track TurnTable not working propperly (Digital)
by fvelazdem 20/11/2023 12:24:40(UTC)
C-track road crossing (H0-scale)
by revmox 19/05/2023 07:20:37(UTC)
Roco AC Sound locomotives running SLOW on analog C-track (General MRR)
by egonzinc 22/04/2023 16:02:25(UTC)
C-Track threeway turnout short circuit (Digital)
by einotuominen 30/03/2023 10:53:07(UTC)
C-track spacing (General MRR)
by Edmielck 20/02/2023 23:34:55(UTC)
Info on Rivarossi AC Locomotives on Marklin C-track (H0-scale)
by egonzinc 08/01/2023 05:46:21(UTC)
Modular Layout with C-track (H0-scale)
by Uwe 10/12/2022 02:25:06(UTC)
C-Track with a flex (H0-scale)
by Puttputtmaru 02/12/2022 22:33:52(UTC)
C-track turnout mechanism stops working (H0-scale)
by Wirring 27/06/2022 22:37:24(UTC)
Operating "snags" on C-track (H0-scale)
by JDennis 01/05/2022 21:14:33(UTC)
Wheels for Non-Marklin Wagons and Coaches on C-Track (H0-scale)
by AlanC 28/04/2022 09:00:37(UTC)
c-track contact track ends touching (H0-scale)
by trainbuff 10/04/2022 00:32:52(UTC)
Running HAG on Marklin C-Track (H0-scale)
by mchesla 08/04/2022 21:56:59(UTC)
Esu wagon on Trix C-Track (H0-scale)
by tabacaru.mvlad 22/02/2022 00:11:33(UTC)
Found the culprit that snaps off all my C-Track turnout Lanterns (H0-scale)
by Dave Banks 05/07/2021 10:37:48(UTC)
Newly discovered C-Track Issue (H0-scale)
by mike c 24/06/2021 21:12:36(UTC)
30000 shorts on some C-track curves (H0-scale)
by xxup 25/05/2021 23:14:39(UTC)
Marklin c-track wiring for z21 (Model railroad wiring)
by Lusito 22/04/2021 15:05:16(UTC)
C-Track and Rolling Stock (H0-scale)
by Ace Wickwire 26/02/2021 16:49:18(UTC)
Early C-track? (H0-scale)
by CGuy 29/11/2020 03:15:14(UTC)
Need for bus wires using C-Track (Great layouts I have seen...)
by Richard Joint 03/08/2020 20:59:21(UTC)
A verified C-track wye configuration (H0-scale)
by BobG100 20/06/2020 09:14:28(UTC)
Trix C-track (H0-scale)
by BobG100 31/05/2020 00:20:33(UTC)
Turntable 7286/7686 with C-track (H0-scale)
by MartinS 27/05/2020 11:47:03(UTC)
COVID-19 The good, the bad & the ugly - aka Marklin rediscovered, where did time go & damn C-track (General MRR)
by black_pete 16/05/2020 16:51:44(UTC)
Marklin c-track turnout lever (H0-scale)
by STE-BM 07/03/2020 21:11:07(UTC)
Modell Tannhofen 8068 from M-track to C-track (General MRR)
by JohnyH 05/01/2020 21:48:18(UTC)
The Geometry of Track, why C-Track and K-Track both missed an opportunity (H0-scale)
by Johnvr 24/10/2019 21:41:42(UTC)
Soldering C-track connectors (Model railroad wiring)
by morsing 12/06/2019 18:37:50(UTC)
Marklin C-track uncoupler wiring (Model railroad wiring)
by Twisterdodger 29/04/2019 16:15:23(UTC)
Translate M-tracks to C-tracks (H0-scale)
by mauel 05/01/2019 22:32:38(UTC)
Roco/ACME/Rocky-Rail Wagons on Marklin C-track (H0-scale)
by nomad777 05/01/2019 17:50:25(UTC)
Connecting a C-Track layout to a 6646 Transformer (H0-scale)
by waterslip 02/01/2019 00:46:37(UTC)
First attempt at trackplan Märklin C-track (Track plans)
by miccar 07/12/2018 21:01:26(UTC)
Running with DC Wheels on AC C-Track? (General MRR)
by mgbeck_98 14/09/2018 17:07:22(UTC)
This page was generated in 0.574 seconds.
