Offline Ferdi
#1 Posted : 22 November 2017 01:31:45(UTC)
Ferdi
This controller drives my 2 locos i.e. a one-motor Marklin BR80 tank loco and a dual-motor LGB diesel V1002027, #20121. The controller's speed-bar consists of 14 blocks, which go black in proportion to the controller's speed setting. This works fine, but the diesel makes the bar blinking when the speed setting is more than 4 or 5 blocks. This raises my question: does that blinking indicate some warning?
I took various power consumption readings of the supply to the controller and found that with both locos running at gradually increasing speed settings beyond 1/2 way, when the consumption eventually reaches 50 Watts, the controller switches itself off. Is that its factory set limit? Is it adjustable?
Ferdi in Melbourne, Australia
#2 Posted : 22 November 2017 04:13:07(UTC)
I believe from a message to the Moderators from Dusan, that you have a Marklin Mobile Station 1.
There were two versions of that controller, one had a maximum output current of 1.2 amps, the other a maximum current output of 1.9 amps. It may well be that you have hit the limit of available current.
From https://www.marklin-user...obile-Station---1-2-1-9A
The 1.9 amps output current versions have the number on the base of the controller 60651.
The 1.2 amps output current versions have the number on the base of the controller 60652.
DV
#3 Posted : 22 November 2017 07:59:51(UTC)
AIUI this blinking indicates that the controller no longer receives mfx feedback from the loco. No real problem.
mfx feedback and rolling wheels do not work well together.
Offline DV
#4 Posted : 22 November 2017 13:05:43(UTC)
DV
Just received an email from Ferdi thanking me in leading him to your reply David. In the email he also stated that he was having problems with registering his new acquisition - 55332 and admitted that his knowledge on how to use the internet and in particular the forum is also limited and therefore decided to explain the registering problem to me.
My knowledge of gauge 1 locos and how they register on a MS1 can be written in capital letters on the back of a postage stampBigGrin BigGrin . I also found out that his new loco has mfx (you learn something new everydayBigGrin ThumpUp )
So I would gather that the 55332 (with mfx) should register automatically, just like a HO mfx loco, correct?
Well, his isn't!
Not having used a MS1 for a very long time, can you connect the MS1 to a program track and then try to register the loco?
Or, do you make sure there are no other locos on the track when you try registration?
Any help to get Ferdi's loco registered would be greatly appreciated.
Many thanks
Dusan V
Offline blid
#5 Posted : 22 November 2017 15:36:03(UTC)
blid
This woun't help Ferdi get his engine going but i might be of interest.
A couple of months ago I did some testing concerning power consumption on my gauge 1 layout.
I can use a CS1 Realoded with the ESU power adaptor or a CS2 60215 with a 60101 power supply.
The Köf I have is an older version, 55742 (fx). It needed 0.027 A when just placed on the rails according to CS1R and 0,016 A with the CS2. Running with sound 0.66 A at 15,9 V/0.36 A at 18.5V.
My mfx railbus, 55098, needed 0.116 A/0.082 A on the rails. Running with sound 1.9 A at 15.7 V / 1.1 A at 18.4 V. If I remember correctly the power requirement was a bit higher when the controllers were turned on (mfx chatter? I don't think there are any capasitors needing power).
Running was 30 of 126 speed steps – rather slow.
My experience is that the programming track don't have enough power to program gauge 1 engines. Place the engine as the only thing on the rails and where the feeder wires are. I don't know anything about MS1 (or MS2).
blid
remote/relay power controller? (Model railroad wiring)
by MikeEK 27/11/2023 09:34:43(UTC)
Need updates for my MS2 Controller- Fort Wayne, Indiana (Digital)
by vnangli 10/09/2023 19:33:14(UTC)
67013 controller (General MRR)
by MikeEK 31/07/2023 10:23:03(UTC)
Help with IR controller Startset 29163 (Digital)
by Steveknz 14/07/2023 09:15:42(UTC)
Marklin Circuit Track and Train Controller (Model railroad software)
by garben 20/06/2023 17:17:09(UTC)
Use of Signals instead of Stop Markers in Train Controller (Model railroad software)
by garben 19/05/2023 20:18:57(UTC)
Train Controller and Marklin 3 Aspect signal. (Model railroad software)
by garben 14/05/2023 16:20:47(UTC)
Alterative controller for Marklin 74861 turntable (General MRR)
by rustya 02/05/2023 02:19:02(UTC)
Train Controller Gold sees Blocks only on the Direct S88 (Model railroad software)
by punksie1 28/04/2023 21:49:51(UTC)
Marklin 39621 Lockup on 6021 controller layout (Digital)
by SteveK-O 03/03/2023 15:46:46(UTC)
RailControl Pro — CS2 and CS3 controller for iPhone, iPad and Mac (Model railroad software)
by northstar 24/02/2023 15:29:28(UTC)
Help! xmas tree layout controller frozen (Digital)
by JetForMe 25/12/2022 10:55:08(UTC)
Better quality controller (Small scale)
by Donb 23/12/2022 19:43:04(UTC)
Das LoDi-Con, new wireles controller, compatible with CS2/3 and several other systems (News from Märklin and others)
by bph 26/10/2022 21:20:06(UTC)
MFX and 6021 controller (Digital)
by cintrans 16/07/2022 01:37:41(UTC)
Marklin Speed Controller (Small scale)
by dannyboyz 30/06/2022 22:48:28(UTC)
Central Station, Mobile Station & 32 Volt controller not working? (General MRR)
by mattj70 06/04/2022 05:43:05(UTC)
Gaugemaster controller (Small scale)
by Snowfun 13/02/2022 17:04:02(UTC)
Rokuhan Rc004 shorty controller (Small scale)
by Oldswine 24/01/2022 02:29:18(UTC)
dcc controller (Mobile station) compatibility (Digital)
by MalvernStation 12/12/2021 21:35:41(UTC)
Help finding 36240 address on 6021 controller (Digital)
by GenDemo 21/11/2021 11:51:04(UTC)
Controller related question (Small scale)
by wildstix 18/11/2021 17:26:29(UTC)
Need help understanding the different controllers (Digital)
by GenDemo 08/10/2021 13:33:09(UTC)
Traincontroller Gold (Model railroad software)
by eurotrain 08/09/2021 17:41:24(UTC)
Morley Vector 03 Crawler Controllers for Z (Small scale)
by Mman 01/07/2021 21:14:59(UTC)
Faller Servo Controller 180725 (General MRR)
by Drongo 24/06/2021 08:59:57(UTC)
Sound Functions using 6021 Controller (Digital)
by Johnvr 12/06/2021 10:11:58(UTC)
Servo Controller (General MRR)
by skukuza 08/06/2021 07:23:43(UTC)
Need advice for controller use (Track plans)
by wildstix 26/05/2021 11:10:26(UTC)
Solid state Controller with 24V reversing? (H0-scale)
by macxlii 09/05/2021 15:46:35(UTC)
Restarting Discussion On Gaugemaster Controller for Z scale (Small scale)
by zoooctan 02/05/2021 11:51:49(UTC)
Marklin 6150 controller/transformer (H0-scale)
by tchiplis 14/02/2021 19:51:38(UTC)
TrainController (Freiwald) Support and Alternatives (Model railroad software)
by andrea80796 28/01/2021 12:00:08(UTC)
Blue controller box manual? (H0-scale)
by marklin_1988_ge 13/01/2021 06:08:11(UTC)
DIY Z Gauge controller (Small scale)
by robfl 03/01/2021 18:38:46(UTC)
Which Controller works best with old M Track? 6021 or MS2? (Digital)
by SteveK-O 08/12/2020 15:38:21(UTC)
DIY Arduino Speed Controller with speed ramp and brake running Marklin loco on my Z Scale test loop (Small scale)
by Big AL 05/12/2020 20:16:19(UTC)
6600 controller (Collector's Corner general)
by hennabm 29/08/2020 19:32:16(UTC)
You can now drive RemoteSign from TrainController (Model railroad software)
by DaleSchultz 12/05/2020 03:31:43(UTC)
Trix locomotives and NCE controller (H0-scale)
by sprigogin 15/12/2019 03:10:36(UTC)
Digital controller (General MRR)
by adabanlis 01/12/2019 15:45:40(UTC)
Traincontroller gold and CS3 (Model railroad software)
by eurotrain 03/10/2019 20:44:44(UTC)
Is the Marklin controller working well with the new locos? (Small scale)
by husafreak 10/09/2019 19:56:24(UTC)
Digital Question (Controller) (Digital)
by mike c 07/07/2019 02:16:39(UTC)
Connecting the Train Controller (Model railroad software)
by mgbeck_98 26/06/2019 02:26:42(UTC)
Possible incompatibility between New Marklin locos and Rokuhan controllers (Small scale)
by husafreak 19/06/2019 00:41:53(UTC)
What controller do I need ? (Digital)
by Ark_42 21/04/2019 21:50:46(UTC)
Marklin Mini Club Motors & Rokuhan/ Pwm Controllers (Small scale)
by Artologic 04/04/2019 22:45:54(UTC)
Alternatives to Marklin AC Analogue Power Controller and DC to AC conversion (General MRR)
by Twinrover1965 24/03/2019 19:11:02(UTC)
Second turnout controller (General MRR)
by tommysus 26/02/2019 20:17:58(UTC)
This page was generated in 0.577 seconds.
